path: root/drivers/s390
2010-01-13[S390] tape_char: add missing compat_ptr conversionHeiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-01-13[S390] zcrypt: add sanity check before copy_from_user()Heiko Carstens
It's not obvious that copy_from_user() is called with a sane length parameter here. Even though it currently seems to be correct better add a check to prevent stack corruption / exploits. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-01-13[S390] con3215: remove empty ioctl functionHeiko Carstens
...instead of adding a compat ioctl function which would do nothing as well. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-01-13[S390] dasd: add proper compat pointer conversion for symmetrix ioctlHeiko Carstens
2010-01-13[S390] tape_block: remove ioctl functionHeiko Carstens
This is just a complicated construct which always returns -EINVAL. Just remove it. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-01-13[S390] fs3270: add missing compat ptr conversionHeiko Carstens
Add missing compat ptr conversion including two additional whitespace changes that aren't worth a separate patch. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-01-13[S390] vmcp: add missing compat ptr conversionHeiko Carstens
2010-01-13[S390] cio: add missing compat ptr conversionHeiko Carstens
2010-01-13[S390] dasd: add missing compat ptr conversionHeiko Carstens
2010-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits) sky2: Fix oops in sky2_xmit_frame() after TX timeout Documentation/3c509: document ethtool support af_packet: Don't use skb after dev_queue_xmit() vxge: use pci_dma_mapping_error to test return value netfilter: ebtables: enforce CAP_NET_ADMIN e1000e: fix and commonize code for setting the receive address registers e1000e: e1000e_enable_tx_pkt_filtering() returns wrong value e1000e: perform 10/100 adaptive IFS only on parts that support it e1000e: don't accumulate PHY statistics on PHY read failure e1000e: call pci_save_state() after pci_restore_state() netxen: update version to 4.0.72 netxen: fix set mac addr netxen: fix smatch warning netxen: fix tx ring memory leak tcp: update the netstamp_needed counter when cloning sockets TI DaVinci EMAC: Handle emac module clock correctly. dmfe/tulip: Let dmfe handle DM910x except for SPARC on-board chips ixgbe: Fix compiler warning about variable being used uninitialized netfilter: nf_ct_ftp: fix out of bounds read in update_nl_seq() mv643xx_eth: don't include cache padding in rx desc buffer size ... Fix trivial conflict in drivers/scsi/cxgb3i/cxgb3i_offload.c
2010-01-07claw: use "claw" as root device nameUrsula Braun
Claw module cannot be loaded together with qeth, because "qeth" has been errorneously used as root device name. It is changed into "claw". Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-04[S390] qdio: convert global statistics to per-device statsJan Glauber
Revamp the qdio performance statistics and move them from procfs to debugfs using the seq_file interface. Since the statistics are not intended for the general user the removal of /proc/qdio_perf should not surprise anyone. The per device statistics are disabled by default, writing 1 to /<debugfs mountpoint>/qdio/<device bus ID>/statistics enables the statistics for the given device. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] Use strim instead of strstrip to avoid false warnings.Heiko Carstens
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] qdio: add counter for input queue full conditionJan Glauber
Add a counter to the qdio performance statistics that indicates that no free buffers were left in the input queue. If the counter gets increased it means that the qdio adapter filled all available buffers and possibly had more buffers ready but could not transmit them. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] qdio: remove superfluous log entries and WARN_ONs.Jan Glauber
* Don't write debug feature log entries for sl, slsb and sbal since these elements can be located from the qdio_q pointer which is also logged. * Convert WARN_ON for wrong alignment of sbal to BUG_ON. * Remove WARN_ON's for wrong alignment of q / qib / slib since these alignments should be guaranteed by kmem_cache_alloc alignment / struct aligned attribute / __get_free_page. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] cio: fix channel path varyPeter Oberparleiter
Channel path vary is currently broken: channel paths which are varied offline are still used by Linux. The reason for this is that: * the path mask indicating which paths of an I/O device can be used is reset by each internal I/O request * the logic that checks if a path group is already in its designated target state incorrectly interprets the result "is correctly set" as "is correctly set and available" Fix this by resetting the path mask only for internal I/O requests which affect the path mask and by correcting the pgid check logic. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] drivers: Correct size given to memsetJulia Lawall
