path: root/drivers/scsi/bnx2i
2013-01-29[SCSI] bnx2i: fix the bit manipulation when setting the error maskTomas Henzl
The intention in bnx2i_send_fw_iscsi_init_msg was to zero out only the lower 32bits, but instead the whole mask64 is zeroed. This patch fixes it. Signed-off-by: Tomas Henzl <thenzl@redhat.com> Acked-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-01-03Drivers: scsi: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Adam Radford <linuxraid@lsi.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-27[SCSI] bnx2i: removed the individual PCI DEVICE ID checkingEddie Wai
Removed the individual PCI DEVICE ID checking inside bnx2i. The device type can easily be read from the corresponding cnic->flags. This will free bnx2i from having to get updated for every new device ID that gets added. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-17[SCSI] bnx2i: Fixed NULL ptr deference for 1G bnx2 Linux iSCSI offloadEddie Wai
This patch fixes the following kernel panic invoked by uninitialized fields in the chip initialization for the 1G bnx2 iSCSI offload. One of the bits in the chip initialization is being used by the latest firmware to control overflow packets. When this control bit gets enabled erroneously, it would ultimately result in a bad packet placement which would cause the bnx2 driver to dereference a NULL ptr in the placement handler. This can happen under certain stress I/O environment under the Linux iSCSI offload operation. This change only affects Broadcom's 5709 chipset. Unable to handle kernel NULL pointer dereference at 0000000000000008 RIP: [<ffffffff881f0e7d>] :bnx2:bnx2_poll_work+0xd0d/0x13c5 Pid: 0, comm: swapper Tainted: G ---- 2.6.18-333.el5debug #2 RIP: 0010:[<ffffffff881f0e7d>] [<ffffffff881f0e7d>] :bnx2:bnx2_poll_work+0xd0d/0x13c5 RSP: 0018:ffff8101b575bd50 EFLAGS: 00010216 RAX: 0000000000000005 RBX: ffff81007c5fb180 RCX: 0000000000000000 RDX: 0000000000000ffc RSI: 00000000817e8000 RDI: 0000000000000220 RBP: ffff81015bbd7ec0 R08: ffff8100817e9000 R09: 0000000000000000 R10: ffff81007c5fb180 R11: 00000000000000c8 R12: 000000007a25a010 R13: 0000000000000000 R14: 0000000000000005 R15: ffff810159f80558 FS: 0000000000000000(0000) GS:ffff8101afebc240(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: 0000000000000008 CR3: 0000000000201000 CR4: 00000000000006a0 Process swapper (pid: 0, threadinfo ffff8101b5754000, task ffff8101afebd820) Stack: 000000000000000b ffff810159f80000 0000000000000040 ffff810159f80520 ffff810159f80500 00cf00cf8008e84b ffffc200100939e0 ffff810009035b20 0000502900000000 000000be00000001 ffff8100817e7810 00d08101b575bea8 Call Trace: <IRQ> [<ffffffff8008e0d0>] show_schedstat+0x1c2/0x25b [<ffffffff881f1886>] :bnx2:bnx2_poll+0xf6/0x231 [<ffffffff8000c9b9>] net_rx_action+0xac/0x1b1 [<ffffffff800125a0>] __do_softirq+0x89/0x133 [<ffffffff8005e30c>] call_softirq+0x1c/0x28 [<ffffffff8006d5de>] do_softirq+0x2c/0x7d [<ffffffff8006d46e>] do_IRQ+0xee/0xf7 [<ffffffff8005d625>] ret_from_intr+0x0/0xa <EOI> [<ffffffff801a5780>] acpi_processor_idle_simple+0x1c5/0x341 [<ffffffff801a573d>] acpi_processor_idle_simple+0x182/0x341 [<ffffffff801a55bb>] acpi_processor_idle_simple+0x0/0x341 [<ffffffff80049560>] cpu_idle+0x95/0xb8 [<ffffffff80078b1c>] start_secondary+0x479/0x488 Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Cc: stable@vger.kernel.org Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/ixgbevf/ixgbevf_main.c
2012-07-08bnx2i: use strlcpy() instead of memcpy() for stringsDan Carpenter
DRV_MODULE_VERSION here is "2.7.2.2" which is only 8 chars but we copy 12 bytes from the stack so it's a small information leak. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Michael Chan <mchan@broadcom.com> Acked-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-08[SCSI] bnx2i: Removed the reference to the netdev->base_addrEddie Wai
The netdev->base_addr parameter has been deprecated in the L2 bnx2 driver. This is used by bnx2i for the BARn iomapping. This patch will directly reference the pci_resource_start instead of using the deprecated netdev->base_addr. This patch is actually a critical bug fix as the 1G bnx2 driver no longer supports the netdev->base_addr in the current kernel of the scsi tree. This means that Broadcom's 1G Linux iSCSI offload solution would not work at all without this patch. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-06-27bnx2x, bnx2fc, bnx2i, cnic: Add statistics support and FCoE capabilities ↵Barak Witkowski
