path: root/drivers/scsi/Kconfig
2017-09-13Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI fixes from James Bottomley: "A tiny update: one patch corrects a Kconfig problem with the shift of the SAS SMP code to BSG and the other removes a vestige of user space target mode" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: scsi: scsi_transport_sas: select BLK_DEV_BSGLIB scsi: Remove Scsi_Host.uspace_req_q
2017-09-05scsi: scsi_transport_sas: select BLK_DEV_BSGLIBArnd Bergmann
Without CONFIG_BLK_DEV_BSGLIB, we get a link error here: drivers/scsi/scsi_transport_sas.o: In function `sas_bsg_initialize': scsi_transport_sas.c:(.text+0xcc0): undefined reference to `bsg_setup_queue' scsi_transport_sas.c:(.text+0xd10): undefined reference to `bsg_setup_queue' drivers/scsi/scsi_transport_sas.o: In function `sas_smp_dispatch': scsi_transport_sas.c:(.text+0xe8c): undefined reference to `bsg_job_done' This modifies the Kconfig 'select' statement accordingly, and matching what we do for the other two scsi_transport implementations that use bsglib. Fixes: 651a01364994 ("scsi: scsi_transport_sas: switch to bsg-lib for SMP passthrough") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-08-16Revert "scsi: default to scsi-mq"Christoph Hellwig
Defaulting to scsi-mq in 4.13-rc has shown various regressions on setups that we didn't previously consider. Fixes for them are in progress, but too invasive to make it in this cycle. So for now revert the commit that defaults to blk-mq for SCSI. For 4.14 we'll plan to try again with these fixes. This reverts commit 5c279bd9e40624f4ab6e688671026d6005b066fa. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-07-24scsi: lpfc: fix linking against modular NVMe supportArnd Bergmann
When LPFC is built-in but NVMe is a loadable module, we fail to link the kernel: drivers/scsi/built-in.o: In function `lpfc_nvme_create_localport': (.text+0x156a82): undefined reference to `nvme_fc_register_localport' drivers/scsi/built-in.o: In function `lpfc_nvme_destroy_localport': (.text+0x156eaa): undefined reference to `nvme_fc_unregister_remoteport' We can avoid this either by forcing lpfc to be a module, or by disabling NVMe support in this case. This implements the former. Fixes: 7d7080335f8d ("scsi: lpfc: Finalize Kconfig options for nvme") Cc: stable@vger.kernel.org Link: https://patchwork.kernel.org/patch/9636569/ Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: default to scsi-mqChristoph Hellwig
Remove the SCSI_MQ_DEFAULT config option and default to the blk-mq I/O path now that we had plenty of testing, and have I/O schedulers for blk-mq. The module option to disable the blk-mq path is kept around for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-15scsi: lpfc: Finalize Kconfig options for nvmeJames Smart
Reviewing the result of what was just added for Kconfig, we made a poor choice. It worked well for full kernel builds, but not so much for how it would be deployed on a distro. Here's the final result: - lpfc will compile in NVME initiator and/or NVME target support based on whether the kernel has the corresponding subsystem support. Kconfig is not used to drive this specifically for lpfc. - There is a module parameter, lpfc_enable_fc4_type, that indicates whether the ports will do FCP-only or FCP & NVME (NVME-only not yet possible due to dependency on fc transport). As FCP & NVME divvys up exchange resources, and given NVME will not be often initially, the default is changed to FCP only. Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com> Signed-off-by: James Smart <james.smart@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-06scsi: lpfc: Rework lpfc Kconfig for NVME optionsJames Smart
Reworked Kconfig so that lfpc only requires the scsi stack. NVME Initiator and NVME Target support can be enabled if the other NVMe subsystems have been enabled. Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com> Signed-off-by: James Smart <james.smart@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-02-23scsi: mac_scsi: Fix MAC_SCSI=m option when SCSI=mFinn Thain
