[ Upstream commit c7702b8c22712a06080e10f1d2dee1a133ec8809 ]
There is a race condition with qla2xxx optrom functions where one thread
might modify optrom buffer, optrom_state while other thread is still
reading from it.
In couple of crashes, it was found that we had successfully passed the
following 'if' check where we confirm optrom_state to be
QLA_SREADING. But by the time we acquired mutex lock to proceed with
memory_read_from_buffer function, some other thread/process had already
modified that option rom buffer and optrom_state from QLA_SREADING to
QLA_SWAITING. Then we got ha->optrom_buffer 0x0 and crashed the system:
if (ha->optrom_state != QLA_SREADING)
return 0;
mutex_lock(&ha->optrom_mutex);
rval = memory_read_from_buffer(buf, count, &off, ha->optrom_buffer,
ha->optrom_region_size);
mutex_unlock(&ha->optrom_mutex);
With current optrom function we get following crash due to a race
condition:
[ 1479.466679] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1479.466707] IP: [<ffffffff81326756>] memcpy+0x6/0x110
[ 1479.473673] Call Trace:
[ 1479.474296] [<ffffffff81225cbc>] ? memory_read_from_buffer+0x3c/0x60
[ 1479.474941] [<ffffffffa01574dc>] qla2x00_sysfs_read_optrom+0x9c/0xc0 [qla2xxx]
[ 1479.475571] [<ffffffff8127e76b>] read+0xdb/0x1f0
[ 1479.476206] [<ffffffff811fdf9e>] vfs_read+0x9e/0x170
[ 1479.476839] [<ffffffff811feb6f>] SyS_read+0x7f/0xe0
[ 1479.477466] [<ffffffff816964c9>] system_call_fastpath+0x16/0x1b
Below patch modifies qla2x00_sysfs_read_optrom,
qla2x00_sysfs_write_optrom functions to get the mutex_lock before
checking ha->optrom_state to avoid similar crashes.
The patch was applied and tested and same crashes were no longer
observed again.
Tested-by: Milan P. Gandhi <mgandhi@redhat.com>
Signed-off-by: Milan P. Gandhi <mgandhi@redhat.com>
Reviewed-by: Laurence Oberman <loberman@redhat.com>
Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com>
[ Upstream commit 4f060736f29a960aba8e781a88837464756200a8 ]
Termination of Immediate Notify IOCB was using wrong
IOCB handle. IOCB completion code was unable to find
appropriate code path due to wrong handle.
Following message is seen in the logs.
"Error entry - invalid handle/queue (ffff)."
Signed-off-by: Quinn Tran <quinn.tran@cavium.com>
Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com>
[ bvanassche: Fixed word order in patch title ]
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
[ Upstream commit 5f35509db179ca7ed1feaa4b14f841adb06ed220 ]
Corrupted ATIO is defined as length of fcp_header & fcp_cmd
payload is less than 0x38. It's the minimum size for a frame to
carry 8..16 bytes SCSI CDB. The exchange will be dropped or
terminated if corrupted.
[ bvanassche: Fixed spelling in patch title ]
commit 74939a0bc772d642b1c12827966c4c3a3c90ea2c upstream.
Signed-off-by: Joe Carnuccio <joe.carnuccio@cavium.com>
commit 1d63496516c61e2e1351f10e6becbfc9ee511395 upstream.
Set bit (BIT_15) to send right ECHO payload information for Diagnostic
Echo Test command.
debug customer issues
commit ce6c668b146cc4f4442111e2bcee4c3af94e1ddf upstream.
Firmware dump allows for debugging customer issues. This patch fixes
start/end pointer calculation to capture T262 template entry for dump
tool.
commit ddff7ed45edce4a4c92949d3c61cd25d229c4a14 upstream.
When pci_enable_device() or pci_enable_device_mem() fail in
qla2x00_probe_one() we bail out but do a call to
pci_disable_device(). This causes the dev_WARN_ON() in
pci_disable_device() to trigger, as the device wasn't enabled
previously.
So instead of taking the 'probe_out' error path we can directly return
*iff* one of the pci_enable_device() calls fails.
Additionally rename the 'probe_out' goto label's name to the more
descriptive 'disable_device'.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Fixes: e315cd28b9ef ("[SCSI] qla2xxx: Code changes for qla data structure refactoring")
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Giridhar Malavali <giridhar.malavali@cavium.com>
commit 5f7c2beef819d9ea2d1b814edf6f5981420e9cf8 upstream.
