path: root/drivers/scsi/nsp32_debug.c
2018-06-19scsi: core: remove Scsi_Cmnd typedefJohannes Thumshirn
This will make subsequent refactoring easier to handle. Note: this patch is nowhere checkpatch clean. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