The mac_scsi driver still gets disabled when SCSI=m. This should have been fixed back when I enabled the tristate but I didn't see the bug. Fixes: 6e9ae6d560e1 ("[PATCH] mac_scsi: Add module option to Kconfig") Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-02-22scsi: qedf: Add QLogic FastLinQ offload FCoE driver framework.Dupuis, Chad
The QLogic FastLinQ Driver for FCoE (qedf) is the FCoE specific module for 41000 Series Converged Network Adapters by QLogic. This patch consists of following changes: - MAINTAINERS Makefile and Kconfig changes for qedf - PCI driver registration - libfc/fcoe host level initialization - SCSI host template initialization and callbacks - Debugfs and log level infrastructure - Link handling - Firmware interface structures - QED core module initialization - Light L2 interface callbacks - I/O request initialization - Firmware I/O completion handling - Firmware ELS request/response handling - FIP request/response handled by the driver itself Signed-off-by: Nilesh Javali <nilesh.javali@cavium.com> Signed-off-by: Manish Rangankar <manish.rangankar@cavium.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@cavium.com> Signed-off-by: Arun Easi <arun.easi@cavium.com> Signed-off-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-02-22scsi: lpfc: add missing Kconfig NVME dependenciesJames Smart
Add missing Kconfig NVME dependencies. Signed-off-by: James Smart <james.smart@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-01-31block: make scsi_request and scsi ioctl support optionalChristoph Hellwig
We only need this code to support scsi, ide, cciss and virtio. And at least for virtio it's a deprecated feature to start with. This should shrink the kernel size for embedded device that only use, say eMMC a bit. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-12-14scsi: qedi: Add QLogic FastLinQ offload iSCSI driver framework.Manish Rangankar
The QLogic FastLinQ Driver for iSCSI (qedi) is the iSCSI specific module for 41000 Series Converged Network Adapters by QLogic. This patch consists of following changes: - MAINTAINERS Makefile and Kconfig changes for qedi, - PCI driver registration, - iSCSI host level initialization, - Debugfs and log level infrastructure. The following indiviual changes are merged into this commit: qedi: Add LL2 iSCSI interface for offload iSCSI. qedi: Add support for iSCSI session management. qedi: Add support for data path. Signed-off-by: Nilesh Javali <nilesh.javali@cavium.com> Signed-off-by: Adheer Chandravanshi <adheer.chandravanshi@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@cavium.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@cavium.com> Signed-off-by: Arun Easi <arun.easi@cavium.com> Signed-off-by: Manish Rangankar <manish.rangankar@cavium.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-17scsi: fc: Use bsg_destroy_jobJohannes Thumshirn
fc_destroy_bsgjob() and bsg_destroy_job() are now 1:1 copies, so use the latter. As bsg_destroy_job() comes from bsg-lib we need to select it in Kconfig once CONFOG_SCSI_FC_ATTRS is active. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-08scsi: g_NCR5380: add HAS_IOPORT_MAP dependencyArnd Bergmann
The driver was changed to call ioport_map, which breaks platforms that cannot provide this function: drivers/scsi/g_NCR5380.o: In function `generic_NCR5380_init_one.constprop.0': g_NCR5380.c:(.text.generic_NCR5380_init_one.constprop.0+0x388): undefined reference to `ioport_map' This adds a Kconfig dependency. Fixes: 04c40f82ccc5 ("scsi: g_NCR5380: Merge g_NCR5380 and g_NCR5380_mmio drivers") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-08scsi: g_NCR5380: Merge g_NCR5380 and g_NCR5380_mmio driversOndrej Zary
Merge the port-mapped IO and memory-mapped IO support (with the help of ioport_map) into the g_NCR5380 module and delete g_NCR5380_mmio. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.com> Tested-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-09-26scsi: dtc: remove from treeChristoph Hellwig
