When removing the driver or when probe fails, we need to delete the PHY
timers.
Signed-off-by: Xiang Chen <chenxiang66@hisilicon.com>
Signed-off-by: John Garry <john.garry@huawei.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 3029 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
Do some minor tidy-up.
Currently we call hisi_sas_softreset_ata_disk() in
hisi_sas_I_T_nexus_reset().
If this fails for open reject reason, there is no reason to fail the IT
nexus reset, so only fail for TMF_RESP_FUNC_FAILED.
Some other strings spilled over multiple lines are reunited.
Signed-off-by: Luo Jiaxing <luojiaxing@huawei.com>
In the function of hisi_sas_init_device(), we added ops->hardreset() to
clear affiliation of STP target port or handle [STP pending] state.
Function hisi_sas_init_device() will be called when a device is found or
during controller reset. At controller reset, we call
hisi_sas_init_device() to re-init the disks, so calling hardreset() is
unnecessary and it also will cause some delay at controller reset.
This patch is to switch HW all error handling from PCI AER to MSI interrupt
due to non-standard PCI implementation. All HW errors which were being
reported through PCI AER can be reported through MSI interrupt also.
Do two things to complete the switch:
1. Notify FW to switch to MSI handling through ACPI DSM.
2. Add MSI handling for some hw errors, ECC errors and poison errors (we
also call some of them AXI reuser error). They were handled only through
PCI AER before.
For old FW reporting PCI AER events, the PCI AER handler will see that the
driver on longer support AER, and will leave the device in offlined state,
which is safe.
Signed-off-by: Xiaofei Tan <tanxiaofei@huawei.com>
In commit 8b8d66531555 ("scsi: hisi_sas: make SAS address of SATA disks
unique"), we ensured that each SATA disk in the system has a unique SAS
address, even if it is fake. That was for v2 hw.
Add this for v3 hw.
In function hisi_sas_init_device(), the log is as follows when error for
hardreset:
hisi_sas_v3_hw 0000:74:02.0: SATA disk hardreset fail: 0xffffffed
Actually if hardreset failed, its return value is negative, so change the
print format from %x to %d.
In commit efdcad62e7b8 ("scsi: hisi_sas: Set PHY linkrate when
disconnected"), we use the sas_phy_data.enable flag to track whether the
PHY was enabled or not, so that we know if we should set the PHY negotiated
linkrate at SAS_LINK_RATE_UNKNOWN or SAS_PHY_DISABLED.
However, it is not proper to use sas_phy_data.enable, since it is only set
when libsas attempts to set the PHY disabled/enabled; hence, it may not
even have an initial value.
As a solution to this problem, introduce hisi_sas_phy.enable to track
whether the PHY is enabled or not, so that we can set the negotiated
linkrate properly when the PHY comes down.
Currently there are two scenarioes which may cause PHY state of hardware
(which is 0) is inconsistent with the state held in software:
- Unplug SAS wire before get_phys_state when SAS controller reset, then the
interrupts of phy down are ignored, phy state is 0 before reset, and it
also gets 0 after reset, so phy down doesn't occur even if unplugged SAS
wire;
- For v3 hw later version, it will close bus when 2 bit ECC error occurs.
So if unplug SAS wire at that time, interrupts of phy down also not
occur. So at last it will cause host reset. It also get phy state 0
before and after reset, the same issue occurs.
To solve it, use hisi_sas_phy_down() directly in rescan topology function.
Add host reset interface to make it easier for testing the host reset
feature.
We found out that for v2 hw, a SATA disk can not be written to after the
system comes up.
In commit ffb1c820b8b6 ("scsi: hisi_sas: remove the check of sas_dev status
in hisi_sas_I_T_nexus_reset()"), we introduced a path where we may issue an
internal abort for a SATA device, but without following it with a
softreset.
We need to always follow an internal abort with a software reset, as per HW
programming flow, so add this.
Fixes: ffb1c820b8b6 ("scsi: hisi_sas: remove the check of sas_dev status in hisi_sas_I_T_nexus_reset()")
Pull more SCSI updates from James Bottomley:
"This is the final round of mostly small fixes and performance
improvements to our initial submit.