advertisement 1. When FCoE offload driver is registered, copy its capabilities to the chip scratchpad. 2. Copy FCoE/iSCSI MAC addresses in aligned manner to chip scratchpad. 3. Add FCoE/iSCSI statistics collection support Signed-off-by: Barak Witkowski <barak@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-10[SCSI] bnx2i: Updated version and copyright yearEddie Wai
Old version: 2.7.0.3 New version: 2.7.2.2 Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-05-10[SCSI] bnx2i: Added the setting of target can_queue via target_allocEddie Wai
This will set the target can_queue limit to the number of preallocated session tasks set during creation. "Could not send nopout" messages were observed without this when the iSCSI connection experiences dropped frames under heavy I/O stress. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-03-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) L2TP doesn't get autoloaded when you try to open an L2TP socket due to a missing module alias, fix from Benjamin LaHaise. 2) Netlabel and RDS should propagate gfp flags given to them by callers, fixes from Dan Carpeneter. 3) Recursive locking fix in usbnet wasn't bulletproof and can result in objects going away mid-flight due to races, fix from Ming Lei. 4) Fix up some confusion about a bool module parameter in netfilter's iptable_filter and ip6table_filter, from Rusty Russell. 5) If SKB recycling is used via napi_reuse_skb() we end up with different amounts of headroom reserved than we had at the original SKB allocation. Fix from Eric Dumazet. 6) Fix races in TG3 driver ring refilling, from Michael Chan. 7) We have callbacks for IPSEC replay notifiers, but some call sites were not using the ops method and instead were calling one of the implementations directly. Oops. Fix from Steffen Klassert. 8) Fix IP address validation properly in the bonding driver, the previous fix only works with netlink where the subnet mask and IP address are changed in one atomic operation. When 'ifconfig' ioctls are used the IP address and the subnet mask are changed in two distinct operations. Fix from Andy Gospodarek. 9) Provide a sky2 module operation to work around power management issues with some BIOSes. From Stephen Hemminger. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: usbnet: consider device busy at each recieved packet bonding: remove entries for master_ip and vlan_ip and query devices instead netfilter: remove forward module param confusion. usbnet: don't clear urb->dev in tx_complete usbnet: increase URB reference count before usb_unlink_urb xfrm: Access the replay notify functions via the registered callbacks xfrm: Remove unused xfrm_state from xfrm_state_check_space RDS: use gfp flags from caller in conn_alloc() netlabel: use GFP flags from caller instead of GFP_ATOMIC l2tp: enable automatic module loading for l2tp_ppp cnic: Fix parity error code conflict tg3: Fix RSS ring refill race condition sky2: override for PCI legacy power management net: fix napi_reuse_skb() skb reserve
2012-03-21cnic: Fix parity error code conflictMichael Chan
The recently added parity error handling used an error code that was already defined for a different error. This could lead to bnx2x firmware assert. We need to fix this with new error codes that are defined for parity error only. Signed-off-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-19[SCSI] bnx2i: Fixed the override of the error_mask module paramEddie Wai
The error_mask module param overrides has a bug which prevented the new module param values to take effect. Also changed the type attribute of the error_mask1/2 module params from int to uint to allow the MSB to be set. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Anil Veerabhadrappa <anilgv@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] bnx2i: use kthread_create_on_node()Eric Dumazet
bnx2i_percpu_thread_create() create per cpu kthread, and should use proper NUMA aware API. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-01-03switch ->is_visible() to returning umode_tAl Viro
2011-12-14[SCSI] bnx2i: Fixed kernel panic caused by unprotected task->sc->request derefEddie Wai
