path: root/drivers/scsi/pmcraid.h
2009-12-10[SCSI] pmcraid: support SMI-S object model of storage poolAnil Ravindranath
PMC-Sierra mgmt application uses SMI-S model. According to SMI-S, the object model exposed by the SMI-S provider should show an StoragePool which contains member disks of a RAID Virtual disk and StorageVolume based on the StoragePool. But according to SMI-S, there is a possibility where StoragePool is created but StorageVolume is not yet created. To satisfy this scenario, we are trying a hidden RAID Virtual disk. The hidden RAID virtual disk will not be exposed to OS. Once a StorageVolume is created for this RAID virtual disk it is exposed. Signed-off-by: Anil Ravindranath<anil_ravindranath@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-26headers: kref.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from kref.h -- not needed, linux/types.h is enough for atomic_t * remove linux/kref.h inclusion from files which do not need it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-12[SCSI] pmcraid: PMC-Sierra MaxRAID driver to support 6Gb/s SAS RAID controllerAnil Ravindranath
Signed-off-by: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