The main regression fix is the ia64 simscsi build failure which was
missed in the serial number elimination conversion"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (24 commits)
scsi: ia64: simscsi: use request tag instead of serial_number
scsi: aacraid: Fix performance issue on logical drives
scsi: lpfc: Fix error codes in lpfc_sli4_pci_mem_setup()
scsi: libiscsi: Hold back_lock when calling iscsi_complete_task
scsi: hisi_sas: Change SERDES_CFG init value to increase reliability of HiLink
scsi: hisi_sas: Send HARD RESET to clear the previous affiliation of STP target port
scsi: hisi_sas: Set PHY linkrate when disconnected
scsi: hisi_sas: print PHY RX errors count for later revision of v3 hw
scsi: hisi_sas: Fix a timeout race of driver internal and SMP IO
scsi: hisi_sas: Change return variable type in phy_up_v3_hw()
scsi: qla2xxx: check for kstrtol() failure
scsi: lpfc: fix 32-bit format string warning
scsi: lpfc: fix unused variable warning
scsi: target: tcmu: Switch to bitmap_zalloc()
scsi: libiscsi: fall back to sendmsg for slab pages
scsi: qla2xxx: avoid printf format warning
scsi: lpfc: resolve static checker warning in lpfc_sli4_hba_unset
scsi: lpfc: Correct __lpfc_sli_issue_iocb_s4 lockdep check
scsi: ufs: hisi: fix ufs_hba_variant_ops passing
scsi: qla2xxx: Fix panic in qla_dfs_tgt_counters_show
Pull SCSI updates from James Bottomley:
"This is mostly update of the usual drivers: arcmsr, qla2xxx, lpfc,
hisi_sas, target/iscsi and target/core.
Additionally Christoph refactored gdth as part of the dma changes. The
major mid-layer change this time is the removal of bidi commands and
with them the whole of the osd/exofs driver and filesystem. This is a
major simplification for block and mq in particular"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (240 commits)
scsi: cxgb4i: validate tcp sequence number only if chip version <= T5
scsi: cxgb4i: get pf number from lldi->pf
scsi: core: replace GFP_ATOMIC with GFP_KERNEL in scsi_scan.c
scsi: mpt3sas: Add missing breaks in switch statements
scsi: aacraid: Fix missing break in switch statement
scsi: kill command serial number
scsi: csiostor: drop serial_number usage
scsi: mvumi: use request tag instead of serial_number
scsi: dpt_i2o: remove serial number usage
scsi: st: osst: Remove negative constant left-shifts
scsi: ufs-bsg: Allow reading descriptors
scsi: ufs: Allow reading descriptor via raw upiu
scsi: ufs-bsg: Change the calling convention for write descriptor
scsi: ufs: Remove unused device quirks
Revert "scsi: ufs: disable vccq if it's not needed by UFS device"
scsi: megaraid_sas: Remove a bunch of set but not used variables
scsi: clean obsolete return values of eh_timed_out
scsi: sd: Optimal I/O size should be a multiple of physical block size
scsi: MAINTAINERS: SCSI initiator and target tweaks
scsi: fcoe: make use of fip_mode enum complete
With default value of register SERDES_CFG, the link is not stable for some
special disks when running IO. According to HW guys' suggestion, need to
make the bit10~19 value of register SERDES_CFG the max value to increase
the reliability of the HiLink.
Reviewed-by: Yupeng Zhou <zhouyupeng1@huawei.com>
target port
If we exchange SAS expander from one SAS controller to other SAS controller
without powering it down, the STP target port will maintain previous
affiliation and reject all subsequent connection requests from other STP
initiator ports with OPEN_REJECT (STP RESOURCES BUSY).
To solve this issue, send HARD RESET to clear the previous affiliation of
STP target port according to SPL (chapter 6.19.4).
We (re-)introduce dev status flag to know if to sleep in NEXUS reset code
or not for remote PHYs. The idea is that if the device is being
initialised, we don't require the delay, and caller would wait for link to
be established, cf. sas_ata_hard_reset().
Co-developed-by: Luo Jiaxing <luojiaxing@huawei.com>
When the PHY comes down, we currently do not set the negotiated linkrate:
root@(none)$ pwd
/sys/class/sas_phy/phy-0:0
root@(none)$ more enable
1
root@(none)$ more negotiated_linkrate
12.0 Gbit
root@(none)$ echo 0 > enable
12.0 Gbit
root@(none)$
This patch fixes the driver code to set it properly when the PHY comes
down.
If the PHY had been enabled, then set unknown; otherwise, flag as disabled.
The logical place to set the negotiated linkrate for this scenario is PHY
down routine, which is called from the PHY down ISR.
However, it is not possible to know if the PHY comes down due to PHY
disable or loss of link, as sas_phy.enabled member is not set until after
the transport disable routine is complete, which races with the PHY down
ISR.
As an imperfect solution, use sas_phy_data.enable as the flag to know if
the PHY is down due to disable. It's imperfect, as sas_phy_data is internal
to libsas.
I can't see another way without adding a new field to hisi_sas_phy and
managing it, or changing SCSI SAS transport.
The later revision of v3 hw has added an function of interrupt coalesce
according to time for PHY RX errors. We set the coalesce time to 1s. Then
we print PHY RX errors count when PHY RX errors happen, and don't need to
worry that there may be too much log prints.