The driver has not seen any maintainer activity or other work that wasn't tree wide conversion or clenaups in the entire history of the git tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinicke <hare@suse.de> Acked-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-09-26scsi: t128: remove from treeChristoph Hellwig
2016-09-26scsi: pas16: remove from treeChristoph Hellwig
2016-09-26scsi: u14-34f: remove from treeChristoph Hellwig
The driver has not seen any maintainer activity or other work that wasn't tree wide conversion or clenaups in the entire history of the git tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinicke <hare@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-09-26scsi: ultrastor: remove from treeChristoph Hellwig
2016-09-26scsi: in2000: remove from treeChristoph Hellwig
2016-09-26scsi: wd7000: remove from treeChristoph Hellwig
2016-08-12smartpqi: initial commit of Microsemi smartpqi driverKevin Barnett
This initial commit contains Microsemi's smartpqi module. [mkp: Minor tweaks to apply to 4.9/scsi-queue] Reviewed-by: Scott Benesh <scott.benesh@microsemi.com> Reviewed-by: Kevin Barnett <kevin.barnett@microsemi.com> Signed-off-by: Kevin Barnett <kevin.barnett@microsemi.com> Signed-off-by: Don Brace <don.brace@microsemi.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The most notable item is IBM virtual SCSI target driver, that was originally ported to target-core back in 2010 by Tomo-san, and has been brought forward to v4.x code by Bryant Ly, Michael Cyr and co over the last months. Also included are two ORDERED task related bug-fixes Bryant + Michael found along the way using ibmvscsis with AIX guests, plus a few miscellaneous target-core + iscsi-target bug-fixes with associated stable tags" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: fix spelling mistake: "limitiation" -> "limitation" target: Fix residual overflow handling in target_complete_cmd_with_length tcm_fc: set and unset FCP_SPPF_TARG_FCN iscsi-target: Fix panic when adding second TCP connection to iSCSI session ibmvscsis: Initial commit of IBM VSCSI Tgt Driver target: Fix ordered task CHECK_CONDITION early exception handling target: Fix ordered task target_setup_cmd_from_cdb exception hang target: Fix max_unmap_lba_count calc overflow target: Fix race between iscsi-target connection shutdown + ABORT_TASK target: Fix missing complete during ABORT_TASK + CMD_T_FABRIC_STOP
2016-07-20ibmvscsis: Initial commit of IBM VSCSI Tgt DriverBryant G. Ly
This driver is a pick up of the old IBM VIO scsi Target Driver that was started by Nick and Fujita 2-4 years ago. http://comments.gmane.org/gmane.linux.scsi/90119 The driver provides a virtual SCSI device on IBM Power Servers. This patch contains the fifth version for an initial merge of the tcm ibmvscsis driver. More information on this driver and config can be found: https://github.com/powervm/ibmvscsis/wiki/Configuration http://www.linux-iscsi.org/wiki/IBM_vSCSI (Drop extra libsrp review breakage + Fix kconfig typo - nab) Signed-off-by: Steven Royer <seroyer@linux.vnet.ibm.com> Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Michael Cyr <mikecyr@linux.vnet.ibm.com> Signed-off-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com> Cc: FUJITA Tomonori <tomof@acm.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-07-12scsi: ultrastor.c depends on ISA_DMA_APIRandy Dunlap
Fix build when CONFIG_ISA_DMA_API is not enabled. Fixes these build errors (on x86_64): ../drivers/scsi/ultrastor.c: In function 'ultrastor_14f_detect': ../drivers/scsi/ultrastor.c:519:5: error: implicit declaration of function 'request_dma' [-Werror=implicit-function-declaration] if (config.dma_channel && request_dma(config.dma_channel,"Ultrastor")) { ^ ../drivers/scsi/ultrastor.c: In function 'ultrastor_release': ../drivers/scsi/ultrastor.c:658:3: error: implicit declaration of function 'free_dma' [-Werror=implicit-function-declaration] free_dma(shost->dma_channel); ^ Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-15lib: scatterlist: move SG pool code from SCSI driver to lib/sg_pool.cMing Lin