After a Qlogic card breaks when initializing (test case), the system can
crash in qla2xxx_eh_abort if processing anything but a scsi command type
srb.
Fixes: 1535aa75a3d8 ("scsi: qla2xxx: fix invalid DMA access after command aborts in PCI device remove")
Signed-off-by: Bill Kuzeja <william.kuzeja@stratus.com>
Acked-By: Himanshu Madhani <himanshu.madhani@cavium.com>
commit bf6061b17a8d47ef0d9344d3ef576a4ff0edf793 upstream.
Add fix to read correct register value for ISP82xx, during check for
register disconnect.ISP82xx has different base register.
Fixes: a465537ad1a4 ("qla2xxx: Disable the adapter and skip error recovery in case of register disconnect")
Signed-off-by: Sawan Chandak <sawan.chandak@cavium.com>
commit c4a9b538ab2a109c5f9798bea1f8f4bf93aadfb9 upstream.
commit 8b666809e10cda9814af3e8be339d35b83909056 upstream.
When FW notify driver or driver detects low FW resource,
driver tries to send out Busy SCSI Status to tell Initiator
side to back off. During the send process, the lock was not held.
Signed-off-by: Quinn Tran <quinn.tran@qlogic.com>
commit ae940f2c472a62904dc18234de5cf3ed28f195ee upstream.
commit 2780f3c8f0233de90b6b47a23fc422b7780c5436 upstream.
Avoid that issuing a LIP as follows:
find /sys -name 'issue_lip'|while read f; do echo 1 > $f; done
triggers the following:
Call Trace:
qla2x00_abort_all_cmds+0xed/0x140 [qla2xxx]
qla2x00_abort_isp_cleanup+0x1e3/0x280 [qla2xxx]
qla2x00_abort_isp+0xef/0x690 [qla2xxx]
qla2x00_do_dpc+0x36c/0x880 [qla2xxx]
kthread+0x10c/0x140
[mkp: consolidated Mauricio's and Bart's fixes]
Signed-off-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com>
Reported-by: Bart Van Assche <bart.vanassche@sandisk.com>
Fixes: 1535aa75a3d8 ("qla2xxx: fix invalid DMA access after command aborts in PCI device remove")
Cc: Himanshu Madhani <himanshu.madhani@cavium.com>
commit fc1ffd6cb38a1c1af625b9833c41928039e733f5 upstream.
During code inspection, while investigating following stack trace
seen on one of the test setup, we found out there was possibility
of memory leak becuase driver was not unwinding the stack properly.
This issue has not been reproduced in a test environment or on a
customer setup.
Here's stack trace that was seen.
[1469877.797315] Call Trace:
[1469877.799940] [<ffffffffa03ab6e9>] qla2x00_mem_alloc+0xb09/0x10c0 [qla2xxx]
[1469877.806980] [<ffffffffa03ac50a>] qla2x00_probe_one+0x86a/0x1b50 [qla2xxx]
[1469877.814013] [<ffffffff813b6d01>] ? __pm_runtime_resume+0x51/0xa0
[1469877.820265] [<ffffffff8157c1f5>] ? _raw_spin_lock_irqsave+0x25/0x90
[1469877.826776] [<ffffffff8157cd2d>] ? _raw_spin_unlock_irqrestore+0x6d/0x80
[1469877.833720] [<ffffffff810741d1>] ? preempt_count_sub+0xb1/0x100
[1469877.839885] [<ffffffff8157cd0c>] ? _raw_spin_unlock_irqrestore+0x4c/0x80
[1469877.846830] [<ffffffff81319b9c>] local_pci_probe+0x4c/0xb0
[1469877.852562] [<ffffffff810741d1>] ? preempt_count_sub+0xb1/0x100
[1469877.858727] [<ffffffff81319c89>] pci_call_probe+0x89/0xb0
[ bvanassche: Fixed spelling in patch description ]
The previous commit 1535aa75a3d8 ("qla2xxx: fix invalid DMA access after
command aborts in PCI device remove") introduced a regression during an
EEH recovery, since the change to the qla2x00_abort_all_cmds() function
calls qla2xxx_eh_abort(), which verifies the EEH recovery condition but
handles it heavy-handed. (commit a465537ad1a4 "qla2xxx: Disable the
adapter and skip error recovery in case of register disconnect.")