During session recovery, the conn_stop call will trigger a flush to all outstanding SCSI cmds in the xmit queue. This will set all outstanding task->sc to NULL prior to the session_teardown call which frees the task memory. In the bnx2i SCSI response processing path, only the task was being checked for NULL under the session lock before the task->sc->request dereferencing. If there are outstanding SCSI cmd responses pending for process, the following kernel panic can be exposed where task->sc was found to be NULL. Call Trace: [ 69.720205] [<ffffffffa040d0d0>] bnx2i_process_new_cqes+0x290/0x3c0 [bnx2i] [ 69.804289] [<ffffffffa040d233>] bnx2i_fastpath_notification+0x33/0xa0 [bnx2 i] [ 69.891490] [<ffffffffa040d37b>] bnx2i_indicate_kcqe+0xdb/0x330 [bnx2i] [ 69.971427] [<ffffffffa03eac5e>] service_kcqes+0x16e/0x1d0 [cnic] [ 70.045132] [<ffffffffa03eacea>] cnic_service_bnx2x_kcq+0x2a/0x50 [cnic] [ 70.126105] [<ffffffffa03ead53>] cnic_service_bnx2x_bh+0x43/0x140 [cnic] [ 70.207081] [<ffffffff81060676>] tasklet_action+0x66/0x110 [ 70.273521] [<ffffffff8106025f>] __do_softirq+0xef/0x220 [ 70.337887] [<ffffffff81447ebc>] call_softirq+0x1c/0x30 This patch adds the !task->sc check and also protects the sc dereferencing under the session lock. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-10-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (204 commits) [SCSI] qla4xxx: export address/port of connection (fix udev disk names) [SCSI] ipr: Fix BUG on adapter dump timeout [SCSI] megaraid_sas: Fix instance access in megasas_reset_timer [SCSI] hpsa: change confusing message to be more clear [SCSI] iscsi class: fix vlan configuration [SCSI] qla4xxx: fix data alignment and use nl helpers [SCSI] iscsi class: fix link local mispelling [SCSI] iscsi class: Replace iscsi_get_next_target_id with IDA [SCSI] aacraid: use lower snprintf() limit [SCSI] lpfc 8.3.27: Change driver version to 8.3.27 [SCSI] lpfc 8.3.27: T10 additions for SLI4 [SCSI] lpfc 8.3.27: Fix queue allocation failure recovery [SCSI] lpfc 8.3.27: Change algorithm for getting physical port name [SCSI] lpfc 8.3.27: Changed worst case mailbox timeout [SCSI] lpfc 8.3.27: Miscellanous logic and interface fixes [SCSI] megaraid_sas: Changelog and version update [SCSI] megaraid_sas: Add driver workaround for PERC5/1068 kdump kernel panic [SCSI] megaraid_sas: Add multiple MSI-X vector/multiple reply queue support [SCSI] megaraid_sas: Add support for MegaRAID 9360/9380 12GB/s controllers [SCSI] megaraid_sas: Clear FUSION_IN_RESET before enabling interrupts ...
2011-09-22Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: MAINTAINERS drivers/net/Kconfig drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c drivers/net/ethernet/broadcom/tg3.c drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c drivers/net/wireless/rt2x00/rt2800usb.c drivers/net/wireless/wl12xx/main.c
2011-08-28[SCSI] bnx2i: Fixed the endian on TTT for NOP out transmissionEddie Wai
The iscsi_nopout task's TTT is defined as __be32 while the DMA memory to the chip is CPU specific. This creates a problem for unsolicited NOP-In responses where the TTT is not the RESERVED tag of 0xFFs. This patch adds a call to be32_to_cpu for the TTT specified. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-08-27[SCSI] iscsi class: sysfs group is_visible callout for iscsi host attrsMike Christie
The iscsi class currently does not support writable sysfs attrs for LLD sysfs settings. This patch converts the iscsi class and driver's host attrs to use the attribute container sysfs group and the sysfs group's is_visible callout to be able to support readable or writable sysfs attrs. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-08-27[SCSI] iscsi class: sysfs group is_visible callout for session attrsMike Christie
The iscsi class currently does not support writable sysfs attrs for LLD sysfs settings. This patch converts the iscsi class and driver's session attrs to use the attribute container sysfs group and the sysfs group's is_visible callout to be able to support readable or writable sysfs attrs. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-08-27[SCSI] iscsi cls: sysfs group is_visible callout for conn attrsMike Christie
The iscsi class currently does not support writable sysfs attrs for LLD sysfs settings. This patch converts the iscsi class and drivers to use the attribute container sysfs group and the sysfs group's is_visible callout to be able to support readable or writable sysfs attrs. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-08-12cnic: Fix select dependencies in bnx2fc/bnx2i Kconfig.David S. Miller
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-10broadcom: Move the Broadcom driversJeff Kirsher