Besides, we use hisi_sas_phy.lock to protect error count value. Because we
update them by calling phy_get_events_v3_hw(), which is also used by core
driver (for get PHY events function).
We relocate phy_get_events_v3_hw() to avoid a further declaration.
For internal IO and SMP IO, there is a time-out timer for them. In the
timer handler, it checks whether IO is done according to the flag
task->task_state_lock.
There is an issue which may cause system suspended: internal IO or SMP IO
is sent, but at that time because of hardware exception (such as inject
2Bit ECC error), so IO is not completed and also not timeout. But, at that
time, the SAS controller reset occurs to recover system. It will release
the resource and set the status of IO to be SAS_TASK_STATE_DONE, so when IO
timeout, it will never complete the completion of IO and wait for ever.
[ 729.123632] Call trace:
[ 729.126791] [<ffff00000808655c>] __switch_to+0x94/0xa8
[ 729.133106] [<ffff000008d96e98>] __schedule+0x1e8/0x7fc
[ 729.138975] [<ffff000008d974e0>] schedule+0x34/0x8c
[ 729.144401] [<ffff000008d9b000>] schedule_timeout+0x1d8/0x3cc
[ 729.150690] [<ffff000008d98218>] wait_for_common+0xdc/0x1a0
[ 729.157101] [<ffff000008d98304>] wait_for_completion+0x28/0x34
[ 729.165973] [<ffff000000dcefb4>] hisi_sas_internal_task_abort+0x2a0/0x424 [hisi_sas_test_main]
[ 729.176447] [<ffff000000dd18f4>] hisi_sas_abort_task+0x244/0x2d8 [hisi_sas_test_main]
[ 729.185258] [<ffff000008971714>] sas_eh_handle_sas_errors+0x1c8/0x7b8
[ 729.192391] [<ffff000008972774>] sas_scsi_recover_host+0x130/0x398
[ 729.199237] [<ffff00000894d8a8>] scsi_error_handler+0x148/0x5c0
[ 729.206009] [<ffff0000080f4118>] kthread+0x10c/0x138
[ 729.211563] [<ffff0000080855dc>] ret_from_fork+0x10/0x18
To solve the issue, callback function task_done of those IOs need to be
called when on SAS controller reset.
According to the tool fortify, phy_up_v3_hw() returns signed value, while
it should return an unsigned value.
So change variable "res" from int to irq_return_t.
The change to use dma_set_mask_and_coherent() incorrectly made a second
call with the 32 bit DMA mask value when the call with the 64 bit DMA
mask value succeeded.
[mkp: fixed commit message]
Fixes: e4db40e7a1a2 ("scsi: hisi_sas: use dma_set_mask_and_coherent")
Cc: <stable@vger.kernel.org>
Suggested-by: Ewan D. Milne <emilne@redhat.com>
Signed-off-by: Hannes Reinecke <hare@suse.com>
Do some very minor tidy-up, for things like needlessly initing variable and
not leaving whitespace before quote endings.
Originally-from: Xiang Chen <chenxiang66@hisilicon.com>
Originally-from: Luo Jiaxing <luojiaxing@huawei.com>
For auto-control irq affinity mode, choose the dq to deliver IO according
to the current CPU.
Then it decreases the performance regression that fio and CQ interrupts are
processed on different node.
For user control irq affinity mode, keep it as before.
To realize it, also need to distinguish the usage of dq lock and sas_dev
lock.
We mark as experimental due to ongoing discussion on managed MSI IRQ
during hotplug:
https://marc.info/?l=linux-scsi&m=154876335707751&w=2
We're almost at the point where we can expose multiple queues to the upper
layer for SCSI MQ, but we need to sort out the per-HBA tags performance
issue.
To support queue mapped to a CPU, it needs to be ensured that issuing an
internal abort is safe, in that it is guaranteed that an internal abort is
processed for a single IO or a device after all the relevant command(s)
which it is attempting to abort have been processed by the controller.
Currently we only deliver commands for any device on a single queue to
solve this problem, as we know that commands issued on the same queue will
be processed in order, and we will not have a scenario where the internal
abort is racing against a command(s) which it is trying to abort.
To enqueue commands on queue mapped to a CPU, choosing a queue for an
command is based on the associated queue for the current CPU, so this is
not safe for internal abort since it would definitely not be guaranteed
that commands for the command devices are issued on the same queue.
To solve this issue, we take a bludgeoning approach, and issue a separate
internal abort on any queue(s) relevant to the command or device, in that
we will be guaranteed that at least one of these internal aborts will be
received last in the controller.
