path: root/drivers/scsi/atari_scsi.h
2014-11-20atari_scsi: Remove headerFinn Thain
The #defines in atari_scsi.h are intended to influence subsequent #includes in atari_scsi.c. IMHO, that's too convoluted. Remove atari_scsi.h by moving those macro definitions to atari_scsi.c, consistent with other NCR5380 drivers. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20atari_scsi: Convert to platform deviceFinn Thain
Convert atari_scsi to platform device and eliminate scsi_register(). Validate __setup options later on so that module options are checked as well. Remove the comment about the scsi mid-layer disabling the host irq as it is no longer true (AFAICT). Also remove the obsolete slow interrupt stuff (IRQ_TYPE_SLOW == 0 anyway). Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20ncr5380: Remove pointless compiler command line override macrosFinn Thain
Compile-time override of scsi host defaults is pointless for drivers that provide module parameters and __setup options for that. Too many macros make the code hard to read so remove them. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20ncr5380: Cleanup host info() methodsFinn Thain
If the host->info() method is not set, then host->name is used by default. For atari_scsi, that is exactly the same text. So remove the redundant info() method. Keep sun3_scsi.c in line with atari_scsi. Some NCR5380 drivers return an empty string from the info() method (arm/cumana_1.c arm/oak.c mac_scsi.c) while other drivers use the default (dmx3191d dtc.c g_NCR5380.c pas16.c t128.c). Implement a common info() method to replace a lot of duplicated code which the various drivers use to announce the same information. This replaces most of the (deprecated) show_info() output and all of the NCR5380_print_info() output. This also eliminates a bunch of code in g_NCR5380 which just duplicates functionality in the core driver. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20ncr5380: Remove unused macrosFinn Thain
Some macros are never evaluated (i.e. FOO, USLEEP, SCSI2 and USE_WRAPPER; and in some drivers, NCR5380_intr and NCR5380_proc_info). DRIVER_SETUP serves no purpose anymore. Remove these macro definitions. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.de> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-05-28scsi/NCR5380: remove unused macro definitionsFinn Thain
Remove the unused (and divergent) debugging macro definitions from the sun3_NCR5380 and atari_NCR5380 drivers. These drivers have been converted to use the common macros in NCR5380.h. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: Sam Creasey <sammy@sammy.net> Acked-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-05-19m68k/atari - atari_scsi: change abort/reset return codesMichael Schmitz
[Resend of earlier patch - added equivalent changes to sun3 NCR5380 code] The abort/reset lowlevel return codes had changed with the new error SCSI handling - update Atari and Sun3 NCR5380 drivers to reflect this. Change reset handling for Atari to clear queues only, do not attempt to call done() on each command aborted by the reset. The EH code should do that for us. Queues _must_ be cleared, otherwise atari_scsi_bus_reset will not release the ST-DMA lock, deadlocking further error recovery. Update the Sun3 NCR5380 driver as well - the Sun3 driver was derived from the Atari one. Kudos to Finn Thain for the Sun3 part and cleaning up the header files. After the header cleanup, the initio.h include (!) can be dropped from sun3_scsi.h now. Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: Sam Creasey <sammy@sammy.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: James E.J. Bottomley <JBottomley@parallels.com> Cc: linux-scsi@vger.kernel.org Signed-off-by: Christoph Hellwig <hch@lst.de>
2013-04-09atari_scsi: switch to ->show_info()Al Viro
2012-04-22scsi/atari: Make more functions staticGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michael Schmitz <schmitzmic@googlemail.com> Cc: James E.J. Bottomley <JBottomley@parallels.com> Cc: linux-scsi@vger.kernel.org
2007-05-04m68k: Atari SCSI driver compile fixesRoman Zippel
Atari SCSI driver compile fixes Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: Atari SCSI revivalMichael Schmitz
SCSI should be working on a TT (but someone should really try!) but causes trouble on a Falcon (as in: it ate a filesystem of mine) at least when used concurrently with IDE. I have the notion it's because locking of the ST-DMA interrupt by IDE is broken in 2.6 (the IDE driver always complains about trying to release an already-released ST-DMA). Needs more work, but that's on the IDE or m68k interrupt side rather than SCSI. Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