Now it's ready to move the mempool based SG chained allocator code from SCSI driver to lib/sg_pool.c, which will be compiled only based on a Kconfig symbol CONFIG_SG_POOL. SCSI selects CONFIG_SG_POOL. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ming Lin <ming.l@ssi.samsung.com> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-11g_ncr5380: Remove CONFIG_SCSI_GENERIC_NCR53C400Finn Thain
This change brings a number of improvements: fewer macros, better test coverage, simpler code and sane Kconfig options. The downside is a small chance of incompatibility (which seems unavoidable). CONFIG_SCSI_GENERIC_NCR53C400 exists to enable or inhibit pseudo DMA transfers when the driver is used with 53C400-compatible cards. Thanks to Ondrej Zary's patches, PDMA now works which means it can be enabled unconditionally. Due to bad design, CONFIG_SCSI_GENERIC_NCR53C400 ties together unrelated functionality as it sets both PSEUDO_DMA and BIOSPARAM macros. This patch effectively enables PSEUDO_DMA and disables BIOSPARAM. The defconfigs and the Kconfig default leave CONFIG_SCSI_GENERIC_NCR53C400 undefined. Red Hat 9 and CentOS 2.1 were the same. This leaves both PSEUDO_DMA and BIOSPARAM disabled. The effect of this patch should be better performance from enabling PSEUDO_DMA. On the other hand, Debian 4 and SLES 10 had CONFIG_SCSI_GENERIC_NCR53C400 enabled, so both PSEUDO_DMA and BIOSPARAM were enabled. This patch might affect configurations like this by disabling BIOSPARAM. My best guess is that this could be a problem only in the vanishingly rare case that 1) the CHS values stored in the boot device partition table are wrong and 2) a 5380 card is in use (because PDMA on 53C400 used to be broken). Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.com> Tested-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-11scsi: reduce CONFIG_SCSI_CONSTANTS=y impact by 8kRasmus Villemoes
On 64 bit, struct error_info has 6 bytes of padding, which amounts to over 4k of wasted space in the additional[] array. We could easily get rid of that by instead using separate arrays for the codes and the pointers. However, we can do even better than that and save an additional 6 bytes per entry: In the table, just store the sizeof() the corresponding string literal. The cumulative sum of these is then the appropriate offset into additional_text, which is built from the concatenation (with '\0's inbetween) of the strings. $ scripts/bloat-o-meter /tmp/vmlinux vmlinux add/remove: 0/0 grow/shrink: 1/1 up/down: 24/-8488 (-8464) function old new delta scsi_extd_sense_format 136 160 +24 additional 11312 2824 -8488 The Kconfig help text used to say that CONFIG_SCSI_CONSTANTS=y costs around 75 KB, but that was a little exaggerated. The actual number was closer to 44K, and 36K with this patch. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reviewed-by: Hannes Reinecke <hare@suse.com> Tested-by: Douglas Gilbert <dgilbert@interlog.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-03-05scsi: storvsc: Fix a build issue reported by kbuild test robotK. Y. Srinivasan
tree: https://na01.safelinks.protection.outlook.com/?url=https%3a%2f%2fgit.kernel.org%2fpub%2fscm%2flinux%2fkernel%2fgit%2ftorvalds%2flinux.git&data=01%7c01%7ckys%40microsoft.com%7ce2e0622715844b79ad7108d32796ec3c%7c72f988bf86f141af91ab2d7cd011db47%7c1&sdata=ubr4GbBaNS%2ftOz%2buJBk0CL9N0UNG9x2TidLgy6Yovg4%3d master head: 03c21cb775a313f1ff19be59c5d02df3e3526471 commit: dac582417bc449b1f7f572d3f1dd9d23eec15cc9 storvsc: Properly support Fibre Channel devices date: 3 weeks ago config: x86_64-randconfig-s3-01281016 (attached as .config) reproduce: git checkout dac582417bc449b1f7f572d3f1dd9d23eec15cc9 # save the attached .config to linux build tree make ARCH=x86_64 All errors (new ones prefixed by >>): drivers/built-in.o: In function `storvsc_remove': >> storvsc_drv.c:(.text+0x213af7): undefined reference to `fc_remove_host' drivers/built-in.o: In function `storvsc_drv_init': >> storvsc_drv.c:(.init.text+0xcbcc): undefined reference to `fc_attach_transport' >> storvsc_drv.c:(.init.text+0xcc06): undefined reference to `fc_release_transport' drivers/built-in.o: In function `storvsc_drv_exit': >> storvsc_drv.c:(.exit.text+0x123c): undefined reference to `fc_release_transport' With this commit, the storvsc driver depends on FC atttributes. Make this dependency explicit. