path: root/drivers/scsi/scsi_priv.h
2020-02-28scsi: core: Remove cmd_list functionalityHannes Reinecke
Remove cmd_list functionality; no users left. With that the scsi_put_command() becomes empty, so remove that one, too. Link: https://lore.kernel.org/r/20200228075318.91255-14-hare@suse.de Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart van Assche <bvanassche@acm.org> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2020-02-12scsi: core: Delete scsi_use_blk_mqJohn Garry
Module param scsi_use_blk_mq has not been referenced for some time, so zap it. Link: https://lore.kernel.org/r/1581355992-139274-1-git-send-email-john.garry@huawei.com Signed-off-by: John Garry <john.garry@huawei.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-11-01scsi: core: avoid host-wide host_busy counter for scsi_mqMing Lei
It isn't necessary to check the host depth in scsi_queue_rq() any more since it has been respected by blk-mq before calling scsi_queue_rq() via getting driver tag. Lots of LUNs may attach to same host and per-host IOPS may reach millions, so we should avoid expensive atomic operations on the host-wide counter in the IO path. This patch implements scsi_host_busy() via blk_mq_tagset_busy_iter() with one scsi command state for reading the count of busy IOs for scsi_mq. It is observed that IOPS is increased by 15% in IO test on scsi_debug (32 LUNs, 32 submit queues, 1024 can_queue, libaio/dio) in a dual-socket system. Cc: Jens Axboe <axboe@kernel.dk> Cc: Ewan D. Milne <emilne@redhat.com> Cc: Omar Sandoval <osandov@fb.com>, Cc: "Martin K. Petersen" <martin.petersen@oracle.com>, Cc: James Bottomley <james.bottomley@hansenpartnership.com>, Cc: Christoph Hellwig <hch@lst.de>, Cc: Kashyap Desai <kashyap.desai@broadcom.com> Cc: Hannes Reinecke <hare@suse.de> Cc: Laurence Oberman <loberman@redhat.com> Cc: Bart Van Assche <bvanassche@acm.org> Link: https://lore.kernel.org/r/20191025065855.6309-1-ming.lei@redhat.com Signed-off-by: Ming Lei <ming.lei@redhat.com> Reviewed-by: Jens Axboe <axboe@kernel.dk> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2019-06-18scsi: sd: Rely on the driver core for asynchronous probingBart Van Assche
As explained during the 2018 LSF/MM session about increasing SCSI disk probing concurrency, the problems with the current probing approach are as follows: - The driver core is unaware of asynchronous SCSI LUN probing. wait_for_device_probe() waits for all asynchronous probes except asynchronous SCSI disk probes. - There is unnecessary serialization between sd_probe() and sd_remove(). This can lead to a deadlock. Hence this patch that modifies the sd driver such that it uses the driver core framework for asynchronous probing. The async domain and get_device()/put_device() pairs that became superfluous due to this change are removed. This patch does not affect the time needed for loading the scsi_debug kernel module with parameters delay=0 and max_luns=256. This patch depends on commit ef0ff68351be ("driver core: Probe devices asynchronously instead of the driver") that went upstream in kernel version v5.1-rc1. Cc: Lee Duncan <lduncan@suse.com> Cc: Hannes Reinecke <hare@suse.com> Cc: Luis Chamberlain <mcgrof@kernel.org> Cc: Johannes Thumshirn <jthumshirn@suse.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2018-11-07scsi: kill off the legacy IO pathJens Axboe
This removes the legacy (non-mq) IO path for SCSI. Cc: linux-scsi@vger.kernel.org Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Tested-by: Ming Lei <ming.lei@redhat.com> Reviewed-by: Omar Sandoval <osandov@fb.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-12-07scsi: dh: Remove scsi_dh_remove_device()Bart Van Assche
Remove this function since it has an empty body. Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Hannes Reinecke <hare@suse.com> Cc: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-12-07scsi: core: Introduce scsi_devinfo_key enumeration typeBart Van Assche
Since symbolic names for the device information keys alread exist, associate an enumeration type with these symbolic values. This change makes it clear what the valid values for the 'key' arguments are. Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Hannes Reinecke <hare@suse.com> Cc: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-11-16scsi: Use 'blist_flags_t' for scsi_devinfo flagsHannes Reinecke
