path: root/drivers/s390
2013-09-30s390/sclp: properly detect line mode consoleChristian Borntraeger
To detect a line mode console we need a message event type for the receive mask and a command event type for the send mask. Checking for a MSG event in the sclp send mask was wrong and might result in line mode consoles not being detected. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-30s390/3270: fix return value check in tty3270_resize_work()Wei Yongjun
In case of error, the function tty3270_alloc_screen() returns ERR_PTR() and never returns NULL. The NULL test in the return value check should be replaced with IS_ERR(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-11s390/vmcore: use vmcore for zfcpdumpMichael Holzheu
Modify the s390 copy_oldmem_page() and remap_oldmem_pfn_range() function for zfcpdump to read from the HSA memory if memory below HSA_SIZE bytes is requested. Otherwise real memory is used. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: Jan Willeke <willeke@de.ibm.com> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-07s390/ap_bus: use and-mask instead of a castHeiko Carstens
Let's get rid of another sparse false positive: drivers/s390/crypto/ap_bus.c:416:64: warning: cast truncates bits from constant value (102030405060708 becomes 5060708) So instead of using a cast let's use an and-mask. That way sparse remains silent and one doesn't always have to check if this is a valid warning/bug or just a false positive. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2013-09-07s390: make various functions static, add declarations to header filesHeiko Carstens
Make various functions static, add declarations to header files to fix a couple of sparse findings. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2013-09-04s390/irq: rework irq subclass handlingHeiko Carstens
Let's not add a function for every external interrupt subclass for which we need reference counting. Just have two register/unregister functions which have a subclass parameter: void irq_subclass_register(enum irq_subclass subclass); void irq_subclass_unregister(enum irq_subclass subclass); Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2013-09-03Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull first round of SCSI updates from James Bottomley: "This patch set is a set of driver updates (ufs, zfcp, lpfc, mpt2/3sas, qla4xxx, qla2xxx [adding support for ISP8044 + other things]). We also have a new driver: esas2r which has a number of static checker problems, but which I expect to resolve over the -rc course of 3.12 under the new driver exception. We also have the error return that were discussed at LSF" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (118 commits) [SCSI] sg: push file descriptor list locking down to per-device locking [SCSI] sg: checking sdp->detached isn't protected when open [SCSI] sg: no need sg_open_exclusive_lock [SCSI] sg: use rwsem to solve race during exclusive open [SCSI] scsi_debug: fix logical block provisioning support when unmap_alignment != 0 [SCSI] scsi_debug: fix endianness bug in sdebug_build_parts() [SCSI] qla2xxx: Update the driver version to 8.06.00.08-k. [SCSI] qla2xxx: print MAC via %pMR. [SCSI] qla2xxx: Correction to message ids. [SCSI] qla2xxx: Correctly print out/in mailbox registers. [SCSI] qla2xxx: Add a new interface to update versions. [SCSI] qla2xxx: Move queue depth ramp down message to i/o debug level. [SCSI] qla2xxx: Select link initialization option bits from current operating mode. [SCSI] qla2xxx: Add loopback IDC-TIME-EXTEND aen handling support. [SCSI] qla2xxx: Set default critical temperature value in cases when ISPFX00 firmware doesn't provide it [SCSI] qla2xxx: QLAFX00 make over temperature AEN handling informational, add log for normal temperature AEN [SCSI] qla2xxx: Correct Interrupt Register offset for ISPFX00 [SCSI] qla2xxx: Remove handling of Shutdown Requested AEN from qlafx00_process_aen(). [SCSI] qla2xxx: Send all AENs for ISPFx00 to above layers. [SCSI] qla2xxx: Add changes in initialization for ISPFX00 cards with BIOS ...
2013-09-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull first batch of s390 updates from Martin Schwidefsky: "The most interesting change is that Martin converted s390 to generic hardirqs. Which means that all current architectures have been converted and that CONFIG_GENERIC_HARDIRQS can be removed. Martin prepared a patch for that already (see genirq branch), but the best time to merge that is probably at the end of the merge window / begin of -rc1. Another patch converts s390 to software referenced bits instead of relying on the reference bit in the storage key. Therefore s390 doesn't use storage keys anymore, except for kvm. Besides that we have improvements, cleanups and fixes in PCI, DASD and all over the place." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (32 commits) s390/pci: use virtual memory for iommu bitmap s390/cio: fix unlocked access of global bitmap s390/pci: update function handle after resume from hibernate s390/pci: try harder to modify a function s390/pci: split lpf s390/hibernate: add early resume function s390/pci: add recover sysfs knob s390/pci: use claim_resource s390/pci/hotplug: convert to be builtin only s390/mm: implement software referenced bits s390/dasd: fix statistics for recovered requests s390/tx: allow program interruption filtering in user space s390/pgtable: fix mprotect for single-threaded KVM guests s390/time: return with irqs disabled from psw_idle s390/kprobes: add support for compare and branch instructions s390/switch_to: fix save_access_regs() / restore_access_regs() s390/bitops: fix inline assembly constraints s390/dasd: enable raw_track_access reads without direct I/O s390/mm: introduce ptep_flush_lazy helper s390/time: clock comparator revalidation ...