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-01-23Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma updates from Doug Ledford: "Initial roundup of 4.5 merge window patches - Remove usage of ib_query_device and instead store attributes in ib_device struct - Move iopoll out of block and into lib, rename to irqpoll, and use in several places in the rdma stack as our new completion queue polling library mechanism. Update the other block drivers that already used iopoll to use the new mechanism too. - Replace the per-entry GID table locks with a single GID table lock - IPoIB multicast cleanup - Cleanups to the IB MR facility - Add support for 64bit extended IB counters - Fix for netlink oops while parsing RDMA nl messages - RoCEv2 support for the core IB code - mlx4 RoCEv2 support - mlx5 RoCEv2 support - Cross Channel support for mlx5 - Timestamp support for mlx5 - Atomic support for mlx5 - Raw QP support for mlx5 - MAINTAINERS update for mlx4/mlx5 - Misc ocrdma, qib, nes, usNIC, cxgb3, cxgb4, mlx4, mlx5 updates - Add support for remote invalidate to the iSER driver (pushed through the RDMA tree due to dependencies, acknowledged by nab) - Update to NFSoRDMA (pushed through the RDMA tree due to dependencies, acknowledged by Bruce)" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (169 commits) IB/mlx5: Unify CQ create flags check IB/mlx5: Expose Raw Packet QP to user space consumers {IB, net}/mlx5: Move the modify QP operation table to mlx5_ib IB/mlx5: Support setting Ethernet priority for Raw Packet QPs IB/mlx5: Add Raw Packet QP query functionality IB/mlx5: Add create and destroy functionality for Raw Packet QP IB/mlx5: Refactor mlx5_ib_qp to accommodate other QP types IB/mlx5: Allocate a Transport Domain for each ucontext net/mlx5_core: Warn on unsupported events of QP/RQ/SQ net/mlx5_core: Add RQ and SQ event handling net/mlx5_core: Export transport objects IB/mlx5: Expose CQE version to user-space IB/mlx5: Add CQE version 1 support to user QPs and SRQs IB/mlx5: Fix data validation in mlx5_ib_alloc_ucontext IB/sa: Fix netlink local service GFP crash IB/srpt: Remove redundant wc array IB/qib: Improve ipoib UD performance IB/mlx4: Advertise RoCE v2 support IB/mlx4: Create and use another QP1 for RoCEv2 IB/mlx4: Enable send of RoCE QP1 packets with IP/UDP headers ...
2016-01-13Merge remote-tracking branch 'mkp-scsi/4.5/scsi-queue' into miscJames Bottomley
2016-01-07Merge branch 'jejb-scsi' into miscJames Bottomley
2016-01-06atari_NCR5380: Remove RESET_BOOT, CONFIG_ATARI_SCSI_TOSHIBA_DELAY and ↵Finn Thain
CONFIG_ATARI_SCSI_RESET_BOOT The atari_NCR5380.c core driver now takes care of bus reset upon driver initialization if required (same as NCR5380.c). Move the Toshiba CD-ROM support into the core driver, enabled with a host flag, so that all NCR5380 drivers can make use of it. Drop the RESET_BOOT macros and the ATARI_SCSI_RESET_BOOT and ATARI_SCSI_TOSHIBA_DELAY Kconfig symbols, which are now redundant. Remove the atari_scsi_reset_boot(), mac_scsi_reset_boot() and sun3_scsi_reset_boot() routines. None of this duplicated code is needed now that all drivers can use NCR5380_maybe_reset_bus(). This brings atari_scsi, mac_scsi and sun3_scsi into line with all of the other NCR5380 drivers. The bus reset may raise an interrupt. That would be new behaviour for atari_scsi only when CONFIG_ATARI_SCSI_RESET_BOOT=n. The ST DMA interrupt is not assigned to atari_scsi at this stage, so CONFIG_ATARI_SCSI_RESET_BOOT=y may well be problematic already. Regardless, do_reset() now raises and clears the interrupt within local_irq_save/restore which should avoid problems. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Hannes Reinecke <hare@suse.com> Tested-by: Ondrej Zary <linux@rainbow-software.org> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-12-18ses: fix discovery of SATA devices in SAS enclosuresJames Bottomley
