path: root/drivers/scsi/aacraid/commctrl.c
2013-11-19aacraid: prevent invalid pointer dereferenceMahesh Rajashekhara
It appears that driver runs into a problem here if fibsize is too small because we allocate user_srbcmd with fibsize size only but later we access it until user_srbcmd->sg.count to copy it over to srbcmd. It is not correct to test (fibsize < sizeof(*user_srbcmd)) because this structure already includes one sg element and this is not needed for commands without data. So, we would recommend to add the following (instead of test for fibsize == 0). Signed-off-by: Mahesh Rajashekhara <Mahesh.Rajashekhara@pmcs.com> Reported-by: Nico Golde <nico@ngolde.de> Reported-by: Fabian Yamaguchi <fabs@goesec.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers: avoid parsing names as kthread_run() format stringsKees Cook
Calling kthread_run with a single name parameter causes it to be handled as a format string. Many callers are passing potentially dynamic string content, so use "%s" in those cases to avoid any potential accidents. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-20[SCSI] aacraid: Series 7 Async. (performance) mode supportMahesh Rajashekhara
- Series 7 Async. (performance) mode support added - New scatter/gather list format for Series 7 - Driver converts s/g list to a firmware suitable list for best performance on Series 7, this can be disabled with driver parameter "aac_convert_sgl" for testing purposes - New container read/write command structure for Series 7 - Fast response support for the SCSI pass-through path added - Async. status response buffer changes Signed-off-by: Mahesh Rajashekhara <Mahesh_Rajashekhara@pmc-sierra.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-01-08drivers/scsi/aacraid/commctrl.c: fix mem leak in aac_send_raw_srb()Jesper Juhl
We leak in drivers/scsi/aacraid/commctrl.c::aac_send_raw_srb() : We allocate memory: ... struct user_sgmap* usg; usg = kmalloc(actual_fibsize - sizeof(struct aac_srb) + sizeof(struct sgmap), GFP_KERNEL); and then neglect to free it: ... for (i = 0; i < usg->count; i++) { u64 addr; void* p; if (usg->sg[i].count > ((dev->adapter_info.options & AAC_OPT_NEW_COMM) ? (dev->scsi_host_ptr->max_sectors << 9) : 65536)) { rcode = -EINVAL; goto cleanup; ... this 'goto' makes 'usg' go out of scope and leak the memory we allocated. Other exits properly kfree(usg), it's just here it is neglected. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23[SCSI] aacraid: Add new code for PMC-Sierra's SRC based controller familyMahesh Rajashekhara
Added new hardware device 0x28b interface for PMC-Sierra's SRC based controller family. - new src.c file for 0x28b specific functions - new XPORT header required - sync. command interface: doorbell bits shifted (SRC_ODR_SHIFT, SRC_IDR_SHIFT) - async. Interface: different inbound queue handling, no outbound I2O queue available, using doorbell ("PmDoorBellResponseSent") and response buffer on the host ("host_rrq") for status - changed AIF (adapter initiated FIBs) interface: "DoorBellAifPending" bit to inform about pending AIF, "AifRequest" command to read AIF, "NoMoreAifDataAvailable" to mark the end of the AIFs Signed-off-by: Mahesh Rajashekhara <aacraid@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-16[SCSI] aacraid: semaphore cleanupThomas Gleixner
Get rid of init_MUTEX[_LOCKED]() and use sema_init() instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: aacraid@adaptec.com Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-25[SCSI] aacraid: Eliminate use after freeJulia Lawall
The debugging code using the freed structure is moved before the kfree. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @free@ expression E; position p; @@ kfree@p(E) @@ expression free.E, subE<=free.E, E1; position free.p; @@ kfree@p(E) ... ( subE = E1 | * E ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-01-17[SCSI] aacraid: fix File System going into read-only modePenchala Narasimha Reddy Chilakala, ERS-HCLTech
These particular problems were reported by Cisco and SAP and customers as well. Cisco reported on RHEL4 U6 and SAP reported on SLES9 SP4 and SLES10 SP2. We added these fixes on RHEL4 U6 and gave a private build to IBM and Cisco. Cisco and IBM tested it for more than 15 days and they reported that they did not see the issue so far. Before the fix, Cisco used to see the issue within 5 days. We generated a patch for SLES9 SP4 and SLES10 SP2 and submitted to Novell. Novell applied the patch and gave a test build to SAP. SAP tested and reported that the build is working properly. We also tested in our lab using the tools "dishogsync", which is IO stress tool and the tool was provided by Cisco. Issue1: File System going into read-only mode Root cause: The driver tends to not free the memory (FIB) when the management request exits prematurely. The accumulation of such un-freed memory causes the driver to fail to allocate anymore memory (FIB) and hence return 0x70000 value to the upper layer, which puts the file system into read only mode. Fix details: The fix makes sure to free the memory (FIB) even if the request exits prematurely hence ensuring the driver wouldn't run out of memory (FIBs). Issue2: False Raid Alert occurs When the Physical Drives and Logical drives are reported as deleted or added, even though there is no change done on the system Root cause: Driver IOCTLs is signaled with EINTR while waiting on response from the lower layers. Returning "EINTR" will never initiate internal retry. Fix details: The issue was fixed by replacing "EINTR" with "ERESTARTSYS" for mid-layer retries. Signed-off-by: Penchala Narasimha Reddy <ServeRAIDDriver@hcl.in> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2008-12-29[SCSI] Clean up my email address and use a single standard address for ↵Alan Cox
everything Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] aacraid: check pci_alloc_consistent errorsFUJITA Tomonori