Moves the drivers for Broadcom devices into drivers/net/ethernet/broadcom/ and the necessary Kconfig and Makefile changes. CC: Eilon Greenstein <eilong@broadcom.com> CC: Michael Chan <mchan@broadcom.com> CC: Matt Carlson <mcarlson@broadcom.com> CC: Gary Zambrano <zambrano@broadcom.com> CC: "Maciej W. Rozycki" <macro@linux-mips.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-07-27Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: Convert to DIV_ROUND_UP_SECTOR_T usage for sectors / dev_max_sectors kernel.h: Add DIV_ROUND_UP_ULL and DIV_ROUND_UP_SECTOR_T macro usage iscsi-target: Add iSCSI fabric support for target v4.1 iscsi: Add Serial Number Arithmetic LT and GT into iscsi_proto.h iscsi: Use struct scsi_lun in iscsi structs instead of u8[8] iscsi: Resolve iscsi_proto.h naming conflicts with drivers/target/iscsi
2011-07-25iscsi: Use struct scsi_lun in iscsi structs instead of u8[8]Andy Grover
struct scsi_lun is also just a struct with an array of 8 octets (64 bits) but using it instead in iscsi structs lets us call scsilun_to_int without a cast, and also lets us copy it using assignment, instead of memcpy(). Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-25iscsi: Resolve iscsi_proto.h naming conflicts with drivers/target/iscsiNicholas Bellinger
This patch renames the following iscsi_proto.h structures to avoid namespace issues with drivers/target/iscsi/iscsi_target_core.h: *) struct iscsi_cmd -> struct iscsi_scsi_req *) struct iscsi_cmd_rsp -> struct iscsi_scsi_rsp *) struct iscsi_login -> struct iscsi_login_req This patch includes useful ISCSI_FLAG_LOGIN_[CURRENT,NEXT]_STAGE*, and ISCSI_FLAG_SNACK_TYPE_* definitions used by iscsi_target_mod, and fixes the incorrect definition of struct iscsi_snack to following RFC-3720 Section 10.16. SNACK Request. Also, this patch updates libiscsi, iSER, be2iscsi, and bn2xi to use the updated structure definitions in a handful of locations. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
2011-07-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (77 commits) [SCSI] fix crash in scsi_dispatch_cmd() [SCSI] sr: check_events() ignore GET_EVENT when TUR says otherwise [SCSI] bnx2i: Fixed kernel panic due to illegal usage of sc->request->cpu [SCSI] bfa: Update the driver version to 3.0.2.1 [SCSI] bfa: Driver and BSG enhancements. [SCSI] bfa: Added support to query PHY. [SCSI] bfa: Added HBA diagnostics support. [SCSI] bfa: Added support for flash configuration [SCSI] bfa: Added support to obtain SFP info. [SCSI] bfa: Added support for CEE info and stats query. [SCSI] bfa: Extend BSG interface. [SCSI] bfa: FCS bug fixes. [SCSI] bfa: DMA memory allocation enhancement. [SCSI] bfa: Brocade-1860 Fabric Adapter vHBA support. [SCSI] bfa: Brocade-1860 Fabric Adapter PLL init fixes. [SCSI] bfa: Added Fabric Assigned Address(FAA) support [SCSI] bfa: IOC bug fixes. [SCSI] bfa: Enable ASIC block configuration and query. [SCSI] bnx2i: Updated copyright and bump version [SCSI] bnx2i: Modified to skip CNIC registration if iSCSI is not supported ... Fix up some trivial conflicts in: - drivers/scsi/bnx2fc/{bnx2fc.h,bnx2fc_fcoe.c}: Crazy broadcom version number conflicts - drivers/target/tcm_fc/tfc_cmd.c Just trivial cleanups done on adjacent lines
2011-07-21[SCSI] bnx2i: Fixed kernel panic due to illegal usage of sc->request->cpuEddie Wai
A kernel panic was observed when passing the sc->request->cpu = -1 to retrieve the per_cpu variable pointer: #0 [ffff880011203960] machine_kexec at ffffffff81022bc3 #1 [ffff8800112039b0] crash_kexec at ffffffff81088630 #2 [ffff880011203a80] __die at ffffffff8139ea20 #3 [ffff880011203aa0] no_context at ffffffff8102f3a7 #4 [ffff880011203ae0] __bad_area_nosemaphore at ffffffff8102f665 #5 [ffff880011203ba0] retint_signal at ffffffff8139dd1f #6 [ffff880011203cc8] bnx2i_indicate_kcqe at ffffffffa03dc4f2 #7 [ffff880011203da8] service_kcqes at ffffffffa03cb04f #8 [ffff880011203e68] cnic_service_bnx2x_kcq at ffffffffa03cb14a #9 [ffff880011203e88] cnic_service_bnx2x_bh at ffffffffa03cb1b3 The problem lies in the slow path sg_io (and perhaps sg_scsi_ioctl) call to blk_get_request->get_request/wait->blk_alloc_request->blk_rq_init which re-initializes the request->cpu to -1. There is no assignment for cpu from that to the request_fn call to low level drivers. When this happens, the sc->request->cpu will be using the init value of -1. This will create a kernel panic when it hits bnx2i because the code refers it to get the per_cpu variables ptr. This change is to put in a guard against that and also for cases when bio affinity/queue completion to the same cpu is not enabled. In those cases, the request->cpu will remain a -1 also. This bug was created from commit: b5cf6b63f73abdc051035f0050b367beeb2ef94c For the case when the blk layer did not setup the request->cpu, bnx2i will complete the sc with the current CPU of the thread. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-21cnic: Add VLAN ID as a parameter during netevent upcallMichael Chan
