Use the per-device cdev_device_interface to store the bsg data in the char
device inode, and thus remove the need to embedd the bsg_class_device
structure in the request_queue.
Link: https://lore.kernel.org/r/20210729064845.1044147-2-hch@lst.de
Move the SCSI-specific bsg code in the SCSI midlayer instead of in the
common bsg code. This just keeps the common bsg code block/ and also
allows building it as a module.
Link: https://lore.kernel.org/r/20210724072033.1284840-15-hch@lst.de
Since scsi_mq_alloc_queue() only has one caller, inline it. This change was
suggested by Christoph Hellwig.
Link: https://lore.kernel.org/r/20210622024654.12543-1-bvanassche@acm.org
Cc: Ming Lei <ming.lei@redhat.com>
Cc: Ed Tsai <ed.tsai@mediatek.com>
Reviewed-by: Ming Lei <ming.lei@redhat.com>
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Improve readability of the code in the SCSI core by introducing an
enumeration type for the values used internally that decide how to continue
processing a SCSI command. The eh_*_handler return values have not been
changed because that would involve modifying all SCSI drivers.
The output of the following command has been inspected to verify that no
out-of-range values are assigned to a variable of type enum
scsi_disposition:
KCFLAGS=-Wassign-enum make CC=clang W=1 drivers/scsi/
Link: https://lore.kernel.org/r/20210415220826.29438-6-bvanassche@acm.org
Cc: Johannes Thumshirn <johannes.thumshirn@wdc.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Daniel Wagner <dwagner@suse.de>
struct request and struct request_queue are declared twice. Remove the
duplicate declarations.
Link: https://lore.kernel.org/r/20210327030850.918018-1-wanjiabing@vivo.com
Signed-off-by: Wan Jiabing <wanjiabing@vivo.com>
SCSI currently uses an atomic variable to track queue depth for each
attached device. The queue depth depends on many factors such as transport
type and device implementation. In addition, the SCSI device queue depth is
not a static entity but changes over time as a result of congestion
management.
While blk-mq currently tracks queue depth for each hctx, it can't easily be
changed to accommodate the SCSI per-device requirement.
The current approach of using an atomic variable doesn't scale well when
there are lots of CPU cores and the disk is very fast. IOPS can be
substantially impacted by the atomic in the hot path.
Replace the atomic variable sdev->device_busy with an sbitmap for tracking
the SCSI device queue depth.
It has been observed that IOPS is improved ~30% by this patchset in the
following test:
1) test machine(32 logical CPU cores)
Thread(s) per core: 2
Core(s) per socket: 8
Socket(s): 2
NUMA node(s): 2
Model name: Intel(R) Xeon(R) Silver 4110 CPU @ 2.10GHz
2) setup scsi_debug:
modprobe scsi_debug virtual_gb=128 max_luns=1 submit_queues=32 delay=0 max_queue=256
3) fio script:
fio --rw=randread --size=128G --direct=1 --ioengine=libaio --iodepth=2048 \
--numjobs=32 --bs=4k --group_reporting=1 --group_reporting=1 --runtime=60 \
--loops=10000 --name=job1 --filename=/dev/sdN
[mkp: fix device_busy reference in mpt3sas]
Link: https://lore.kernel.org/r/20210122023317.687987-14-ming.lei@redhat.com
Link: https://lore.kernel.org/linux-block/20200119071432.18558-6-ming.lei@redhat.com/
Cc: Omar Sandoval <osandov@fb.com>
Cc: Kashyap Desai <kashyap.desai@broadcom.com>
Cc: Sumanesh Samanta <sumanesh.samanta@broadcom.com>
Cc: Ewan D. Milne <emilne@redhat.com>
Tested-by: Sumanesh Samanta <sumanesh.samanta@broadcom.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: Ming Lei <ming.lei@redhat.com>
Add infinite retry support to SCSI midlayer by combining common checks for
retries into some helper functions, and then checking for the
-1/SCSI_CMD_RETRIES_NO_LIMIT.
