* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (207 commits)
[SCSI] gdth: fix CONFIG_ISA build failure
[SCSI] esp_scsi: remove __dev{init,exit}
[SCSI] gdth: !use_sg cleanup and use of scsi accessors
[SCSI] gdth: Move members from SCp to gdth_cmndinfo, stage 2
[SCSI] gdth: Setup proper per-command private data
[SCSI] gdth: Remove gdth_ctr_tab[]
[SCSI] gdth: switch to modern scsi host registration
[SCSI] gdth: gdth_interrupt() gdth_get_status() & gdth_wait() fixes
[SCSI] gdth: clean up host private data
[SCSI] gdth: Remove virt hosts
[SCSI] gdth: Reorder scsi_host_template intitializers
[SCSI] gdth: kill gdth_{read,write}[bwl] wrappers
[SCSI] gdth: Remove 2.4.x support, in-kernel changelog
[SCSI] gdth: split out pci probing
[SCSI] gdth: split out eisa probing
[SCSI] gdth: split out isa probing
gdth: Make one abuse of scsi_cmnd less obvious
[SCSI] NCR5380: Use scsi_eh API for REQUEST_SENSE invocation
[SCSI] usb storage: use scsi_eh API in REQUEST_SENSE execution
[SCSI] scsi_error: Refactoring scsi_error to facilitate in synchronous REQUEST_SENSE
Change PortAddr to be an unsigned int instead of an unsigned short (IO
Port address are 24 bit on parisc). Fix a couple of printk argument
warnings. Remove the Kconfig marking as 'BROKEN'.
I haven't removed the #warning yet because virt_to_bus/bus_to_virt are
only eliminated for narrow boards. Wide boards need more work.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Description:
** support ARC1200/1201/1202 SATA RAID adapter, which is named
ACB_ADAPTER_TYPE_B
** modify the arcmsr_pci_slot_reset function
** modify the arcmsr_pci_ers_disconnect_forepart function
** modify the arcmsr_pci_ers_need_reset_forepart function
Signed-off-by: Nick Cheng <nick.cheng@areca.com.tw>
This adds minimum target driver support like the srp transport does:
- fc_remote_port_{rolechg,delete} calls
scsi_tgt_it_nexus_{create,destroy} for target drivers.
- add callbacks to notify target drivers of the nexus and tmf
operation results to fc_function_template.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
it's better to remove tgt dependencies in srp transport class since
most people want only initiator support.
This converts libsrp and ibmvstgt to use srp transport.
Acked-by: Brian King <brking@us.ibm.com>
This adds minimum target driver support:
- srp_rport_{add,del} calls scsi_tgt_it_nexus_{create,destroy} for
target drivers.
- add a callback to notify target drivers of the nexus operation
results to srp_function_template.
This converts ibmvscsi to use the srp transport class.
This adds srp transport class that works with ib_srp and ibmvscsi.
It creates only /sys/class/{srp_host,srp_remote_ports} and
srp_remote_ports has only "port_id" attribute.
viola:/sys/class/srp_remote_ports/port-0:1# ls
device port_id subsystem uevent
viola:/sys/class/srp_remote_ports/port-0:1# cat port_id
4c:49:4e:55:58:20:56:49:4f:00:00:00:00:00:00:00
Introduce CONFIG_CHECK_SIGNATURE to control inclusion of check_signature()
and avoid problems on platforms that don't have readb().
Let the few legacy (ISA || PCI || X86) drivers that need check_signature()
select CONFIG_CHECK_SIGNATURE.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
m68k: Fix a few hickups in drivers/scsi/Kconfig
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (60 commits)
[SCSI] libsas: make ATA functions selectable by a config option
[SCSI] bsg: unexport sg v3 helper functions
[SCSI] bsg: fix bsg_unregister_queue
[SCSI] bsg: make class backlinks
[SCSI] 3w-9xxx: add support for 9690SA
[SCSI] bsg: fix bsg_register_queue error path
[SCSI] ESP: Increase ESP_BUS_TIMEOUT to 275.