Memset should be given the size of the structure, not the size of the pointer. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ type T; T *x; expression E; @@ memset(x, E, sizeof( + * x)) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] tape: Add pr_fmt() macro to all tape source filesMichael Holzheu
Without defining the pr_fmt() macro, the "tape: " prefix will not be printed when using the pr_xxx printk macros. This patch adds the missing definitions. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] tty: PTR_ERR return of wrong pointer in fs3270_open()Roel Kluin
Return the PTR_ERR of the correct pointer. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] dasd: PTR_ERR return of wrong pointer inRoel Kluin
2009-12-18[S390] dasd: move dasd-diag kmsg to dasdStefan Haberland
The DIAG discipline does not have a own driver name. It shows up as dasd-eckd or dasd-fba. So messages for dasd-diag are moved to the generic dasd part. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] cio: fix drvdata usage for the console subchannelSebastian Ott
Using dev_set_drvdata prior to device_register will force the driver core to kmalloc its private data. Since we use this for the console subchannel lets set the drvdata before taking the subchannels spinlock. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-15tree-wide: convert open calls to remove spaces to skip_spaces() lib functionAndré Goddard Rosa
Makes use of skip_spaces() defined in lib/string.c for removing leading spaces from strings all over the tree. It decreases lib.a code size by 47 bytes and reuses the function tree-wide: text data bss dec hex filename 64688 584 592 65864 10148 (TOTALS-BEFORE) 64641 584 592 65817 10119 (TOTALS-AFTER) Also, while at it, if we see (*str && isspace(*str)), we can be sure to remove the first condition (*str) as the second one (isspace(*str)) also evaluates to 0 whenever *str == 0, making it redundant. In other words, "a char equals zero is never a space". Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below, and found occurrences of this pattern on 3 more files: drivers/leds/led-class.c drivers/leds/ledtrig-timer.c drivers/video/output.c @@ expression str; @@ ( // ignore skip_spaces cases while (*str && isspace(*str)) { \(str++;\|++str;\) } | - *str && isspace(*str) ) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Neil Brown <neilb@suse.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: David Howells <dhowells@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (222 commits) [SCSI] zfcp: Remove flag ZFCP_STATUS_FSFREQ_TMFUNCNOTSUPP [SCSI] zfcp: Activate fc4s attributes for zfcp in FC transport class [SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED [SCSI] zfcp: Update FSF error reporting [SCSI] zfcp: Improve ELS ADISC handling [SCSI] zfcp: Simplify handling of ct and els requests [SCSI] zfcp: Remove ZFCP_DID_MASK [SCSI] zfcp: Move WKA port to zfcp FC code [SCSI] zfcp: Use common code definitions for FC CT structs [SCSI] zfcp: Use common code definitions for FC ELS structs [SCSI] zfcp: Update FCP protocol related code [SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport [SCSI] zfcp: Assign scheduled work to driver queue [SCSI] zfcp: Remove STATUS_COMMON_REMOVE flag as it is not required anymore [SCSI] zfcp: Implement module unloading [SCSI] zfcp: Merge trace code for fsf requests in one function [SCSI] zfcp: Access ports and units with container_of in sysfs code [SCSI] zfcp: Remove suspend callback [SCSI] zfcp: Remove global config_mutex [SCSI] zfcp: Replace local reference counting with common kref ...
2009-12-09Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (72 commits) [S390] 3215/3270 console: remove wrong comment [S390] dasd: remove BKL from extended error reporting code [S390] vmlogrdr: remove BKL [S390] vmur: remove BKL [S390] zcrypt: remove BKL [S390] 3270: remove BKL [S390] vmwatchdog: remove lock_kernel() from open() function [S390] monwriter: remove lock_kernel() from open() function [S390] monreader: remove lock_kernel() from open() function [S390] s390: remove unused nfsd #includes [S390] ftrace: build ftrace.o when CONFIG_FTRACE_SYSCALLS is set for s390 [S390] etr/stp: put correct per cpu variable [S390] tty3270: move keyboard compat ioctls [S390] sclp: improve servicability setting [S390] s390: use change recording override for kernel mapping [S390] MAINTAINERS: Add s390 drivers block [S390] use generic sockios.h header file [S390] use generic termbits.h header file [S390] smp: remove unused typedef and defines [S390] cmm: free pages on hibernate. ...