The current discovery routines use the VPD 0x83 inquiry page to find the device SAS address and match it to the end point in the enclosure. This doesn't work for SATA devices because expanders (or hosts) simply make up an endpoint address for STP and thus the address returned by the VPD page never matches. Instead of doing this, for SAS attached devices, match by the direct endpoint address instead. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2015-12-15Merge branch 'rdma-cq.2' of git://git.infradead.org/users/hch/rdma into ↵Doug Ledford
4.5/rdma-cq Signed-off-by: Doug Ledford <dledford@redhat.com> Conflicts: drivers/infiniband/ulp/srp/ib_srp.c - Conflicts with changes in ib_srp.c introduced during 4.4-rc updates
2015-12-11irq_poll: make blk-iopoll available outside the block layerChristoph Hellwig
The new name is irq_poll as iopoll is already taken. Better suggestions welcome. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
2015-12-03Merge branch 'mkp-fixes' into fixesJames Bottomley
2015-11-25hisi_sas: Add initial bare main driverJohn Garry
This patch adds the initial bare main driver for the HiSilicon SAS HBA. This only introduces the changes to build and load the main driver module. The complete driver consists of the core main module and also a module platform driver for driving the hw. The HBA is a platform device. Signed-off-by: John Garry <john.garry@huawei.com> Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-20scsi: hpsa: select CONFIG_SCSI_SAS_ATTRArnd Bergmann
The hpsa driver recently started using the sas transport class, but it does not ensure that the corresponding code is actually built, which may lead to a link error: drivers/built-in.o: In function `hpsa_free_sas_phy': (.text+0x1ce874): undefined reference to `sas_port_delete_phy' (.text+0x1ce87c): undefined reference to `sas_phy_free' drivers/built-in.o: In function `hpsa_alloc_sas_port': (.text+0x1ceb9c): undefined reference to `sas_port_alloc_num' (.text+0x1ceba8): undefined reference to `sas_port_add' drivers/built-in.o: In function `hpsa_init': (.init.text+0x8838): undefined reference to `sas_attach_transport' (.init.text+0x8868): undefined reference to `sas_release_transport This adds 'select SCSI_SAS_ATTR' in the Kconfig entry, just like we do for all other drivers using those functions. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: d04e62b9d63a ("hpsa: add in sas transport class") Reviewed-by: Christoph Hellwig <hch@lst.de> Acked-by: Don Brace <don.brace@pmcs.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-20scsi: advansys needs ISA dma api for ISA supportArnd Bergmann
The advansys drvier uses the request_dma function that is used on ISA machines for the internal DMA controller, which causes build errors on platforms that have ISA slots but do not provide the ISA DMA API: drivers/scsi/advansys.c: In function 'advansys_board_found': drivers/scsi/advansys.c:11300:10: error: implicit declaration of function 'request_dma' [-Werror=implicit-function-declaration] The problem now showed up in ARM randconfig builds after commit 6571fb3f8b7f ("advansys: Update to version 3.5 and remove compilation warning") made it possible to build on platforms that have neither VIRT_TO_BUS nor ISA_DMA_API but that do have ISA. This adds the missing dependency. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-13Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull final round of SCSI updates from James Bottomley: "Sorry for the delay in this patch which was mostly caused by getting the merger of the mpt2/mpt3sas driver, which was seen as an essential item of maintenance work to do before the drivers diverge too much. Unfortunately, this caused a compile failure (detected by linux-next), which then had to be fixed up and incubated. In addition to the mpt2/3sas rework, there are updates from pm80xx, lpfc, bnx2fc, hpsa, ipr, aacraid, megaraid_sas, storvsc and ufs plus an assortment