[SCSI] libsas: fix scr_read/write users and update the libata documentation
[SCSI] mpt fusion: update Kconfig help
[SCSI] scsi_transport_sas: add destructor for bsg
[SCSI] iscsi_tcp: buggered kmalloc()
[SCSI] qla2xxx: Update version number to 8.02.00-k2.
[SCSI] qla2xxx: Add ISP25XX support.
[SCSI] qla2xxx: Use pci_try_set_mwi().
[SCSI] qla2xxx: Use PCI-X/PCI-Express read control interfaces.
[SCSI] qla2xxx: Re-factor isp_operations to static structures.
[SCSI] qla2xxx: Validate mid-layer 'underflow' during check-condition handling.
[SCSI] qla2xxx: Correct setting of 'current' and 'supported' speeds during FDMI registration.
[SCSI] qla2xxx: Generalize iIDMA support.
[SCSI] qla2xxx: Generalize FW-Interface-2 support.
The sas transport class attaches one bsg device to every SAS object
(host, device, expander, etc). LLDs can define a function to handle
SMP requests via sas_function_template::smp_handler.
Make a "menuconfig" out of the Kconfig objects "menu, ..., endmenu",
so that the user can disable all the options in that menu at once
instead of having to disable each option separately.
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Make some offending drivers depend on it and set CONFIG_ARCH_NO_VIRT_TO_BUS
for ppc64 so that we don't build those drivers.
This gets PowerPC allmodconfig and allyesconfig much closer to building.
Cc: Al Viro <viro@ftp.linux.org.uk>
Acked-by: David Miller <davem@davemloft.net>
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (166 commits)
[SCSI] ibmvscsi: convert to use the data buffer accessors
[SCSI] dc395x: convert to use the data buffer accessors
[SCSI] ncr53c8xx: convert to use the data buffer accessors
[SCSI] sym53c8xx: convert to use the data buffer accessors
[SCSI] ppa: coding police and printk levels
[SCSI] aic7xxx_old: remove redundant GFP_ATOMIC from kmalloc
[SCSI] i2o: remove redundant GFP_ATOMIC from kmalloc from device.c
[SCSI] remove the dead CYBERSTORMIII_SCSI option
[SCSI] don't build scsi_dma_{map,unmap} for !HAS_DMA
[SCSI] Clean up scsi_add_lun a bit
[SCSI] 53c700: Remove printk, which triggers because of low scsi clock on SNI RMs
[SCSI] sni_53c710: Cleanup
[SCSI] qla4xxx: Fix underrun/overrun conditions
[SCSI] megaraid_mbox: use mutex instead of semaphore
[SCSI] aacraid: add 51245, 51645 and 52245 adapters to documentation.
[SCSI] qla2xxx: update version to 8.02.00-k1.
[SCSI] qla2xxx: add support for NPIV
[SCSI] stex: use resid for xfer len information
[SCSI] Add Brownie 1200U3P to blacklist
[SCSI] scsi.c: convert to use the data buffer accessors
Not converted to the 2.6 kconfig system and no code in the tree.
With
dma-mapping-prevent-dma-dependent-code-from-linking-on.patch
scsi fails to build on !HAS_DMA architectures:
drivers/built-in.o(.text+0x20af6): In function `scsi_dma_map':
: undefined reference to `dma_map_sg'
drivers/built-in.o(.text+0x20b5c): In function `scsi_dma_unmap':
: undefined reference to `dma_unmap_sg'
I split those functions out into a new file. Builds on s390 and i386.
Move scsi_dma_{map,unmap} into scsi_lib_dma.c which is only build if
HAS_DMA is set.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Cc: James Bottomley <James.Bottomley@SteelEye.com>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Dan Williams <dan.j.williams@intel.com>
On Mon, 11 Jun 2007 20:28:16 +0200 api wrote:
> Good day,
> When doing make menuconfig one comes across CONFIG_BLK_DEV_SD.
> The help file states that this is for scsi disks.NO MENTION IS MADE THAT
> IT IS NEEDE FOR SATA DISKS AS WELL!
> Would have saved me a lot of time if the help was up to date.
