Return of the bi_rw tests is no longer bool after commit 74450be1. So
testing against constants doesn't make sense anymore. Fix this bug in
osd_req_read by removing "== 1" in test.
This is not a problem now, where REQ_WRITE is 1, but this can change
in the future and we don't want to rely on that.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Remove the current bio flags and reuse the request flags for the bio, too.
This allows to more easily trace the type of I/O from the filesystem
down to the block driver. There were two flags in the bio that were
missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've
renamed two request flags that had a superflous RW in them.
Note that the flags are in bio.h despite having the REQ_ name - as
blkdev.h includes bio.h that is the only way to go for now.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Doing CHECK="smatch --two-passes gives:
drivers/scsi/osd/osd_initiator.c +1435 osd_finalize_request warning: assignment to 'ret' was never used
Which is an unchecked possible allocation failure, Fixed.
Reported-by: Dan Carpenter <error27@gmail.com>
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
So libosd has decided to sacrifice some code simplicity for the sake of
a clean API. One of these things is the possibility for users to call
osd_end_request, in any condition at any state. This opens up some
problems with calling blk_put_request when out-side of the completion
callback but calling __blk_put_request when detecting a from-completion
state.
The current hack was working just fine until exofs decided to operate on
all devices in parallel and wait for the sum of the requests, before
deallocating all osd-requests at once. There are two new possible cases
1. All request in a group are deallocated as part of the last request's
async-done, request_queue is locked.
2. All request in a group where executed asynchronously, but
de-allocation was delayed to after the async-done, in the context of
another thread. Async execution but request_queue is not locked.
The solution I chose was to separate the deallocation of the osd_request
which has the information users need, from the deallocation of the
internal(2) requests which impose the locking problem. The internal
block-requests are freed unconditionally inside the async-done-callback,
when we know the queue is always locked. If at osd_end_request time we
still have a bock-request, then we know it did not come from within an
async-done-callback and we can call the regular blk_put_request.
The internal requests were used for carrying error information after
execution. This information is now copied to osd_request members for
later analysis by user code.
The external API and behaviour was unchanged, except now it really
supports what was previously advertised.
Reported-by: Vineet Agarwal <checkout.vineet@gmail.com>
Cc: Stable Tree <stable@kernel.org>
Administer some love to the osd_req_decode_sense function
* Fix a bad bug with osd_req_decode_sense(). If there was no scsi
residual, .i.e the request never reached the target, then all the
osd_sense_info members where garbage.
* Add grossly missing in/out_resid to osd_sense_info and fill them in
properly.
* Define an osd_err_priority enum which divides the possible errors into
7 categories in ascending severity. Each category is also assigned a
Linux return code translation.
Analyze the different osd/scsi/block returned errors and set the
proper osd_err_priority and Linux return code accordingly.
* extra check a few situations so not to get stuck with inconsistent
error view. Example an empty residual with an error code, and other
places ...
Lots of libosd's osd_req_decode_sense clients had this logic in some
form or another. Consolidate all these into one place that should
actually know about osd returns. Thous translating it to a more
abstract error.
When an error was detected in an attribute list do to
a target bug. We would print an error but spin endlessly
regardless. Fix it.
The (never tested) osd_sense_attribute_identification case
has never worked. The loop was never advanced on.
Fix it to work as intended.
On 10/30/2009 04:39 PM, Roel Kluin wrote:
I found this by code analysis, searching for while
loops that test a local variable, but do not modify
the variable.
Reported-by: Roel Kluin <roel.kluin@gmail.com>
Define an osd_dev_info structure that Uniquely identifies an OSD
device lun on the network. The identification is built from unique
target attributes and is the same for all network/SAN machines.
osduld_info_lookup() - NEW
New API that will lookup an osd_dev by its osd_dev_info.
This is used by pNFS-objects for cross network global device
identification. And by exofs multy-device support, the device
info is specified in the on-disk exofs device table.
osduld_device_info() - NEW
Given an osd_dev handle returns its associated osd_dev_info.
The ULD fetches this information at startup and hangs it on
each OSD device. (This is a fast operation that can be called
at any condition)
osduld_device_same() - NEW
With a given osd_dev at one hand and an osd_dev_info
at another, we would like to know if they are the same
device.
Two osd_dev handles can be checked by:
osduld_device_same(od1, osduld_device_info(od2));
osd_auto_detect_ver() - REVISED
Now returns an osd_dev_info structure. Is only called once
by ULD as before. See added comments for how to use.
The true logic of this patch will be clear in the next patch where we
use the class_find_device() API. When doing so the use of an internal
kref leaves us a narrow window where a find is started while the actual
object can go away. Using the device's kobj reference solves this
problem because now the same kref is used for both operations. (Remove
and find)
Core changes
* Embed a struct device in uld_ structure and use device_register
instead of devie_create. Set __remove to be the device release
function.
* __uld_get/put is just get_/put_device. Now every thing is accounted
for on the device object. Internal kref is removed.
* At __remove() we can safely de-allocate the uld_ structure. (The
function has moved to avoid forward declaration)
Some cleanups
* Use class register/unregister is cleaner for this driver now.
