path: root/drivers/scsi/arm
2010-02-18ARM: 5944/1: scsi: fix timer setup in fas216.cGuennadi Liakhovetski
mod_timer() takes an absolute time and not a delay as its argument. Cc: <stable@kernel.org> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-28Merge branch 'master' into develRussell King
Conflicts: arch/arm/include/asm/elf.h arch/arm/kernel/module.c
2009-03-24[ARM] cumana: Fix a long standing bogonAlan Cox
Should be using strncmp as the data from user space may be unterminated (Bug #8004) Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-11[ARM] dma: Use sensible DMA parameters for Acorn driversRussell King
The hardware supports transfers up to a page boundary per buffer. Currently, we work around that in the DMA code by splitting each buffer up as we run through the scatterlist. Avoid this by telling the block layers about the hardware restriction. Eventually, this will allow us to phase out the splitting code, but not until the old IDE layer allows us to control the value it gives to blk_queue_segment_boundary(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-03[ARM] rpc: acornscsi: update to new style ecard driverRussell King
Update acornscsi as per all the other ecard drivers to use MMIO accessors rather than the obsolete 'pc io' style inb/outb accessors. Use ecard_request_resources()/ecard_release_resources() for easier resource handling, rather than requesting 5 separate regions individually. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] rpc: acornscsi: stop using private __stringify()Russell King
The kernel has its own, so let's use that instead. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] rpc: acornscsi: convert hardware accessors to take 'AS_Host *'Russell King
2008-07-03[ARM] rpc: acornscsi: fixup abort/reset methods, fix build errorsRussell King
Revive the AcornSCSI driver, update it for the replacement command abort and host reset methods, and fix the build errors in acornscsi-io.S. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] rpc: acornscsi: remove unused 'ADDR' macroRussell King
2008-04-07[SCSI] Remove random noop unchecked_isa_dma usersAndi Kleen
Lots of drivers set it to 0. Remove that. Patch should be a nop. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-18[SCSI] fas216: fix up the previous fas216 commitJames Bottomley
Apparently the fix to [SCSI] fas216: Use scsi_eh API for REQUEST_SENSE invocation didn't show up in the final version sent to linus. Correct this omission. Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] fas216: Use scsi_eh API for REQUEST_SENSE invocationBoaz Harrosh
Use new scsi_eh_prep/restor_cmnd() for synchronous REQUEST_SENSE invocation. This also converts the driver to the new accessor based scatterlist implementation. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] arm: convert to accessors and !use_sg cleanupBoaz Harrosh
- convert to accessors and !use_sg cleanup Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Tested-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-31[ARM] Fix an rpc_defconfig regressionRussell King
Fix: CC drivers/scsi/arm/powertec.o In file included from drivers/scsi/arm/powertec.c:29: drivers/scsi/arm/scsi.h: In function 'next_SCp': drivers/scsi/arm/scsi.h:42: error: 'struct scatterlist' has no member named 'page' drivers/scsi/arm/scsi.h: In function 'init_SCp': drivers/scsi/arm/scsi.h:80: error: 'struct scatterlist' has no member named 'page' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-31Remove the arm26 portAdrian Bunk
The arm26 port has been in a state where it was far from even compiling for quite some time. Ian Molton agreed with the removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20[ARM] rpc: update Acorn SCSI drivers to modern ecard interfacesRussell King
2007-05-11[ARM] ecard: add ecardm_iomap() / ecardm_iounmap()Russell King
Add devres ecardm_iomap() and ecardm_iounmap() for Acorn expansion cards. Convert all expansion card drivers to use them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] ecard: add helper function for setting ecard irq opsRussell King
Rather than having every driver fiddle about setting its private IRQ operations and data, provide a helper function to contain this functionality in one place. Arrange to remove the driver-private IRQ operations and data when the device is removed from the driver, and remove the driver private code to do this. This fixes potential problems caused by drivers forgetting to remove these hooks. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-04[ARM] ARM SCSI: Don't try to dma_map_sg too many scatterlist entriesRussell King
An off-by-one bug meant we were always trying to map one too many scatterlist entries. This was mostly harmless prior to the checks going in to consistent_sync(), but now causes the kernel to BUG. Also, powertec.c was missing an assignment to info->ec. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-04[ARM] ARM FAS216: don't modify scsi_cmnd request_bufflenRussell King
SCSI doesn't want drivers to modify request_bufflen, so keep a driver-private copy of this in the scsi_pointer structure instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Adrian Bunk <bunk@stusta.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (54 commits) [SCSI] Initial Commit of qla4xxx [SCSI] raid class: handle component-add errors [SCSI] SCSI megaraid_sas: handle thrown errors [SCSI] SCSI aic94xx: handle sysfs errors [SCSI] SCSI st: fix error handling in module init, sysfs [SCSI] SCSI sd: fix module init/exit error handling [SCSI] SCSI osst: add error handling to module init, sysfs [SCSI] scsi: remove hosts.h [SCSI] scsi: Scsi_Cmnd convertion in aic7xxx_old.c [SCSI] megaraid_sas: sets ioctl timeout and updates version,changelog [SCSI] megaraid_sas: adds tasklet for cmd completion [SCSI] megaraid_sas: prints pending cmds before setting hw_crit_error [SCSI] megaraid_sas: function pointer for disable interrupt [SCSI] megaraid_sas: frame count optimization [SCSI] megaraid_sas: FW transition and q size changes [SCSI] qla2xxx: Update version number to 8.01.07-k2. [SCSI] qla2xxx: Stall mid-layer error handlers while rport is blocked. [SCSI] qla2xxx: Add MODULE_FIRMWARE tags. [SCSI] qla2xxx: Add support for host port state FC transport attribute. [SCSI] qla2xxx: Add support for fabric name FC transport attribute. ...
