path: root/drivers/scsi/bnx2fc
2017-09-07Merge branch 'fixes' into miscJames Bottomley
2017-08-25scsi: bnx2fc: remove obsolete bnx2fc_eh_host_reset() definitionHannes Reinecke
Never used anywhere. Signed-off-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-07-26scsi: bnx2fc: Simplify CPU hotplug codeThomas Gleixner
The CPU hotplug related code of this driver can be simplified by: 1) Consolidating the callbacks into a single state. The CPU thread can be torn down on the CPU which goes offline. There is no point in delaying that to the CPU dead state 2) Let the core code invoke the online/offline callbacks and remove the extra for_each_online_cpu() loops. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-07-26scsi: bnx2fc: Prevent recursive cpuhotplug lockingThomas Gleixner
The BNX2FC module init/exit code installs/removes the hotplug callbacks with the cpu hotplug lock held. This worked with the old CPU locking implementation which allowed recursive locking, but with the new percpu rwsem based mechanism this is not longer allowed. Use the _cpuslocked() variants to fix this. Reported-by: kernel test robot <fengguang.wu@intel.com> Acked-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-07-26scsi: bnx2fc: Plug CPU hotplug raceThomas Gleixner
bnx2fc_process_new_cqes() has protection against CPU hotplug, which relies on the per cpu thread pointer. This protection is racy because it happens only partially with the per cpu fp_work_lock held. If the CPU is unplugged after the lock is dropped, the wakeup code can dereference a NULL pointer or access freed and potentially reused memory. Restructure the code so the thread check and wakeup happens with the fp_work_lock held. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-07-06Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is mostly updates of the usual suspects: lpfc, qla2xxx, bnx2fc, qedf, hpsa, hisi_sas, smartpqi, cxlflash, aacraid, csiostor along with a host of minor and miscellaneous changes" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (276 commits) qla2xxx: Fix NVMe entry_type for iocb packet on BE system scsi: qla2xxx: avoid unused-function warning scsi: snic: fix a couple of spelling mistakes/typos scsi: qla2xxx: fix a bunch of typos and spelling mistakes scsi: lpfc: don't double count abort errors scsi: lpfc: spin_lock_irq() is not nestable scsi: hisi_sas: optimise DMA slot memory scsi: ibmvfc: constify dev_pm_ops structures. scsi: ibmvscsi: constify dev_pm_ops structures. scsi: cxlflash: Update debug prints in reset handlers scsi: cxlflash: Update send_tmf() parameters scsi: cxlflash: Avoid double free of character device scsi: Add STARGET_CREATED_REMOVE state to scsi_target_state scsi: ses: do not add a device to an enclosure if enclosure_add_links() fails. scsi: ufs: flush eh_work when eh_work scheduled. scsi: qla2xxx: Protect access to qpair members with qpair->qp_lock scsi: sun_esp: fix device reference leaks scsi: fnic: changing queue command to return result DID_IMM_RETRY when rport is init scsi: fnic: correct speed display and add support for 25,40 and 100G scsi: fnic: added timestamp reporting in fnic debug stats ...
