path: root/drivers/scsi/NCR5380.c
2013-04-09NCR5830: switch to ->show_info()Al Viro
2013-01-03Drivers: scsi: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Adam Radford <linuxraid@lsi.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-02-12[SCSI] remove flush_scheduled_work() usagesTejun Heo
Simple conversions to drop flush_scheduled_work() usages in drivers/scsi. More involved ones will be done in separate patches. * NCR5380, megaraid_sas: cancel_delayed_work() + flush_scheduled_work() -> cancel_delayed_work_sync(). * mpt2sas_scsih: drop unnecessary flush_scheduled_work(). * arcmsr_hba, ipr, pmcraid: flush the used work explicitly instead of using flush_scheduled_work(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11NCR5380: bit MR_DMA_MODE set twice in NCR5380_transfer_dma()Roel Kluin
Besides keeping the line short, the second setting of the MR_DMA_MODE bit was removed. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-29[SCSI] Clean up my email address and use a single standard address for ↵Alan Cox
everything Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] NCR5380: fix section mismatchRandy Dunlap
Many release() methods that are not __exit or __devexit call this __devexit function, so remove its "__devexit" attribute. scsi/g_NCR5380.c: WARNING: vmlinux.o(.text+0xadaf8c): Section mismatch: reference to .exit.text:NCR5380_exit (between 'generic_NCR5380_release_resources' and 'generic_NCR5380_biosparam') WARNING: vmlinux.o(.text+0xadd18c): Section mismatch: reference to .exit.text:NCR5380_exit (between 'generic_NCR5380_release_resources' and 'generic_NCR5380_biosparam') scsi/pas16.c, seagate.c: WARNING: vmlinux.o(.text+0xb29e91): Section mismatch: reference to .exit.text:NCR5380_exit (between 'pas16_release' and 'seagate_st0x_info') t128.c: WARNING: vmlinux.o(.text+0xb2a774): Section mismatch: reference to .exit.text:NCR5380_exit (between 't128_release' and 't128_biosparam') dtc.c, sym2/sym_fw.c: WARNING: vmlinux.o(.text+0xb2f215): Section mismatch: reference to .exit.text:NCR5380_exit (between 'dtc_release' and 'sym_fw1_patch') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] NCR5380: minor irq handler cleanupsJeff Garzik
* remove unnecessary cast * remove unnecessary use of 'irq' function arg Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] NCR5380 family: convert to accessors & !use_sg cleanupBoaz Harrosh
- This patch depends on: NCR5380: Use scsi_eh API for REQUEST_SENSE invocation - convert to accessors and !use_sg cleanup - FIXME: Not sg-chain ready look for ++cmd->SCp.buffer Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James <James.Bottomley@HansenPartnership.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-12[SCSI] NCR5380: Use scsi_eh API for REQUEST_SENSE invocationBoaz Harrosh
- Use new scsi_eh_prep/restor_cmnd() for synchronous REQUEST_SENSE invocation. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] Fix mistaken uses of ->doneMatthew Wilcox
All these drivers meant to call ->scsi_done() but got confused. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (166 commits) [SCSI] ibmvscsi: convert to use the data buffer accessors [SCSI] dc395x: convert to use the data buffer accessors [SCSI] ncr53c8xx: convert to use the data buffer accessors [SCSI] sym53c8xx: convert to use the data buffer accessors [SCSI] ppa: coding police and printk levels [SCSI] aic7xxx_old: remove redundant GFP_ATOMIC from kmalloc [SCSI] i2o: remove redundant GFP_ATOMIC from kmalloc from device.c [SCSI] remove the dead CYBERSTORMIII_SCSI option [SCSI] don't build scsi_dma_{map,unmap} for !HAS_DMA [SCSI] Clean up scsi_add_lun a bit [SCSI] 53c700: Remove printk, which triggers because of low scsi clock on SNI RMs [SCSI] sni_53c710: Cleanup [SCSI] qla4xxx: Fix underrun/overrun conditions [SCSI] megaraid_mbox: use mutex instead of semaphore [SCSI] aacraid: add 51245, 51645 and 52245 adapters to documentation. [SCSI] qla2xxx: update version to 8.02.00-k1. [SCSI] qla2xxx: add support for NPIV [SCSI] stex: use resid for xfer len information [SCSI] Add Brownie 1200U3P to blacklist [SCSI] scsi.c: convert to use the data buffer accessors ...
