path: root/drivers/scsi/aic94xx
2010-08-11drivers/scsi/aic94xx/aic94xx_init.c: correct the size argument to kmallocJulia Lawall
In each case, the destination of the allocation has type struct **, so the elements of the array should have pointer type, not structure type. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @disable sizeof_type_expr@ type T; T **x; @@ x = <+...sizeof( - T + *x )...+> // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Rolf Eike Beer <eike-kernel@sf-tec.de> Cc: Joe Perches <joe@perches.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-07-28[SCSI] Unify SAM_ and SAM_STAT_ macrosJames Bottomley
We have two separate definitions for identical constants with nearly the same name. One comes from the generic headers in scsi.h; the other is an enum in libsas.h ... it's causing confusion about which one is correct (fortunately they both are). Fix this by eliminating the libsas.h duplicate Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-04tree-wide: fix misspelling of "definition" in commentsAdam Buchbinder
"Definition" is misspelled "defintion" in several comments; this patch fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02[SCSI] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[jejb: limit ioctl to returning 20 characters to avoid overrun on long device names and add a few more conversions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-10aic94xx: treat firmware data as constDavid Woodhouse
2008-05-02[SCSI] aic94xx: fix section mismatchSam Ravnborg
Fix following warnings: WARNING: vmlinux.o(.data+0x17aa88): Section mismatch in reference from the variable asd_pcidev_data to the function .devinit.text:asd_aic9410_setup() WARNING: vmlinux.o(.data+0x17aa98): Section mismatch in reference from the variable asd_pcidev_data to the function .devinit.text:asd_aic9410_setup() WARNING: vmlinux.o(.data+0x17aaa8): Section mismatch in reference from the variable asd_pcidev_data to the function .devinit.text:asd_aic9405_setup() asd_pcidev_data is only used by __devinit asd_pci_probe. So mark is const and annotate it __devinitconst to fix the warnings. [akpm@linux-foundation.org: fix warning] Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] aic94xx: cleanupsAdrian Bunk
- static functions in .c files shouldn't be marked inline - make needlessly global code static - remove the unused aic94xx_seq.c:asd_unpause_lseq() - #if 0 other unused code [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] aic94xx: Use sas_request_addr() to provide SAS WWN if the adapter ↵Darrick J. Wong
lacks one If the aic94xx chip doesn't have a SAS address in the chip's flash memory, make libsas get one for us. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-24[SCSI] aic94xx: fix TMF ascb handling to prevent sequencer panicJames Bottomley
This is a particularly nasty bug. The problem is that if any internal ascb times out, currently we free it even though it's pending at the sequencer. This results in the sequencer getting terminally confused and the error message: BUG:sequencer:dl:no ascb Being returned when it comes back. The way to fix this is to manage freeing the ascb from the tasklet completion routine, so that we only free it when the sequencer actually returns it. The code is also altered to use on stack completions and transfer variables. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-23[SCSI] aic94xx: plumb in I_T_nexus_reset task management functionJames Bottomley
Currently aic94xx has no exported I_T_nexus_reset function. This is a bit of a huge problem, since sas_ata relies on this function to perform an ATA phy reset and also it means that if abort fails, we really have no bigger hammer to hit everything with. Plumb in the I_T_nexus_reset by quiescing the sequencer, sending the correct phy reset (link for ATA and hard for SAS) and then carefully resuming the sequencer again. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-22[SCSI] aic94xx: fix sequencer hang on error recoveryJames Bottomley
The clear nexus I_T and clear nexus I_T_L functions in the aic94xx specify the SUSPEND_TX flag which causes the sequencer to be suspended until it receives a RESUME_TX. Unfortunately, nothing ever sends the resume, so the sequencer on the link is stopped forever, leading to eventual timeouts and I/O errors. Since clear nexus commands are only executed as part of error recovery, it's perfectly fine to keep the sequencer running on the link ... as soon as the recovery function is completed, we'll send it the commands to retry. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-18[SCSI] aic94xx: fix REQ_TASK_ABORT and REQ_DEVICE_RESETJames Bottomley
