Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc).
Here is a short excerpt of the semantic patch performing
this transformation:
type T2;
expression x;
identifier f,fld;
expression E;
expression E1,E2;
expression e1,e2,e3,y;
statement S;
x =
- kmalloc
+ kzalloc
(E1,E2)
... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\)
- memset((T2)x,0,E1);
expression E1,E2,E3;
- kzalloc(E1 * E2,E3)
+ kcalloc(E1,E2,E3)
[akpm@linux-foundation.org: get kcalloc args the right way around]
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Cc: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Pierre Ossman <drzeus-list@drzeus.cx>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Greg KH <greg@kroah.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Add printk levels
Clean up some oddities of formatting
Fix goto labels
Signed-off-by: Alan Cox <alan@redhat.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
kernel: INFO: trying to register non-static key.
kernel: the code is fine but needs lockdep annotation.
kernel: turning off the locking correctness validator.
kernel: [<c04051ed>] show_trace_log_lvl+0x58/0x16a
kernel: [<c04057fa>] show_trace+0xd/0x10
kernel: [<c0405913>] dump_stack+0x19/0x1b
kernel: [<c043b1e2>] __lock_acquire+0xf0/0x90d
kernel: [<c043bf70>] lock_acquire+0x4b/0x6b
kernel: [<c061472f>] _spin_lock_irqsave+0x22/0x32
kernel: [<c04363d3>] prepare_to_wait+0x17/0x4b
kernel: [<f89a24b6>] lpfc_do_work+0xdd/0xcc2 [lpfc]
kernel: [<c04361b9>] kthread+0xc3/0xf2
kernel: [<c0402005>] kernel_thread_helper+0x5/0xb
Another case of non-static lockdep keys; duplicate the paradigm set by
DECLARE_COMPLETION_ONSTACK and introduce DECLARE_WAIT_QUEUE_HEAD_ONSTACK.
Cc: Greg KH <gregkh@suse.de>
Cc: Markus Lidel <markus.lidel@shadowconnect.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This patch removes a bouncing email address from the kernel sources.
ppa cannot handle highmem pages, and like imm, which already has
this patch, the device is slow, so performance is not a big issue,
so just force pages to be in low memory (hence mapped).
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
They deal with wrapping correctly and are nicer to read.
Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br>
Wrap a highly common idiom. Makes the code easier to read, helps pave
the way for sdev->{id,channel} removal, and adds a token that can easily
by grepped-for in the future.
There are a couple sdev_id() and scmd_printk() updates thrown in as well.
Rejections fixed up and
infrastructure for it.
Let it rip!