Link: https://lore.kernel.org/r/1601566554-26752-2-git-send-email-michael.christie@oracle.com
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Signed-off-by: Mike Christie <michael.christie@oracle.com>
After commit f664a3cc17b7 ("scsi: kill off the legacy IO path"),
scsi_sdb_cache is not used anymore. Remove it.
Link: https://lore.kernel.org/r/20200619154117.10262-2-huobean@gmail.com
Signed-off-by: Bean Huo <beanhuo@micron.com>
Remove cmd_list functionality; no users left. With that the
scsi_put_command() becomes empty, so remove that one, too.
Link: https://lore.kernel.org/r/20200228075318.91255-14-hare@suse.de
Reviewed-by: Bart van Assche <bvanassche@acm.org>
Signed-off-by: Hannes Reinecke <hare@suse.de>
Module param scsi_use_blk_mq has not been referenced for some time, so zap
it.
Link: https://lore.kernel.org/r/1581355992-139274-1-git-send-email-john.garry@huawei.com
Signed-off-by: John Garry <john.garry@huawei.com>
It isn't necessary to check the host depth in scsi_queue_rq() any more
since it has been respected by blk-mq before calling scsi_queue_rq() via
getting driver tag.
Lots of LUNs may attach to same host and per-host IOPS may reach millions,
so we should avoid expensive atomic operations on the host-wide counter in
the IO path.
This patch implements scsi_host_busy() via blk_mq_tagset_busy_iter() with
one scsi command state for reading the count of busy IOs for scsi_mq.
It is observed that IOPS is increased by 15% in IO test on scsi_debug (32
LUNs, 32 submit queues, 1024 can_queue, libaio/dio) in a dual-socket
system.
Cc: Omar Sandoval <osandov@fb.com>,
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>,
Cc: James Bottomley <james.bottomley@hansenpartnership.com>,
Cc: Christoph Hellwig <hch@lst.de>,
Cc: Laurence Oberman <loberman@redhat.com>
Cc: Bart Van Assche <bvanassche@acm.org>
Link: https://lore.kernel.org/r/20191025065855.6309-1-ming.lei@redhat.com
Reviewed-by: Jens Axboe <axboe@kernel.dk>
As explained during the 2018 LSF/MM session about increasing SCSI disk
probing concurrency, the problems with the current probing approach are as
follows:
- The driver core is unaware of asynchronous SCSI LUN probing.
wait_for_device_probe() waits for all asynchronous probes except
asynchronous SCSI disk probes.
- There is unnecessary serialization between sd_probe() and sd_remove().
This can lead to a deadlock.
Hence this patch that modifies the sd driver such that it uses the driver
core framework for asynchronous probing. The async domain and
get_device()/put_device() pairs that became superfluous due to this change
are removed.
This patch does not affect the time needed for loading the scsi_debug
kernel module with parameters delay=0 and max_luns=256.
This patch depends on commit ef0ff68351be ("driver core: Probe devices
asynchronously instead of the driver") that went upstream in kernel version
v5.1-rc1.
Cc: Lee Duncan <lduncan@suse.com>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Luis Chamberlain <mcgrof@kernel.org>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Dan Williams <dan.j.williams@intel.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
This removes the legacy (non-mq) IO path for SCSI.
Cc: linux-scsi@vger.kernel.org
Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com>
Tested-by: Ming Lei <ming.lei@redhat.com>
Reviewed-by: Omar Sandoval <osandov@fb.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Remove this function since it has an empty body.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Since symbolic names for the device information keys alread exist,
associate an enumeration type with these symbolic values. This change
makes it clear what the valid values for the 'key' arguments are.
As per recommendation from Linus we should be using a distinct type for
blacklist flags.
[mkp: was cut against an older kernel, applied by hand]
Signed-off-by: Hannes Reinecke <hare@suse.com>
Pull SCSI updates from James Bottomley:
"This is mostly updates of the usual suspects: lpfc, qla2xxx, hisi_sas,
megaraid_sas, pm80xx, mpt3sas, be2iscsi, hpsa. and a host of minor
updates.