of changes including some year 2038 issues, a fix for a remove before detach issue in some drivers and a couple of other minor issues" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (141 commits) mpt3sas: fix inline markers on non inline function declarations sd: Clear PS bit before Mode Select. ibmvscsi: set max_lun to 32 ibmvscsi: display default value for max_id, max_lun and max_channel. mptfusion: don't allow negative bytes in kbuf_alloc_2_sgl() scsi: pmcraid: replace struct timeval with ktime_get_real_seconds() mvumi: 64bit value for seconds_since1970 be2iscsi: Fix bogus WARN_ON length check scsi_scan: don't dump trace when scsi_prep_async_scan() is called twice mpt3sas: Bump mpt3sas driver version to 09.102.00.00 mpt3sas: Single driver module which supports both SAS 2.0 & SAS 3.0 HBAs mpt2sas, mpt3sas: Update the driver versions mpt3sas: setpci reset kernel oops fix mpt3sas: Added OEM Gen2 PnP ID branding names mpt3sas: Refcount fw_events and fix unsafe list usage mpt3sas: Refcount sas_device objects and fix unsafe list usage mpt3sas: sysfs attribute to report Backup Rail Monitor Status mpt3sas: Ported WarpDrive product SSS6200 support mpt3sas: fix for driver fails EEH, recovery from injected pci bus error mpt3sas: Manage MSI-X vectors according to HBA device type ...
2015-11-11mpt3sas: Single driver module which supports both SAS 2.0 & SAS 3.0 HBAsSreekanth Reddy
Modified the mpt3sas driver to have a single driver module which supports both SAS 2.0 & SAS 3.0 HBA devices. * Added SAS 2.0 HBA device IDs to the mpt3sas_pci_table pci table. * Created two separate SCSI host templates for SAS2 and SAS3 HBAs so that, during the driver load time driver can use corresponding host template(based the pci device ID) while registering a scsi host adapter instance for that pci device. * Registered two IOCTL devices, mpt2ctl is for SAS2 HBAs & mpt3ctl for SAS3 HBAs. Also updated the code to make sure that mpt2ctl device processes only those ioctl cmds issued for the SAS2 HBAs and mpt3ctl device processes only those ioctl cmds issued for the SAS3 HBAs. * Added separate indexing for SAS2 and SAS3 HBAs. * Replaced compile time check 'MPT2SAS_SCSI' to run time check 'hba_mpi_version_belonged' whereever needed. * Aliased this merged driver to mpt2sas using MODULE_ALIAS. * Moved global varaible 'driver_name' to per adapter instance variable. * Created two raid function template and used corresponding raid function templates based on the run time check 'hba_mpi_version_belonged'. * Moved mpt2sas_warpdrive.c file from mpt2sas to mpt3sas folder and renamed it as mpt3sas_warpdrive.c. * Also renamed the functions in mpt3sas_warpdrive.c file to follow current driver function name convention. * Updated the Makefile to build mpt3sas_warpdrive.o file for these WarpDrive-specific functions. * Also in function mpt3sas_setup_direct_io(), used sector_div() API instead of division operator (which gives compilation errors on 32 bit machines). * Removed mpt2sas files, mpt2sas directory & mpt3sas_module.c file. * Added module parameter 'hbas_to_enumerate' which permits using this merged driver as a legacy mpt2sas driver or as a legacy mpt3sas driver. Here are the available options for this module parameter: 0 - Merged driver which enumerates both SAS 2.0 & SAS 3.0 HBAs 1 - Acts as legacy mpt2sas driver, which enumerates only SAS 2.0 HBAs 2 - Acts as legacy mpt3sas driver, which enumerates only SAS 3.0 HBAs * Removed mpt2sas entries from SCSI's Kconfig and Makefile files. Signed-off-by: Sreekanth Reddy <Sreekanth.Reddy@avagotech.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "Trivial stuff from trivial tree that can be trivially summed up as: - treewide drop of spurious unlikely() before IS_ERR() from Viresh Kumar - cosmetic fixes (that don't really affect basic functionality of the driver) for pktcdvd and bcache, from Julia Lawall and Petr Mladek - various comment / printk fixes and updates all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: bcache: Really show state of work pending bit hwmon: applesmc: fix comment typos Kconfig: remove comment about scsi_wait_scan module class_find_device: fix reference to argument "match" debugfs: document that debugfs_remove*() accepts NULL and error values net: Drop unlikely before IS_ERR(_OR_NULL) mm: Drop unlikely before IS_ERR(_OR_NULL) fs: Drop unlikely before IS_ERR(_OR_NULL) drivers: net: Drop unlikely before IS_ERR(_OR_NULL) drivers: misc: Drop unlikely before IS_ERR(_OR_NULL) UBI: Update comments to reflect UBI_METAONLY flag pktcdvd: drop null test before destroy functions