The bnx2fc driver needs to handle netdev events on VLAN devices. Signed-off-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-29[SCSI] bnx2i: Updated copyright and bump versionEddie Wai
Bumped version from 2.6.2.3 to 2.7.0.3 Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] bnx2i: Modified to skip CNIC registration if iSCSI is not supportedEddie Wai
The init routine will now examine the cnic->max_iscsi_conn variable before registering to CNIC during ulp_init. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] bnx2i: Added the use of kthreads to handle SCSI cmd completionEddie Wai
This patch breaks the SCSI cmd completion into two parts: 1. The bh will allocate and queued work to the cmd specific CPU IO completion kthread. The CPU for the cmd is from the sc->request->cpu. 2. The CPU specific IO completion kthread will call the scsi_cmd_resp routine to do the actual cmd completion. In the normal case, these IO completion kthreads should complete before the blk IO times out at 60s. However, in the case when these kthreads are blocked for whatever reason and exceeded the timeout, the call to conn_destroy will have to iterate and exhaust all related work in the percpu work list for all online CPUs. This will guarantee the protection of the work->session and conn pointers before they get freed. Also modified the event coalescing formula to have at least the event_coal_min outstanding cmds in the pipeline so the SCSI producer would not get underrun. Also changed the following SCSI parameters: - can_queue from 1024 to 2048 - cmds_per_lun from 24 to 128 Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Benjamin Li <benli@broadcom.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] iscsi: Use struct scsi_lun in iscsi structs instead of u8[8]Andy Grover
2011-06-21cnic, bnx2i: Add support for new devices - 57800, 57810, and 57840Michael Chan
And change iSCSI RQ doorbell size from 16B to 64B to match new firmware. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-15New 7.0 FW: bnx2x, cnic, bnx2i, bnx2fcVlad Zolotarov
New FW/HSI (7.0): - Added support to 578xx chips - Improved HSI - much less driver's direct access to the FW internal memory needed. New implementation of the HSI handling layer in the bnx2x (bnx2x_sp.c): - Introduced chip dependent objects that have chip independent interfaces for configuration of MACs, multicast addresses, Rx mode, indirection table, fast path queues and function initialization/cleanup. - Objects functionality is based on the private function pointers, which allows not only a per-chip but also PF/VF differentiation while still preserving the same interface towards the driver. - Objects interface is not influenced by the HSI changes which do not require providing new parameters keeping the code outside the bnx2x_sp.c invariant with regard to such HSI chnages. Changes in a CNIC, bnx2fc and bnx2i modules due to the new HSI. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-05-24[SCSI] bnx2i: Optimized the iSCSI offload performanceEddie Wai
Modified the event coalescing code for iSCSI offload to combat both corner cases and optimize performance as follows: 1. Added mechanism to loop back a second time to process any leftover CQEs that was generated by the hardware during the time the driver is busy processing previous CQEs in the bh. This not only helps the performance but also fixes the corner case when no more CQEs are being generated in the pipeline; so those leftover CQEs will get a a chance to be processed. 2. Added ARM_CQE_FP to distinguish between fast path arming versus slow path arming. This change will guarantee that the CQEs will always get a chance to be re-armed during fast path completions. 3. Removed the inline event coalescing division for perf optimization. Also fixed a division-by-zero error when the event_coal_div module param was set to 0. 4. Changed the default SQ WQEs size from 256 to 128 to match chip default. 5. Changed the cmd_per_lun from 32 to 24. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-05-24[SCSI] bnx2i: Updated the connection shutdown/cleanup timeoutEddie Wai