There's no major behaviour change or additions to the core in all of
this, so the potential for regressions should be small (biggest
potential being in the scsi error handler changes)"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (203 commits)
scsi: lpfc: Fix hard lock up NMI in els timeout handling.
scsi: mpt3sas: remove a stray KERN_INFO
scsi: mpt3sas: cleanup _scsih_pcie_enumeration_event()
scsi: aacraid: use timespec64 instead of timeval
scsi: scsi_transport_fc: add 64GBIT and 128GBIT port speed definitions
scsi: qla2xxx: Suppress a kernel complaint in qla_init_base_qpair()
scsi: mpt3sas: fix dma_addr_t casts
scsi: be2iscsi: Use kasprintf
scsi: storvsc: Avoid excessive host scan on controller change
scsi: lpfc: fix kzalloc-simple.cocci warnings
scsi: mpt3sas: Update mpt3sas driver version.
scsi: mpt3sas: Fix sparse warnings
scsi: mpt3sas: Fix nvme drives checking for tlr.
scsi: mpt3sas: NVMe drive support for BTDHMAPPING ioctl command and log info
scsi: mpt3sas: Add-Task-management-debug-info-for-NVMe-drives.
scsi: mpt3sas: scan and add nvme device after controller reset
scsi: mpt3sas: Set NVMe device queue depth as 128
scsi: mpt3sas: Handle NVMe PCIe device related events generated from firmware.
scsi: mpt3sas: API's to remove nvme drive from sml
scsi: mpt3sas: API 's to support NVMe drive addition to SML
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Device handlers are optional, and for some handlers like ALUA only
implemented for certain device types. So suppress any errors for
unsupported devices.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Rename several functions to make it easy to see which queue type a
function is intended for.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Just like for the scsi-mq code path, in the single queue SCSI code path
only add commands to the per-device command list if required by the SCSI
LLD. This patch will make it easier to merge the single-queue and
multiqueue command initialization code.
This patch does not change any functionality.
Cc: Israel Rukshin <israelr@mellanox.com>
Cc: Max Gurtovoy <maxg@mellanox.com>
Cc: Benjamin Block <bblock@linux.vnet.ibm.com>
"This update includes the usual round of major driver updates
(hisi_sas, ufs, fnic, cxlflash, be2iscsi, ipr, stex). There's also the
usual amount of cosmetic and spelling stuff"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (155 commits)
scsi: qla4xxx: fix spelling mistake: "Tempalate" -> "Template"
scsi: stex: make S6flag static
scsi: mac_esp: fix to pass correct device identity to free_irq()
scsi: aacraid: pci_alloc_consistent() failures on ARM64
scsi: ufs: make ufshcd_get_lists_status() register operation obvious
scsi: ufs: use MASK_EE_STATUS
scsi: mac_esp: Replace bogus memory barrier with spinlock
scsi: fcoe: make fcoe_e_d_tov and fcoe_r_a_tov static
scsi: sd_zbc: Do not write lock zones for reset
scsi: sd_zbc: Remove superfluous assignments
scsi: sd: sd_zbc: Rename sd_zbc_setup_write_cmnd
scsi: Improve scsi_get_sense_info_fld
scsi: sd: Cleanup sd_done sense data handling
scsi: sd: Improve sd_completed_bytes
scsi: sd: Fix function descriptions
scsi: mpt3sas: remove redundant wmb
scsi: mpt: Move scsi_remove_host() out of mptscsih_remove_host()
scsi: sg: reset 'res_in_use' after unlinking reserved array
scsi: mvumi: remove code handling zero scsi_sg_count(scmd) case
scsi: fusion: fix spelling mistake: "Persistancy" -> "Persistency"
There hasn't been any reports for HBAs where asynchronous abort
would not work, so we should make it mandatory and remove
the fallback.
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
scsi_eh_scmd_add() currently only will fail if no
error handler thread is started (which will never be the
case) or if the state machine encounters an illegal transition.
But if we're encountering an invalid state transition
chances is we cannot fixup things with the error handler.
So better add a WARN_ON for illegal host states and
make scsi_dh_scmd_add() a void function.