So, for aborting a single command, we can just force the internal abort to
be issued on the same queue as the command which we are trying to abort.
For aborting all commands associated with a device, we issue a separate
internal abort on all relevant queues. Issuing multiple internal aborts in
this fashion would have not side affect.
If sending IOs to many disks from single queue, it is possible that the
queue may be full. To avoid the situation, change queue depth from 512 to
4096 which is the max number of IOs for v3 hw.
Add an interface to manually trigger a debugfs dump.
This patch adds support for DIX to v3 hw driver.
For this, we build upon support for DIF, most significantly is adding new
DMA map and unmap paths.
Some pre-existing macro precedence issues are also tidied. They were
detected by checkpatch --strict.
This call must have been missed when I reworked the debugfs feature for
upstreaming, so add it back.
A NULL-pointer dereference was introduced for TMF SSP commands from the
upstreaming reworking.
Fix this by relocating the scsi_get_prot_op() callsite.
Fixes: d6a9000b81be ("scsi: hisi_sas: Add support for DIF feature for v2 hw")
Sparse detected some problems in the driver, so tidy them up.
Some sizes we allocate for debugfs structure are incorrect, so fix them.
Hot-plugging SAS wire of direct hard disk backplane may cause disk lost. We
have done this test with several types of SATA disk from different venders,
and only two models from Seagate has this problem, ST4000NM0035-1V4107 and
ST3000VM002-1ET166.
The root cause is that the disk doesn't send D2H frame after OOB finished.
SAS controller will issue phyup interrupt only when D2H frame is received,
otherwise, will be waiting there all the time.
When this issue happen, we can find the disk again with link reset. To fix
this issue, we setup an timer after OOB finished. If the PHY is not up in
20s, do link reset. Notes: the 20s is an experience value.
The SAS controller cannot support a programmed minimum linkrate of > 1.5G
(it will always negotiate to 1.5G at least), so just reject it.
This solves a strange situation where the PHY negotiated linkrate may be
less than the programmed minimum linkrate.
In function hisi_sas_alloc(), parameter shost is not used, so remove it.
When issing a hardreset to a SATA device when running IO, it is possible
that abnormal CQs of the device are returned. Then enter error handler, it
doesn't enter function hisi_sas_abort_task() as there is no timeout IO, and
it doesn't set device as HISI_SAS_DEV_EH. So when hardreset by libata
later, it actually doesn't issue hardreset as there is a check to judge
whether device is in error.
For this situation, actually need to hardreset the device to recover.
So remove the check of sas_dev status in hisi_sas_I_T_nexus_reset().
Before we add the check to avoid the endless loop of reset for
directly-attached SATA device at probe time, actually we flutter it for
it, so it is not necessary to add the check now.
When injecting 2 bit ECC error, it will cause fatal AXI interrupts. Before
the recovery of SAS controller reset, the internal of SAS controller is in
error. If CQ interrupts return at the time, actually it is exception CQ
interrupt, and it may cause resource release in disorder.
To avoid the exception situation, shutdown AXI bus after fatal AXI
interrupt. In SAS controller reset, it will restart AXI bus. For later
version of v3 hw, hardware will shutdown AXI bus for this situation, so
just fix current ver of v3 hw.
Send primitive NOTIFY to SSP situation only, or it causes underflow issue
when sending IO. Also rename hisi_sas_hw.sl_notify() to hisi_sas_hw.
sl_notify_ssp().
This patch creates debugfs file for ITCT and adds file operations.
Sparse can detect some type casting issues in the debugfs code, so fix it
up.
Also a missing static qualifier is added to hisi_sas_debugfs_to_reg_name().
When calling debugfs functions, there is no need to ever check the return
value. The function can work or not, but the code logic should never do
something different based on this.
Currently we set the protection parameters after calling scsi_add_host()
for v3 hw.
They should be set beforehand, so make this change.
Appearantly this fixes our DIX issue (not mainline yet) also, but more
testing required.
This patch create debugfs file for IOST and add file operations.
This patch create debugfs file for DQ and add file operations
This patch create debugfs file for CQ and add file operations.
This patch create debugfs file for port register and add file operations.
This patch create debugfs file for global register and add file
operations.
This patch takes snapshot for global regs, port regs, CQ, DQ, IOST, ITCT.
Add code for snapshot trig and generate dump directory.
This patch allocates snapshot memory for global reg, port regs, CQ, DQ,
IOST, ITCT.
When we fail to allocate memory for some registers, we free the memory
and set hisi_sas_debugfs_enable as 0 to stop loading debugfs from running.
This patch creates root directory at hisi_sas_init() and generates device
directory when we probe device driver.
And we remove the root directory at hisi_sas_exit(), but recursively
delete device directory when we remove device driver.
