Queued work processing will now be serialized with its own
lower-priority spinlock. This also simplifies the work-queue
interface for future work-queue consumers.
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
In case the onboard firmware is unable to be read or loaded for
operation, attempt to fallback to a limited-operational firmware
image stored in a different flash region. This will allow a user
to reflash and correct a board with proper operational firmware.
Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com>
Firmware currently provides PB and PGF TLVs.
Read adapter's physical port number from interrupt pin register
and use it instead of pci function number to offset into the
nvram to obtain the port's configuration parameters.
srbs used to maintain a reference to the request queue on which
it was enqueued. This is no longer required as the request queue
pointer is now maintained in the scsi host that issues the srb.
Set the module parameter ql2xmultique_tag to 1 to enable this
feature. In this mode, the total number of response queues
created is equal to the number of online cpus. Turning the block
layer's rq_affinity mode on enables requests to be routed to the
proper cpu and at the same time it enables completion of the IO
in a response queue that is affined to the cpu in the request
path.
Set the number of request queues to the module paramater
ql2xmaxqueues. Each vport gets a request queue. The QoS value
set to the request queues determines priority control for queued
IOs. If QoS value is not specified, the vports use the default
queue 0.
Cull and export VN_Port MAC address and VLAN_ID information on
supported FCoE ISPs.
As updates will occur using low-level option-rom manipulation
routines.
Firmware semantics changed for 24xx and above ISPs in their
handling of the specified execution-throttle passed during
firmware initialization. The original codes use of a theoretical
maximum (0xffff, as carried over from earlier ISPs) could in fact
act as a throttle in some circumstances. Now set the value based
of the firmware's own 'resource' (exchange IOCBs) capabilities.
The original code to 'resize request-queues' based on iocb-counts
and employed during early ISP23xx testing was too
overly-pessimistic with regards to latencies in the firmware
pulling requests. Recent ISPs can easily keep up processing a
stream of commands from an abbreviated (effectively, half the
original size) queue.
Rather than assuming a particular layout of the data. Applies to
recent ISPs only.
Interface allows for the update of onboard EDC firmware
present on mezzanine ISP25xx type cards.
General cleanup of extraneous/legacy crud.
Additional cleanups and
Ensure that an ISP-abort has completed before performing any
update. After the update do not wait for an ISP-abort completion,
instead just wait until the ISP is reset. This avoids long
delays due to waiting for loop ready in qla2x00_abort_isp().
Signed-off-by: Lalit Chandivade <lalit.chandivade@qlogic.com>
Given the low-level interface varies from one flash-part
manufacturer to the next, the Flash-Access-Control (FAC) mailbox
command makes the specific flash type transparent to the driver
by encapsulating a basic set of accessor and update routines.
Use these new routines where applicable by querying FAC opcode
get-sector-size at init-time.
Reflects layout and format of latest specification.
Recent ISPs use this data to configure FCF information.
Original code used an overabundance of indirect pointers to
function helpers. Instead, the driver can exploit the immutable
properties of a queue's ISP-association and ID, which are both
known at queue initialization-time.
To ensure smooth operations amongst the FCoE and NIC side
components of the ISP81xx chip, the FCoE driver (qla2xxx) must
ensure the 10gb NIC driver (qlge) does not timeout waiting for
IDC (Inter-Driver Communication) acknowledgments. The
acknowledgment requirements are trivial -- a simple mirroring of
incoming mailbox registers during the AEN to a process-context
capable mailbox command.
Codes to support new FCoE boards.
Original code would inadvertanly place I/Os on the default
request-queue. Also, correctly pass in the proper MSI-X vector
during response-queue initialization.
In preparation for new ISP types with varying dump procedures.
with MSI-X enabled.
ROMs in recent ISPs have MSI-X support, so it's no longer
necessary for the driver to fallback to interrupt polling during
ISP re-initialization.
Software should not touch this region of flash, as the firmware
will be the only writer and consumer of the region.
Following changes have been made:
1. Scan outstanding commands only in the queue where it is submitted
2. Update queue registers directly in the fast path
3. Queue specific BAR is remapped only for multiq capable adapters
Following changes have been made.
1. qla_hw_data structure holds an array for request queue pointers,
and an array for response queue pointers.