2009-12-08Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timers, init: Limit the number of per cpu calibration bootup messages posix-cpu-timers: optimize and document timer_create callback clockevents: Add missing include to pacify sparse x86: vmiclock: Fix printk format x86: Fix printk format due to variable type change sparc: fix printk for change of variable type clocksource/events: Fix fallout of generic code changes nohz: Allow 32-bit machines to sleep for more than 2.15 seconds nohz: Track last do_timer() cpu nohz: Prevent clocksource wrapping during idle nohz: Type cast printk argument mips: Use generic mult/shift factor calculation for clocks clocksource: Provide a generic mult/shift factor calculation clockevents: Use u32 for mult and shift factors nohz: Introduce arch_needs_cpu nohz: Reuse ktime in sub-functions of tick_check_idle. time: Remove xtime_cache time: Implement logarithmic time accumulation
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits) security/tomoyo: Remove now unnecessary handling of security_sysctl. security/tomoyo: Add a special case to handle accesses through the internal proc mount. sysctl: Drop & in front of every proc_handler. sysctl: Remove CTL_NONE and CTL_UNNUMBERED sysctl: kill dead ctl_handler definitions. sysctl: Remove the last of the generic binary sysctl support sysctl net: Remove unused binary sysctl code sysctl security/tomoyo: Don't look at ctl_name sysctl arm: Remove binary sysctl support sysctl x86: Remove dead binary sysctl support sysctl sh: Remove dead binary sysctl support sysctl powerpc: Remove dead binary sysctl support sysctl ia64: Remove dead binary sysctl support sysctl s390: Remove dead sysctl binary support sysctl frv: Remove dead binary sysctl support sysctl mips/lasat: Remove dead binary sysctl support sysctl drivers: Remove dead binary sysctl support sysctl crypto: Remove dead binary sysctl support sysctl security/keys: Remove dead binary sysctl support sysctl kernel: Remove binary sysctl logic ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-07[S390] 3215/3270 console: remove wrong commentHeiko Carstens
When converting these two drivers from bootmem to slab allocations I forgot to remove two comments which state that this wouldn't be possible. So remove them now since this caused confusion already. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] dasd: remove BKL from extended error reporting codeMartin Schwidefsky
2009-12-07[S390] vmlogrdr: remove BKLMartin Schwidefsky
2009-12-07[S390] vmur: remove BKLMartin Schwidefsky
2009-12-07[S390] zcrypt: remove BKLMartin Schwidefsky
2009-12-07[S390] 3270: remove BKLMartin Schwidefsky
Replace BLK use in fs3270 with mutex. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] vmwatchdog: remove lock_kernel() from open() functionGerald Schaefer
The lock_kernel() calls in the open() function are unnecessary because misc_register() is called last in module_init() and concurrent open() calls are handled by other means. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] monwriter: remove lock_kernel() from open() functionGerald Schaefer
2009-12-07[S390] monreader: remove lock_kernel() from open() functionGerald Schaefer
2009-12-07[S390] tty3270: move keyboard compat ioctlsArnd Bergmann
All keyboard ioctls are compatible, so we can simply move the compat handling into the vt and tty3270 drivers. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] sclp: improve servicability settingMartin Schwidefsky
Set dump indicator on read-scp-info command to get meaningful dumps. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] tape: remove BKL from tape driverMartin Schwidefsky
Replace BLK with a per device mutex. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] tape: cleanup reference countingMartin Schwidefsky
Rename tape_get_device to tape_find_device and tape_get_device_reference to tape_get_device. The old names didn't make too much sense. Follow the get_device()/put_device() semantic and convert tape_put_device to a void function. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] tape: fix tape remove functionMartin Schwidefsky
Fix a bug introduced with git commit dff59b64af94dc58: - if (cdev->dev.driver_data != NULL) { + if (!dev_get_drvdata(&cdev->dev)) { These two are not equivalent. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] tape: remove f_pos changes from read / write function.Martin Schwidefsky
The change to f_pos in the read / write method has no effect as the value is controlled by the VFS layer, e.g. for vfs_read: loff_t pos = file_pos_read(file); ret = vfs_read(file, buf, count, &pos); file_pos_write(file, pos); Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] zcrypt: Do not simultaneously schedule hrtimerFelix Beck
Protect the hrtimer ap_poll_timer from being scheduled at the same time from several processes. Signed-off-by: Felix Beck <felix.beck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] zcrypt: adjust speed rating of cex3 adaptersFelix Beck
Cex3 needs a lower speed rating. Otherwise cex2 adapters will be prefered. Signed-off-by: Felix Beck <felix.beck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] zcrypt: adjust speed rating between cex2 and pcixccFelix Beck
Cards with lower speed rating are prefered. Thus change adjust the speed rating of cex2c adapters to be prefered before pcixcc, although they should not appear in the same machine anyway. Signed-off-by: Felix Beck <felix.beck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