As per recommendation from Linus we should be using a distinct type for blacklist flags. [mkp: was cut against an older kernel, applied by hand] Signed-off-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-11-14Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is mostly updates of the usual suspects: lpfc, qla2xxx, hisi_sas, megaraid_sas, pm80xx, mpt3sas, be2iscsi, hpsa. and a host of minor updates. There's no major behaviour change or additions to the core in all of this, so the potential for regressions should be small (biggest potential being in the scsi error handler changes)" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (203 commits) scsi: lpfc: Fix hard lock up NMI in els timeout handling. scsi: mpt3sas: remove a stray KERN_INFO scsi: mpt3sas: cleanup _scsih_pcie_enumeration_event() scsi: aacraid: use timespec64 instead of timeval scsi: scsi_transport_fc: add 64GBIT and 128GBIT port speed definitions scsi: qla2xxx: Suppress a kernel complaint in qla_init_base_qpair() scsi: mpt3sas: fix dma_addr_t casts scsi: be2iscsi: Use kasprintf scsi: storvsc: Avoid excessive host scan on controller change scsi: lpfc: fix kzalloc-simple.cocci warnings scsi: mpt3sas: Update mpt3sas driver version. scsi: mpt3sas: Fix sparse warnings scsi: mpt3sas: Fix nvme drives checking for tlr. scsi: mpt3sas: NVMe drive support for BTDHMAPPING ioctl command and log info scsi: mpt3sas: Add-Task-management-debug-info-for-NVMe-drives. scsi: mpt3sas: scan and add nvme device after controller reset scsi: mpt3sas: Set NVMe device queue depth as 128 scsi: mpt3sas: Handle NVMe PCIe device related events generated from firmware. scsi: mpt3sas: API's to remove nvme drive from sml scsi: mpt3sas: API 's to support NVMe drive addition to SML ...
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-25scsi: scsi_dh: suppress errors from unsupported devicesHannes Reinecke
Device handlers are optional, and for some handlers like ALUA only implemented for certain device types. So suppress any errors for unsupported devices. Signed-off-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-08-25scsi: Document which queue type a function is intended forBart Van Assche
Rename several functions to make it easy to see which queue type a function is intended for. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Hannes Reinecke <hare@suse.com> Cc: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-12scsi: Only add commands to the device command list if required by the LLDBart Van Assche
Just like for the scsi-mq code path, in the single queue SCSI code path only add commands to the per-device command list if required by the SCSI LLD. This patch will make it easier to merge the single-queue and multiqueue command initialization code. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Cc: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-12scsi: Introduce scsi_start_queue()Bart Van Assche
This patch does not change any functionality. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Israel Rukshin <israelr@mellanox.com> Cc: Max Gurtovoy <maxg@mellanox.com> Cc: Benjamin Block <bblock@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-05-04Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This update includes the usual round of major driver updates (hisi_sas, ufs, fnic, cxlflash, be2iscsi, ipr, stex). There's also the usual amount of cosmetic and spelling stuff" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (155 commits) scsi: qla4xxx: fix spelling mistake: "Tempalate" -> "Template" scsi: stex: make S6flag static scsi: mac_esp: fix to pass correct device identity to free_irq() scsi: aacraid: pci_alloc_consistent() failures on ARM64 scsi: ufs: make ufshcd_get_lists_status() register operation obvious scsi: ufs: use MASK_EE_STATUS scsi: mac_esp: Replace bogus memory barrier with spinlock scsi: fcoe: make fcoe_e_d_tov and fcoe_r_a_tov static scsi: sd_zbc: Do not write lock zones for reset scsi: sd_zbc: Remove superfluous assignments scsi: sd: sd_zbc: Rename sd_zbc_setup_write_cmnd scsi: Improve scsi_get_sense_info_fld scsi: sd: Cleanup sd_done sense data handling scsi: sd: Improve sd_completed_bytes scsi: sd: Fix function descriptions scsi: mpt3sas: remove redundant wmb scsi: mpt: Move scsi_remove_host() out of mptscsih_remove_host() scsi: sg: reset 'res_in_use' after unlinking reserved array scsi: mvumi: remove code handling zero scsi_sg_count(scmd) case scsi: fusion: fix spelling mistake: "Persistancy" -> "Persistency" ...