2006-10-03[SCSI] scsi: Scsi_Cmnd convertion in arm subtreeHenne
Changes the obsolete Scsi_Cmnd to struct scsi_cmnd in the arm subdir of the scsi-subsys. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-06[ARM] Fix Acorn platform SCSI driver build failuresRussell King
SCSI folk forgot to fix up all the uses of 'buffer' before deleting this struct member. Do it for them to rescue the resulting build failures. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-06[ARM] Fix NCR5380-based SCSI card buildRussell King
The NCR5380-based SCSI cards need the SCSI SPI transport selected to build correctly. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-26[PATCH] fix compile regression for a few scsi driversChristoph Hellwig
This fixes three drivers to compile again after my patch that removes the data_cmnd member from struct scsi_cmnd. The fas216 change is trivial, it should have been using ->cmnd all the time. NCR53C9 (which seem to be mostly duplicate driver with esp.c!) is doing something odd, it should only have looked at ->cmnd before not the saved copy that is kept for the error handlers sake. Note that it really should deal with the sync setting themselves but use the generic domain validation code that get this right - but that's for later let's push this simple compile fix for now. And sorry for the late fix for this, I have been busy with OLS and associated activities last week. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] More BUG_ON conversionEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] Remove MODULE_PARMRusty Russell
MODULE_PARM was actually breaking: recent gcc version optimize them out as unused. It's time to replace the last users, which are generally in the most unloved drivers anyway. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[ARM] Remove asm/irq.h includes from ARM driversRussell King
Many ARM drivers do not need to include asm/irq.h - remove this unnecessary include from some ARM drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-15[SCSI] Rename scsi_print_msg to spi_print_msgMatthew Wilcox
Rename scsi_print_msg to spi_print_msg and move its prototype from scsi_dbg.h to scsi_transport_spi.h Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15[SCSI] Move scsi_print_msg to SPI classMatthew Wilcox
scsi_print_msg() is an SPI-specific concept. This patch moves it from constants.c to scsi_transport_spi.c and updates the Kconfig to link in the SPI class for the drivers which use scsi_print_msg(). Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09[SCSI] remove Scsi_Device typedefChristoph Hellwig
2005-11-09[SCSI] remove Scsi_Pointer typedefChristoph Hellwig
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-11-07[PATCH] kfree cleanup: drivers/scsiJesper Juhl
This is the drivers/scsi/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/scsi/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Use sg_set_buf/sg_init_one where applicableDavid Hardeman
This patch uses sg_set_buf/sg_init_one in some places where it was duplicated. Signed-off-by: David Hardeman <david@2gen.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-08-23[PATCH] Kconfig fix (acornscsi)Al Viro
acornscsi had been broken for a long time; marked as such Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/s390/net/qeth_sys.c - ↵Yani Ioannou
drivers/usb/gadget/pxa2xx_udc.c: update device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-17[SCSI] allow sleeping in ->eh_host_reset_handler()Jeff Garzik
2005-06-17[SCSI] Remove no-op implementations of SCSI EH hooksJeff Garzik
Drivers need not implement a hook that returns FAILED, and does nothing else, since the SCSI midlayer code will do that for us. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-18[PATCH] remove old scsi data direction macros
these have been wrappers for the generic dma direction bits since 2.5.x. This patch converts the few remaining drivers and removes the macros. Arjan noticed there's some hunk in here that shouldn't. Updated patch below: Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-18[PATCH] remove outdated print_* functions
We have the scsi_print_* functions in the proper namespace for a long time now and there weren't a lot users left. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