2015-09-29Kconfig: remove comment about scsi_wait_scan moduleRolf Eike Beer
This module has been removed in commit 6072609d9bb91ff54aee3ef29304bd5b4fc88aae ([SCSI] Remove scsi_wait_scan module), so this module is gone since 3.6. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-07-30cxlflash: Base support for IBM CXL Flash AdapterMatthew R. Ochs
SCSI device driver to support filesystem access on the IBM CXL Flash adapter. Supported-by: Stephen Bates <stephen.bates@pmcs.com> Reviewed-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Matthew R. Ochs <mrochs@linux.vnet.ibm.com> Signed-off-by: Manoj N. Kumar <manoj@linux.vnet.ibm.com> Reviewed-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-06-23Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is the usual grab bag of driver updates (lpfc, hpsa, megaraid_sas, cxgbi, be2iscsi) plus an assortment of minor updates. There is also one new driver: the Cisco snic. The advansys driver has been rewritten to get rid of the warning about converting it to the DMA API, the tape statistics patch got in and finally, there's a resuffle of SCSI header files to separate more cleanly initiator from target mode (and better share the common definitions)" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (156 commits) snic: driver for Cisco SCSI HBA qla2xxx: Fix indentation qla2xxx: Comment out unreachable code fusion: remove dead MTRR code advansys: fix compilation errors and warnings when CONFIG_PCI is not set mptsas: fix depth param in scsi_track_queue_full megaraid: fix irq setup process regression lpfc: Update version to 10.7.0.0 for upstream patch set. lpfc: Fix to drop PLOGIs from fabric node till LOGO processing completes lpfc: Fix scsi task management error message. lpfc: Fix cq_id masking problem. lpfc: Fix scsi prep dma buf error. lpfc: Add support for using block multi-queue lpfc: Devices are not discovered during takeaway/giveback testing lpfc: Fix vport deletion failure. lpfc: Check for active portpeerbeacon. lpfc: Update driver version for upstream patch set 10.6.0.1. lpfc: Change buffer pool empty message to miscellaneous category lpfc: Fix incorrect log message reported for empty FCF record. lpfc: Fix rport leak. ...
2015-06-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "As usual, mostly comment, kerneldoc and printk() fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: lpfc: Grammar s/an negative/a negative/ ARM: lib/lib1funcs.S: fix typo s/substractions/subtractions/ cx25821: cx25821-medusa-reg.h: fix 0x0x prefix lib: crc-itu-t.[ch] fix 0x0x prefix in integer constants rapidio: Fix kerneldoc and comment qla4xxx: Fix printk() in qla4_83xx_read_reset_template() and qla4_83xx_pre_loopback_config() treewide: Kconfig: fix wording / spelling usb/serial: fix grammar in Kconfig help text for FTDI_SIO megaraid_sas: fix kerneldoc netfilter: ebtables: fix comment grammar drm/radeon: fix comment isdn: fix grammar in comment ARM: KVM: fix comment
2015-06-19snic: driver for Cisco SCSI HBANarsimhulu Musini
Cisco has developed a new PCI HBA interface called sNIC, which stands for SCSI NIC. This is a new storage feature supported on specialized network adapter. The new PCI function provides a uniform host interface and abstracts backend storage. [jejb: fix up checkpatch errors] Signed-off-by: Narsimhulu Musini <nmusini@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-05-26treewide: Kconfig: fix wording / spellingMasanari Iida
This patch fix spelling typos in Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
