Remove the tagged argument from scsi_adjust_queue_depth, and just let it
handle the queue depth. For most drivers those two are fairly separate,
given that most modern drivers don't care about the SCSI "tagged" status
of a command at all, and many old drivers allow queuing of multiple
untagged commands in the driver.
Instead we start out with the ->simple_tags flag set before calling
->slave_configure, which is how all drivers actually looking at
->simple_tags except for one worke anyway. The one other case looks
broken, but I've kept the behavior as-is for now.
Except for that we only change ->simple_tags from the ->change_queue_type,
and when rejecting a tag message in a single driver, so keeping this
churn out of scsi_adjust_queue_depth is a clear win.
Now that the usage of scsi_adjust_queue_depth is more obvious we can
also remove all the trivial instances in ->slave_alloc or ->slave_configure
that just set it to the cmd_per_lun default.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Allow a driver to ask for block layer tags by setting .use_blk_tags in the
host template, in which case it will always see a valid value in
request->tag, similar to the behavior when using blk-mq. This means even
SCSI "untagged" commands will now have a tag, which is especially useful
when using a host-wide tag map.
Unless we want to build a SPI tag message we should just check SCMD_TAGGED
instead of reverse engineering a tag type through the use of
scsi_populate_tag_msg.
Also rename the function to spi_populate_tag_msg, make it behave like the
other spi message helpers, and move it to the spi transport class.
Most drivers use exactly the same implementation, so provide it as a
library function.
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Added big endian annotations to relevant data structure fields, and necessary
byte swappings to support little endian builds.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
Now that we're using 64-bit LUNs internally we need to increase
the size of max_luns to 64 bits, too.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Ewan Milne <emilne@redhat.com>
Replace various -20/+19 hardcoded nice values with MIN_NICE/MAX_NICE.
Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/ff13819fd09b7a5dba5ab5ae797f2e7019bdfa17.1394532288.git.yangds.fnst@cn.fujitsu.com
Cc: devel@driverdev.osuosl.org
Cc: devicetree@vger.kernel.org
Cc: fcoe-devel@open-fcoe.org
Cc: linux390@de.ibm.com
Cc: linux-mm@kvack.org
Cc: linux-s390@vger.kernel.org
Cc: linux-scsi@vger.kernel.org
Cc: nbd-general@lists.sourceforge.net
Cc: ocfs2-devel@oss.oracle.com
Cc: openipmi-developer@lists.sourceforge.net
Cc: qla2xxx-upstream@qlogic.com
[ Consolidated the patches, twiddled the changelog. ]
This fixes an issue seen with devices getting marked offline
in a scenario where a VIOS was getting rebooted while a
client VFC adapter is in SCSI EH and prevents unnecessary
EH escalation in some scenarios.
Acked-by: Robert Jennings <rcj@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Adds support for a new VIOS feature that allows ibmvfc to
optimize terminate_rport_io by telling the VIOS the target
is no longer accessible on the fabric and that it should
not send an ABTS out on the fabric to the device.
If attempting to abort requests due to a fail fail timeout
or error handling while the link is down, we cannot send
an abort out on the fabric. We can, however, send a cancel
to the VIOS. This fixes ibmvfc to send a cancel in this
case to prevent error handling from failing and/or
escalating.
Adds support for receiving FAST_IO_FAIL from fc_block_scsi_eh
when in error recovery. This fixes cases of devices being
taken offline when they are no longer accessible on the fabric,
preventing them from coming back online when the fabric recovers.
The flags on a cancel operation are intended to indicate what,
if any, TMF will follow the cancel request. This fixes a case
where we were incorrectly setting the abort task set flag on
the cancel flag when we were cancelling an abort task set.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Adam Radford <linuxraid@lsi.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
This fixes an issues seen where a Fabric RSCN event was received
while the link was down, which resulted in repeated attempts to log back
into the fabric, which then failed, resulting in the ibmvfc driver
taking the host offline. Fix this by delaying taking any action
regarding the fabric RSCN until the link comes back up.
If an abort request times out to the virtual fibre channel adapter,
the ibmvfc driver will kick off a reset of the adapter. This
patch ensures we wait for the both the abort request and the
request being aborted to be completed prior to exiting the
eh_abort handler. This fixes a bug where the ibmvfc driver
was erroneously returning success to the eh_abort handler
then later sending back a response to the same command.
This makes vio_register_driver() get the module owner & name at compile
time like PCI drivers do, and adds a name pointer directly in struct
vio_driver to avoid having to explicitly initialize the embedded
struct device.
If a Virtual I/O server fails in a dual virtual I/O server multipath
configuration, ensure we delete all remote ports so that path failover
can occur. For a single path configuration, the remote ports will
go into devloss state.
By changing field ordering we can avoid a couple of memory holes in
the tables that use the ibmvfc_async_desc structure.
Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com>
Acked-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Move the mid-layer's ->queuecommand() invocation from being locked
with the host lock to being unlocked to facilitate speeding up the
critical path for drivers who don't need this lock taken anyway.
The patch below presents a simple SCSI host lock push-down as an
equivalent transformation. No locking or other behavior should change
with this patch. All existing bugs and locking orders are preserved.
Additionally, add one parameter to queuecommand,
struct Scsi_Host *
and remove one parameter from queuecommand,
void (*done)(struct scsi_cmnd *)
Scsi_Host* is a convenient pointer that most host drivers need anyway,
and 'done' is redundant to struct scsi_cmnd->scsi_done.
Minimal code disturbance was attempted with this change. Most drivers
needed only two one-line modifications for their host lock push-down.
Acked-by: James Bottomley <James.Bottomley@suse.de>
If a Virtual I/O server is rebooted, the client fibre channel sees a
transport event on its CRQ, which causes it to attempt to reconnect
to the CRQ. For a period of time during the VIOS reboot, the client's
attempts to register the CRQ will return H_CLOSED, indicating the server
side is not currently registered. The ibmvfc driver was not handling
this well and was taking the virtual adapter offline. Fix this by
re-enabling our interrupt and waiting for the event on our CRQ
indicating the server is back, at which point we can reconnect.
This removes the driver's get_host_def_dev_loss_tmo
callback and just has the driver set the dev loss
using the fc class fc_host_dev_loss_tmo macro like is
done for other fc params.
This patch also removes the module dev loss param.
To override the value the fc host sysfs value being
added in the fc class patch can be used instead of the driver
module param.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
By default, ibmvfc does not log any async events in order
to avoid flooding the log with them. Improve on this by
logging by default events that are not likely to flood the
log, such as link up/down. Having these events in the log
will improve the ability to debug issues with ibmvfc.
This fixes a bug where the driver was resetting the
rport dev_loss_tmo when devices were added by adding
support for the get_host_def_dev_loss_tmo callout.
Patch has only been compile tested.
The ibmvfc driver was incorrectly obtaining a scsi_target pointer
from an fc_rport. The way it is coded ensures that ibmvfc's
terminate_rport_io handler does absolutely nothing. Fix this up
to iterate through affected devices differently, sending cancel
and abort task set as appropriate. Without this patch,
fast_io_fail_tmo is broken for ibmvfc.
Commit 43c8da907ccc656935d1085701f4db83385d8a59 introduced a race
condition which can occur when adding/deleting rports. There are
two possible threads now that can be deleting rports in the ibmvfc
driver, which can result in list_del being called twice, resulting
in an oops. This patch adds a new state to the ibmvfc_target struct
to indicate the target has been removed from the list and is in
the process of being deleted.
Adds support for fc_block_scsi_eh to block the EH handlers if
the target device is in the blocked state to ensure we don't
take devices offline.
This fixes a softlockup seen on resume. During resume, the CRQ
must be reenabled. However, the H_ENABLE_CRQ hcall used to do
this may return H_BUSY or H_LONG_BUSY. When this happens, the
caller is expected to retry later. Normally the H_ENABLE_CRQ
succeeds relatively soon. However, we have seen cases where
this can take long enough to see softlockup warnings.
This patch changes a simple loop, which was causing the
softlockup, to a loop at task level which sleeps between
retries rather than simply spinning.
Merging in current state of Linus' tree to deal with merge conflicts and
build failures in vio.c after merge.
drivers/i2c/busses/i2c-cpm.c
drivers/i2c/busses/i2c-mpc.c
drivers/net/gianfar.c
Also fixed up one line in arch/powerpc/kernel/vio.c to use the
correct node pointer.
This allows bin_attr->read,write,mmap callbacks to check file specific data
(such as inode owner) as part of any privilege validation.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
The following structure elements duplicate the information in
'struct device.of_node' and so are being eliminated. This patch
makes all readers of these elements use device.of_node instead.
(struct of_device *)->node
(struct dev_archdata *)->prom_node (sparc)
(struct dev_archdata *)->of_node (powerpc & microblaze)
If a command times out resulting in EH getting invoked, we wait for the
aborted commands to come back after sending the abort. Shorten
the amount of time we wait for these responses, to ensure we don't
get stuck in EH for several minutes.
Commands which are completed by the VIOS are placed on a CRQ
in kernel memory for the ibmvfc driver to process. Each CRQ
entry is 16 bytes. The ibmvfc driver reads the first 8 bytes
to check if the entry is valid, then reads the next 8 bytes to get
the handle, which is a pointer the completed command. This fixes
an issue seen on Power 7 where the processor reordered the
loads from memory, resulting in processing command completion
with a stale handle. This could result in command timeouts,
and also early completion of commands.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Adds support for resuming from suspend for IBM VFC devices. We may have
lost an interrupt over the suspend, so we just kick the interrupt handler
to process anything that is outstanding. We expect to find a transport event
indicating we need to reestablish our CRQ.
