path: root/drivers/scsi/osd/Kbuild
2009-06-10[SCSI] osd: Remove out-of-tree left oversBoaz Harrosh
* Delete Makefile. It is only used for out-of-tree compilation and was never needed. It slipped in by mistake. * Remove from Kbuild all the out of tree stuff as promised. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] libosd: SCSI/OSD Sense decoding supportBoaz Harrosh
Implementation of the osd_req_decode_sense() API. Can be called by library users to decode what failed in command executions. Add SCSI_OSD_DPRINT_SENSE Kconfig variable. Possible values are: 0 - Do not print any errors to messages file <KERN_ERR> 1 - (Default) Print only decoded errors that are not recoverable. Recoverable errors are those that the target has complied with the request but with a warning. For example read passed end of object will return zeros after the last valid byte. 2- Print all errors. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] osd_uld: OSD scsi ULDBoaz Harrosh
Add a Linux driver module that registers as a SCSI ULD and probes for OSD type SCSI devices. When an OSD-type SCSI device is found a character device is created in the form of /dev/osdX - where X goes from 0 up to hard coded 64. The Major character device number used is 260. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Reviewed-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] libosd: OSDv1 preliminary implementationBoaz Harrosh
Implementation of the most basic OSD functionality and infrastructure. Mainly Format, Create/Remove Partition, Create/Remove Object, and read/write. - Add Makefile and Kbuild to compile libosd.ko - osd_initiator.c Implementation file for osd_initiator.h and osd_sec.h APIs - osd_debug.h - Some kprintf macro definitions Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Reviewed-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