Commit 669f044170d8 ("scsi: srp_transport: Move queuecommand() wait code
to SCSI core") can make scsi_internal_device_block() sleep. However,
the mpt3sas driver can call this function from an interrupt
handler. Hence add a second argument to scsi_internal_device_block()
that restores the old behavior of this function for the mpt3sas handler.
The call chain that triggered an "IRQ handler enabled interrupts"
complaint is as follows:
_base_interrupt()
-> _base_async_event()
-> mpt3sas_scsih_event_callback()
-> _scsih_check_topo_delete_events()
-> _scsih_block_io_to_children_attached_directly()
-> _scsih_block_io_device()
-> _scsih_internal_device_block()
-> scsi_internal_device_block()
Reported-by: Omar Sandoval <osandov@osandov.com>
Cc: Omar Sandoval <osandov@osandov.com>
Cc: Sagi Grimberg <sagi@grimberg.me>
Cc: Sathya Prakash <sathya.prakash@broadcom.com>
Cc: Chaitra P B <chaitra.basappa@broadcom.com>
Cc: Suganath Prabu Subramani <suganath-prabu.subramani@broadcom.com>
Cc: Sreekanth Reddy <Sreekanth.Reddy@broadcom.com>
Cc: <stable@vger.kernel.org> # v4.10+
Tested-by: Omar Sandoval <osandov@fb.com>
Rely on the new block layer functionality to allocate additional driver
specific data behind struct request instead of implementing it in SCSI
itѕelf.
Signed-off-by: Jens Axboe <axboe@fb.com>
Currently blk-mq always allocates the sense buffer using normal GFP_KERNEL
allocation. Refactor the cmd pool code to split the cmd and sense allocation
and share the code to allocate the sense buffers as well as the sense buffer
slab caches between the legacy and blk-mq path.
Note that this switches to lazy allocation of the sense slab caches - the
slab caches (not the actual allocations) won't be destroy until the scsi
module is unloaded instead of keeping track of hosts using them.
"This update includes the usual round of major driver updates (hpsa,
be2iscsi, hisi_sas, zfcp, cxlflash). There's a new incarnation of hpsa
called smartpqi for which a driver is added, there's some cleanup work
of the ibm vscsi target and updates to libfc, plus a whole host of
minor fixes and updates and finally the removal of several ISA drivers
which seem not to have been used for years"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (173 commits)
scsi: mvsas: Mark symbols static where possible
scsi: pm8001: Mark symbols static where possible
scsi: arcmsr: Simplify user_len checking
scsi: fcoe: fix off by one in eth2fc_speed()
scsi: dtc: remove from tree
scsi: t128: remove from tree
scsi: pas16: remove from tree
scsi: u14-34f: remove from tree
scsi: ultrastor: remove from tree
scsi: in2000: remove from tree
scsi: wd7000: remove from tree
scsi: scsi_dh_alua: Fix memory leak in alua_rtpg()
scsi: lpfc: Mark symbols static where possible
scsi: hpsa: correct call to hpsa_do_reset
scsi: ufs: Get a TM service response from the correct offset
scsi: ibmvfc: Fix I/O hang when port is not mapped
scsi: megaraid_sas: clean function declarations in megaraid_sas_base.c up
scsi: ipr: Remove redundant messages at adapter init time
scsi: ipr: Don't log unnecessary 9084 error details
scsi: smartpqi: raid bypass lba calculation fix
This patch avoids that the following memory leak is triggered if
use_blk_mq is disabled after a SCSI host has been allocated by the
ib_srp driver and before the same SCSI host is freed:
unreferenced object 0xffff8803a168c568 (size 256):
backtrace:
[<ffffffff81620c95>] kmemleak_alloc+0x45/0xa0
[<ffffffff811bb104>] __kmalloc_node+0x1e4/0x400
[<ffffffff81309fe4>] blk_mq_alloc_tag_set+0xb4/0x230
[<ffffffff814731b7>] scsi_mq_setup_tags+0xc7/0xd0
[<ffffffff81469c26>] scsi_add_host_with_dma+0x216/0x2d0
[<ffffffffa064bef5>] srp_create_target+0xe55/0x13d0 [ib_srp]
[<ffffffff8143ce23>] dev_attr_store+0x13/0x20