This problem warrants a more general/optimistic solution right into
qla2xxx_eh_abort() (eg in case a real command abort arrives during EEH
recovery, or if it takes long enough to trigger command aborts); but
it's still worth to add a check to ensure the code added by the previous
commit is correct and contained within its owner function.
This commit just adds a 'if (!ha->flags.eeh_busy)' check around it.
(ahem; a trivial fix for this -rc series; sorry for this oversight.)
With it applied, both PCI device remove and EEH recovery works fine.
If a command is aborted in the kernel but not in the adapter, it might be
considered complete and its DMA memory released, but it is still alive in
the adapter, which will trigger an invalid DMA access upon its completion
(in the DMA operations to deliver the command response to the driver).
On powerpc platforms with IOMMU/EEH capabilities, the problem is observed
during PCI device removal with ongoing IO requests -- which might trigger
an EEH event very often, pointing to a 'TCE Request Page Access Error'.
In that path, which is qla2x00_remove_one(), the commands are aborted in
qla2x00_abort_all_cmds(), which does not perform an abort in the adapter
as is done in qla2xxx_eh_abort() for example.
So, this patch changes qla2x00_abort_all_cmds() to abort commands in the
adapter too, with a call to qla2xxx_eh_abort(), which already implements
all the logic to submit abort requests and handle responses.
Reported-by: Naresh Bannoth <nbannoth@in.ibm.com>
When the driver is unloading, in qla2x00_remove_one(), there is a single
call/point in time to abort ongoing commands, qla2x00_abort_all_cmds(),
which is still several steps away from the call to scsi_remove_host().
If more commands continue to arrive and be processed during that
interval, when the driver is tearing down and releasing its structures,
it might potentially hit an oops due to invalid memory access:
Unable to handle kernel paging request for data at address 0x00000138
NIP [d000000004700a40] qla2xxx_queuecommand+0x80/0x3f0 [qla2xxx]
LR [d000000004700a10] qla2xxx_queuecommand+0x50/0x3f0 [qla2xxx]
So, fail commands in qla2xxx_queuecommand() if the UNLOADING bit is set.
A system can get hung task timeouts if a qlogic board fails during
initialization (if the board breaks again or fails the init). The hang
involves the scsi scan.
In a nutshell, since commit beb9e315e6e0 ("qla2xxx: Prevent removal and
board_disable race"):
...it is possible to have freed ha (base_vha->hw) early by a call to
qla2x00_remove_one when pdev->enable_cnt equals zero:
if (!atomic_read(&pdev->enable_cnt)) {
scsi_host_put(base_vha->host);
kfree(ha);
pci_set_drvdata(pdev, NULL);
return;
Almost always, the scsi_host_put above frees the vha structure
(attached to the end of the Scsi_Host we're putting) since it's the last
put, and life is good. However, if we are entering this routine because
the adapter has broken sometime during initialization AND a scsi scan is
already in progress (and has done its own scsi_host_get), vha will not
be freed. What's worse, the scsi scan will access the freed ha structure
through qla2xxx_scan_finished:
if (time > vha->hw->loop_reset_delay * HZ)
return 1;
The scsi scan keeps checking to see if a scan is complete by calling
qla2xxx_scan_finished. There is a timeout value that limits the length
of time a scan can take (hw->loop_reset_delay, usually set to 5
seconds), but this definition is in the data structure (hw) that can get
freed early.
This can yield unpredictable results, the worst of which is that the
scsi scan can hang indefinitely. This happens when the freed structure
gets reused and loop_reset_delay gets overwritten with garbage, which
the scan obliviously uses as its timeout value.
The fix for this is simple: at the top of qla2xxx_scan_finished, check
for the UNLOADING bit in the vha structure (_vha is not freed at this
point). If UNLOADING is set, we exit the scan for this adapter
immediately. After this last reference to the ha structure, we'll exit
the scan for this adapter, and continue on.
This problem is hard to hit, but I have run into it doing negative
testing many times now (with a test specifically designed to bring it
out), so I can verify that this fix works. My testing has been against a
RHEL7 driver variant, but the bug and patch are equally relevant to to
the upstream driver.
Fixes: beb9e315e6e0 ("qla2xxx: Prevent removal and board_disable race")
Cc: <stable@vger.kernel.org> # v3.18+
Instead of defining a local version of it.