2013-09-03[SCSI] zfcp: enable FCP hardware data router by defaultSteffen Maier
Enabling the data router support by default can increase performance in certain situations. It is safe to do so and tolerated in LPAR and under z/VM in case there is no data router support in that environment. Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Reviewed-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-09-03[SCSI] zfcp: dead code removalMartin Peschke
Get rid of unused function zfcp_fsf_get_req and corresponding prototype definition. Commit a54ca0f62f953898b05549391ac2a8a4dad6482b in v2.6.28 "[SCSI] zfcp: Redesign of the debug tracing for HBA records." accidentally introduced this code which was dead in the first place. Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-09-03[SCSI] zfcp: cleanup use of obsolete strict_strto* functionsMartin Peschke
strict_strtoul and friends are obsolete. Use kstrtoul functions instead. Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-09-03[SCSI] zfcp: consistently use appropriate SBAL flag definitionsMartin Peschke
minor cleanup for status read request Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-08-30s390/cio: fix unlocked access of global bitmapSebastian Ott
Access to the slow_subchannel_set has to be secured via the slow_subchannel_lock. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-30s390/hibernate: add early resume functionSebastian Ott
Some functions that do arch specific resume actions are called directly from swsusp_asm64.S . Before we add another function call provide a generic s390_early_resume function which can be used for this purpose. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-28s390/dasd: fix statistics for recovered requestsStefan Weinhuber
When a recovery cqr is cleaned up, copy the start time, stop time, and start device to the original cqr. These times are needed later when the original request is finalized and counted in the DASD statistics. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-22[SCSI] zfcp: remove access control tables interface (keep sysfs files)Martin Peschke
By popular demand, this patch brings back a couple of sysfs attributes removed by commit 663e0890e31cb85f0cca5ac1faaee0d2d52880b5 "[SCSI] zfcp: remove access control tables interface". The content has been irrelevant for years, but the files must be there forever for whatever user space tools that may rely on them. Since these files always return a constant value, a new stripped down show-macro was required. Otherwise build warnings would have been introduced. Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-08-22[SCSI] zfcp: fix schedule-inside-lock in scsi_device list loopsMartin Peschke
BUG: sleeping function called from invalid context at kernel/workqueue.c:2752 in_atomic(): 1, irqs_disabled(): 1, pid: 360, name: zfcperp0.0.1700 CPU: 1 Not tainted 3.9.3+ #69 Process zfcperp0.0.1700 (pid: 360, task: 0000000075b7e080, ksp: 000000007476bc30) <snip> Call Trace: ([<00000000001165de>] show_trace+0x106/0x154) [<00000000001166a0>] show_stack+0x74/0xf4 [<00000000006ff646>] dump_stack+0xc6/0xd4 [<000000000017f3a0>] __might_sleep+0x128/0x148 [<000000000015ece8>] flush_work+0x54/0x1f8 [<00000000001630de>] __cancel_work_timer+0xc6/0x128 [<00000000005067ac>] scsi_device_dev_release_usercontext+0x164/0x23c [<0000000000161816>] execute_in_process_context+0x96/0xa8 [<00000000004d33d8>] device_release+0x60/0xc0 [<000000000048af48>] kobject_release+0xa8/0x1c4 [<00000000004f4bf2>] __scsi_iterate_devices+0xfa/0x130 [<000003ff801b307a>] zfcp_erp_strategy+0x4da/0x1014 [zfcp] [<000003ff801b3caa>] zfcp_erp_thread+0xf6/0x2b0 [zfcp] [<000000000016b75a>] kthread+0xf2/0xfc [<000000000070c9de>] kernel_thread_starter+0x6/0xc [<000000000070c9d8>] kernel_thread_starter+0x0/0xc Apparently, the ref_count for some scsi_device drops down to zero, triggering device removal through execute_in_process_context(), while the lldd error recovery thread iterates through a scsi device list. Unfortunately, execute_in_process_context() decides to immediately execute that device removal function, instead of scheduling asynchronous execution, since it detects process context and thinks it is safe to do so. But almost all calls to shost_for_each_device() in our lldd are inside spin_lock_irq, even in thread context. Obviously, schedule() inside spin_lock_irq sections is a bad idea. Change the lldd to use the proper iterator function, __shost_for_each_device(), in combination with required locking. Occurences that need to be changed include all calls in zfcp_erp.c, since those might be executed in zfcp error recovery thread context with a lock held. Other occurences of shost_for_each_device() in zfcp_fsf.c do not need to be changed (no process context, no surrounding locking). The problem was introduced in Linux 2.6.37 by commit b62a8d9b45b971a67a0f8413338c230e3117dff5 "[SCSI] zfcp: Use SCSI device data zfcp_scsi_dev instead of zfcp_unit". Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Cc: stable@vger.kernel.org #2.6.37+ Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-08-22[SCSI] zfcp: fix lock imbalance by reworking request queue lockingMartin Peschke