* cdev ref-counting games are no longer necessary
I have incremented the device version string in case of new bugs.
Note: Previous bugfix of taking the reference around fput() still
applies.
If scsi has released the device (logout), and exofs has last
reference on the osduld_device it will be freed by
osd_uld_release() within the call to fput(). But this will
oops in cdev_release() which is called after the fops->release.
(cdev is embedded within osduld_device). __uld_get/put pair
makes sure we have a cdev for the duration of fput()
drivers/message/fusion/mptsas.c
fixed up conflict between req->data_len accessors and mptsas driver updates.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
* Delete Makefile. It is only used for out-of-tree compilation
and was never needed. It slipped in by mistake.
* Remove from Kbuild all the out of tree stuff as promised.
libosd has it's own sense decoding and printout. Don't
let scsi_lib duplicate that printout. (Which is done wrong
in regard to osd commands)
This patch was inspired by Al Viro, for simplifying and fixing the
retrieval of osd-devices by in-kernel users, eg: file systems.
In-Kernel users, now, go through the same path user-mode does by
opening a file on the osd char-device and though holding a reference
to both the device and the Module.
A file pointer was added to the osd_dev structure which is now
allocated for each user. The internal osd_dev is no longer exposed
outside of the uld. I wanted to do that for a long time so each
libosd user can have his own defaults on the device.
The API is left the same, so user code need not change.
It is no longer needed to open/close a file handle on the osd
char-device from user-mode, before mounting an exofs on it.
CC: Al Viro <viro@ZenIV.linux.org.uk>
libosd users that need to work with bios, must sometime use
the request_queue associated with the osd_dev. Make a wrapper for
that, and convert all in-tree users.
For supporting of chained-bios we can not inspect the first
bio only, as before. Caller shall pass the total length of the
request, ie. sum_bytes(bio-chain).
Also since the bio might be a chain we don't set it's direction
on behalf of it's callers. The bio direction should be properly
set prior to this call. So fix a couple of write users that now
need to set the bio direction properly
[In this patch I change both library code and user sites at
exofs, to make it easy on integration. It should be submitted
via James's scsi-misc tree.]
CC: Jeff Garzik <jeff@garzik.org>
_osd_req_finalize_data_integrity was trying to deduce the number of
out_bytes from passed osd_request->out.bio. This is wrong when
the bio is chained. The caller of _osd_req_finalize_data_integrity
has more ready available information and should just pass it.
Also in the light of future support for CDB-continuation segment this is
a better solution.
By popular demand, define usefull wrappers for osd_req_read/write
that recieve kernel pointers. All users had their own.
Also remove these from exofs
Shorten out the Attributes names.
Align all results on column 24.
Print system ID in a new line.
drivers/block/hd.c
drivers/block/mg_disk.c
Use new blk_make_request() to allocate a request from bio
and avoid using deprecated blk_rq_append_bio().
This patch is dependent on a block layer patch titled:
[BLOCK] New blk_make_request() takes bio returns request
This is the last usage of blk_rq_append_bio in osd, it can now
be un-exported.
CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Now that blk_rq_map_kern will append the buffer onto the
request we can use it easily for adding extra segments
(eg. attributes)
[BLOCK] allow blk_rq_map_kern to append to requests
With recent unification of fields, it's now guaranteed that
rq->data_len always equals blk_rq_bytes(). Convert all non-IDE direct
users to accessors. IDE will be converted in a separate patch.
Boaz: spotted incorrect data_len/resid_len conversion in osd.
[ Impact: convert direct rq->data_len usages to blk_rq_bytes() ]
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Cc: Pete Zaitcev <zaitcev@redhat.com>
Cc: Eric Moore <Eric.Moore@lsi.com>
Cc: Markus Lidel <Markus.Lidel@shadowconnect.com>
Cc: Darrick J. Wong <djwong@us.ibm.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Boaz Harrosh <bharrosh@panasas.com>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
... use kern_path() where possible
[folded a fix from rdd]
OSC's OSD2 target: [git clone git://git.open-osd.org/osc-osd/ master]
(Initiator code prior to this patch must use: "git checkout CDB_VER_OSD2r01"
in the target tree above)
This is a summery of the wire changes:
* OSDv2_ADDITIONAL_CDB_LENGTH == 192 => 228 (Total CDB is now 236 bytes)
* Attributes List Element Header grew, so attribute values are 8 bytes
aligned.
* Cryptographic keys and signatures are 20 => 32
* Few new definitions.
(Still missing new standard definitions attribute values, these do not change
wire format and will be added later when needed)
In OSD2r04 draft, cryptographic key size changed to 32 bytes from
OSD1's 20 bytes. This causes a couple of on-the-wire structures
to change, including the CDB.
In this patch the OSD1/OSD2 handling is separated out in regard
to affected structures, but on-the-wire is still the same. All
on the wire changes will be submitted in one patch for bisect-ability.
In OSD2r05 draft each attribute list element header was changed
so attribute-value would be 8 bytes aligned. In OSD2r01-r04
it was aligned on 2 bytes. (This is because in OSD2r01 the complete
element was 8 bytes padded at end but the header was not adjusted
and caused permanent miss-alignment.)