[<ffffffff8125f030>] sysfs_kf_write+0x40/0x50
[<ffffffff8125e397>] kernfs_fop_write+0x137/0x1c0
[<ffffffff811d8c13>] __vfs_write+0x23/0x140
[<ffffffff811d92e0>] vfs_write+0xb0/0x190
[<ffffffff811da5b4>] SyS_write+0x44/0xa0
[<ffffffff8162c8a5>] entry_SYSCALL_64_fastpath+0x18/0xa8
Fixes: 9aa9cc4221f5 ("scsi: remove the disable_blk_mq host flag")
Cc: Martin K. Petersen <martin.petersen@oracle.com>
We get 2 warnings about global functions without a declaration in the
scsi driver when building with W=1:
drivers/scsi/scsi_lib.c:467:6: warning: no previous prototype for 'scsi_requeue_run_queue' [-Wmissing-prototypes]
drivers/scsi/scsi_lib.c:2609:6: warning: no previous prototype for 'scsi_evt_thread' [-Wmissing-prototypes]
In fact, both functions are declared in drivers/scsi/scsi_scan.c but
need to move them into scsi_priv.h.
Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org>
On larger installations it is useful to disable automatic LUN scanning,
and only add the required LUNs via udev rules. This can speed up bootup
dramatically.
This patch introduces a new scan module parameter value 'manual', which
works like 'none', but can be overridden by setting the 'rescan' value
from scsi_scan_target to 'SCSI_SCAN_MANUAL'. And it updates all
relevant callers to set the 'rescan' value to 'SCSI_SCAN_MANUAL' if
invoked via the 'scan' option in sysfs.
Reviewed-by: Ewan D. Milne <emilne@redhat.com>
Tested-by: Laurence Oberman <loberman@redhat.com>
As scsi_dh.c is now always compiled in we should be moving
the 'dh_state' attribute to the generic code.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.com>
The commit 1bab0de0274f ("dm-mpath, scsi_dh: don't let dm detach device
handlers") removed reference counting of attached scsi device handler.
As a result, handler data is freed immediately via scsi_dh->detach()
in the context of scsi_remove_device() where activation request can be
still in flight.
This patch moves scsi_dh_handler_detach() to sdev releasing function,
scsi_device_dev_release_usercontext(), at that point the device
is already in quiesced state.
Fixes: 1bab0de0274f ("dm-mpath, scsi_dh: don't let dm detach device handlers")
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Acked-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Stop building scsi_dh as a separate module and integrate it fully into the
core SCSI code with explicit callouts at bus scan time. For now the
callouts are placed at the same point as the old bus notifiers were called,
but in the future we will be able to look at ALUA INQUIRY data earlier on.
Note that this also means that the device handler modules need to be loaded
by the time we scan the bus. The next patches will add support for
autoloading device handlers at bus scan time to make sure they are always
loaded if they are enabled in the kernel config.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Acked-by: Mike Snitzer <snitzer@redhat.com>
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks
depending on CONFIG_PM_RUNTIME may now be changed to depend on
CONFIG_PM.
Replace CONFIG_PM_RUNTIME with CONFIG_PM everywhere under
drivers/scsi/ and in include/scsi/scsi_device.h.
Reviewed-by: Aaron Lu <aaron.lu@intel.com>
scsi_lib.c is where the rest of the I/O submission path lives, so move
scsi_dispatch_cmd there and mark it static.
There's only one caller left, so inline it and reduce the blk-mq vs !blk-mq
diff a litte bit.
This patch adds support for an alternate I/O path in the scsi midlayer
which uses the blk-mq infrastructure instead of the legacy request code.
Use of blk-mq is fully transparent to drivers, although for now a host
template field is provided to opt out of blk-mq usage in case any unforseen
incompatibilities arise.