Except for SCSI no device drivers distinguish between physical and
hardware segment limits. Consolidate the two into a single segment
limit.
This patch modifies scsi_host_template->change_queue_depth so that
it takes an argument indicating why it is being called. This will be
used so that if a LLD needs to do some extra processing when
handling queue fulls or later ramp ups, it can do so.
This is a simple port of the drivers setting a change_queue_depth
callback. In the patch I just have these LLDs adjust the queue depth
if the user was requesting it.
[Vasu.Dev: v2
Also converted pmcraid_change_queue_depth and then verified
all modules compile using "make allmodconfig" for any new build
warnings on X86_64.
Updated original description after combing two original
patches from Mike to make this patch git bisectable.]
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
[jejb: fixed up 53c700]
Adds support for FC passthru via BSG.
When issuing a Cancel to the virtual fibre channel adapter,
the interface specifies a flags field for the client to indicate
what kind of error recovery is being performed. Fix up these
flags for terminate_rport_io to indicate an abort task set
rather than a target reset.
Remove a parameter to ibmvfc_init_host which is always set to
zero by all callers.
Need to grab the host lock around the call to ibmvfc_link_down.
When processing the response to either a LUN reset,
target reset, or an abort task set, the ibmvfc driver needs to
treat as success receiving a response with a non-zero
status in the response IU along with a general transport
error with the FCP response code being zero. The VIOS
currently guarantees this cannot happen, but a future version
of VIOS may allow this to be returned, so ensure we handle
this response combination correctly for TMFs, as we already
do for SCSI commands.
The allocated struct is manually zeroed after allocation, so avoid using
the (broken) kzalloc mempool (which does not re-zero previously used items
when they are returned to the pool).
Signed-off-by: Sage Weil <sage@newdream.net>
Fixes a problem seen where sending a PRLI to a target
resulted in it sending a LOGO. This caused the ibmvfc
driver to go back through discovery again, which caused
another PRLI attempt, which caused another LOGO. Fix this
behavior by ignoring LOGO if we haven't even logged into
the target yet.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Since async events could indicate changes to link status, or
events which could affect decisions made during discovery, we should
process async events prior to command completion responses.
There are several scenarios where the ibmvfc driver needs to
try to log back into a target on the fabric. Today when these events
occur, we simply go through re-discovery for all attached targets,
assuming that either the query of the name server or an ADISC will
indicate we might need to log back into the target, which doesn't
work for all scenarios. Fix this by taking note of the affected target(s)
in these conditions and ensuring we try to PLOGI back into the target.
For certain scenarios during device rediscovery, we detect we need
to log back into a target. Currently we do just that - PLOGI/PRLI
back into the target. Change the code to delete and add the target
from the FC transport layer as well, to ensure we handle any cases
where the target may have changed.
The virtual I/O server controlling the NPIV adapter associated with
a virtual fibre channel adapter can send a HALT event to the client.
When this occurs, the client can no longer send commands until a RESUME
is received. By adding support for flush on halt, we will get all of
our outstanding commands flushed back before the Virtual I/O server
enters the halt state, eliminating potential command timeouts for
outstanding commands which might occur if we did not support this feature.
This patch adds support for a new command supported by the Virtual I/O
Server, NPIV Logout. The command will abort all outstanding commands
and log out of the fabric. Currently, the only way to do this is
by breaking the CRQ, which can take a fairly long time when lots of
commands are outstanding. The NPIV Logout commands provides a mechanism
to accomplish virtually the same function, but is much faster.
Fixes the following deadlock scenario shown below. We currently allow
queuecommand to send commands when the ibmvfc workqueue is scanning for
new rports, so we should also allow EH to function at this time as well.
