path: root/drivers/scsi/gdth_proc.c
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-18[SCSI] gdth: don't call pci_free_consistent under spinlockJames Bottomley
The spinlock is held over too large a region: pscratch is a permanent address (it's allocated at boot time and never changes). All you need the smp lock for is mediating the scratch in use flag, so fix this by moving the spinlock into the case where we set the pscratch_busy flag to false. Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-12[SCSI] gdth: Move members from SCp to gdth_cmndinfo, stage 2Boaz Harrosh
- Cleanup the rest of the scsi_cmnd->SCp members and move them to gdth_cmndinfo: SCp.this_residual => priority SCp.buffers_residual => timeout SCp.Status => status and dma_dir SCp.Message => info SCp.have_data_in => volatile wait_for_completion SCp.sent_command => OpCode SCp.phase => phase - Two more members will be naturally removed in the !use_sg cleanup TODO: What is the meaning of gdth_cmndinfo.phase? (rhetorically) Signed-off-by Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Setup proper per-command private dataBoaz Harrosh
- scsi_cmnd and specifically ->SCp of, where heavily abused with internal meaning members and flags. So introduce a new struct gdth_cmndinfo, put it on ->host_scribble and define a gdth_cmnd_priv() accessor to retrieve it from a scsi_cmnd. - The structure now holds two members: internal_command - replaces the IS_GDTH_INTERNAL_CMD() croft. sense_paddr - which was a 64-bit spanning on 2 32-bit members of SCp. More overloaded members from SCp and scsi_cmnd will be moved in a later patch (For easy review). - Split up gdth_queuecommand to an additional internal_function. The later is the one called by gdth_execute(). This will be more evident later in the scsi accessors patch, but it also facilitates in the differentiation between internal_command and external. And the setup of gdth_cmndinfo of each command. Signed-off-by Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: clean up host private dataBoaz Harrosh
- Based on same patch from Christoph Hellwig <hch@lst.de> - Get rid of all the indirection in the Scsi_Host private data and always put the gdth_ha_str directly into it. - Change all internal functions prototype to recieve an "gdth_ha_str *ha" pointer directlly and kill all that redundent access to the "gdth_ctr_tab[]" controller-table. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Remove virt hostsChristoph Hellwig
The virt_ctr option allows to register a new scsi_host for each bus on the raid controller. This non-default option makes no sense with the current scsi code and prevents cleaning up the host registration, so remove it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Remove 2.4.x support, in-kernel changelogJeff Garzik
* Remove in-source changelog. It's archived permanently in git and various kernel archives, and changelogs should exist purely in git. * Remove 2.4.x kernel support. It is an active obstacle to modernizing this driver, at this point. This includes killing gdth_kcompat.h which is 100% redundant in modern kernels. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] gdth: Stop abusing ->done for internal commandsMatthew Wilcox
The ->done member was being used to mark commands as being internal. I decided to put a magic number in ->underflow instead. I believe this to be safe as no current user of ->underflow has any of the bottom 9 bits set. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] remove the scsi_request interface from the gdth driverLeubner, Achim
Initial pass at converting the gdth driver away from the scsi_request interface so that the request interface can be removed post 2.6.18 without breaking gdth. Based on changes from Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09[SCSI] remove Scsi_Device typedefChristoph Hellwig