2. The base request and response queues are created by default.
3. Additional request and response queues are created at the time of vport
creation. If queue resources are exhausted during vport creation, newly
created vports use the default queue.
4. Requests are sent to the request queue that the vport was assigned
in the beginning.
5. Responses are completed on the response queue with which the request queue
is associated with.
[fixup memcpy argument reversal spotted by davej@redhat.com]
Following changes have been made to the qla2xxx FC driver in
preparation for the multi- queue and future SR IOV hardware.
1. scsi_qla_host structure has been changed to contain scsi host
specific data only.
2. A new structure, qla_hw_data is created to contain HBA specific
hardware data.
3. Request and response IO specific data strucures are created.
4. The global list of fcports for the hba is not maintained anymore,
instead a fcport list is construted on per scsi_qla_host.
Signed-of-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com>
Use correct block size (4K) for erase command 0x20 for Atmel
Flash. Use dword addresses for determining sector boundary.
Cc: Stable Tree <stable@kernel.org>
we are using 28bit pci (bus/dev/fn + 12 bits) as irq number, so the
cache for irq number should be 32 bit too.
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
To instatiate pre-configured vport entities defined within an
HBA's flash memory.
The Flash Layout Table (FLT) present on many recent HBAs encodes
flash usage information, organizes data stored into separate
regions and presents the information uniformly to the driver.
Use this information rather than using specific hard-coded values
based on ISP type.
Currently Firmware does not have counters for input megabytes and
output megabytes, therefore driver counts these values depending
on the status of the scsi command and direction of the command.
The values are exported in the FC_HOST path.
Now that qla2xxx has been converted to mutexes, it no longer needs the
semaphore include.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
During internal testing, we've seen issues (hangs) with the
'deferred' vport tear-down-processing typically accompanied with
the fc_remove_host() call. This is due to the current
implementation's back-end vport handling being performed by the
physical-HA's DPC thread where premature shutdown could lead to
latent vport requests without a processor.
This should also address a problem reported by Gal Rosen
(http://marc.info/?l=linux-scsi&m=121731664417358&w=2) where the
driver would attempt to awaken a previously torn-down DPC thread
from interrupt context by implicitly calling wake_up_process()
rather than the driver's qla2xxx_wake_dpc() helper. Rather, than
reshuffle the remove_one() device-removal code, during unload,
depend on the driver's timer to wake-up the DPC process, by
limiting wake-ups based on an 'unloading' flag.
Recent ISPs have this information written at manufacturing time,
so use the information. This also reduces future churn of the
qla_devtbl.h file contents, as the driver can now depend on the
information to be present in VPD.
Removed repeated or unnecessary operations during vport
creation/deletion.
Signed-off-by: Shyam Sundar <shyam.sundar@qlogic.com>
Signed-off-by: Seokmann Ju <seokmann.ju@qlogic.com>
Signed-off-by: Ravi Anand <ravi.anand@qlogic.com>
This parameter counts the total number of ISP aborts during
driver execution. The value is exported through a DEVICE_ATTR()
off the scsi_host.
The semaphore vport_sem is used as a mutex. Convert it to the
mutex API.
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
The member is not needed as there's no non-scatter-gather
list I/Os submitted by the upper-layers.
Now that infrastructure is present within the midlayer and there
is a clear distinction between what is expected from a device and
target reset, convert the current device-reset codes to a
target-reset, and add codes to perform a proper device-reset (LUN
reset).
In the process of adding reset support, collapse and consolidate
large sections of mailbox-command (TMF issuance) codes,
generalize the two 'wait-for-commands-to-complete' functions, and
add a generic-reset routine for use by midlayer reset functions.
Some switches return 0x09 (Command not supported) as the reason
code for GPSC failure. Check for this code, and disable
additional GPSC queries if found.
The Flash Descriptor Table (FDT) present on many recent HBAs
encodes flash accessing characteristics of the flash-part used on
the HBA. Use this information during flash manipulation (writes)
rather than using specific hard-coded values based on queried
manufacturer and device IDs.
Strip unused (DEBUG-ONLY) enabled functions, inlines, useless
wrappers, and unused DPC flags from the code. Another step in
the migration towards a cleaner (less-crusty) driver.