This patch adds wait_event_interruptible_lock_irq_timeout(), which is a straight-forward descendant of wait_event_interruptible_timeout() and wait_event_interruptible_lock_irq(). The zfcp driver used to call wait_event_interruptible_timeout() in combination with some intricate and error-prone locking. Using wait_event_interruptible_lock_irq_timeout() as a replacement nicely cleans up that locking. This rework removes a situation that resulted in a locking imbalance in zfcp_qdio_sbal_get(): BUG: workqueue leaked lock or atomic: events/1/0xffffff00/10 last function: zfcp_fc_wka_port_offline+0x0/0xa0 [zfcp] It was introduced by commit c2af7545aaff3495d9bf9a7608c52f0af86fb194 "[SCSI] zfcp: Do not wait for SBALs on stopped queue", which had a new code path related to ZFCP_STATUS_ADAPTER_QDIOUP that took an early exit without a required lock being held. The problem occured when a special, non-SCSI I/O request was being submitted in process context, when the adapter's queues had been torn down. In this case the bug surfaced when the Fibre Channel port connection for a well-known address was closed during a concurrent adapter shut-down procedure, which is a rare constellation. This patch also fixes these warnings from the sparse tool (make C=1): drivers/s390/scsi/zfcp_qdio.c:224:12: warning: context imbalance in 'zfcp_qdio_sbal_check' - wrong count at exit drivers/s390/scsi/zfcp_qdio.c:244:5: warning: context imbalance in 'zfcp_qdio_sbal_get' - unexpected unlock Last but not least, we get rid of that crappy lock-unlock-lock sequence at the beginning of the critical section. It is okay to call zfcp_erp_adapter_reopen() with req_q_lock held. Reported-by: Mikulas Patocka <mpatocka@redhat.com> Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Cc: stable@vger.kernel.org #2.6.35+ Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-08-22s390/dasd: enable raw_track_access reads without direct I/OStefan Weinhuber
The ECKD protocol supports reading of tracks with arbitrary format as raw track images. The DASD device driver supports this in its raw_track_access mode. In this mode it maps each track to sixteen 4096 byte sectors and rejects all requests that are not properly aligned to this mapping. An application that wants to use a DASD in raw_track_access mode will usually use direct I/O to make sure that properly aligned requests are directly submitted to the driver. However, applications that are not aware of this mode, e.g. udev, will encounter I/O errors. To make the use without direct I/O possible and avoid this kind of alignment errors, we now pad unaligned read requests with a dummy page, so that we can always read full tracks. Please note that writing is still only possible for full track images that are properly aligned. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-22s390/sclp: reword cpu capability change messageHeiko Carstens
Change wording for the cpu capabiity changed message: If such an event occurs it only means that a cpu capability *may* have changed. A cpu capability change event may also occur for other reasons. Also change the severity of the message from warning to informational. If such an event happens user space should into /proc/sysinfo and verify if some capability values changed, if that is of interest. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-22s390: convert interrupt handling to use generic hardirqMartin Schwidefsky
With the introduction of PCI it became apparent that s390 should convert to generic hardirqs as too many drivers do not have the correct dependency for GENERIC_HARDIRQS. On the architecture level s390 does not have irq lines. It has external interrupts, I/O interrupts and adapter interrupts. This patch hard-codes all external interrupts as irq #1, all I/O interrupts as irq #2 and all adapter interrupts as irq #3. The additional information from the lowcore associated with the interrupt is stored in the pt_regs of the interrupt frame, where the interrupt handler can pick it up. For PCI/MSI interrupts the adapter interrupt handler scans the relevant bit fields and calls generic_handle_irq with the virtual irq number for the MSI interrupt. Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-22s390/airq: introduce adapter interrupt vector helperMartin Schwidefsky