2017-06-27scsi: bnx2fc: Update version number to 2.11.8.Chad Dupuis
Signed-off-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: bnx2fc: Make rport_terminate_io callback a NOOP.Chad Dupuis
Do not call the stock libfc terminate rport i/o handler so we won't reset the libfc exchange manager and kill any outstanding discovery requests. Signed-off-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: bnx2fc: If IO is still in cleanup then do not return to SCSI layer.Chad Dupuis
In eh_abort, driver is calling scsi->done() for a IO for which cleanup is pending. As the IO is outstanding with the firmware, it may do DMA associated with the IO. This may lead to heap corruption. Do not complete the IO for which cleanup is still pending. Return failure from eh_abort and let the SCSI-ml retry the IO. Signed-off-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: bnx2fc: Adjust bnx2fc_npiv_create_vports for WWNNs from NVRAM that are ↵Chad Dupuis
zero. Some vports addresses stored in NVRAM may have zero for the WWNN. Adjust the WWNN that we'll use to be the same as the WWPN. Signed-off-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: bnx2fc: Update copyright for 2017.Chad Dupuis
2017-06-27scsi: bnx2fc: Check for connection offload before sending RRQ.Chad Dupuis
If the connection is not offloaded then the backpointers from the tgt pointer are undefined. Signed-off-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: bnx2fc: Add filters to the non-offload FCoE receive path.Chad Dupuis
Add the following filters to bnx2fc_recv_frame(): 1. Filter out invalid packets - eth->dest_mac[3] matches FC frame's D_ID 2. Filter out packets that are not from our connected target - In FIP_ST_ENABLED mode - eth->src_mac matches fcoe_ctlr->dest_addr 3. Filter out packets where if d_id of the packet doesn't belong to the device when one is already assigned a port_id, only then this packet is dropped Signed-off-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-16networking: make skb_put & friends return void pointersJohannes Berg
It seems like a historic accident that these return unsigned char *, and in many places that means casts are required, more often than not. Make these functions (skb_put, __skb_put and pskb_put) return void * and remove all the casts across the tree, adding a (u8 *) cast only where the unsigned char pointer was used directly, all done with the following spatch: @@ expression SKB, LEN; typedef u8; identifier fn = { skb_put, __skb_put }; @@ - *(fn(SKB, LEN)) + *(u8 *)fn(SKB, LEN) @@ expression E, SKB, LEN; identifier fn = { skb_put, __skb_put }; type T; @@ - E = ((T *)(fn(SKB, LEN))) + E = fn(SKB, LEN) which actually doesn't cover pskb_put since there are only three users overall. A handful of stragglers were converted manually, notably a macro in drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many instances in net/bluetooth/hci_sock.c. In the former file, I also had to fix one whitespace problem spatch introduced. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-05-24scsi: bnx2fc: fix race condition in bnx2fc_get_host_stats()Maurizio Lombardi
If multiple tasks attempt to read the stats, it may happen that the start_req_done completion is re-initialized while still being used by another task, causing a list corruption. This patch fixes the bug by adding a mutex to serialize the calls to bnx2fc_get_host_stats(). WARNING: at lib/list_debug.c:48 list_del+0x6e/0xa0() (Not tainted) Hardware name: PowerEdge R820 list_del corruption. prev->next should be ffff882035627d90, but was ffff884069541588 Pid: 40267, comm: perl Not tainted 2.6.32-642.3.1.el6.x86_64 #1 Call Trace: [<ffffffff8107c691>] ? warn_slowpath_common+0x91/0xe0 [<ffffffff8107c796>] ? warn_slowpath_fmt+0x46/0x60 [<ffffffff812ad16e>] ? list_del+0x6e/0xa0 [<ffffffff81547eed>] ? wait_for_common+0x14d/0x180 [<ffffffff8106c4a0>] ? default_wake_function+0x0/0x20 [<ffffffff81547fd3>] ? wait_for_completion_timeout+0x13/0x20 [<ffffffffa05410b1>] ? bnx2fc_get_host_stats+0xa1/0x280 [bnx2fc] [<ffffffffa04cf630>] ? fc_stat_show+0x90/0xc0 [scsi_transport_fc] [<ffffffffa04cf8b6>] ? show_fcstat_tx_frames+0x16/0x20 [scsi_transport_fc] [<ffffffff8137c647>] ? dev_attr_show+0x27/0x50 [<ffffffff8113b9be>] ? __get_free_pages+0xe/0x50 [<ffffffff812170e1>] ? sysfs_read_file+0x111/0x200 [<ffffffff8119a305>] ? vfs_read+0xb5/0x1a0 [<ffffffff8119b0b6>] ? fget_light_pos+0x16/0x50 [<ffffffff8119a651>] ? sys_read+0x51/0xb0 [<ffffffff810ee1fe>] ? __audit_syscall_exit+0x25e/0x290 [<ffffffff8100b0d2>] ? system_call_fastpath+0x16/0x1b Signed-off-by: Maurizio Lombardi <mlombard@redhat.com> Acked-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/signal.h> We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/signal.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Support TX_RING in AF_PACKET TPACKET_V3 mode, from Sowmini Varadhan. 2) Simplify classifier state on sk_buff in order to shrink it a bit. From Willem de Bruijn. 3) Introduce SIPHASH and it's usage for secure sequence numbers and syncookies. From Jason A. Donenfeld. 4) Reduce CPU usage for ICMP replies we are going to limit or suppress, from Jesper Dangaard Brouer. 5) Introduce Shared Memory Communications socket layer, from Ursula Braun. 6) Add RACK loss detection and allow it to actually trigger fast recovery instead of just assisting after other algorithms have triggered it. From Yuchung Cheng. 7) Add xmit_more and BQL support to mvneta driver, from Simon Guinot. 8) skb_cow_data avoidance in esp4 and esp6, from Steffen Klassert. 9) Export MPLS packet stats via netlink, from Robert Shearman. 10) Significantly improve inet port bind conflict handling, especially when an application is restarted and changes it's setting of reuseport. From Josef Bacik. 11) Implement TX batching in vhost_net, from Jason Wang. 12) Extend the dummy device so that VF (virtual function) features, such as configuration, can be more easily tested. From Phil Sutter. 13) Avoid two atomic ops per page on x86 in bnx2x driver, from Eric Dumazet. 14) Add new bpf MAP, implementing a longest prefix match trie. From Daniel Mack. 15) Packet sample offloading support in mlxsw driver, from Yotam Gigi. 16) Add new aquantia driver, from David VomLehn. 17) Add bpf tracepoints, from Daniel Borkmann. 18) Add support for port mirroring to b53 and bcm_sf2 drivers, from Florian Fainelli. 19) Remove custom busy polling in many drivers, it is done in the core networking since 4.5 times. From Eric Dumazet. 20) Support XDP adjust_head in virtio_net, from John Fastabend. 21) Fix several major holes in neighbour entry confirmation, from Julian Anastasov. 22) Add XDP support to bnxt_en driver, from Michael Chan. 23) VXLAN offloads for enic driver, from Govindarajulu Varadarajan. 24) Add IPVTAP driver (IP-VLAN based tap driver) from Sainath Grandhi. 25) Support GRO in IPSEC protocols, from Steffen Klassert" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1764 commits) Revert "ath10k: Search SMBIOS for OEM board file extension" net: socket: fix recvmmsg not returning error from sock_error bnxt_en: use eth_hw_addr_random() bpf: fix unlocking of jited image when module ronx not set arch: add ARCH_HAS_SET_MEMORY config net: napi_watchdog() can use napi_schedule_irqoff() tcp: Revert "tcp: tcp_probe: use spin_lock_bh()" net/hsr: use eth_hw_addr_random() net: mvpp2: enable building on 64-bit platforms net: mvpp2: switch to build_skb() in the RX path net: mvpp2: simplify MVPP2_PRS_RI_* definitions net: mvpp2: fix indentation of MVPP2_EXT_GLOBAL_CTRL_DEFAULT net: mvpp2: remove unused register definitions net: mvpp2: simplify mvpp2_bm_bufs_add() net: mvpp2: drop useless fields in mvpp2_bm_pool and related code net: mvpp2: remove unused 'tx_skb' field of 'struct mvpp2_tx_queue' net: mvpp2: release reference to txq_cpu[] entry after unmapping net: mvpp2: handle too large value in mvpp2_rx_time_coal_set() net: mvpp2: handle too large value handling in mvpp2_rx_pkts_coal_set() net: mvpp2: remove useless arguments in mvpp2_rx_{pkts, time}_coal_set ...
