path: root/drivers/scsi/dc395x.c
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-11dc395x: decrease iteration for tag_number of max_command in start_scsi()Roel Kluin
The tag_number reaches dcb->max_command + 1 after the loop, but when the tag_number equals dcb->max_command an error message is already issued. The last iteration therefore appears obsolete. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Oliver Neukum <oliver@neukum.name> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-09tree-wide: fix typos "selct" + "slect" -> "select"Uwe Kleine-König
This patch was generated by git grep -E -i -l 's(le|el)ct' | xargs -r perl -p -i -e 's/([Ss])(le|el)ct/$1elect/ with only skipping net/netfilter/xt_SECMARK.c and include/linux/netfilter/xt_SECMARK.h which have a struct member called selctx. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-04-07[SCSI] Remove random noop unchecked_isa_dma usersAndi Kleen
Lots of drivers set it to 0. Remove that. Patch should be a nop. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] dc395x: fix uninitialized var warningAndrew Morton
drivers/scsi/dc395x.c: In function 'dc395x_init_one': drivers/scsi/dc395x.c:4270: warning: 'ptr' may be used uninitialized in this function Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16[SCSI] add use_sg_chaining option to scsi_host_templateFUJITA Tomonori
This option is true if a low-level driver can support sg chaining. This will be removed eventually when all the drivers are converted to support sg chaining. q->max_phys_segments is set to SCSI_MAX_SG_SEGMENTS if false. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[SCSI] Remove ->pid field from scsi_cmndMatthew Wilcox
The pid field is a duplicate of the serial_number field and has been scheduled for removal for a long time. A few drivers were still using it, so just change them to use serial_number instead. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-15[SCSI] dc395x: convert to use the data buffer accessorsFUJITA Tomonori
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Jens Axboe <jens.axboe@oracle.com> did the for_each_sg cleanup. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jamie Lenehan <lenehan@twibble.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] use %zu for size_tAl Viro
2006-10-06Various drivers' irq handlers: kill dead code, needless castsJeff Garzik
- Eliminate casts to/from void* - Eliminate checks for conditions that never occur. These typically fall into two classes: 1) Checking for 'dev_id == NULL', then it is never called with NULL as an argument. 2) Checking for invalid irq number, when the only caller (the system) guarantees the irq handler is called with the proper 'irq' number argument. Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-26[SCSI] pci_module_init conversion in scsi subsystemHenrik Kretzschmar
Converts pci_module_init() to pci_register_driver() in the scsi subsys on 23 drivers which only return the value of pci_module_init(). Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-26[SCSI] dc395x: fix printk format warningRandy Dunlap
drivers/scsi/dc395x.c:1224: warning: format '%i' expects type 'int', but argument 5 has type 'size_t' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-10[SCSI] Remove last page_address from dc395x.cGuennadi Liakhovetski
Dynamically map scattergather buffer instead of using page_address(). Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-14[SCSI] dc395x: dynamically map scatter-gather for PIOGuennadi Liakhovetski
The current dc395x driver uses PIO to transfer up to 4 bytes which do not get transferred by DMA (under unclear circumstances). For this the driver uses page_address() which is broken on highmem. Apart from this the actual calculation of the virtual address is wrong (even without highmem). So, e.g., for reading it reads bytes from the driver to a wrong address and returns wrong data, I guess, for writing it would just output random data to the device. The proper fix, as suggested by many, is to dynamically map data using kmap_atomic(page, KM_BIO_SRC_IRQ) / kunmap_atomic(virt). The reason why it has not been done until now, although I've done some preliminary patches more than a year ago was that nobody interested in fixing this problem was able to reliably reproduce it. Now it changed - with the help from Sebastian Frei (CC'ed) I was able to trigger the PIO path. Thus, I was also able to test and debug it. There are 4 cases when PIO is used in dc395x - data-in / -out with and without scatter-gather. I was able to reproduce and test only data-in with and without SG. So, the data-out path is still untested, but it is also somewhat simpler than the data-in. Fredrik Roubert (also CC'ed) also had PIO triggering on his system, and in his case it was data-out without SG. It would be great if he could test the attached patch on his system, but even if he cannot, I would still request to apply the patch and just wait if anybody cries... Implementation: I put 2 new functions in scsi_lib.c and their declarations in scsi_cmnd.h. I exported them without _GPL, although, I don't feel strongly about that - not many drivers are likely to use them. But there is at least one more - I want to use them in tmscsim.c. Whether these are the right files for the functions and their declarations - not sure either. Actually, they are not scsi-specific, so, might go somewhere around other scattergather magic? They are not platform specific either, and most SG functions are defined under arch/*/... As these issues were discussed previously there were some more routines suggested to manipulate scattergather buffers, I think, some of them were needed around crypto code... So, might be a common place reasonable, like lib/scattergather.c? I am open here. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-26[SCSI] dc395x: "fix" virt_addr calculation on AUTO_REQSENSEGuennadi Liakhovetski
The patch below "fixes" calculation of the virt_addr for the AUTO_REQSENSE case. I put "fixes" in quotes because the real fix would be to completely remove it, but that's beyond the scope of this patch. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-07[PATCH] kfree cleanup: drivers/scsiJesper Juhl
This is the drivers/scsi/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/scsi/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-20[SCSI] dc395x: atomic_kmap for PIOGuennadi Liakhovetski
2005-08-14Revert "dc395x: Fix support for highmem"Linus Torvalds
It introduces a repeatable oops in the driver, which is a bigger problem than the patch tries to solve. From the original description: Author: Jamie Lenehan <lenehan@twibble.org> Date: Thu Mar 3 14:41:40 2005 +0200 [PATCH] dc395x: Fix support for highmem From: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Removes the page_to_virt and maps sg lists dynamically. This makes the driver work with highmem pages. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Jamie Lenehan <lenehan@twibble.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-17[SCSI] allow sleeping in ->eh_bus_reset_handler()Jeff Garzik