2017-04-06scsi: make asynchronous aborts mandatoryHannes Reinecke
There hasn't been any reports for HBAs where asynchronous abort would not work, so we should make it mandatory and remove the fallback. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-04-06scsi: make scsi_eh_scmd_add() always succeedHannes Reinecke
scsi_eh_scmd_add() currently only will fail if no error handler thread is started (which will never be the case) or if the state machine encounters an illegal transition. But if we're encountering an invalid state transition chances is we cannot fixup things with the error handler. So better add a WARN_ON for illegal host states and make scsi_dh_scmd_add() a void function. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-01scsi: mpt3sas: Avoid sleeping in interrupt contextBart Van Assche
Commit 669f044170d8 ("scsi: srp_transport: Move queuecommand() wait code to SCSI core") can make scsi_internal_device_block() sleep. However, the mpt3sas driver can call this function from an interrupt handler. Hence add a second argument to scsi_internal_device_block() that restores the old behavior of this function for the mpt3sas handler. The call chain that triggered an "IRQ handler enabled interrupts" complaint is as follows: _base_interrupt() -> _base_async_event() -> mpt3sas_scsih_event_callback() -> _scsih_check_topo_delete_events() -> _scsih_block_io_to_children_attached_directly() -> _scsih_block_io_device() -> _scsih_internal_device_block() -> scsi_internal_device_block() Reported-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Omar Sandoval <osandov@osandov.com> Cc: Hannes Reinecke <hare@suse.com> Cc: Sagi Grimberg <sagi@grimberg.me> Cc: Christoph Hellwig <hch@lst.de> Cc: Sathya Prakash <sathya.prakash@broadcom.com> Cc: Chaitra P B <chaitra.basappa@broadcom.com> Cc: Suganath Prabu Subramani <suganath-prabu.subramani@broadcom.com> Cc: Sreekanth Reddy <Sreekanth.Reddy@broadcom.com> Cc: <stable@vger.kernel.org> # v4.10+ Tested-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-01-27scsi: allocate scsi_cmnd structures as part of struct requestChristoph Hellwig
Rely on the new block layer functionality to allocate additional driver specific data behind struct request instead of implementing it in SCSI itѕelf. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-27scsi: respect unchecked_isa_dma for blk-mqChristoph Hellwig
Currently blk-mq always allocates the sense buffer using normal GFP_KERNEL allocation. Refactor the cmd pool code to split the cmd and sense allocation and share the code to allocate the sense buffers as well as the sense buffer slab caches between the legacy and blk-mq path. Note that this switches to lazy allocation of the sense slab caches - the slab caches (not the actual allocations) won't be destroy until the scsi module is unloaded instead of keeping track of hosts using them. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-10-07Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This update includes the usual round of major driver updates (hpsa, be2iscsi, hisi_sas, zfcp, cxlflash). There's a new incarnation of hpsa called smartpqi for which a driver is added, there's some cleanup work of the ibm vscsi target and updates to libfc, plus a whole host of minor fixes and updates and finally the removal of several ISA drivers which seem not to have been used for years" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (173 commits) scsi: mvsas: Mark symbols static where possible scsi: pm8001: Mark symbols static where possible scsi: arcmsr: Simplify user_len checking scsi: fcoe: fix off by one in eth2fc_speed() scsi: dtc: remove from tree scsi: t128: remove from tree scsi: pas16: remove from tree scsi: u14-34f: remove from tree scsi: ultrastor: remove from tree scsi: in2000: remove from tree scsi: wd7000: remove from tree scsi: scsi_dh_alua: Fix memory leak in alua_rtpg() scsi: lpfc: Mark symbols static where possible scsi: hpsa: correct call to hpsa_do_reset scsi: ufs: Get a TM service response from the correct offset scsi: ibmvfc: Fix I/O hang when port is not mapped scsi: megaraid_sas: clean function declarations in megaraid_sas_base.c up scsi: ipr: Remove redundant messages at adapter init time scsi: ipr: Don't log unnecessary 9084 error details scsi: smartpqi: raid bypass lba calculation fix ...