This driver has been failing under heavy load with aic94xx: escb_tasklet_complete: REQ_TASK_ABORT, reason=0x6 aic94xx: escb_tasklet_complete: Can't find task (tc=4) to abort! The second message is because the driver fails to identify the task it's being asked to abort. On closer inpection, there's a thinko in the for each task loop over pending tasks in both the REQ_TASK_ABORT and REQ_DEVICE_RESET cases where it doesn't look at the task on the pending list but at the one on the ESCB (which is always NULL). Fix by looking at the right task. Also add a print for the case where the pending SCB doesn't have a task attached. Not sure if this will fix all the problems, but it's a definite first step. Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] aic94xx: fix ABORT_TASK define conflictBoaz Harrosh
include/scsi/scsi.h as a definition: #define ABORT_TASK 0x0d on the other hand drivers/scsi/aic94xx/aic94xx_sas.h has: #define ABORT_TASK 0x03 rename the latter to SCB_ABORT_TASK Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-25[SCSI] libsas: abstract STP task status into a functionJames Bottomley
Break out the frame processor for STP tasks from aic94xx so they can be shared by other SAS HBA's Original patch from Jeff Garzik <jeff@garzik.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] aic94xx: fix section mismatchesRandy Dunlap
Fix section mismatch warning: WARNING: vmlinux.o(.init.text+0x23be6): Section mismatch: reference to .exit.text:asd_unmap_ha (between 'asd_pci_probe' and 'qla4xxx_module_init') + WARNING: vmlinux.o(.text+0x1ec8a8): Section mismatch: reference to .exit.text:as d_unmap_ioport (between 'asd_unmap_ha' and 'asd_remove_dev_attrs') WARNING: vmlinux.o(.text+0x1ec8b1): Section mismatch: reference to .exit.text:as d_unmap_memio (between 'asd_unmap_ha' and 'asd_remove_dev_attrs') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libsas: Convert sas_proto users to sas_protocolDarrick J. Wong
sparse complains about the mixing of enums in libsas. Since the underlying numeric values of both enums are the same, combine them to get rid of the warning. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] aic94xx: update BIOS image from user space.Gilbert Wu
1. Create a file "update_bios" in sysfs to allow user to update bios from user space. 2. The BIOS image file can be downloaded from web site "http://www.adaptec.com/en-US/downloads/bios_fw/bios_fw_ver?productId=SAS-48300&dn=Adaptec+Serial+Attached+SCSI+48300" and copy the BIOS image into /lib/firmware folder. 3. The aic994xx will accept "update bios_file" and "verify bios_file" commands to perform update and verify BIOS image . For example: Type "echo "update asc483c01.ufi" > /sys/devices/.../update_bios" to update BIOS image from /lib/firmware/as483c01.ufi file into HBA's flash memory. Type "echo "verify asc483c01.ufi" > /sys/devices/.../update_bios" to verify BIOS image between /lib/firmware/asc48c01.ufi file and HBA's flash memory. 4. Type "cat /sys/devices/.../update_bios" to view the status or result of updating BIOS. Signed-off-by: Gilbert Wu <gilbert_wu@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-11-14aic94xx_sds: rename FLASH_SIZEAndrew Morton
arm: drivers/scsi/aic94xx/aic94xx_sds.c:381:1: warning: "FLASH_SIZE" redefined In file included from include/asm/arch/irqs.h:22, from include/asm/irq.h:4, from include/asm/hardirq.h:6, from include/linux/hardirq.h:7, from include/asm-generic/local.h:5, from include/asm/local.h:1, from include/linux/module.h:19, from include/linux/device.h:21, from include/linux/pci.h:52, from drivers/scsi/aic94xx/aic94xx_sds.c:28: include/asm/arch/platform.h:444:1: warning: this is the location of the previous definition Cc: Gilbert Wu <gilbert_wu@adaptec.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16aic94xx: sg chaining supportJens Axboe
2007-10-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (207 commits) [SCSI] gdth: fix CONFIG_ISA build failure [SCSI] esp_scsi: remove __dev{init,exit} [SCSI] gdth: !use_sg cleanup and use of scsi accessors [SCSI] gdth: Move members from SCp to gdth_cmndinfo, stage 2 [SCSI] gdth: Setup proper per-command private data [SCSI] gdth: Remove gdth_ctr_tab[] [SCSI] gdth: switch to modern scsi host registration [SCSI] gdth: gdth_interrupt() gdth_get_status() & gdth_wait() fixes [SCSI] gdth: clean up host private data [SCSI] gdth: Remove virt hosts [SCSI] gdth: Reorder scsi_host_template intitializers [SCSI] gdth: kill gdth_{read,write}[bwl] wrappers [SCSI] gdth: Remove 2.4.x support, in-kernel changelog [SCSI] gdth: split out pci probing [SCSI] gdth: split out eisa probing [SCSI] gdth: split out isa probing gdth: Make one abuse of scsi_cmnd less obvious [SCSI] NCR5380: Use scsi_eh API for REQUEST_SENSE invocation [SCSI] usb storage: use scsi_eh API in REQUEST_SENSE execution [SCSI] scsi_error: Refactoring scsi_error to facilitate in synchronous REQUEST_SENSE ...