2017-02-21Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This update includes the usual round of major driver updates (ncr5380, ufs, lpfc, be2iscsi, hisi_sas, storvsc, cxlflash, aacraid, megaraid_sas, ...). There's also an assortment of minor fixes and the major update of switching a bunch of drivers to pci_alloc_irq_vectors from Christoph" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (188 commits) scsi: megaraid_sas: handle dma_addr_t right on 32-bit scsi: megaraid_sas: array overflow in megasas_dump_frame() scsi: snic: switch to pci_irq_alloc_vectors scsi: megaraid_sas: driver version upgrade scsi: megaraid_sas: Change RAID_1_10_RMW_CMDS to RAID_1_PEER_CMDS and set value to 2 scsi: megaraid_sas: Indentation and smatch warning fixes scsi: megaraid_sas: Cleanup VD_EXT_DEBUG and SPAN_DEBUG related debug prints scsi: megaraid_sas: Increase internal command pool scsi: megaraid_sas: Use synchronize_irq to wait for IRQs to complete scsi: megaraid_sas: Bail out the driver load if ld_list_query fails scsi: megaraid_sas: Change build_mpt_mfi_pass_thru to return void scsi: megaraid_sas: During OCR, if get_ctrl_info fails do not continue with OCR scsi: megaraid_sas: Do not set fp_possible if TM capable for non-RW syspdIO, change fp_possible to bool scsi: megaraid_sas: Remove unused pd_index from megasas_build_ld_nonrw_fusion scsi: megaraid_sas: megasas_return_cmd does not memset IO frame to zero scsi: megaraid_sas: max_fw_cmds are decremented twice, remove duplicate scsi: megaraid_sas: update can_queue only if the new value is less scsi: megaraid_sas: Change max_cmd from u32 to u16 in all functions scsi: megaraid_sas: set pd_after_lb from MR_BuildRaidContext and initialize pDevHandle to MR_DEVHANDLE_INVALID scsi: megaraid_sas: latest controller OCR capability from FW before sending shutdown DCMD ...
2017-02-06scsi: remove eh_timed_out methods in the transport templateChristoph Hellwig
Instead define the timeout behavior purely based on the host_template eh_timed_out method and wire up the existing transport implementations in the host templates. This also clears up the confusion that the transport template method overrides the host template one, so some drivers have to re-override the transport template one. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-02-06net-next: treewide use is_vlan_dev() helper function.Parav Pandit
This patch makes use of is_vlan_dev() function instead of flag comparison which is exactly done by is_vlan_dev() helper function. Signed-off-by: Parav Pandit <parav@mellanox.com> Reviewed-by: Daniel Jurgens <danielj@mellanox.com> Acked-by: Stephen Hemminger <stephen@networkplumber.org> Acked-by: Jon Maxwell <jmaxwell37@gmail.com> Acked-by: Johannes Thumshirn <jth@kernel.org> Acked-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-01-14locking/atomic, kref: Add kref_read()Peter Zijlstra
Since we need to change the implementation, stop exposing internals. Provide kref_read() to read the current reference count; typically used for debug messages. Kills two anti-patterns: atomic_read(&kref->refcount) kref->refcount.counter Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-12-25scsi/bnx2fc: Convert to hotplug state machineSebastian Andrzej Siewior
Install the callbacks via the state machine. No functional change. This is the minimal fixup so we can remove the hotplug notifier mess completely. The real rework of this driver to use work queues is still stuck in review/testing on the SCSI mailing list. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com> Cc: linux-scsi@vger.kernel.org Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Chad Dupuis <chad.dupuis@qlogic.com> Cc: QLogic-Storage-Upstream@qlogic.com Cc: Johannes Thumshirn <jth@kernel.org> Cc: Christoph Hellwig <hch@lst.de> Link: http://lkml.kernel.org/r/20161221192111.757309869@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-11-08scsi: libfc: Remove fc_rport_init()Hannes Reinecke
Function is empty now and can be removed. Signed-off-by: Hannes Reinecke <hare@suse.com> Acked-by: Johannes Thumshirn <jth@kernel.org> Reviewed-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-08scsi: libfc: Replace ->rport_logoff callback with function callHannes Reinecke
The ->rport_logoff callback only ever had one implementation, so we can as well call it directly and drop the callback. Signed-off-by: Hannes Reinecke <hare@suse.com> Acked-by: Johannes Thumshirn <jth@kernel.org> Reviewed-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-09-09scsi: bnx2fc: Mark symbols static where possibleBaoyou Xie
