path: root/drivers/scsi/hosts.c
2006-04-10[PATCH] move ->eh_strategy_handler to the transport classChristoph Hellwig
Overriding the whole EH code is a per-transport, not per-host thing. Move ->eh_strategy_handler to the transport class, same as ->eh_timed_out. Downside is that scsi_host_alloc can't check for the total lack of EH anymore, but the transition period from old EH where we needed it is long gone already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-02-27[SCSI] SCSI core kmalloc2kzallocJes Sorensen
Change the core SCSI code to use kzalloc rather than kmalloc+memset where possible. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] turn most scsi semaphores into mutexesArjan van de Ven
the scsi layer is using semaphores in a mutex way, this patch converts these into using mutexes instead Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-06[BLOCK] update SCSI to use new blk_ordered for barriersTejun Heo
All ordered request related stuff delegated to HLD. Midlayer now doens't deal with ordered setting or prepare_flush callback. sd.c updated to deal with blk_queue_ordered setting. Currently, ordered tag isn't used as SCSI midlayer cannot guarantee request ordering. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-04Merge by HandJames Bottomley
Conflicts in dec_esp.c (Thanks Bacchus), scsi_transport_iscsi.c and scsi_transport_fc.h Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[SCSI] move the mid-layer printk's over to shost/starget/sdev_printkJames Bottomley
This should eliminate (at least in the mid layer) to make numeric assumptions about any of the enumeration variables. As a side effect, it will also make all the messages consistent and line us up nicely for the error logging strategy (if it ever shows itself again). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[PATCH] gfp_t: drivers/scsiAl Viro
2005-10-02[SCSI] fix potential panic with proc on module removalJames Bottomley
There's a problem in our host release in that it calls scsi_proc_hostdir_rm(). However, if you hold a reference to the host as you remove the module, the host template (which proc uses) will be freed and the system will panic when the host device is finally released. Fix this by moving scsi_proc_hostdir_rm() to where it should be: in scsi_remove_host(). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-19[SCSI] fix oops on usb storage device disconnectJames Bottomley
We fix the oops by enforcing the host state model. There have also been two extra states added: SHOST_CANCEL_RECOVERY and SHOST_DEL_RECOVERY so we can take the model through host removal while the recovery thread is active. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-06[SCSI] switch EH thread startup to the kthread APIChristoph Hellwig
2005-07-30[SCSI] host state model update: mediate host add/remove raceMike Anderson
Add support to not allow additions to a host when it is being removed. Signed-off-by: Mike Anderson <andmike@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-30[SCSI] host state model update: reimplement scsi_host_cancelMike Anderson
Remove the old scsi_host_cancel function as it has not been working for sometime do to the device list possibly being empty when it is called and possible race issues. Add setting of SHOST_CANCEL at the state of beginning of scsi_remove_host. Signed-off-by: Mike Anderson <andmike@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-30[SCSI] host state model update: replace old host bitmap stateMike Anderson
Migrate the current SCSI host state model to a model like SCSI device is using. Signed-off-by: Mike Anderson <andmike@us.ibm.com> Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-26[SCSI] remove scsi_set_deviceChristoph Hellwig
scsi_add_host is the proper place to set the device, but people copy the scsi_set_device usage from older drivers again and again. note that this leaves some legacy drivers like qlogicisp/qlogicfc without pci association in sysfs, but they're scheduled to go away soon anyway. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-24[PATCH] make various thing staticAdrian Bunk
Another rollup of patches which give various symbols static scope Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