We need to check the address that pci_alloc_consistent() returns since it might fail. When pci_alloc_consistent() fails, some IOMMUs set the dma_handle argument to zero. So we can't use fibptr->hw_fib_pa directly here. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Aacraid List <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] aacraid: prevent copy_from_user() BUG!Mark Salyzyn
Seen: kernel BUG at arch/i386/lib/usercopy.c:872 under a 2.6.18-8.el5 kernel. Traced it to a garbage-in/garbage-out ioctl condition in the aacraid driver. Adaptec's special ioctl scb passthrough needs to check the validity of the individual scatter gather count fields to the maximum the adapter supports. Doing so will have the side effect of preventing copy_from_user() from bugging out while populating the dma buffers. This is a hardening effort, issue was triggered by an errant version of the management tools and thus the BUG should not be seen in the field. [jejb: fixed up compile failure] Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-02-07[SCSI] aacraid: fib context lock for management ioctls (take 2)Salyzyn, Mark
The first patch (a119ee8ee3045bf559d4cf02d72b112f3de2a15b) was a bit too aggressive and nested the locks (!) unit testing was in error. This patch was reverted by 203a512f0976e8ba85df36d76b40af6c80239121. This new patch should fix the locks correctly. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] Revert "[SCSI] aacraid: fib context lock for management ioctls"James Bottomley
This reverts commit a119ee8ee3045bf559d4cf02d72b112f3de2a15b. Adaptec found this was causing system lockups. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-25[SCSI] aacraid: fib context lock for management ioctlsSalyzyn, Mark
Alan noticed the lack of locking surrounding the driver's dealings with the fib context managed by the trio of ioctls that are used by the RAID management applications to retrieve Adapter Initiated FIBs. I merely expanded the fib lock to include the fib context. There have been no field reports of any issues generally because the applications are relatively static and do not come and go often enough to stress this area. I bloated this patch a little with some space junk. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: remove pigs in spaceSalyzyn, Mark
I was amazed at how much embedded space was present in the aacraid driver source files. Just selected five files from the set to clean up for now and the attached patch swelled to 73K in size! - Removed trailing space or tabs - Removed spaces embedded within tabs - Replaced leading 8 spaces with tabs - Removed spaces before ) - Removed ClusterCommand as it was unused (noticed it as one triggered by above) - Replaced scsi_status comparison with 0x02, to compare against SAM_STATUS_CHECK_CONDITION. - Replaced a long series of spaces with tabs - Replaced some simple if...defined() with ifdef/ifndef Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: fix multiple definition of automatic variable warning.Salyzyn, Mark
The 'entry' automatic variable was defined at the top and within a block that uses it, removed the definition from the block that uses it. Some cosmetic changes were made while in the same file. This patch should be inert. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-29fix abuses of ptrdiff_tAl Viro
Use of ptrdiff_t in places like - if (!access_ok(VERIFY_WRITE, u_tmp->rx_buf, u_tmp->len)) + if (!access_ok(VERIFY_WRITE, (u8 __user *) + (ptrdiff_t) u_tmp->rx_buf, + u_tmp->len)) is wrong; for one thing, it's a bad C (it's what uintptr_t is for; in general we are not even promised that ptrdiff_t is large enough to hold a pointer, just enough to hold a difference between two pointers within the same object). For another, it confuses the fsck out of sparse. Use unsigned long or uintptr_t instead. There are several places misusing ptrdiff_t; fixed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-01[SCSI] aacraid: resolve compiler warnings using ptrdiff_tSalyzyn, Mark
Unsigned long is not always the same size as a pointer, namely on 32 bit systems with 64 bit address space. Ptrdiff_t is the same size as a pointer in all configurations. By using ptrdiff_t we can mitigate the warning messages on these configurations. There should be no side effects of this patch. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] aacraid: fix srb ioctl for 64 bitsMark Haverkamp
Received from Mark Salyzyn, The raw srb ioctl is supposed to be able to take packets with 32 and 64 bit virtual address SG elements, it did not handle the frames with 64 bit SG elements well when communicating with 64 bit DMA capable adapters, and it did not handle the 32 bit limited DMA adapters at all. The enclosed patch now handles all four quadrants (32 bit / 64 bit SG elements in SRB requests + 32 bit or 64 bit DMA capable adapters) This fix is required before Java based management applications in a 64 bit user space can submit raw srb requests to the array physical components via the ioctl mechanism, the allocated user memory pool on 64 bit machines under this environment forced the management software's hands to submit 64 bit user space virtual address SG elements in via the ioctl. Signed-off-by: Mark Haverkamp <markh@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] aacraid: Fix ioctl handling when adapter resetsMark Haverkamp
Received from Mark Salyzyn, Outstanding ioctl calls still have some problems with aborting cleanly in the face of a reset iop recovery action should the adapter ever enter into a Firmware Assert (BlinkLED) condition. The enclosed patch resolves some uncovered flawed handling. Signed-off-by: Mark Haverkamp <markh@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] aacraid: Fix struct element name issueMark Haverkamp