Trivial fix to spelling mistakes in ql_dbg messages.
Acked-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
The "if (test_bit(UNLOADING..." line was indented one tab more than it
should have been. There was an extra parenthesis around the
qla2x00_reset_active() function call. I lined up the conditions a bit
so that it shows how they group together.
Pull trivial tree updates from Jiri Kosina.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
fat: fix error message for bogus number of directory entries
fat: fix typo s/supeblock/superblock/
ASoC: max9877: Remove unused function declaration
dw2102: don't output spurious blank lines to the kernel log
init: fix Kconfig text
ARM: io: fix comment grammar
ocfs: fix ocfs2_xattr_user_get() argument name
scsi/qla2xxx: Remove erroneous unused macro qla82xx_get_temp_val1()
Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Fixes: 969a619 ("qla2xxx: Add support for buffer to buffer credit value for ISP27XX.")
Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com>
disconnect.
If there is error recovery going on due to command timeout and
there is register disconnect, then disable the adapter.
Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com>
[mkp: Folded in compile fix]
During hot swap of PCI device, there can be PCI error on device,
during normal driver unload. The race between normal driver unload and
driver unload due to PCI error, can lead to system crash.Fix is to check
if there is unload going on and allow that function to unload the driver.
Properly initialize IO statistics to avoid initial 0xFFFFFFF (-1) values.
Cleanup/simplify usage of pointer to statistics structure.
When VP decoupling enabled, there could be a window where, FLOGI from initiators
can be dropped before VP0 is enabled, causing link level recovery.
Retry FLOGI to avoid link level recovery.
qla2xxx first calls request_irq() and then does the setup of the queue
entry data needed in the interrupt handlers in when using MSI-X. This
could lead to a NULL pointer dereference when an IRQ fires between the
request_irq() call and the assignment of the qentry data structure to
the rsp->msix field. A possible case for such a race would be in the
kdump case when the HBA's IRQs are still enabled but the driver is
undergoing a new initialisation and thus is not aware of already
activated IRQs in the HBA.
Reviewed-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
In qla24xx_process_response_queue() rsp->msix->cpuid may trigger NULL
pointer dereference when rsp->msix is NULL:
[ 5.622457] NULL pointer dereference at 0000000000000050
[ 5.622457] IP: [<ffffffff8155e614>] qla24xx_process_response_queue+0x44/0x4b0
[ 5.622457] PGD 0
[ 5.622457] Oops: 0000 [#1] SMP
[ 5.622457] Modules linked in:
[ 5.622457] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.6.3-x86_64 #1
[ 5.622457] Hardware name: HP ProLiant DL360 G5, BIOS P58 05/02/2011
[ 5.622457] task: ffff8801a88f3740 ti: ffff8801a8954000 task.ti: ffff8801a8954000
[ 5.622457] RIP: 0010:[<ffffffff8155e614>] [<ffffffff8155e614>] qla24xx_process_response_queue+0x44/0x4b0
[ 5.622457] RSP: 0000:ffff8801afb03de8 EFLAGS: 00010002
[ 5.622457] RAX: 0000000000000000 RBX: 0000000000000032 RCX: 00000000ffffffff
[ 5.622457] RDX: 0000000000000002 RSI: ffff8801a79bf8c8 RDI: ffff8800c8f7e7c0
[ 5.622457] RBP: ffff8801afb03e68 R08: 0000000000000000 R09: 0000000000000000
[ 5.622457] R10: 00000000ffff8c47 R11: 0000000000000002 R12: ffff8801a79bf8c8
[ 5.622457] R13: ffff8800c8f7e7c0 R14: ffff8800c8f60000 R15: 0000000000018013