> I hope this can be changed so others can make a kernel for sata systems
> quicker.
Add help info for BLK_DEV_SD referring to its use in
SATA or PATA driver configurations.
Add help text for "ATA" indicating that it probably needs
some SCSI config symbols enabled in order to be useful.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
New driver for Amiga Zorro bus NCR53c710 SCSI controllers, using the 53c700
SCSI core.
New driver for the Amiga 4000T built-in NCR53c710 SCSI controller, using the
53c700 SCSI core.
New driver for the MVME16x NCR53C710 SCSI controller, using the 53c700 SCSI
core.
New driver for the BVME6000 NCR53C710 SCSI controller, using the 53c700 SCSI
core.
Add m68k support to the 53c700 SCSI driver
Reported by Meelis Roos.
drivers/scsi/jazz_esp.c
Same changes made by both SCSI and SPARC trees: problem with UTF-8
conversion in the copyright.
This is basically a straight conversion. I have one of these things, so
I know it works ... my problem is that it has a wierd SCA like
connector, so I can't connect anything to it (no cables).
However, previously it panic'd in the interrupt, now it completes a bus
scan.
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (38 commits)
kconfig: fix mconf segmentation fault
kbuild: enable use of code from a different dir
kconfig: error out if recursive dependencies are found
kbuild: scripts/basic/fixdep segfault on pathological string-o-death
kconfig: correct minor typo in Kconfig warning message.
kconfig: fix path to modules.txt in Kconfig help
usr/Kconfig: fix typo
kernel-doc: alphabetically-sorted entries in index.html of 'htmldocs'
kbuild: be more explicit on missing .config file
kbuild: clarify the creation of the LOCALVERSION_AUTO string.
kbuild: propagate errors from find in scripts/gen_initramfs_list.sh
kconfig: refer to qt3 if we cannot find qt libraries
kbuild: handle compressed cpio initramfs-es
kbuild: ignore section mismatch warning for references from .paravirtprobe to .init.text
kbuild: remove stale comment in modpost.c
kbuild/mkuboot.sh: allow spaces in CROSS_COMPILE
kbuild: fix make mrproper for Documentation/DocBook/man
kbuild: remove kconfig binaries during make mrproper
kconfig/menuconfig: do not hardcode '.config'
kbuild: override build timestamp & version
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (87 commits)
[SCSI] fusion: fix domain validation loops
[SCSI] qla2xxx: fix regression on sparc64
[SCSI] modalias for scsi devices
[SCSI] sg: cap reserved_size values at max_sectors
[SCSI] BusLogic: stop using check_region
[SCSI] tgt: fix rdma transfer bugs
[SCSI] aacraid: fix aacraid not finding device
[SCSI] aacraid: Correct SMC products in aacraid.txt
[SCSI] scsi_error.c: Add EH Start Unit retry
[SCSI] aacraid: [Fastboot] Panics for AACRAID driver during 'insmod' for kexec test.
[SCSI] ipr: Driver version to 2.3.2
[SCSI] ipr: Faster sg list fetch
[SCSI] ipr: Return better qc_issue errors
[SCSI] ipr: Disrupt device error
[SCSI] ipr: Improve async error logging level control
[SCSI] ipr: PCI unblock config access fix
[SCSI] ipr: Fix for oops following SATA request sense
[SCSI] ipr: Log error for SAS dual path switch
[SCSI] ipr: Enable logging of debug error data for all devices
[SCSI] ipr: Add new PCI-E IDs to device table
SCSI should be working on a TT (but someone should really try!) but causes
trouble on a Falcon (as in: it ate a filesystem of mine) at least when
used concurrently with IDE. I have the notion it's because locking of the
ST-DMA interrupt by IDE is broken in 2.6 (the IDE driver always complains
about trying to release an already-released ST-DMA). Needs more work, but
that's on the IDE or m68k interrupt side rather than SCSI.
Signed-off-by: Michael Schmitz <schmitz@debian.org>
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Documentation/modules.txt doesn't exist, but
Documentation/kbuild/modules.txt does.
Signed-off-by: Alexander E. Patrakov
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Major features:
1) Tagged queuing support.