2016-09-26scsi: Avoid that toggling use_blk_mq triggers a memory leakBart Van Assche
This patch avoids that the following memory leak is triggered if use_blk_mq is disabled after a SCSI host has been allocated by the ib_srp driver and before the same SCSI host is freed: unreferenced object 0xffff8803a168c568 (size 256): backtrace: [<ffffffff81620c95>] kmemleak_alloc+0x45/0xa0 [<ffffffff811bb104>] __kmalloc_node+0x1e4/0x400 [<ffffffff81309fe4>] blk_mq_alloc_tag_set+0xb4/0x230 [<ffffffff814731b7>] scsi_mq_setup_tags+0xc7/0xd0 [<ffffffff81469c26>] scsi_add_host_with_dma+0x216/0x2d0 [<ffffffffa064bef5>] srp_create_target+0xe55/0x13d0 [ib_srp] [<ffffffff8143ce23>] dev_attr_store+0x13/0x20 [<ffffffff8125f030>] sysfs_kf_write+0x40/0x50 [<ffffffff8125e397>] kernfs_fop_write+0x137/0x1c0 [<ffffffff811d8c13>] __vfs_write+0x23/0x140 [<ffffffff811d92e0>] vfs_write+0xb0/0x190 [<ffffffff811da5b4>] SyS_write+0x44/0xa0 [<ffffffff8162c8a5>] entry_SYSCALL_64_fastpath+0x18/0xa8 Fixes: 9aa9cc4221f5 ("scsi: remove the disable_blk_mq host flag") Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: <stable@vger.kernel.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-08-31scsi: move function declarations to scsi_priv.hBaoyou Xie
We get 2 warnings about global functions without a declaration in the scsi driver when building with W=1: drivers/scsi/scsi_lib.c:467:6: warning: no previous prototype for 'scsi_requeue_run_queue' [-Wmissing-prototypes] drivers/scsi/scsi_lib.c:2609:6: warning: no previous prototype for 'scsi_evt_thread' [-Wmissing-prototypes] In fact, both functions are declared in drivers/scsi/scsi_scan.c but need to move them into scsi_priv.h. Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-11scsi: disable automatic target scanHannes Reinecke
On larger installations it is useful to disable automatic LUN scanning, and only add the required LUNs via udev rules. This can speed up bootup dramatically. This patch introduces a new scan module parameter value 'manual', which works like 'none', but can be overridden by setting the 'rescan' value from scsi_scan_target to 'SCSI_SCAN_MANUAL'. And it updates all relevant callers to set the 'rescan' value to 'SCSI_SCAN_MANUAL' if invoked via the 'scan' option in sysfs. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Tested-by: Laurence Oberman <loberman@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-12-02scsi_dh: move 'dh_state' sysfs attribute to generic codeHannes Reinecke
As scsi_dh.c is now always compiled in we should be moving the 'dh_state' attribute to the generic code. Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-10-27scsi_dh: fix use-after-free when removing scsi deviceJunichi Nomura
The commit 1bab0de0274f ("dm-mpath, scsi_dh: don't let dm detach device handlers") removed reference counting of attached scsi device handler. As a result, handler data is freed immediately via scsi_dh->detach() in the context of scsi_remove_device() where activation request can be still in flight. This patch moves scsi_dh_handler_detach() to sdev releasing function, scsi_device_dev_release_usercontext(), at that point the device is already in quiesced state. Fixes: 1bab0de0274f ("dm-mpath, scsi_dh: don't let dm detach device handlers") Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-08-28scsi_dh: integrate into the core SCSI codeChristoph Hellwig
Stop building scsi_dh as a separate module and integrate it fully into the core SCSI code with explicit callouts at bus scan time. For now the callouts are placed at the same point as the old bus notifiers were called, but in the future we will be able to look at ALUA INQUIRY data earlier on. Note that this also means that the device handler modules need to be loaded by the time we scan the bus. The next patches will add support for autoloading device handlers at bus scan time to make sure they are always loaded if they are enabled in the kernel config. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2014-12-15SCSI / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PMRafael J. Wysocki
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks depending on CONFIG_PM_RUNTIME may now be changed to depend on CONFIG_PM. Replace CONFIG_PM_RUNTIME with CONFIG_PM everywhere under drivers/scsi/ and in include/scsi/scsi_device.h. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Christoph Hellwig <hch@lst.de>