2007-06-01parse errors in ifdefsYoann Padioleau
Fix various bits of obviously-busted code which we're not happening to compile, due to ifdefs. Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Jan Kara <jack@ucw.cz> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-24[SCSI] ncr5380 warning fixesAndrew Morton
squish these: drivers/scsi/NCR5380.c:360: warning: 'phases' defined but not used drivers/scsi/NCR5380.c:360: warning: 'phases' defined but not used drivers/scsi/NCR5380.c:633: warning: 'NCR5380_print_options' defined but not used drivers/scsi/NCR5380.c:708: warning: 'NCR5380_proc_info' defined but not used drivers/scsi/NCR5380.c:360: warning: 'phases' defined but not used drivers/scsi/NCR5380.c:579: warning: 'NCR5380_probe_irq' defined but not used drivers/scsi/NCR5380.c:360: warning: 'phases' defined but not used drivers/scsi/NCR5380.c:708: warning: 'notyet_generic_proc_info' defined but not used drivers/scsi/NCR5380.c:708: warning: 'notyet_generic_proc_info' defined but not used Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-24[SCSI] NCR5380: Replace yield() with a better alternativeAmol Lad
Replaced yield() with cond_resched() Signed-off-by: Amol Lad <amol@verismonetworks.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-06[SCSI] fix up request buffer reference in various scsi driversChristoph Hellwig
Various scsi drivers use scsi_cmnd.buffer and scsi_cmnd.bufflen in their queuecommand functions. Those fields are internal storage for the midlayer only and are used to restore the original payload after request_buffer and request_bufflen have been overwritten for EH. Using the buffer and bufflen fields means they do very broken things in error handling. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15[SCSI] Rename scsi_print_msg to spi_print_msgMatthew Wilcox
Rename scsi_print_msg to spi_print_msg and move its prototype from scsi_dbg.h to scsi_transport_spi.h Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-07[PATCH] drivers/scsi: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_uninterruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[SCSI] use scmd_id(), scmd_channel() throughout codeJeff Garzik
Wrap a highly common idiom. Makes the code easier to read, helps pave the way for sdev->{id,channel} removal, and adds a token that can easily by grepped-for in the future. There are a couple sdev_id() and scmd_printk() updates thrown in as well. Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] use sfoo_printk() in driversJeff Garzik
2005-10-16[SCSI] NCR5380: fix undefined preprocessor identifierRandy Dunlap
Fix 12 undefined preprocessor identifier warnings (4 each in 3 driver builds): drivers/scsi/NCR5380.c:2744:16: warning: undefined preprocessor identifier 'NDEBUG_ABORT' drivers/scsi/NCR5380.c:2744:16: warning: "NDEBUG_ABORT" is not defined Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-07[PATCH] -Wundef fixes (ncr5380)viro@ZenIV.linux.org.uk
NDEBUG and NDEBUG_ABORT are almost always used as integers in NCR5380; added define to 0 if they are not defined, switched lone ifdef NDEBUG into if. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-17[SCSI] allow sleeping in ->eh_bus_reset_handler()Jeff Garzik
2005-06-17[SCSI] Remove no-op implementations of SCSI EH hooksJeff Garzik
Drivers need not implement a hook that returns FAILED, and does nothing else, since the SCSI midlayer code will do that for us. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-18[PATCH] remove outdated print_* functions
We have the scsi_print_* functions in the proper namespace for a long time now and there weren't a lot users left. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