OSD1 elements are not padded and might be or might not be aligned.
OSD1 is still supported.
In this code we do all the code re-factoring to separate OSD1/OSD2
differences but do not change actual wire format. All wire format
changes will happen in one patch later, for bisect-ability.
bio_map_kern() returns an ERR_PTR() not NULL.
Found by smatch (http://repo.or.cz/w/smatch.git). Compile tested.
Remove the creation of the symlink from the device to
it's class. On modern systems this is already created by
a udev rule and would WARN on load. On old systems it is
not needed, none of the current osd user-mode tools use
this link.
A fix for a very serious and stupid bug in osd_initiator. It
used to call blk_put_request() regardless of if it was from
the end_io callback or if called after a sync execution.
It should call the unlocked version __blk_put_request() instead.
Also fixed is the remove of _abort_unexecuted_bios hack, and use of
blk_end_request(,-ERROR,) to deallocate half baked requests. I've
audited the code and it should be safe.
Reported and
Tested-by: Xu Yang <onlyxuyang@qq.com>
Very old OSC's Target had a BUG in the Get/Set attributes where
it was looking in the wrong places for attribute lists length.
If used with the open-osd initiator, the initiator would dereference
a NULL pointer when retrieving system_information attributes.
Checks are added that retrieval of each attribute is successful
before accessing its value.
Kconfig file for the drivers/scsi/osd subdirectory.
Adds the following config items:
config SCSI_OSD_INITIATOR
config SCSI_OSD_ULD
config SCSI_OSD_DPRINT_SENSE
config SCSI_OSD_DEBUG
Reviewed-by: Benny Halevy <bhalevy@panasas.com>
Implementation of the osd_req_decode_sense() API. Can be called by
library users to decode what failed in command executions.
Add SCSI_OSD_DPRINT_SENSE Kconfig variable. Possible values are:
0 - Do not print any errors to messages file <KERN_ERR>
1 - (Default) Print only decoded errors that are not recoverable.
Recoverable errors are those that the target has complied with
the request but with a warning. For example read passed end of
object will return zeros after the last valid byte.
2- Print all errors.
Auto detect an OSDv2 or OSDv1 target at run time. Note how none
of the OSD API calls change. The tests do not know what device
version it is.
This test now passes against both the IBM-OSD-SIM OSD1 target
as well as OSC's OSD2 target.
Add support for OSD2 at run time. It is now possible to run with
both OSDv1 and OSDv2 targets at the same time. The actual detection
should be preformed by the security manager, as the version is encoded
in the capability structure.
Some commands declared in header are not yet implemented. Put them
as stubs in .c file, just so they take their place in the file
Add support for the various List-objects commands. List-partitions-in-device,
List-collections-in-partition, List-objects-in-partition,
List-objects-in-collection. All these support partial listing and continuation.
Add support for the different Flush commands and options.
Layout the signing of OSD's CDB and all-data security modes. The actual
code for signing the data and CDB is missing, but the code flow and the extra
buffer segments are all in place.
Support for both List-Mode and Page-Mode osd attributes. One of
these operations may be added to most other operations.
Define the OSD standard's attribute pages constants and structures
(osd_attributes.h)
Kernel clients like exofs can retrieve struct osd_dev(s)
by means of below API.
+ osduld_path_lookup() - given a path (e.g "/dev/osd0") locks and
returns the corresponding struct osd_dev, which is then needed
for subsequent libosd use.
+ osduld_put_device() - free up use of an osd_dev.
Devices can be shared by multiple clients. The osd_uld_device's
life time is governed by an embedded kref structure.
The osd_uld_device holds an extra reference to both it's
char-device and it's scsi_device, and will release these just
before the final deallocation.
There are three possible lock sources of the osd_uld_device
1. First and for most is the probe() function called by
scsi-ml upon a successful login into a target. Released in release()
when logout.
2. Second by user-mode file handles opened on the char-dev.
3. Third is here by Kernel users.
All three locks must be removed before the osd_uld_device is freed.
The MODULE has three lock sources as well:
1. scsi-ml at probe() time, removed after release(). (login/logout)
2. The user-mode file handles open/close.
3. Import symbols by client modules like exofs.
TODO:
This API is not enough for the pNFS-objects LD. A more versatile
API will be needed. Proposed API could be:
struct osd_dev *osduld_sysid_lookup(const char id[OSD_SYSTEMID_LEN]);
Add a Linux driver module that registers as a SCSI ULD and probes
for OSD type SCSI devices.
When an OSD-type SCSI device is found a character device is created
in the form of /dev/osdX - where X goes from 0 up to hard coded 64.
The Major character device number used is 260.
Implementation of the most basic OSD functionality and
infrastructure. Mainly Format, Create/Remove Partition,
Create/Remove Object, and read/write.
- Add Makefile and Kbuild to compile libosd.ko
- osd_initiator.c Implementation file for osd_initiator.h
and osd_sec.h APIs
- osd_debug.h - Some kprintf macro definitions