In general replacing the legacy request code with blk-mq is a simple and
mostly mechanical transformation. The biggest exception is the new code
that deals with the fact the I/O submissions in blk-mq must happen from
process context, which slightly complicates the I/O completion handler.
The second biggest differences is that blk-mq is build around the concept
of preallocated requests that also include driver specific data, which
in SCSI context means the scsi_cmnd structure. This completely avoids
dynamic memory allocations for the fast path through I/O submission.
Due the preallocated requests the MQ code path exclusively uses the
host-wide shared tag allocator instead of a per-LUN one. This only
affects drivers actually using the block layer provided tag allocator
instead of their own. Unlike the old path blk-mq always provides a tag,
although drivers don't have to use it.
For now the blk-mq path is disable by defauly and must be enabled using
the "use_blk_mq" module parameter. Once the remaining work in the block
layer to make blk-mq more suitable for slow devices is complete I hope
to make it the default and eventually even remove the old code path.
Based on the earlier scsi-mq prototype by Nicholas Bellinger.
Thanks to Bart Van Assche and Robert Elliot for testing, benchmarking and
various sugestions and code contributions.
Reviewed-by: Webb Scales <webbnh@hp.com>
Acked-by: Jens Axboe <axboe@kernel.dk>
Tested-by: Bart Van Assche <bvanassche@acm.org>
Tested-by: Robert Elliott <elliott@hp.com>
The SCSI standard defines 64-bit values for LUNs, and large arrays
employing large or hierarchical LUN numbers become more and more
common.
So update the linux SCSI stack to use 64-bit LUN numbers.
Reviewed-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Ewan Milne <emilne@redhat.com>
async_schedule() sd resume work to allow disks and other devices to
resume in parallel.
This moves the entirety of scsi_device resume to an async context to
ensure that scsi_device_resume() remains ordered with respect to the
completion of the start/stop command. For the duration of the resume,
new command submissions (that do not originate from the scsi-core) will
be deferred (BLKPREP_DEFER).
It adds a new ASYNC_DOMAIN_EXCLUSIVE(scsi_sd_pm_domain) as a container
of these operations. Like scsi_sd_probe_domain it is flushed at
sd_remove() time to ensure async ops do not continue past the
end-of-life of the sdev. The implementation explicitly refrains from
reusing scsi_sd_probe_domain directly for this purpose as it is flushed
at the end of dpm_resume(), potentially defeating some of the benefit.
Given sdevs are quiesced it is permissible for these resume operations
to bleed past the async_synchronize_full() calls made by the driver
core.
We defer the resolution of which pm callback to call until
scsi_dev_type_{suspend|resume} time and guarantee that the callback
parameter is never NULL. With this in place the type of resume
operation is encoded in the async function identifier.
There is a concern that async resume could trigger PSU overload. In the
enterprise, storage enclosures enforce staggered spin-up regardless of
what the kernel does making async scanning safe by default. Outside of
that context a user can disable asynchronous scanning via a kernel
command line or CONFIG_SCSI_SCAN_ASYNC. Honor that setting when
deciding whether to do resume asynchronously.
Inspired by Todd's analysis and initial proposal [2]:
https://01.org/suspendresume/blogs/tebrandt/2013/hard-disk-resume-optimization-simpler-approach
Cc: Len Brown <len.brown@intel.com>
Cc: Phillip Susi <psusi@ubuntu.com>
[alan: bug fix and clean up suggestion]
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Suggested-by: Todd Brandt <todd.e.brandt@linux.intel.com>
[djbw: kick all resume work to the async queue]
When a command runs into a timeout we need to send an 'ABORT TASK'
TMF. This is typically done by the 'eh_abort_handler' LLDD callback.
Conceptually, however, this function is a normal SCSI command, so
there is no need to enter the error handler.
This patch implements a new scsi_abort_command() function which
invokes an asynchronous function scsi_eh_abort_handler() to
abort the commands via the usual 'eh_abort_handler'.
If abort succeeds the command is either retried or terminated,
depending on the number of allowed retries. However, 'eh_eflags'
records the abort, so if the retry would fail again the
command is pushed onto the error handler without trying to
abort it (again); it'll be cleared up from SCSI EH.