Received from Mark Salyzyn, This patch is to resolve a namespace issue that will result from a patch expected in the future that adds a new interface; rationalized as correcting a long term issue where hw_fib, instead of hw_fib_va, refers to the virtual address space and hw_fib_pa refers to the physical address space. A small fragment of this patch also cleans up an unused variable that was close to the patch fragments. Signed-off-by: Mark Haverkamp <markh@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-19[SCSI] aacraid: Reset adapter in recovery timeoutMark Haverkamp
Received from Mark Salyzyn If the adapter is in blinkled (Firmware Assert) when error recovery timeout actions have been triggered, perform an adapter warm reset and restart the initialization. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-19[SCSI] aacraid: interruptible ioctlMark Haverkamp
Received from Mark Salyzyn This patch allows the FSACTL_SEND_LARGE_FIB, FSACTL_SENDFIB and FSACTL_SEND_RAW_SRB ioctl calls into the aacraid driver to be interruptible. Only necessary if the adapter and/or the management software has gone into some sort of misbehavior and the system is being rebooted, thus permitting the user management software applications to be killed relatively cleanly. The FIB queue resource is held out of the free queue until the adapter finally, if ever, completes the command. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-13[SCSI] aacraid: Re-start helper thread if it diesMark Haverkamp
Received from Mark Salyzyn Since the helper thread for the driver can be killed unceremoniously by an application, we detect the loss of the helper and restart it. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] aacraid: Update global function namesMark Haverkamp
Received from Mark Salyzyn, Reduce the possibility of namespace collision. Prefix with aac_. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] aacraid: Fix default FIB sizeMark Haverkamp
Received from Mark Salyzyn. If the adapter has not instructed us otherwise that it can handle a 'large' FIB, then it can handle at most a 2KB FIB. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] aacraid: remove compiler warningMark Haverkamp
Received from Mark Salyzyn. This patch resolves a compiler warning on 64 bit architectures. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] aacraid: fix struct element cpu orderMark Haverkamp
Received from Mark Salyzyn. The compat field needed to be in cpu order. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-05[SCSI] aacraid: aif registration timeout fixMark Haverkamp
Received from Mark Salyzyn from Adaptec: If the Adapter is quiet and does not produce an AIF event packets to be picked up by the management applications for longer than the timeout interval of two minutes, the cleanup code that deals with aging out registrants could erroneously drop the registration. The timeout is there to clean up should the management application die and fail to poll for updated AIF event packets. Moving the timer update from the ioctl code that delivers an AIF to the polling registrant to the bottom of the ioctl means the timeout is reset with any management application polling activity regardless if an AIF is delivered or not removing the erroneous timeout cleanups. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-05[SCSI] aacraid: driver version updateMark Haverkamp
Received from Mark Salyzyn from Adaptec. Fixes a bug in check_revision. It should return the driver version not the firmware version. Update driver version number. Update driver version string. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-26Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-for-linus-2.6Linus Torvalds
2005-07-14[SCSI] aacraid: Fix sgmap errorMark Haverkamp
The wrong sgmap structure is being assigned in aac_send_raw_srb. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-12[PATCH] aacraid: swapped kmalloc args.Dave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-17[SCSI] aacraid: regression fixMark Haverkamp
The fixes for sparse warnings mixed in with the fixups for the raw_srb handler resulted in a bug that showed up in the 32 bit environments when trying to issue calls directly to the physical devices that are part of the arrays (ioctl scsi passthrough). Received from Mark Salyzyn at adaptec. Applied comment from Christoph to remove cpu_to_le32(0) Applied Mark S fix of missing memcpy. It applies to the scsi-misc-2.6 git tree. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] 2.6 aacraid: Variable FIB size (updated patch)Mark Haverkamp
New code from the Adaptec driver. Performance enhancement for newer adapters. I hope that this isn't too big for a single patch. I believe that other than the few small cleanups mentioned, that the changes are all related. - Added Variable FIB size negotiation for new adapters. - Added support to maximize scatter gather tables and thus permit requests larger than 64KB/each. - Limit Scatter Gather to 34 elements for ROMB platforms. - aac_printf is only enabled with AAC_QUIRK_34SG - Large FIB ioctl support - some minor cleanup Passes sparse check. I have tested it on x86 and ppc64 machines. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] aacraid: remove sparse warningsMark Haverkamp
This patch addresses the sparse -Wbitwise warnings that Christoph wanted me to eliminate. This mostly consisted of making data structure elements of hardware associated structures the __le* equivalent. Although there were a couple places where there was mixing of cpu and le variable math. These changes have been tested on both an x86 and ppc machine running bonnie++. The usage of the LE32_ALL_ONES macro has been eliminated. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] drivers/scsi/aacraid/: make some functions staticAdrian Bunk
This patch makes some needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