2007-10-12[SCSI] aic94xx: fix SSP IU status print-outJeff Garzik
The SSP response DPRINTK in asd_get_response_tasklet() was printing a hardcoded status result, rather than the status from the SSP response IU. Arguably, this should not be a DPRINTK either, since the admin might want to know about this. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] aic94xx: Free scsi host on errorMatthew Wilcox
If an error occurred during initialisation, we would sometimes fail to call scsi_host_put() and thus end up with a leaked scsi_host. It was also possible to miss calling scsi_remove_host(). Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] aic94xx: Add new PCI ID for ASC58300Gilbert Wu
Add new HBA PCI ID (0x416) for ASC58300 which has eight port SAS and SATA PCI-X 133MHz low profile host bus adapter with two mini SAS 4x external connectors. Signed-off-by: Gilbert Wu <gilbert_wu@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-02aic94xx: fix DMA data direction for SMP requestsJeff Garzik
DMA-mapped SMP (scsi management protocol) requests going /to/ the device need the PCI DMA data direction to indicate such. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-07-26[SCSI] libsas: Remove PCI dependenciesJeff Garzik
Eliminate unnecessary PCI dependencies in libsas. It should use generic DMA and struct device like other subsystems. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-22Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (60 commits) [SCSI] libsas: make ATA functions selectable by a config option [SCSI] bsg: unexport sg v3 helper functions [SCSI] bsg: fix bsg_unregister_queue [SCSI] bsg: make class backlinks [SCSI] 3w-9xxx: add support for 9690SA [SCSI] bsg: fix bsg_register_queue error path [SCSI] ESP: Increase ESP_BUS_TIMEOUT to 275. [SCSI] libsas: fix scr_read/write users and update the libata documentation [SCSI] mpt fusion: update Kconfig help [SCSI] scsi_transport_sas: add destructor for bsg [SCSI] iscsi_tcp: buggered kmalloc() [SCSI] qla2xxx: Update version number to 8.02.00-k2. [SCSI] qla2xxx: Add ISP25XX support. [SCSI] qla2xxx: Use pci_try_set_mwi(). [SCSI] qla2xxx: Use PCI-X/PCI-Express read control interfaces. [SCSI] qla2xxx: Re-factor isp_operations to static structures. [SCSI] qla2xxx: Validate mid-layer 'underflow' during check-condition handling. [SCSI] qla2xxx: Correct setting of 'current' and 'supported' speeds during FDMI registration. [SCSI] qla2xxx: Generalize iIDMA support. [SCSI] qla2xxx: Generalize FW-Interface-2 support. ...
2007-07-18[SCSI] libsas, aic94xx: fix dma mapping cockups with ATAJames Bottomley
This one was noticed by Gilbert Wu of Adaptec: The libata core actually does the DMA mapping for you, so there has to be an exception in the device drivers that *don't* do dma mapping for ATA commands. However, since we've already done this, libsas must now dma map any ATA commands that it wishes to issue ... and yes, this is a horrible mess. Additionally, the test in aic94xx for ATA protocols isn't quite right. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] aic94xx: Don't call pci_map_sg for already-mapped scatterlistsDarrick J. Wong
It turns out that libata has already dma_map_sg'd the scatterlist entries that go with an ata_queued_cmd by the time it calls sas_ata_qc_issue. sas_ata_qc_issue passes this scatterlist to aic94xx. Unfortunately, aic94xx assumes that any scatterlist passed to it needs to be pci_map_sg'd... which blows away the mapping that libata created! This causes (on a x260) Calgary IOMMU table leaks and duplicate frees when aic94xx and libata try to {pci,dma}_unmap_sg the scatterlist. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Key this check off ATA_PROTOCOL_STP Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] libsas: fixup NCQ for SATA disksJames Bottomley
We actually had two problems: the one with the tag (which is fixed by zeroing the tag before sending the taskfile to the sequencer) but the other with the fact that we sent our first NCQ command to the device before the sequencer had been informed of the NCQ tagging capabilities. I fixed the latter by moving the rphy_add() to the correct point in the code after the NCQ capabilities are set up. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] aic94xx: SATA tag mask not set correctlyDarrick J. Wong
The aic94xx controller has a bitmask establishing which tags are ok to use with a SATA NCQ disk. When the queue depth is 32, however, the expression that is used sets the mask to zero, not 0xFFFFFFFF. This patch widens the width of the integer so that this case is handled properly. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] Add SATA support to libsasDarrick J. Wong
