path: root/drivers/scsi/g_NCR5380.c
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2010-08-11g_NCR5380: fix broken MMIO compilationOndrej Zary
The ifdefs are broken so the MMIO code is never compiled and so it's broken too. Fix them all. Untested as I don't have the hardware. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Reviewed-by: Andy Walls <awalls@md.metrocast.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11g_NCR5380: remove misleading pnp error messageOndrej Zary
Remove misleading error message that appears after pnp card has been detected correctly. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-25[SCSI] NCR5380: Fix bugs and canonicalize irq handler usageJeff Garzik
* Always pass the same value to free_irq() that we pass to request_irq(). This fixes several bugs. * Always call NCR5380_intr() with 'irq' and 'dev_id' arguments. Note, scsi_falcon_intr() is the only case now where dev_id is not the scsi_host. * Always pass Scsi_Host to request_irq(). For most cases, the drivers already did so, and I merely neated the source code line. In other cases, either NULL or a non-sensical value was passed, verified to be unused, then changed to be Scsi_Host in anticipation of the future. In addition to the bugs fixes, this change makes the interface usage consistent, which in turn enables the possibility of directly referencing Scsi_Host from all NCR5380_intr() invocations. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-12[SCSI] NCR5380: fix NCR53C400_PSEUDO_DMA is not definedGabriel C
In file included from drivers/scsi/g_NCR5380_mmio.c:9: drivers/scsi/g_NCR5380.c:559:5: warning: "NCR53C400_PSEUDO_DMA" is not defined Signed-off-by: Gabriel Craciunescu <nix.or.die@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-06[SCSI] Improve inquiry printingMatthew Wilcox
- Replace scsi_device_types array API with scsi_device_type function API. Gets rid of a lot of common code, as well as being easier to use. - Add the new device types in SPC4 r05a, and rename some of the older ones. - Reformat the printing of inquiry data; now fits on one line and includes PQ. I think I've addressed all the feedback from the previous versions. My current test box prints: scsi 2:0:1:0: Direct access HP 18.2G ATLAS10K3_18_SCA HP05 PQ: 0 ANSI: 2 Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-24[PATCH] remove ISA legacy functions: drivers/scsi/g_NCR5380.cAl Viro
switched CONFIG_SCSI_G_NCR5380_MEM code in g_NCR5380 to ioremap(); massaged g_NCR5380.h accordingly. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[SCSI] remove Scsi_Device typedefChristoph Hellwig
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-06-17[SCSI] Remove no-op implementations of SCSI EH hooksJeff Garzik
Drivers need not implement a hook that returns FAILED, and does nothing else, since the SCSI midlayer code will do that for us. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