The PCI code is the first user of adapter interrupts vectors. Add a set of helpers to airq.c to separate the adatper interrupt code from the PCI bits. The helpers allow for adapter interrupt vectors of any size. Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-22s390/dasd: cleanup timeout and transport error messagesStefan Weinhuber
Just a small update to the wording of the messages, to bring them more in line with our other messages. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-22s390: replace strict_strtoul() with kstrtoul()Jingoo Han
The usage of strict_strtoul() is not preferred, because strict_strtoul() is obsolete. Thus, kstrtoul() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-30s390/dasd: fix hanging devices after path eventsStefan Haberland
The processing of the dasd_block tasklet may have been interrupted by a path event. Restart the dasd tasklets in sleep_on_immediately function. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-19s390/zcrypt: Alias for new zcrypt device driver base moduleIngo Tuchscherer
The zcrypt device driver has been split into base/bus module, api-module, card modules and message type modules. The base module has been renamed from z90crypt to ap. A module alias (with the well-known z90crypt identifier) will be introduced that enable users to use their existing way to load the zcrypt device driver. Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-16s390/qdio: remove unused variableSebastian Ott
Fix a "set but not used" warning found via make W=1. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-04Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull first round of SCSI updates from James Bottomley: "The patch set is mostly driver updates (usf, zfcp, lpfc, mpt2sas, megaraid_sas, bfa, ipr) and a few bug fixes. Also of note is that the Buslogic driver has been rewritten to a better coding style and 64 bit support added. We also removed the libsas limitation on 16 bytes for the command size (currently no drivers make use of this)" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (101 commits) [SCSI] megaraid: minor cut and paste error fixed. [SCSI] ufshcd-pltfrm: remove unnecessary dma_set_coherent_mask() call [SCSI] ufs: fix register address in UIC error interrupt handling [SCSI] ufshcd-pltfrm: add missing empty slot in ufs_of_match[] [SCSI] ufs: use devres functions for ufshcd [SCSI] ufs: Fix the response UPIU length setting [SCSI] ufs: rework link start-up process [SCSI] ufs: remove version check before IS reg clear [SCSI] ufs: amend interrupt configuration [SCSI] ufs: wrap the i/o access operations [SCSI] storvsc: Update the storage protocol to win8 level [SCSI] storvsc: Increase the value of scsi timeout for storvsc devices [SCSI] MAINTAINERS: Add myself as the maintainer for BusLogic SCSI driver [SCSI] BusLogic: Port driver to 64-bit. [SCSI] BusLogic: Fix style issues [SCSI] libiscsi: Added new boot entries in the session sysfs [SCSI] aacraid: Fix for arrays are going offline in the system. System hangs [SCSI] ipr: IOA Status Code(IOASC) update [SCSI] sd: Update WRITE SAME heuristics [SCSI] fnic: potential dead lock in fnic_is_abts_pending() ...
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-07-03Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - various misc bits - I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been distracted. There has been quite a bit of activity. - About half the MM queue - Some backlight bits - Various lib/ updates - checkpatch updates - zillions more little rtc patches - ptrace - signals - exec - procfs - rapidio - nbd - aoe - pps - memstick - tools/testing/selftests updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits) tools/testing/selftests: don't assume the x bit is set on scripts selftests: add .gitignore for kcmp selftests: fix clean target in kcmp Makefile selftests: add .gitignore for vm selftests: add hugetlbfstest self-test: fix make clean selftests: exit 1 on failure kernel/resource.c: remove the unneeded assignment in function __find_resource aio: fix wrong comment in aio_complete() drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode drivers/memstick/host/r592.c: convert to module_pci_driver drivers/memstick/host/jmb38x_ms: convert to module_pci_driver pps-gpio: add device-tree binding and support drivers/pps/clients/pps-gpio.c: convert to module_platform_driver drivers/pps/clients/pps-gpio.c: convert to devm_* helpers drivers/parport/share.c: use kzalloc Documentation/accounting/getdelays.c: avoid strncpy in accounting tool aoe: update internal version number to v83 aoe: update copyright date aoe: perform I/O completions in parallel ...