We get a few warnings when building kernel with W=1: drivers/scsi/bnx2fc/bnx2fc_els.c:257:6: warning: no previous prototype for 'bnx2fc_srr_compl' [-Wmissing-prototypes] drivers/scsi/bnx2fc/bnx2fc_els.c:367:6: warning: no previous prototype for 'bnx2fc_rec_compl' [-Wmissing-prototypes] drivers/scsi/bnx2fc/bnx2fc_fcoe.c:628:5: warning: no previous prototype for 'bnx2fc_percpu_io_thread' [-Wmissing-prototypes] drivers/scsi/bnx2fc/bnx2fc_fcoe.c:1413:26: warning: no previous prototype for 'bnx2fc_interface_create' [-Wmissing-prototypes] drivers/scsi/bnx2fc/bnx2fc_hwi.c:997:21: warning: no previous prototype for 'bnx2fc_alloc_work' [-Wmissing-prototypes] drivers/scsi/bnx2fc/bnx2fc_io.c:1082:5: warning: no previous prototype for 'bnx2fc_abts_cleanup' [-Wmissing-prototypes] .... In fact, these functions are only used in the file in which they are declared and don't need a declaration, but can be made static. so this patch marks these functions with 'static'. Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-09-09scsi: bnx2fc: Simplify codeChristophe JAILLET
Calling 'list_splice' followed by 'INIT_LIST_HEAD' is equivalent to 'list_splice_init'. This has been spotted with the following coccinelle script: ///// @@ expression y,z; @@ - list_splice(y,z); - INIT_LIST_HEAD(y); + list_splice_init(y,z); Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Acked-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-13fcoe: use enum for fip_modeHannes Reinecke
The FIP mode is independent on the FIP state machine, so use a separate enum for that instead of overloading it with state machine values. Signed-off-by: Hannes Reinecke <hare@suse.com> Acked-by: Johannes Thumshirn <jth@kernel.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-12fcoe: convert to kworkerSebastian Andrzej Siewior
The driver creates its own per-CPU threads which are updated based on CPU hotplug events. It is also possible to use kworkers and remove some of the kthread infrastrucure. The code checked ->thread to decide if there is an active per-CPU thread. By using the kworker infrastructure this is no longer possible (or required). The thread pointer is saved in `kthread' instead of `thread' so anything trying to use thread is caught by the compiler. Currently only the bnx2fc driver is using struct fcoe_percpu_s and the kthread member. After a CPU went offline, we may still enqueue items on the "offline" CPU. This isn't much of a problem. The work will be done on a random CPU. The allocated crc_eof_page page won't be cleaned up. It is probably expected that the CPU comes up at some point so it should not be a problem. The crc_eof_page memory is released of course once the module is removed. This patch was only compile-tested due to -ENODEV. Cc: Vasu Dev <vasu.dev@intel.com> Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Cc: fcoe-devel@open-fcoe.org Cc: linux-scsi@vger.kernel.org Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Tested-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-12bnx2fc: replace printk() with BNX2FC_IO_DBG()Maurizio Lombardi
The "fcp_rsp_code = %d" message isn't an error, it's meant to be informative only. This patch prevents a flood of such messages in some situations. Signed-off-by: Maurizio Lombardi <mlombard@redhat.com> Tested-by: Laurence Oberman <loberman@redhat.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Acked-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-15bnx2fc: Update version number to 2.10.3.Chad Dupuis
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-15bnx2fc: Check sc_cmd device and host pointer before returning the command to ↵Chad Dupuis
the mid-layer. When we are in connection recovery and the internal command timer on a request pops, either the scsi_cmnd->device or scsi_cmnd->device->host back pointers may be NULL as the device that the command that the request was submitted on may have been subsequently reaped due to the connection recovery. This can cause one or both of the pointers above to be NULL and cause a system crash if we try to return the command to the midlayer. Instead, double check the pointers before the return to the midlayer so as to prevent the crash and let the upper layers finish the session recovery and rediscover the device. Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-15bnx2fc: Print netdev device name when FCoE is successfully initialized.Chad Dupuis
2016-04-15bnx2fc: Print when we send a fip keep alive.Chad Dupuis
2016-04-15bnx2fc: Add driver tunables.Joe Carnuccio
Per customer request, add the following driver tunables: o devloss_tmo o max_luns o queue_depth o tm_timeout tm_timeout is set per scsi_host in /sys/class/scsi_host/hostX/tm_timeout. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-02-23bnx2fc: bnx2fc_eh_abort(): fix wrong return code.Maurizio Lombardi
