path: root/drivers/scsi/arm
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-24ARM: ecard: get rid of NO_IRQ madnessRussell King
Get rid of the NO_IRQ madness from Acorn expansion card handling code. Thankfully, are relatively few users of this here, and so it's easy to audit. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-23SCSI: arm fas216: fix missing ';'Russell King
f281233 (SCSI host lock push-down) broke the fas216 build: drivers/scsi/arm/fas216.h: In function 'fas216_noqueue_command': drivers/scsi/arm/fas216.h:354: error: storage class specified for parameter 'fas216_intr' drivers/scsi/arm/fas216.h:356: error: storage class specified for parameter 'fas216_remove' ... Fix it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-18ARM: 5944/1: scsi: fix timer setup in fas216.cGuennadi Liakhovetski
mod_timer() takes an absolute time and not a delay as its argument. Cc: <stable@kernel.org> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-28Merge branch 'master' into develRussell King
Conflicts: arch/arm/include/asm/elf.h arch/arm/kernel/module.c
2009-03-24[ARM] cumana: Fix a long standing bogonAlan Cox
Should be using strncmp as the data from user space may be unterminated (Bug #8004) Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-11[ARM] dma: Use sensible DMA parameters for Acorn driversRussell King
The hardware supports transfers up to a page boundary per buffer. Currently, we work around that in the DMA code by splitting each buffer up as we run through the scatterlist. Avoid this by telling the block layers about the hardware restriction. Eventually, this will allow us to phase out the splitting code, but not until the old IDE layer allows us to control the value it gives to blk_queue_segment_boundary(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-03[ARM] rpc: acornscsi: update to new style ecard driverRussell King
Update acornscsi as per all the other ecard drivers to use MMIO accessors rather than the obsolete 'pc io' style inb/outb accessors. Use ecard_request_resources()/ecard_release_resources() for easier resource handling, rather than requesting 5 separate regions individually. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] rpc: acornscsi: stop using private __stringify()Russell King
The kernel has its own, so let's use that instead. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] rpc: acornscsi: convert hardware accessors to take 'AS_Host *'Russell King
2008-07-03[ARM] rpc: acornscsi: fixup abort/reset methods, fix build errorsRussell King
Revive the AcornSCSI driver, update it for the replacement command abort and host reset methods, and fix the build errors in acornscsi-io.S. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] rpc: acornscsi: remove unused 'ADDR' macroRussell King
2008-04-07[SCSI] Remove random noop unchecked_isa_dma usersAndi Kleen
Lots of drivers set it to 0. Remove that. Patch should be a nop. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-18[SCSI] fas216: fix up the previous fas216 commitJames Bottomley
Apparently the fix to [SCSI] fas216: Use scsi_eh API for REQUEST_SENSE invocation didn't show up in the final version sent to linus. Correct this omission. Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] fas216: Use scsi_eh API for REQUEST_SENSE invocationBoaz Harrosh
Use new scsi_eh_prep/restor_cmnd() for synchronous REQUEST_SENSE invocation. This also converts the driver to the new accessor based scatterlist implementation. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] arm: convert to accessors and !use_sg cleanupBoaz Harrosh
- convert to accessors and !use_sg cleanup Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Tested-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-31[ARM] Fix an rpc_defconfig regressionRussell King
Fix: CC drivers/scsi/arm/powertec.o In file included from drivers/scsi/arm/powertec.c:29: drivers/scsi/arm/scsi.h: In function 'next_SCp': drivers/scsi/arm/scsi.h:42: error: 'struct scatterlist' has no member named 'page' drivers/scsi/arm/scsi.h: In function 'init_SCp': drivers/scsi/arm/scsi.h:80: error: 'struct scatterlist' has no member named 'page' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-31Remove the arm26 portAdrian Bunk
The arm26 port has been in a state where it was far from even compiling for quite some time. Ian Molton agreed with the removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20[ARM] rpc: update Acorn SCSI drivers to modern ecard interfacesRussell King
2007-05-11[ARM] ecard: add ecardm_iomap() / ecardm_iounmap()Russell King
Add devres ecardm_iomap() and ecardm_iounmap() for Acorn expansion cards. Convert all expansion card drivers to use them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] ecard: add helper function for setting ecard irq opsRussell King
Rather than having every driver fiddle about setting its private IRQ operations and data, provide a helper function to contain this functionality in one place. Arrange to remove the driver-private IRQ operations and data when the device is removed from the driver, and remove the driver private code to do this. This fixes potential problems caused by drivers forgetting to remove these hooks. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-04[ARM] ARM SCSI: Don't try to dma_map_sg too many scatterlist entriesRussell King