[hare: smatch detected stray switch fixed]
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
This is in preparation for teaching async_synchronize_full() to sync all
pending async work, and not just on the async_running domain. This
conversion is functionally equivalent, just embedding the existing list
in a new async_domain type.
The .registered attribute is used in a later patch to distinguish
between domains that want to be flushed by async_synchronize_full()
versus those that only expect async_synchronize_{full|cookie}_domain to
be used for flushing.
[jejb: add async.h to scsi_priv.h for struct async_domain]
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Tested-by: Eldad Zack <eldad@fogrefinery.com>
The return value of scsi_queue_insert() is ignored by all its
callers, hence change the return type of this function into
void.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Tejun Heo <tj@kernel.org>
Use blk_queue_dead() to test whether the queue is dead instead
of !sdev. Since scsi_prep_fn() may be invoked concurrently with
__scsi_remove_device(), keep the queuedata (sdev) pointer in
__scsi_remove_device(). This patch fixes a kernel oops that
can be triggered by USB device removal. See also
http://www.spinics.net/lists/linux-scsi/msg56254.html.
Other changes included in this patch:
- Swap the blk_cleanup_queue() and kfree() calls in
scsi_host_dev_release() to make that code easier to grasp.
- Remove the queue dead check from scsi_run_queue() since the
queue state can change anyway at any point in that function
where the queue lock is not held.
- Remove the queue dead check from the start of scsi_request_fn()
since it is redundant with the scsi_device_online() check.
Reported-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Cc: <stable@kernel.org>
This has scsi_internal_device_unblock/scsi_target_unblock take
the new state to set the devices as an argument instead of
always setting to running. The patch also converts users of these
functions.
This allows the FC and iSCSI class to transition devices from blocked
to transport-offline, so that when fast_io_fail/replacement_timeout
has fired we do not set the devices back to running. Instead, we
set them to SDEV_TRANSPORT_OFFLINE.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
sd injects and synchronizes probe work on the global kernel-wide domain.
This runs into conflict with PM that wants to perform resume actions in
async context:
[ 494.237079] INFO: task kworker/u:3:554 blocked for more than 120 seconds.
[ 494.294396] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 494.360809] kworker/u:3 D 0000000000000000 0 554 2 0x00000000
[ 494.420739] ffff88012e4d3af0 0000000000000046 ffff88013200c160 ffff88012e4d3fd8
[ 494.484392] ffff88012e4d3fd8 0000000000012500 ffff8801394ea0b0 ffff88013200c160
[ 494.548038] ffff88012e4d3ae0 00000000000001e3 ffffffff81a249e0 ffff8801321c5398
[ 494.611685] Call Trace:
[ 494.632649] [<ffffffff8149dd25>] schedule+0x5a/0x5c
[ 494.674687] [<ffffffff8104b968>] async_synchronize_cookie_domain+0xb6/0x112
[ 494.734177] [<ffffffff810461ff>] ? __init_waitqueue_head+0x50/0x50
[ 494.787134] [<ffffffff8131a224>] ? scsi_remove_target+0x48/0x48
[ 494.837900] [<ffffffff8104b9d9>] async_synchronize_cookie+0x15/0x17
[ 494.891567] [<ffffffff8104ba49>] async_synchronize_full+0x54/0x70 <-- here we wait for async contexts to complete
[ 494.943783] [<ffffffff8104b9f5>] ? async_synchronize_full_domain+0x1a/0x1a
[ 495.002547] [<ffffffffa00114b1>] sd_remove+0x2c/0xa2 [sd_mod]
[ 495.051861] [<ffffffff812fe94f>] __device_release_driver+0x86/0xcf
[ 495.104807] [<ffffffff812fe9bd>] device_release_driver+0x25/0x32 <-- here we take device_lock()
[ 853.511341] INFO: task kworker/u:4:549 blocked for more than 120 seconds.