Hook the scsi_host_template functions in libsas to delegate functionality to libata when appropriate. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Misc code changes and merge fixes and update for libata->drivers/ata move Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-22[SCSI] aic94xx: asd_clear_nexus should fail if the cleared task does not ↵Darrick J. Wong
complete Every so often, the driver will call asd_clear_nexus to clean out a task. It is supposed to be the case that the CLEAR NEXUS does not go on the done list until after the task itself has been put on the done list, but for some reason this doesn't always happen. Thus, the wait_for_completion_timeout call times out, and we return success. This makes libsas free the task even though the task hasn't completed, leading to a BUG_ON message from aic94xx_hwi.c around line 341. We should return failure from asd_clear_nexus so that libsas tries again; at a bare minimum it shouldn't be freeing active tasks. I _think_ this will fix one of the SCB timeout crash problems (though I've not been able to reproduce it lately...) Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16[SCSI] aic94xx: tie driver to the major number of the sequencer firmwareJames Bottomley
The sequencer firmware file has both a string (currently showing V17/10c6) and a number (currently set to 1.1). It has become apparent that Adaptec may issue sequencer firmware in the future which could be incompatible with the current driver. Therefore, the driver will be tied to the particular major number of the firmware (i.e. the current driver will load any 1.x firmware). Additionally, the driver will print out both the ascii string and the major number, so with this pach the current firmware will print out aic94xx: Found sequencer firmware version 1.1 (V17/10c6) Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (97 commits) [SCSI] zfcp: removed wrong comment [SCSI] zfcp: use of uninitialized variable [SCSI] zfcp: Invalid locking order [SCSI] aic79xx: use dma_get_required_mask() [SCSI] aic79xx: fix bracket mismatch in unused macro [SCSI] BusLogic: Replace 'boolean' by 'bool' [SCSI] advansys: clean up warnings [SCSI] 53c7xx: brackets fix in uncompiled code [SCSI] nsp_cs: remove old scsi code [SCSI] aic79xx: make ahd_match_scb() static [SCSI] DAC960: kmalloc->kzalloc/Casting cleanups [SCSI] scsi_kmap_atomic_sg(): check that local irqs are disabled [SCSI] Buslogic: local_irq_disable() is redundant after local_irq_save() [SCSI] aic94xx: update for v28 firmware [SCSI] scsi_error: Fix lost EH commands [SCSI] aic94xx: Add default bus reset handler [SCSI] aic94xx: Remove TMF result code munging [SCSI] libsas: Add an LU reset mechanism to the error handler [SCSI] libsas: Don't BUG when connecting two expanders via wide port [SCSI] st: fix Tape dies if wrong block size used, bug 7919 ...
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-03[SCSI] aic94xx: update for v28 firmwareWu, Gilbert
These changes work compatibly with the old V17 firmware Contribution: Ed Chim <ed_chim@adaptec.com> Gilbert Wu <gilbert_wu@adaptec.com> Change Log: 1. Use dword instead of qword to display the value of Connection State register for debug purpose. 2. There are some registers location of AIC94xx chip has been changed according to the new V28 firmware. The patch has redefined the register location and provided initialization. 3. The new sequencer firmware v28 for Aic94xx SAS/SATA Linux open source device driver can be downloaded from http://www.adaptec.com/NR/exeres/35B611BC-9789-4B5B-82C6-85A2CCA8A46A.htm Signed-off-by: Gilbert Wu <gilbert_wu@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-03[SCSI] aic94xx: Add default bus reset handlerDarrick J. Wong
2007-02-03[SCSI] aic94xx: Remove TMF result code mungingDarrick J. Wong
In asd_initiate_ssp_tmf, the TMF result code is replaced with TMF_RESP_FUNC_FAILED except when the TMF returns a result code immediately. However, TMFs can return result codes via an ESCB... yet these codes are also replaced with "FAILED". The only values that can fall into that case are TMF_* codes anyway, so get rid of this code where COMPLETE and SUCCESS are turned into FAILED. This also lets us propagate those TMF_* codes up to the caller. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-27[SCSI] aic94xx: Register eh_device_reset_handlerDarrick J. Wong
Register libsas's default device reset code with the scsi. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