An off-by-one bug meant we were always trying to map one too many scatterlist entries. This was mostly harmless prior to the checks going in to consistent_sync(), but now causes the kernel to BUG. Also, powertec.c was missing an assignment to info->ec. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-04[ARM] ARM FAS216: don't modify scsi_cmnd request_bufflenRussell King
SCSI doesn't want drivers to modify request_bufflen, so keep a driver-private copy of this in the scsi_pointer structure instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Adrian Bunk <bunk@stusta.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (54 commits) [SCSI] Initial Commit of qla4xxx [SCSI] raid class: handle component-add errors [SCSI] SCSI megaraid_sas: handle thrown errors [SCSI] SCSI aic94xx: handle sysfs errors [SCSI] SCSI st: fix error handling in module init, sysfs [SCSI] SCSI sd: fix module init/exit error handling [SCSI] SCSI osst: add error handling to module init, sysfs [SCSI] scsi: remove hosts.h [SCSI] scsi: Scsi_Cmnd convertion in aic7xxx_old.c [SCSI] megaraid_sas: sets ioctl timeout and updates version,changelog [SCSI] megaraid_sas: adds tasklet for cmd completion [SCSI] megaraid_sas: prints pending cmds before setting hw_crit_error [SCSI] megaraid_sas: function pointer for disable interrupt [SCSI] megaraid_sas: frame count optimization [SCSI] megaraid_sas: FW transition and q size changes [SCSI] qla2xxx: Update version number to 8.01.07-k2. [SCSI] qla2xxx: Stall mid-layer error handlers while rport is blocked. [SCSI] qla2xxx: Add MODULE_FIRMWARE tags. [SCSI] qla2xxx: Add support for host port state FC transport attribute. [SCSI] qla2xxx: Add support for fabric name FC transport attribute. ...
2006-10-03[SCSI] scsi: Scsi_Cmnd convertion in arm subtreeHenne
Changes the obsolete Scsi_Cmnd to struct scsi_cmnd in the arm subdir of the scsi-subsys. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-06[ARM] Fix Acorn platform SCSI driver build failuresRussell King
SCSI folk forgot to fix up all the uses of 'buffer' before deleting this struct member. Do it for them to rescue the resulting build failures. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-06[ARM] Fix NCR5380-based SCSI card buildRussell King
The NCR5380-based SCSI cards need the SCSI SPI transport selected to build correctly. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-26[PATCH] fix compile regression for a few scsi driversChristoph Hellwig
This fixes three drivers to compile again after my patch that removes the data_cmnd member from struct scsi_cmnd. The fas216 change is trivial, it should have been using ->cmnd all the time. NCR53C9 (which seem to be mostly duplicate driver with esp.c!) is doing something odd, it should only have looked at ->cmnd before not the saved copy that is kept for the error handlers sake. Note that it really should deal with the sync setting themselves but use the generic domain validation code that get this right - but that's for later let's push this simple compile fix for now. And sorry for the late fix for this, I have been busy with OLS and associated activities last week. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] More BUG_ON conversionEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] Remove MODULE_PARMRusty Russell
MODULE_PARM was actually breaking: recent gcc version optimize them out as unused. It's time to replace the last users, which are generally in the most unloved drivers anyway. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[ARM] Remove asm/irq.h includes from ARM driversRussell King
Many ARM drivers do not need to include asm/irq.h - remove this unnecessary include from some ARM drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-15[SCSI] Rename scsi_print_msg to spi_print_msgMatthew Wilcox
Rename scsi_print_msg to spi_print_msg and move its prototype from scsi_dbg.h to scsi_transport_spi.h Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15[SCSI] Move scsi_print_msg to SPI classMatthew Wilcox
scsi_print_msg() is an SPI-specific concept. This patch moves it from constants.c to scsi_transport_spi.c and updates the Kconfig to link in the SPI class for the drivers which use scsi_print_msg(). Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09[SCSI] remove Scsi_Device typedefChristoph Hellwig
2005-11-09[SCSI] remove Scsi_Pointer typedefChristoph Hellwig
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-11-07[PATCH] kfree cleanup: drivers/scsiJesper Juhl
This is the drivers/scsi/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/scsi/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Use sg_set_buf/sg_init_one where applicableDavid Hardeman
This patch uses sg_set_buf/sg_init_one in some places where it was duplicated. Signed-off-by: David Hardeman <david@2gen.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