[ 5.622457] FS: 0000000000000000(0000) GS:ffff8801afb00000(0000) knlGS:0000000000000000
[ 5.622457] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 5.622457] CR2: 0000000000000050 CR3: 0000000001e07000 CR4: 00000000000006e0
[ 5.622457] Stack:
[ 5.622457] ffff8801afb03e30 ffffffff810c0f2d 0000000000000086 0000000000000002
[ 5.622457] ffff8801afb03e28 ffffffff816570e1 ffff8800c8994628 0000000000000002
[ 5.622457] ffff8801afb03e60 ffffffff816772d4 b47c472ad6955e68 0000000000000032
[ 5.622457] Call Trace:
[ 5.622457] <IRQ>
[ 5.622457] [<ffffffff810c0f2d>] ? __wake_up_common+0x4d/0x80
[ 5.622457] [<ffffffff816570e1>] ? usb_hcd_resume_root_hub+0x51/0x60
[ 5.622457] [<ffffffff816772d4>] ? uhci_hub_status_data+0x64/0x240
[ 5.622457] [<ffffffff81560d00>] qla24xx_intr_handler+0xf0/0x2e0
[ 5.622457] [<ffffffff810d569e>] ? get_next_timer_interrupt+0xce/0x200
[ 5.622457] [<ffffffff810c89b4>] handle_irq_event_percpu+0x64/0x100
[ 5.622457] [<ffffffff810c8a77>] handle_irq_event+0x27/0x50
[ 5.622457] [<ffffffff810cb965>] handle_edge_irq+0x65/0x140
[ 5.622457] [<ffffffff8101a498>] handle_irq+0x18/0x30
[ 5.622457] [<ffffffff8101a276>] do_IRQ+0x46/0xd0
[ 5.622457] [<ffffffff817f8fff>] common_interrupt+0x7f/0x7f
[ 5.622457] <EOI>
[ 5.622457] [<ffffffff81020d38>] ? mwait_idle+0x68/0x80
[ 5.622457] [<ffffffff8102114a>] arch_cpu_idle+0xa/0x10
[ 5.622457] [<ffffffff810c1b97>] default_idle_call+0x27/0x30
[ 5.622457] [<ffffffff810c1d3b>] cpu_startup_entry+0x19b/0x230
[ 5.622457] [<ffffffff810324c6>] start_secondary+0x136/0x140
[ 5.622457] Code: 00 00 65 48 8b 04 25 28 00 00 00 48 89 45 d0 31 c0 48 8b 47 58 a8 02 0f 84 c5 00 00 00 48 8b 46 50 49 89 f4 65 8b 15 34 bb aa 7e <39> 50 50 74 11 89 50 50 48 8b 46 50 8b 40 50 41 89 86 60 8b 00
[ 5.622457] RIP [<ffffffff8155e614>] qla24xx_process_response_queue+0x44/0x4b0
[ 5.622457] RSP <ffff8801afb03de8>
[ 5.622457] ---[ end trace fa2b19c25106d42b ]---
[ 5.622457] Kernel panic - not syncing: Fatal exception in interrupt
The affected code was introduced by commit cdb898c52d1dfad4b4800b83a58b3fe5d352edde
(qla2xxx: Add irq affinity notification).
Only dereference rsp->msix when it has been set so the machine can boot
fine. Possibly rsp->msix is unset because:
[ 3.479679] qla2xxx [0000:00:00.0]-0005: : QLogic Fibre Channel HBA Driver: 8.07.00.33-k.
[ 3.481839] qla2xxx [0000:13:00.0]-001d: : Found an ISP2432 irq 17 iobase 0xffffc90000038000.
[ 3.484081] qla2xxx [0000:13:00.0]-0035:0: MSI-X; Unsupported ISP2432 (0x2, 0x3).
[ 3.485804] qla2xxx [0000:13:00.0]-0037:0: Falling back-to MSI mode -258.
[ 3.890145] scsi host0: qla2xxx
[ 3.891956] qla2xxx [0000:13:00.0]-00fb:0: QLogic QLE2460 - PCI-Express Single Channel 4Gb Fibre Channel HBA.
[ 3.894207] qla2xxx [0000:13:00.0]-00fc:0: ISP2432: PCIe (2.5GT/s x4) @ 0000:13:00.0 hdma+ host#=0 fw=7.03.00 (9496).
[ 5.714774] qla2xxx [0000:13:00.0]-500a:0: LOOP UP detected (4 Gbps).
Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org>
Acked-by: Quinn Tran <quinn.tran@qlogic.com>
CC: <stable@vger.kernel.org> # 4.5+
Fixes: cdb898c52d1dfad4b4800b83a58b3fe5d352edde
Signed-off-by: James Bottomley <jejb@linux.vnet.ibm.com>
That macros uses logical "&&" instead of bit-wise "&" which is
apparently wrong. Since the macro is completely unused, simply
remove it, so that nobody can accidentially use it anymore.
Signed-off-by: Thomas Huth <thuth@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Here are the outstanding target pending updates for v4.7-rc1.