2014-11-24scsi: move scsi_dispatch_cmd to scsi_lib.cChristoph Hellwig
scsi_lib.c is where the rest of the I/O submission path lives, so move scsi_dispatch_cmd there and mark it static. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-11-24scsi: remove scsi_next_commandChristoph Hellwig
There's only one caller left, so inline it and reduce the blk-mq vs !blk-mq diff a litte bit. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-07-25scsi: add support for a blk-mq based I/O path.Christoph Hellwig
This patch adds support for an alternate I/O path in the scsi midlayer which uses the blk-mq infrastructure instead of the legacy request code. Use of blk-mq is fully transparent to drivers, although for now a host template field is provided to opt out of blk-mq usage in case any unforseen incompatibilities arise. In general replacing the legacy request code with blk-mq is a simple and mostly mechanical transformation. The biggest exception is the new code that deals with the fact the I/O submissions in blk-mq must happen from process context, which slightly complicates the I/O completion handler. The second biggest differences is that blk-mq is build around the concept of preallocated requests that also include driver specific data, which in SCSI context means the scsi_cmnd structure. This completely avoids dynamic memory allocations for the fast path through I/O submission. Due the preallocated requests the MQ code path exclusively uses the host-wide shared tag allocator instead of a per-LUN one. This only affects drivers actually using the block layer provided tag allocator instead of their own. Unlike the old path blk-mq always provides a tag, although drivers don't have to use it. For now the blk-mq path is disable by defauly and must be enabled using the "use_blk_mq" module parameter. Once the remaining work in the block layer to make blk-mq more suitable for slow devices is complete I hope to make it the default and eventually even remove the old code path. Based on the earlier scsi-mq prototype by Nicholas Bellinger. Thanks to Bart Van Assche and Robert Elliot for testing, benchmarking and various sugestions and code contributions. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Webb Scales <webbnh@hp.com> Acked-by: Jens Axboe <axboe@kernel.dk> Tested-by: Bart Van Assche <bvanassche@acm.org> Tested-by: Robert Elliott <elliott@hp.com>
2014-07-17scsi: use 64-bit LUNsHannes Reinecke
The SCSI standard defines 64-bit values for LUNs, and large arrays employing large or hierarchical LUN numbers become more and more common. So update the linux SCSI stack to use 64-bit LUN numbers. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Christoph Hellwig <hch@infradead.org> Reviewed-by: Ewan Milne <emilne@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-04-10scsi: async sd resumeDan Williams
async_schedule() sd resume work to allow disks and other devices to resume in parallel. This moves the entirety of scsi_device resume to an async context to ensure that scsi_device_resume() remains ordered with respect to the completion of the start/stop command. For the duration of the resume, new command submissions (that do not originate from the scsi-core) will be deferred (BLKPREP_DEFER). It adds a new ASYNC_DOMAIN_EXCLUSIVE(scsi_sd_pm_domain) as a container of these operations. Like scsi_sd_probe_domain it is flushed at sd_remove() time to ensure async ops do not continue past the end-of-life of the sdev. The implementation explicitly refrains from reusing scsi_sd_probe_domain directly for this purpose as it is flushed at the end of dpm_resume(), potentially defeating some of the benefit. Given sdevs are quiesced it is permissible for these resume operations to bleed past the async_synchronize_full() calls made by the driver core. We defer the resolution of which pm callback to call until scsi_dev_type_{suspend|resume} time and guarantee that the callback parameter is never NULL. With this in place the type of resume operation is encoded in the async function identifier. There is a concern that async resume could trigger PSU overload. In the enterprise, storage enclosures enforce staggered spin-up regardless of what the kernel does making async scanning safe by default. Outside of that context a user can disable asynchronous scanning via a kernel command line or CONFIG_SCSI_SCAN_ASYNC. Honor that setting when deciding whether to do resume asynchronously. Inspired by Todd's analysis and initial proposal [2]: https://01.org/suspendresume/blogs/tebrandt/2013/hard-disk-resume-optimization-simpler-approach Cc: Len Brown <len.brown@intel.com> Cc: Phillip Susi <psusi@ubuntu.com> [alan: bug fix and clean up suggestion] Acked-by: Alan Stern <stern@rowland.harvard.edu> Suggested-by: Todd Brandt <todd.e.brandt@linux.intel.com> [djbw: kick all resume work to the async queue] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-12-19[SCSI] improved eh timeout handlerHannes Reinecke