If the link is not ready, the bnx2fc_eh_abort() function should return FAILED. Signed-off-by: Maurizio Lombardi <mlombard@redhat.com> Reviewed-by: Ewan Milne <emilne@redhat.com> Acked-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-02-23bnx2fc: Show information about log levels in 'modinfo'Jose Castillo
This patch adds the information of the different values that can be used in the module parameter 'debug_logging', as it is shown below: $ modinfo bnx2fc [...] parm: debug_logging:Option to enable extended logging, Default is 0 - no logging. 0x01 - SCSI cmd error, cleanup. 0x02 - Session setup, cleanup, etc. 0x04 - lport events, link, mtu, etc. 0x08 - ELS logs. 0x10 - fcoe L2 fame related logs. 0xff - LOG all messages. (int) Signed-off-by: Jose Castillo <jcastillo@redhat.com> Acked-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-09bnx2fc: Update version number to 2.9.6.Chad Dupuis
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Tomas Henzl <thenzl@redhat.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-11-09bnx2fc: Remove explicit logouts.Chad Dupuis
Explicit logouts from bnx2fc were causing race conditions in either returning stale SCSI commands or not allowing a target to log back in. Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Tomas Henzl <thenzl@redhat.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-11-09bnx2fc: Fix FCP RSP residual parsing.Chad Dupuis
2015-11-09bnx2fc: Set ELS transfer length correctly for middle path commands.Chad Dupuis
2015-11-09bnx2fc: Remove 'NetXtreme II' from source files.Chad Dupuis
2015-11-09bnx2fc: Update copyright for 2015.Chad Dupuis
2015-11-09scsi: use host wide tags by defaultChristoph Hellwig
This patch changes the !blk-mq path to the same defaults as the blk-mq I/O path by always enabling block tagging, and always using host wide tags. We've had blk-mq available for a few releases so bugs with this mode should have been ironed out, and this ensures we get better coverage of over tagging setup over different configs. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <axboe@kernel.dk> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-11-09bnx2fc: reduce stack usage in __bnx2fc_enableArnd Bergmann
When the bnx2fc driver was changed to read the npiv table from nvram, the stack of the __bnx2fc_enable function gained an additional 1028 byte structure that gcc rightfully warns about: drivers/scsi/bnx2fc/bnx2fc_fcoe.c: In function '__bnx2fc_enable': drivers/scsi/bnx2fc/bnx2fc_fcoe.c:2134:1: warning: the frame size of 1128 bytes is larger than 1024 bytes [-Wframe-larger-than=] In order to avoid a possible kernel stack overflow and to get rid of the warning, this changes the function to use a dynamic allocation of the structure using kzalloc. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 2971ff67bd3 ("bnx2fc: Read npiv table from nvram and create vports.") Acked-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-10-27bnx2fc: Do not log error for netevents that need no actionShirish Pargaonkar
Do not log error for netevents that need no action such as NETDEV_REGISTER 0x0005, NETDEV_CHANGEADDR, and NETDEV_CHANGENAME. It results in logging error messages such as these [ 35.315872] bnx2fc: Unknown netevent 5 [ 35.315935] bnx2fc: Unknown netevent 8 [ 35.353866] bnx2fc: Unknown netevent 10 and generating bug reports. Remove logging this message as an ERROR instead of turning them into either DEBUG or INFO level messages. Signed-off-by: Shirish Pargaonkar <spargaonkar@suse.com> Acked-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-08-06bnx2fc: Read npiv table from nvram and create vports.Joe Carnuccio
Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-18Merge remote-tracking branch 'scsi-queue/drivers-for-3.19' into for-linusJames Bottomley
2014-12-08Merge remote-tracking branch 'scsi-queue/drivers-for-3.19' into for-linusJames Bottomley
Conflicts: drivers/scsi/scsi_debug.c Agreed and tested resolution to a merge problem between a fix in scsi_debug and a driver update Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2014-12-08Merge remote-tracking branch 'scsi-queue/core-for-3.19' into for-linusJames Bottomley
2014-12-04fc: FCP_PTA_SIMPLE is 0Christoph Hellwig
Not need to have an if/else to either assign FCP_PTA_SIMPLE or 0 to a variable. Btw, it seems we really should factor generating a fcp cmnd from a scsi_cmnd into a common helper. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com Reviewed-by: Hannes Reinecke <hare@suse.de>