scsi_eh_3 D 0000000000000000 12304 1279 2
Call Trace:
[c0000002f7257730] [c0000002f72577e0] 0xc0000002f72577e0 (unreliable)
[c0000002f7257900] [c0000000000118f4] .__switch_to+0x158/0x1a0
[c0000002f72579a0] [c0000000004f8b40] .schedule+0x8d4/0x9dc
[c0000002f7257b60] [c0000000004f8f08] .schedule_timeout+0xa8/0xe8
[c0000002f7257c50] [d0000000001d23e0] .ibmvfc_wait_while_resetting+0xe4/0x140 [ibmvfc]
[c0000002f7257d20] [d0000000001d3984] .ibmvfc_eh_abort_handler+0x60/0xe4 [ibmvfc]
[c0000002f7257dc0] [d000000000366714] .scsi_error_handler+0x38c/0x674 [scsi_mod]
[c0000002f7257f00] [c0000000000a7470] .kthread+0x78/0xc4
[c0000002f7257f90] [c000000000029b8c] .kernel_thread+0x4c/0x68
ibmvfc_3 D 0000000000000000 12432 1280 2
Call Trace:
[c0000002f7253540] [c0000002f72535f0] 0xc0000002f72535f0 (unreliable)
[c0000002f7253710] [c0000000000118f4] .__switch_to+0x158/0x1a0
[c0000002f72537b0] [c0000000004f8b40] .schedule+0x8d4/0x9dc
[c0000002f7253970] [c0000000004f8e98] .schedule_timeout+0x38/0xe8
[c0000002f7253a60] [c0000000004f80cc] .wait_for_common+0x138/0x220
[c0000002f7253b40] [c0000000000a2784] .flush_cpu_workqueue+0xac/0xcc
[c0000002f7253c10] [c0000000000a2960] .flush_workqueue+0x58/0xa0
[c0000002f7253ca0] [d0000000000827fc] .fc_flush_work+0x4c/0x64 [scsi_transport_fc]
[c0000002f7253d20] [d000000000082db4] .fc_remote_port_add+0x48/0x6c4 [scsi_transport_fc]
[c0000002f7253dd0] [d0000000001d7d04] .ibmvfc_work+0x820/0xa7c [ibmvfc]
[c0000002f7253f00] [c0000000000a7470] .kthread+0x78/0xc4
[c0000002f7253f90] [c000000000029b8c] .kernel_thread+0x4c/0x68
fc_wq_3 D 0000000000000000 10720 1283 2
Call Trace:
[c0000002f559ac30] [c0000002f559ace0] 0xc0000002f559ace0 (unreliable)
[c0000002f559ae00] [c0000000000118f4] .__switch_to+0x158/0x1a0
[c0000002f559aea0] [c0000000004f8b40] .schedule+0x8d4/0x9dc
[c0000002f559b060] [c0000000004f8e98] .schedule_timeout+0x38/0xe8
[c0000002f559b150] [c0000000004f80cc] .wait_for_common+0x138/0x220
[c0000002f559b230] [c0000000002721c4] .blk_execute_rq+0xb4/0x100
[c0000002f559b360] [d00000000036a1f8] .scsi_execute+0x118/0x194 [scsi_mod]
[c0000002f559b420] [d00000000036a32c] .scsi_execute_req+0xb8/0x124 [scsi_mod]
[c0000002f559b500] [d0000000000c1330] .sd_sync_cache+0x8c/0x108 [sd_mod]
[c0000002f559b5e0] [d0000000000c15b4] .sd_shutdown+0x9c/0x158 [sd_mod]
[c0000002f559b660] [d0000000000c16d0] .sd_remove+0x60/0xb4 [sd_mod]
[c0000002f559b700] [c000000000392ecc] .__device_release_driver+0xd0/0x118
[c0000002f559b7a0] [c000000000393080] .device_release_driver+0x30/0x54
[c0000002f559b830] [c000000000392108] .bus_remove_device+0x128/0x16c
[c0000002f559b8d0] [c00000000038f94c] .device_del+0x158/0x234
[c0000002f559b960] [d00000000036f078] .__scsi_remove_device+0x5c/0xd4 [scsi_mod]
[c0000002f559b9f0] [d00000000036f124] .scsi_remove_device+0x34/0x58 [scsi_mod]
[c0000002f559ba80] [d00000000036f204] .__scsi_remove_target+0xb4/0x120 [scsi_mod]
[c0000002f559bb10] [d00000000036f338] .__remove_child+0x2c/0x44 [scsi_mod]
[c0000002f559bb90] [c00000000038f11c] .device_for_each_child+0x54/0xb4
[c0000002f559bc50] [d00000000036f2e0] .scsi_remove_target+0x70/0x9c [scsi_mod]
[c0000002f559bce0] [d000000000083454] .fc_starget_delete+0x24/0x3c [scsi_transport_fc]
[c0000002f559bd70] [c0000000000a2368] .run_workqueue+0x118/0x208
[c0000002f559be30] [c0000000000a2580] .worker_thread+0x128/0x154
[c0000002f559bf00] [c0000000000a7470] .kthread+0x78/0xc4
[c0000002f559bf90] [c000000000029b8c] .kernel_thread+0x4c/0x68
The ibmvfc driver currently logs errors during discovery for several
transient fabric errors, which generally get retried. If retries
do not work, we see multiple errors in the log. If retries do work,
we see errors in the log which may be confusing since the retry worked.
This patch enhances the discovery time error logging to only log errors
for command failures during discovery if all allowed retries have been
used up. The existing behavior of logging all failures can be restored
by setting the hosts log_level to a value of 3 or greater.