When a command runs into a timeout we need to send an 'ABORT TASK' TMF. This is typically done by the 'eh_abort_handler' LLDD callback. Conceptually, however, this function is a normal SCSI command, so there is no need to enter the error handler. This patch implements a new scsi_abort_command() function which invokes an asynchronous function scsi_eh_abort_handler() to abort the commands via the usual 'eh_abort_handler'. If abort succeeds the command is either retried or terminated, depending on the number of allowed retries. However, 'eh_eflags' records the abort, so if the retry would fail again the command is pushed onto the error handler without trying to abort it (again); it'll be cleared up from SCSI EH. [hare: smatch detected stray switch fixed] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20[SCSI] async: introduce 'async_domain' typeDan Williams
This is in preparation for teaching async_synchronize_full() to sync all pending async work, and not just on the async_running domain. This conversion is functionally equivalent, just embedding the existing list in a new async_domain type. The .registered attribute is used in a later patch to distinguish between domains that want to be flushed by async_synchronize_full() versus those that only expect async_synchronize_{full|cookie}_domain to be used for flushing. [jejb: add async.h to scsi_priv.h for struct async_domain] Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Tested-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20[SCSI] Change return type of scsi_queue_insert() into voidBart Van Assche
The return value of scsi_queue_insert() is ignored by all its callers, hence change the return type of this function into void. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Tejun Heo <tj@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20[SCSI] Fix device removal NULL pointer dereferenceBart Van Assche
Use blk_queue_dead() to test whether the queue is dead instead of !sdev. Since scsi_prep_fn() may be invoked concurrently with __scsi_remove_device(), keep the queuedata (sdev) pointer in __scsi_remove_device(). This patch fixes a kernel oops that can be triggered by USB device removal. See also http://www.spinics.net/lists/linux-scsi/msg56254.html. Other changes included in this patch: - Swap the blk_cleanup_queue() and kfree() calls in scsi_host_dev_release() to make that code easier to grasp. - Remove the queue dead check from scsi_run_queue() since the queue state can change anyway at any point in that function where the queue lock is not held. - Remove the queue dead check from the start of scsi_request_fn() since it is redundant with the scsi_device_online() check. Reported-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: <stable@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20[SCSI] core, classes, mpt2sas: have scsi_internal_device_unblock take new stateMike Christie
This has scsi_internal_device_unblock/scsi_target_unblock take the new state to set the devices as an argument instead of always setting to running. The patch also converts users of these functions. This allows the FC and iSCSI class to transition devices from blocked to transport-offline, so that when fast_io_fail/replacement_timeout has fired we do not set the devices back to running. Instead, we set them to SDEV_TRANSPORT_OFFLINE. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-05-17[SCSI] sd: limit the scope of the async probe domainDan Williams
