Based on an original implementation by Ed Nadolski and Artur Wojcik
In preparation for S3/S4 support refactor initialization so that
driver-load and resume-from-suspend can share the common init path of
isci_host_init(). Organize the initialization into objects that are
self-contained to the driver (initialized by isci_host_init) versus
those that have some upward registration (initialized at allocation time
asd_sas_phy, asd_sas_port, dma allocations). The largest change is
moving the the validation of the oem and module parameters from
isci_host_init() to isci_host_alloc().
The S3/S4 approach being taken is that libsas will be tasked with
remembering the state of the domain and the lldd is free to be
forgetful. In the case of isci we'll just re-init using a subset of the
normal driver load path.
[clean up some unused / mis-indented function definitions in host.h]
Signed-off-by: Ed Nadolski <edmund.nadolski@intel.com>
Signed-off-by: Artur Wojcik <artur.wojcik@intel.com>
v1.3 allows the attenuation of the attached cables to be specified to
the driver in terms of 'short', 'medium', and 'long' (see probe_roms.h).
These settings (per phy) are retrieved from the platform oem-parameters
(BIOS rom) or via a module parameter override.
Reviewed-by: Jiangbi Liu <jiangbi.liu@intel.com>
Signed-off-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
v1.1 allows finer grained tuning of the SSC (spread-spectrum-clocking)
settings for SAS and SATA. See notes in probe_roms.h
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Fixes bug where max_concurr_spinup oem parameter should be
overriden by max_concurr_spinup user parameter. Override should
happen only when max_concurr_spinup user parameter is specified
in command line (greater than 0). Also this fix shortens variables
representing max_conxurr_spinup for oem and user parameters.
Signed-off-by: Andrzej Jakowski <andrzej.jakowski@intel.com>
The distinction between scic_sds_ scic_ and sci_ are no longer relevant
so just unify the prefixes on sci_. The distinction between isci_ and
sci_ is historically significant, and useful for comparing the old
'core' to the current Linux driver. 'sci_' represents the former core as
well as the routines that are closer to the hardware and protocol than
their 'isci_' brethren. sci == sas controller interface.
Also unwind the 'sds1' out of the parameter structs.
Reported-by: Christoph Hellwig <hch@lst.de>
Remove the distinction between these two implementations and unify on
isci_host (local instances named ihost). Hmmm, we had two
'oem_parameters' instances, one was unused... nice.
We can call the EFI get_variable service routine directly to retrieve
the EFI variable that holds the OEM parameters table.
* Move port configuration agent implementation
* Merge core/scic_sds_port.[ch] into port.[ch]
cross driver constants are spread out over multiple header files, consolidate
them into isci.h, and push some includes out to the source files that need
them.
TODO: remove SCI_MODE_SIZE infrastructure.
TODO: task.h is full of inlines that are too large
The element_length is 2 bytes.
Reported-by: Yinghai Lu <yinghai.lu@oracle.com>
Acked-by: Dave Jiang <dave.jiang@intel.com>
Converting the all CAPS data types to lower case.
Reported-by: Christoph Hellwig <hch@infradead.org>
The original apc mode definition is the correct one, the fix from commit
4711ba10 "isci: fix oem parameter initialization and mode detection" was based
on a typo from a specification update.
1/ Since commit 858d4aa7 "isci: Move firmware loading to per PCI device" we have
been silently falling back to built-in defaults for the parameter settings by
skipping the call to scic_oem_parameters_set().
2/ The afe parameters from the firmware were not being honored
3/ The latest oem parameter definition flips the mode_type values which are
now 0: for APC 1: for MPC. For APC we need to make sure all the phys
default to the same address otherwise strict_wide_ports will cause duplicate
domains.
4/ Fix up the driver announcement to indicate the source of the
parameters.
5/ Fix up the sas addresses to be unique per controller (in the fallback case)
Updating the EFI variable OEM parameter retrieval after examining the EFI
variable exported via sysfs.
Added fixups for the OROM parsing code after testing with BIOS OROM
These are the finalized values that the driver can expect to see in
production.
1/ add OEM paramater support for mode_type (MPC vs APC)
2/ add OEM parameter support for max_number_concurrent_device_spin_up
3/ cleanup scic_sds_controller_start_next_phy
todo: hook up the amp control afe parameters into the afe init code
Signed-off-by: Henryk Dembkowski <henryk.dembkowski@intel.com>
Signed-off-by: Jacek Danecki <Jacek.Danecki@intel.com>
[cleaned up scic_sds_controller_start_next_phy]
Adding EFI variable retrieving for OEM parameters. Still need GUID and
variable name.
Also updated the data struct for oem parameters and hex file for firmware
[fix CONFIG_EFI=n compile error]
We need to scan the OROM for signature and grab the OEM parameters. We
also need to do the same for EFI. If all fails then we resort to user
binary blob, and if that fails then we go to the defaults.
Share the format with the create_fw utility so that all possible sources
of the parameters are in-sync.