2) Will properly negotiate for synchronous transfers even on
devices that reject the wide negotiation message, such as
CDROMs
3) Significantly lower kernel stack usage in interrupt
handler path by elimination of function vector arrays,
replaced by a top-level switch statement state machine.
4) Uses generic scsi infrastructure as much as possible to
avoid code duplication.
5) Automatic request of sense data in response to CHECK_CONDITION
6) Portable to other platforms using ESP such as DEC and Sun3
systems.
Remove the unused SCSI-related kernel config variables
SCSI_NCR53C8XX_PROFILE_SUPPORT
53C700_IO_MAPPED
AIC79XX_ENABLE_RD_STRM
AIC7XXX_PROBE_EISA_VL
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Currently scsi_wait_scan is only built modular if SCSI is modular.
However, it's perfectly possible for a built in SCSI still to have
modular drivers and thus need scsi_wait_scan as a module. Therefore,
scsi_wait_scan should always be built as a module (unless the kernel
doesn't support modules).
This patch adds a SCSI driver for the onboard 53c710 chip of some
SNI RM machines.
Apparently the driver compiles and runs, so tidy up some macro warnings
and bring it back as unBROKEN.
Make sun3 scsi drivers compile/work again (though with way too many warnings...)
Tested on 3/50, 3/60.
Signed-off-by: Sam Creasey <sammy@sammy.net>
- add comments for various devices
- remove unused device ids(0xf350, 0x4301, 0x8301, 0x8302)
- add new device id(0xe350)
- fix vendor id of st_vsc
- modify Kconfig help info
Signed-off-by: Ed Lin <ed.lin@promise.com>
This is IBM Virtual SCSI target driver for tgt. The driver is based on
the original ibmvscsis driver:
http://lkml.org/lkml/2005/10/17/99
Signed-off-by: Santiago Leon <santil@us.ibm.com>
libsrp provides helper functions for SRP target drivers.
Some SRP target drivers would be out of drivers/scsi/ so we added an
entry for libsrp in drivers/scsi/Kconfig.
Makefile and Kconfig for tgt.
Without this patch, the user has to add a kernel command line parameter
to get asynchronous SCSI scanning. Now they can select the default at
compile time and still override it at boot time if they need to.
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Both SCSI_IPR_TRACE and SCSI_IPR_DUMP should be defaulted to
yes when SCSI_IPR is enabled.
Signed-off-by: Brian King <brking@us.ibm.com>
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (54 commits)
[SCSI] Initial Commit of qla4xxx
[SCSI] raid class: handle component-add errors
[SCSI] SCSI megaraid_sas: handle thrown errors
[SCSI] SCSI aic94xx: handle sysfs errors
[SCSI] SCSI st: fix error handling in module init, sysfs
[SCSI] SCSI sd: fix module init/exit error handling
[SCSI] SCSI osst: add error handling to module init, sysfs
[SCSI] scsi: remove hosts.h
[SCSI] scsi: Scsi_Cmnd convertion in aic7xxx_old.c
[SCSI] megaraid_sas: sets ioctl timeout and updates version,changelog
[SCSI] megaraid_sas: adds tasklet for cmd completion
[SCSI] megaraid_sas: prints pending cmds before setting hw_crit_error
[SCSI] megaraid_sas: function pointer for disable interrupt
[SCSI] megaraid_sas: frame count optimization
[SCSI] megaraid_sas: FW transition and q size changes
[SCSI] qla2xxx: Update version number to 8.01.07-k2.
[SCSI] qla2xxx: Stall mid-layer error handlers while rport is blocked.
[SCSI] qla2xxx: Add MODULE_FIRMWARE tags.
[SCSI] qla2xxx: Add support for host port state FC transport attribute.
[SCSI] qla2xxx: Add support for fabric name FC transport attribute.
open-iSCSI driver for Qlogic Corporation's iSCSI HBAs
Signed-off-by: Ravi Anand <ravi.anand@qlogic.com>
Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com>
Signed-off-by: Doug Maxey <dwm@bubba.enoyolf.org>