sd injects and synchronizes probe work on the global kernel-wide domain. This runs into conflict with PM that wants to perform resume actions in async context: [ 494.237079] INFO: task kworker/u:3:554 blocked for more than 120 seconds. [ 494.294396] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 494.360809] kworker/u:3 D 0000000000000000 0 554 2 0x00000000 [ 494.420739] ffff88012e4d3af0 0000000000000046 ffff88013200c160 ffff88012e4d3fd8 [ 494.484392] ffff88012e4d3fd8 0000000000012500 ffff8801394ea0b0 ffff88013200c160 [ 494.548038] ffff88012e4d3ae0 00000000000001e3 ffffffff81a249e0 ffff8801321c5398 [ 494.611685] Call Trace: [ 494.632649] [<ffffffff8149dd25>] schedule+0x5a/0x5c [ 494.674687] [<ffffffff8104b968>] async_synchronize_cookie_domain+0xb6/0x112 [ 494.734177] [<ffffffff810461ff>] ? __init_waitqueue_head+0x50/0x50 [ 494.787134] [<ffffffff8131a224>] ? scsi_remove_target+0x48/0x48 [ 494.837900] [<ffffffff8104b9d9>] async_synchronize_cookie+0x15/0x17 [ 494.891567] [<ffffffff8104ba49>] async_synchronize_full+0x54/0x70 <-- here we wait for async contexts to complete [ 494.943783] [<ffffffff8104b9f5>] ? async_synchronize_full_domain+0x1a/0x1a [ 495.002547] [<ffffffffa00114b1>] sd_remove+0x2c/0xa2 [sd_mod] [ 495.051861] [<ffffffff812fe94f>] __device_release_driver+0x86/0xcf [ 495.104807] [<ffffffff812fe9bd>] device_release_driver+0x25/0x32 <-- here we take device_lock() [ 853.511341] INFO: task kworker/u:4:549 blocked for more than 120 seconds. [ 853.568693] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 853.635119] kworker/u:4 D ffff88013097b5d0 0 549 2 0x00000000 [ 853.695129] ffff880132773c40 0000000000000046 ffff880130790000 ffff880132773fd8 [ 853.758990] ffff880132773fd8 0000000000012500 ffff88013288a0b0 ffff880130790000 [ 853.822796] 0000000000000246 0000000000000040 ffff88013097b5c8 ffff880130790000 [ 853.886633] Call Trace: [ 853.907631] [<ffffffff8149dd25>] schedule+0x5a/0x5c [ 853.949670] [<ffffffff8149cc44>] __mutex_lock_common+0x220/0x351 [ 854.001225] [<ffffffff81304bd7>] ? device_resume+0x58/0x1c4 [ 854.049082] [<ffffffff81304bd7>] ? device_resume+0x58/0x1c4 [ 854.097011] [<ffffffff8149ce48>] mutex_lock_nested+0x2f/0x36 <-- here we wait for device_lock() [ 854.145591] [<ffffffff81304bd7>] device_resume+0x58/0x1c4 [ 854.192066] [<ffffffff81304d61>] async_resume+0x1e/0x45 [ 854.237019] [<ffffffff8104bc93>] async_run_entry_fn+0xc6/0x173 <-- ...while running in async context Provide a 'scsi_sd_probe_domain' so that async probe actions actions can be flushed without regard for the state of PM, and allow for the resume path to handle devices that have transitioned from SDEV_QUIESCE to SDEV_DEL prior to resume. Acked-by: Alan Stern <stern@rowland.harvard.edu> [alan: uplevel scsi_sd_probe_domain, clarify scsi_device_resume] Signed-off-by: Dan Williams <dan.j.williams@intel.com> [jejb: remove unneeded config guards in include file] Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-18[SCSI] scsi_pm: Fix bug in the SCSI power management handlerAlan Stern
This patch (as1520) fixes a bug in the SCSI layer's power management implementation. LUN scanning can be carried out asynchronously in do_scan_async(), and sd uses an asynchronous thread for the time-consuming parts of disk probing in sd_probe_async(). Currently nothing coordinates these async threads with system sleep transitions; they can and do attempt to continue scanning/probing SCSI devices even after the host adapter has been suspended. As one might expect, the outcome is not ideal. This is what the "prepare" stage of system suspend was created for. After the prepare callback has been called for a host, target, or device, drivers are not allowed to register any children underneath them. Currently the SCSI prepare callback is not implemented; this patch rectifies that omission. For SCSI hosts, the prepare routine calls scsi_complete_async_scans() to wait until async scanning is finished. It might be slightly more efficient to wait only until the host in question has been scanned, but there's currently no way to do that. Besides, during a sleep transition we will ultimately have to wait until all the host scanning has finished anyway. For SCSI devices, the prepare routine calls async_synchronize_full() to wait until sd probing is finished. The routine does nothing for SCSI targets, because asynchronous target scanning is done only as part of host scanning. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: <stable@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-12-15[SCSI] scsi_dh: code cleanup and remove the references to scsi_dev_infoMoger, Babu
