path: root/drivers/scsi/scsi_debug.c
2008-02-18[SCSI] scsi_debug: disable clusteringFUJITA Tomonori
scsi_debug does at several places: for_each_sg(sdb->table.sgl, sg, sdb->table.nents, k) { kaddr = (unsigned char *) kmap_atomic(sg_page(sg), KM_USER0); We cannot do something like that with the clustering enabled (or we can use scsi_kmap_atomic_sg). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] scsi_debug: add XDWRITEREAD_10 supportFUJITA Tomonori
2008-01-30[SCSI] scsi_debug: add bidi data transfer supportFUJITA Tomonori
This enables fill_from_dev_buffer and fetch_to_dev_buffer to handle bidi commands. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] scsi_debug: add get_data_transfer_info helper functionFUJITA Tomonori
This adds get_data_transfer_info helper function that get lha and sectors for READ_* and WRITE_* commands (and XDWRITEREAD_10 later). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] scsi_debug: convert to use the data buffer accessorsBoaz Harrosh
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-16scsi_debug: support sg chainingJens Axboe
Signed-off-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-19[SCSI] Make scsi_host_template::proc_name const char * instead of char *.Kristian Høgsberg
Signed-off-by: Kristian Høgsberg <krh@redhat.com> collapsed with fw-sbp2 patch "Drop cast to non-const char * in host template initialization." from Kristian Høgsberg Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] scsi_debug: correct parameter default textRandy Dunlap
Correct the module info text for the default value of "every_nth" to 0. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-13[SCSI] scsi_debug: error processingDouglas Gilbert
After discussions in the thread titled: [PATCH] scsi_debug: illegal blocking memory allocation here is a patch containing the discussed fix and some other fixes and additions. The patch is against lk 2.6.20-rc3 . The version is bumped to 1.81 . ChangeLog: - Change several GFP_KERNEL allocations to GFP_ATOMIC as they can be called from queuecommand() context - check above allocation returns and if out of memory report DID_REQUEUE in two cases, DID_NO_CONNECT in another, and fail slave configure() in another - add support for WRITE BUFFER command - add aborted_command error injection support (opts mask 0x10), similar mechanism to recovered_error injection. Signed-off-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] scsi_debug: support REPORT TARGET PORT GROUPSHannes Reinecke
This patch adds support for REPORT TARGET PORT GROUPS. This is used eg for the multipathing priority callout to determine the path priority. With this patch multipath-tools can use the existing mpath_prio_alua callout to exercise the path priority grouping. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-23[SCSI] scsi_debug version 1.80Douglas Gilbert
See http://www.torque.net/sg/sdebug26.html for more information on the scsi_debug driver. ChangeLog: - add 'vpd_use_hostno' parameter to allow simulated hosts to see the same set of targets (and luns). For testing multipath software. - add 'fake_rw' parameter to ignore the data in READ and WRITE commands - add support for log subpages (new in SPC-4) - yield appropriate block descriptor for MODE SENSE commands (only for pdt=0 (i.e. disks)) - REQUEST SENSE response no longer shows the stopped power condition (SAT changed to agree with SPC-3) Signed-off-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-12[SCSI] scsi_debug: must_check fixesRandy Dunlap
Check all __must_check warnings in scsi_debug. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-03Merge ../scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/nsp32.c drivers/scsi/pcmcia/nsp_cs.c Removal of randomness flag conflicts with SA_ -> IRQF_ global replacement. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-26[SCSI] scsi_debug version 1.79Douglas Gilbert
- add 'virtual_gb' parameter to simulate large storage (by wrapping in dev_size_mb megabytes of actual ram) - add 'no_lun_0' parameter to skip lun 0 on each target (but still respond as required to INQUIRY + REPORT LUNS) - add well know lu support - add MODE SELECT commands support [pages: 0xa and 0x1c] - add LOG SENSE command support [pages: 0xd and 0x2f] - add READ CAPACITY (16) support - increase number of mode pages supported (to read), mainly transport specific (SAS) mode (sub)pages - add more VPD pages and extend others, including ATA information VPD page - START STOP UNIT now maintains a state machine - READ (16) and WRITE (16) cope with lbas larger than 32 bits (needed for the 'virtual_gb' parameter) - allow single command transfers up to 32 MB - more precise error (sense data) messages Signed-off-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] SCSI core kmalloc2kzallocJes Sorensen
Change the core SCSI code to use kzalloc rather than kmalloc+memset where possible. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-13[PATCH] Add Pseudo LLD bus_type probe and remove methodsRussell King
Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10Merge by hand (whitespace conflicts in libata.h)James Bottomley
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[SCSI] use scmd_id(), scmd_channel() throughout codeJeff Garzik
Wrap a highly common idiom. Makes the code easier to read, helps pave the way for sdev->{id,channel} removal, and adds a token that can easily by grepped-for in the future. There are a couple sdev_id() and scmd_printk() updates thrown in as well. Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] use {sdev,scmd,starget,shost}_printk in generic codeJeff Garzik
rejections fixed and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-24[PATCH] make various thing staticAdrian Bunk
Another rollup of patches which give various symbols static scope Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