2013-07-03clean up scary strncpy(dst, src, strlen(src)) usesKees Cook
Fix various weird constructions of strncpy(dst, src, strlen(src)). Length limits should be about the space available in the destination, not repurposed as a method to either always include or always exclude a trailing NULL byte. Either the NULL should always be copied (using strlcpy), or it should not be copied (using something like memcpy). Readable code should not depend on the weird behavior of strncpy when it hits the length limit. Better to avoid the anti-pattern entirely. [akpm@linux-foundation.org: revert getdelays.c part due to missing bsd/string.h] Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [staging] Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [acpi] Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ursula Braun <ursula.braun@de.ibm.com> Cc: Frank Blaschka <blaschka@linux.vnet.ibm.com> Cc: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-01s390/dasd: Fail all requests when DASD_FLAG_ABORTIO is setHannes Reinecke
Whenever a DASD request encounters a timeout we might need to abort all outstanding requests on this or even other devices. This is especially useful if one wants to fail all devices on one side of a RAID10 configuration, even though only one device exhibited an error. To handle this I've introduced a new device flag DASD_FLAG_ABORTIO. This flag is evaluated in __dasd_process_request_queue() and will invoke blk_abort_request() for all outstanding requests with DASD_CQR_FLAGS_FAILFAST set. This will cause any of these requests to be aborted immediately if the blk_timeout function is activated. The DASD_FLAG_ABORTIO is also evaluated in __dasd_process_request_queue to abort all new request which would have the DASD_CQR_FLAGS_FAILFAST bit set. The flag can be set with the new ioctls 'BIODASDABORTIO' and removed with 'BIODASDALLOWIO'. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: Add 'timeout' attributeHannes Reinecke
This patch adds a 'timeout' attibute to the DASD driver. When set to non-zero, the blk_timeout function will be enabled with the timeout specified in the attribute. Setting 'timeout' to '0' will disable block timeouts. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01block/dasd: detailed I/O errorsHannes Reinecke
The DASD driver is using FASTFAIL as an equivalent to the transport errors in SCSI. And the 'steal lock' function maps roughly to a reservation error. So we should be returning the appropriate error codes when completing a request. Acked-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: Reduce amount of messages for specific errorsHannes Reinecke
Whenever a request has been aborted internally by the driver there is no sense data to be had. And printing lots of messages stalls the system, so better to print out a short one-liner. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: Implement block timeout handlingHannes Reinecke
This patch implements generic block layer timeout handling callbacks for DASDs. When the timeout expires the respective cqr is aborted. With this timeout handler time-critical request abort is guaranteed as the abort does not depend on the internal state of the various DASD driver queues. Signed-off-by: Hannes Reinecke <hare@suse.de> Acked-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: process all requests in the device taskletHannes Reinecke
Originally the DASD device tasklet would process the entries on the ccw_queue until the first non-final request was found. Which was okay as long as all requests have the same retries and expires parameter. However, as we're now allowing to modify both it is possible to have requests _after_ the first request which already have expired. So we need to check all requests in the device tasklet. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: make number of retries configurableHannes Reinecke
Instead of having the number of retries hard-coded in the various functions we should be using a default retry value, which can be modified via sysfs. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: Clarify commentHannes Reinecke
dasd_cancel_req will never return 1, only 0. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-28treewide: relase -> releaseGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-06-26s390/vmwatchdog: do not use static dataSebastian Ott
Using static data for fields which are accessed by HW will fail if the driver is build as a module (since this would be vmalloc'ed memory). This Bug was revealed via "s390: remove virt_to_phys implementation" - the old virt_to_phys implementation would have translated the address but it was not guaranteed that the memory was contiguous. Fix it by putting the data on the stack. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/airq: simplify adapter interrupt codeMartin Schwidefsky
There are three users of adapter interrupts: AP, QDIO and PCI. Each registers a single adapter interrupt with independent ISCs. Define a "struct airq" with the interrupt handler, a pointer and a mask for the local summary indicator and the ISC for the adapter interrupt source. Convert the indicator array with its fixed number of adapter interrupt sources per ISE to an array of hlists. This removes the limitation to 32 adapter interrupts per ISC and allows for arbitrary memory locations for the local summary indicator. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/sclp: remove duplicated include from sclp_ctl.cWei Yongjun
Remove duplicated include. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/irq: store interrupt information in pt_regsMartin Schwidefsky
Copy the interrupt parameters from the lowcore to the pt_regs structure in entry[64].S and reduce the arguments of the low level interrupt handler to the pt_regs pointer only. In addition move the test-pending-interrupt loop from do_IRQ to entry[64].S to make sure that interrupt information is always delivered via pt_regs. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/drivers: Cocci spatch "ptr_ret.spatch"Thomas Meyer
Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/net: Cocci spatch "ptr_ret.spatch"Thomas Meyer
2013-06-26s390/dasd: Cocci spatch "ptr_ret.spatch"Thomas Meyer
2013-06-26s390/ap_bus: Cocci spatch "ptr_ret.spatch"Thomas Meyer
2013-06-26s390/chsc: Use snprintf instead of sprintfMichael Holzheu
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