The highlights this round include:
- Allow external PR/ALUA metadata path be defined at runtime via top
level configfs attribute (Lee)
- Fix target session shutdown bug for ib_srpt multi-channel (hch)
- Make TFO close_session() and shutdown_session() optional (hch)
- Drop se_sess->sess_kref + convert tcm_qla2xxx to internal kref
(hch)
- Add tcm_qla2xxx endpoint attribute for basic FC jammer (Laurence)
- Refactor iscsi-target RX/TX PDU encode/decode into common code
(Varun)
- Extend iscsit_transport with xmit_pdu, release_cmd, get_rx_pdu,
validate_parameters, and get_r2t_ttt for generic ISO offload
(Varun)
- Initial merge of cxgb iscsi-segment offload target driver (Varun)
The bulk of the changes are Chelsio's new driver, along with a number
of iscsi-target common code improvements made by Varun + Co along the
way"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (29 commits)
iscsi-target: Fix early sk_data_ready LOGIN_FLAGS_READY race
cxgbit: Use type ISCSI_CXGBIT + cxgbit tpg_np attribute
iscsi-target: Convert transport drivers to signal rdma_shutdown
iscsi-target: Make iscsi_tpg_np driver show/store use generic code
tcm_qla2xxx Add SCSI command jammer/discard capability
iscsi-target: graceful disconnect on invalid mapping to iovec
target: need_to_release is always false, remove redundant check and kfree
target: remove sess_kref and ->shutdown_session
iscsi-target: remove usage of ->shutdown_session
tcm_qla2xxx: introduce a private sess_kref
target: make close_session optional
target: make ->shutdown_session optional
target: remove acl_stop
target: consolidate and fix session shutdown
cxgbit: add files for cxgbit.ko
iscsi-target: export symbols
iscsi-target: call complete on conn_logout_comp
iscsi-target: clear tx_thread_active
iscsi-target: add new offload transport type
iscsi-target: use conn_transport->transport_type in text rsp
Pull SCSI updates from James Bottomley:
"First round of SCSI updates for the 4.6+ merge window.
This batch includes the usual quota of driver updates (bnx2fc, mp3sas,
hpsa, ncr5380, lpfc, hisi_sas, snic, aacraid, megaraid_sas). There's
also a multiqueue update for scsi_debug, assorted bug fixes and a few
other minor updates (refactor of scsi_sg_pools into generic code, alua
and VPD updates, and struct timeval conversions)"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (138 commits)
mpt3sas: Used "synchronize_irq()"API to synchronize timed-out IO & TMs
mpt3sas: Set maximum transfer length per IO to 4MB for VDs
mpt3sas: Updating mpt3sas driver version to 13.100.00.00
mpt3sas: Fix initial Reference tag field for 4K PI drives.
mpt3sas: Handle active cable exception event
mpt3sas: Update MPI header to 2.00.42
Revert "lpfc: Delete unnecessary checks before the function call mempool_destroy"
eata_pio: missing break statement
hpsa: Fix type ZBC conditional checks
scsi_lib: Decode T10 vendor IDs
scsi_dh_alua: do not fail for unknown VPD identification
scsi_debug: use locally assigned naa
scsi_debug: uuid for lu name
scsi_debug: vpd and mode page work
scsi_debug: add multiple queue support
bfa: fix bfa_fcb_itnim_alloc() error handling
megaraid_sas: Downgrade two success messages to info
cxlflash: Fix to resolve dead-lock during EEH recovery
scsi_debug: rework resp_report_luns
scsi_debug: use pdt constants
This patch introduces support for TCM_QLA2XXX_DEBUG and
associated tcm_qla2xxx_tpg->tpg_attrib.jam_host checking
used to test dropped packets to FC host environments.
Tested by: Laurence Oberman <loberman@redhat.com>
Signed-off-by: Laurence Oberman <loberman@redhat.com>
This stops abusing the common sess_kref to overload it for private
usage, which allows removing the shutdown_session method as well.
This patch fix spelling typos in printk from various part
of the codes.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
struct register_host_info stores a 64-bit UTC system time timestamp.
This patch removes the use of 'struct timeval' to obtain that timestamp
as its tv_sec value will overflow on 32-bit systems in year 2038 beyond.
The patch uses ktime_get_real_seconds() which returns a 64-bit seconds value.
Signed-off-by: Tina Ruchandani <ruchandani.tina@gmail.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