All the handlers have now implemented the match function so We don't need to use scsi_dev_info any more for matching purposes. Signed-off-by: Babu Moger <babu.moger@netapp.com> Acked-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-15PM: Remove CONFIG_PM_OPSRafael J. Wysocki
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be replaced with CONFIG_PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-01-24[SCSI] scsi_dh: Use scsi_devinfo functions to do matching of device_handler ↵Peter Jones
tables. Previously we were using strncmp in order to avoid having to include whitespace in the devlist, but this means "HSV1000" matches a device list entry that says "HSV100", which is wrong. This patch changes scsi_dh.c to use scsi_devinfo's matching functions instead, since they handle these cases correctly. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-24[SCSI] Add scsi_dev_info_list_del_keyed()Peter Jones
For scsi_dh.c to use devinfo lists, we have to be able to remove entries before rmmod. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-06SCSI: remove fake "address-of" expressionAlan Stern
Fake "address-of" expressions that evaluate to NULL generally confuse readers and can provoke compiler warnings. This patch (as1411) removes one such fake expression, using an "#ifdef" in its place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-28[SCSI] implement runtime Power ManagementAlan Stern
This patch (as1398b) adds runtime PM support to the SCSI layer. Only the machanism is provided; use of it is up to the various high-level drivers, and the patch doesn't change any of them. Except for sg -- the patch expicitly prevents a device from being runtime-suspended while its sg device file is open. The implementation is simplistic. In general, hosts and targets are automatically suspended when all their children are asleep, but for them the runtime-suspend code doesn't actually do anything. (A host's runtime PM status is propagated up the device tree, though, so a runtime-PM-aware lower-level driver could power down the host adapter hardware at the appropriate times.) There are comments indicating where a transport class might be notified or some other hooks added. LUNs are runtime-suspended by calling the drivers' existing suspend handlers (and likewise for runtime-resume). Somewhat arbitrarily, the implementation delays for 100 ms before suspending an eligible LUN. This is because there typically are occasions during bootup when the same device file is opened and closed several times in quick succession. The way this all works is that the SCSI core increments a device's PM-usage count when it is registered. If a high-level driver does nothing then the device will not be eligible for runtime-suspend because of the elevated usage count. If a high-level driver wants to use runtime PM then it can call scsi_autopm_put_device() in its probe routine to decrement the usage count and scsi_autopm_get_device() in its remove routine to restore the original count. Hosts, targets, and LUNs are not suspended while they are being probed or removed, or while the error handler is running. In fact, a fairly large part of the patch consists of code to make sure that things aren't suspended at such times. [jejb: fix up compile issues in PM config variations] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-28[SCSI] convert to the new PM frameworkAlan Stern
This patch (as1397b) converts the SCSI midlayer to use the new PM callbacks (struct dev_pm_ops). A new source file, scsi_pm.c, is created to hold the new callback routines, and the existing suspend/resume code is moved there. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-15driver model: constify attribute groupsDavid Brownell
Let attribute group vectors be declared "const". We'd like to let most attribute metadata live in read-only sections... this is a start. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-21sd, sr: fix Driver 'sd' needs updating messageHannes Reinecke
If a SCSI ULD driver sets blk_queue_prep_rq(), it should clean it up itself on remove(), and not from the bus callbacks. This removes the need to hook into bus->remove(), which should not be used at the same time as driver->remove(). [jejb: fix sdkp initialisation problem due to mismerge] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