[ 853.568693] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 853.635119] kworker/u:4 D ffff88013097b5d0 0 549 2 0x00000000
[ 853.695129] ffff880132773c40 0000000000000046 ffff880130790000 ffff880132773fd8
[ 853.758990] ffff880132773fd8 0000000000012500 ffff88013288a0b0 ffff880130790000
[ 853.822796] 0000000000000246 0000000000000040 ffff88013097b5c8 ffff880130790000
[ 853.886633] Call Trace:
[ 853.907631] [<ffffffff8149dd25>] schedule+0x5a/0x5c
[ 853.949670] [<ffffffff8149cc44>] __mutex_lock_common+0x220/0x351
[ 854.001225] [<ffffffff81304bd7>] ? device_resume+0x58/0x1c4
[ 854.049082] [<ffffffff81304bd7>] ? device_resume+0x58/0x1c4
[ 854.097011] [<ffffffff8149ce48>] mutex_lock_nested+0x2f/0x36 <-- here we wait for device_lock()
[ 854.145591] [<ffffffff81304bd7>] device_resume+0x58/0x1c4
[ 854.192066] [<ffffffff81304d61>] async_resume+0x1e/0x45
[ 854.237019] [<ffffffff8104bc93>] async_run_entry_fn+0xc6/0x173 <-- ...while running in async context
Provide a 'scsi_sd_probe_domain' so that async probe actions actions can
be flushed without regard for the state of PM, and allow for the resume
path to handle devices that have transitioned from SDEV_QUIESCE to
SDEV_DEL prior to resume.
[alan: uplevel scsi_sd_probe_domain, clarify scsi_device_resume]
[jejb: remove unneeded config guards in include file]
This patch (as1520) fixes a bug in the SCSI layer's power management
implementation.
LUN scanning can be carried out asynchronously in do_scan_async(), and
sd uses an asynchronous thread for the time-consuming parts of disk
probing in sd_probe_async(). Currently nothing coordinates these
async threads with system sleep transitions; they can and do attempt
to continue scanning/probing SCSI devices even after the host adapter
has been suspended. As one might expect, the outcome is not ideal.
This is what the "prepare" stage of system suspend was created for.
After the prepare callback has been called for a host, target, or
device, drivers are not allowed to register any children underneath
them. Currently the SCSI prepare callback is not implemented; this
patch rectifies that omission.
For SCSI hosts, the prepare routine calls scsi_complete_async_scans()
to wait until async scanning is finished. It might be slightly more
efficient to wait only until the host in question has been scanned,
but there's currently no way to do that. Besides, during a sleep
transition we will ultimately have to wait until all the host scanning
has finished anyway.
For SCSI devices, the prepare routine calls async_synchronize_full()
to wait until sd probing is finished. The routine does nothing for
SCSI targets, because asynchronous target scanning is done only as
part of host scanning.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@kernel.org>
All the handlers have now implemented the match function so We don't need to
use scsi_dev_info any more for matching purposes.
Signed-off-by: Babu Moger <babu.moger@netapp.com>
Acked-by: Hannes Reinecke <hare@suse.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits)
[SCSI] scsi_dh_rdac: Add MD36xxf into device list
[SCSI] scsi_debug: add consecutive medium errors
[SCSI] libsas: fix ata list corruption issue
[SCSI] hpsa: export resettable host attribute
[SCSI] hpsa: move device attributes to avoid forward declarations
[SCSI] scsi_debug: Logical Block Provisioning (SBC3r26)
[SCSI] sd: Logical Block Provisioning update
[SCSI] Include protection operation in SCSI command trace
[SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try)
[SCSI] target: Fix volume size misreporting for volumes > 2TB
[SCSI] bnx2fc: Broadcom FCoE offload driver
[SCSI] fcoe: fix broken fcoe interface reset
[SCSI] fcoe: precedence bug in fcoe_filter_frames()
[SCSI] libfcoe: Remove stale fcoe-netdev entries
[SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h
[SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument
[SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs
[SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out"
[SCSI] libfc: Fixing a memory leak when destroying an interface
[SCSI] megaraid_sas: Version and Changelog update
Fix up trivial conflicts due to whitespace differences in
drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