Modified the 10s wait time for inflight offload connections to advance to the next state to 2s based on test result. Modified the 20s shutdown timeout to 30s based on test result. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Cc: stable@kernel.org Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-05-24[SCSI] bnx2i: Fixed packet error created when the sq_size is set to 16Eddie Wai
The number of chip's internal command cell, which is use to generate SCSI cmd packets to the target, was not initialized correctly by the driver when the sq_size is changed from the default 128. This, in turn, will create a problem where the chip's transmit pipe will erroneously reuse an old command cell that is no longer valid. The fix is to correctly initialize the chip's command cell upon setup. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Cc: stable@kernel.org Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-02-24[SCSI] bnx2i: fix null ptr ref in conn get paramMike Christie
bnx2i has some checks to try and make sure the ep is not destroyed while the addr/port is getting read. However, if after this check: if (!(bnx2i_conn && bnx2i_conn->ep && bnx2i_conn->ep->hba)) goto out; bnx2i_conn->ep is cleared by ep_disconnect then we will oops. This patches fixes the problem by having the driver use the get_ep_param callback instead of get_conn_param. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Updated to version 2.6.2.3Eddie Wai
Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Added iSCSI text pdu support for iSCSI offloadEddie Wai
This is part of an effort to support send target discovery via the iSCSI offload path. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Added jumbo MTU support for the no shost caseEddie Wai
For scenarios where the shost is not being passed to bnx2i for the iSCSI offload connection request, the code would consult the routing table to select the CNIC device. This code path will erroneously error out if the corresponding L2 interface's MTU has been setup to > 1500. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Added support for the 57712(E) devicesEddie Wai
Moved all PCI_DEVICE_ID_NX2_57712(E) definitions to pci_ids.h Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Michael Chan <mchan@broadcom.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Added handling for unsupported iSCSI offload hbaEddie Wai
The hba will now be unregistered and freed when iSCSI offload is not supported by the NIC. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Fixed the 32-bit swapping of the LUN field for nopouts for 5771XEddie Wai
Fixed a bug where the 64-bit LUN field for nopouts were 32-bit swapped. This only pertains to 5771X devices. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Allow ep CONNECT_FAILED condition to go through proper cleanupEddie Wai
Allow CNIC to go through the proper cleanup procedure for an endpoint which failed to connect. Proper cleanup is necessary for the chip to reset back to the initial state for the offloaded endpoint. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-24[SCSI] bnx2i: Added reconnect fix connecting against Lefthand targetsEddie Wai
The nopout's reserved field was not being initialized to zero before being reused. Stale CDB values from previous SCSI cmds of the same BHS offset was the cause of the disconnection initiated by the Lefthand target. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (147 commits) [SCSI] arcmsr: fix write to device check [SCSI] lpfc: lower stack use in lpfc_fc_frame_check [SCSI] eliminate an unnecessary local variable from scsi_remove_target() [SCSI] libiscsi: use bh locking instead of irq with session lock [SCSI] libiscsi: do not take host lock in queuecommand [SCSI] be2iscsi: fix null ptr when accessing task hdr [SCSI] be2iscsi: fix gfp use in alloc_pdu [SCSI] libiscsi: add more informative failure message during iscsi scsi eh [SCSI] gdth: Add missing call to gdth_ioctl_free [SCSI] bfa: remove unused defintions and misc cleanups [SCSI] bfa: remove inactive functions [SCSI] bfa: replace bfa_assert with WARN_ON [SCSI] qla2xxx: Use sg_next to fetch next sg element while walking sg list. [SCSI] qla2xxx: Fix to avoid recursive lock failure during BSG timeout. [SCSI] qla2xxx: Remove code to not reset ISP82xx on failure. [SCSI] qla2xxx: Display mailbox register 4 during 8012 AEN for ISP82XX parts. [SCSI] qla2xxx: Don't perform a BIG_HAMMER if Get-ID (0x20) mailbox command fails on CNAs. [SCSI] qla2xxx: Remove redundant module parameter permission bits [SCSI] qla2xxx: Add sysfs node for displaying board temperature. [SCSI] qla2xxx: Code cleanup to remove unwanted comments and code. ...
