path: root/drivers/s390
2016-12-25ktime: Cleanup ktime_set() usageThomas Gleixner
ktime_set(S,N) was required for the timespec storage type and is still useful for situations where a Seconds and Nanoseconds part of a time value needs to be converted. For anything where the Seconds argument is 0, this is pointless and can be replaced with a simple assignment. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-23Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull late SCSI updates from James Bottomley: "This is mostly stuff which missed the initial pull. There's a new driver: qedi, and some ufs, ibmvscsis and ncr5380 updates plus some assorted driver fixes and also a fix for the bug where if a device goes into a blocked state between configuration and sysfs device add (which can be a long time under async probing) it would become permanently blocked" * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (30 commits) scsi: avoid a permanent stop of the scsi device's request queue scsi: mpt3sas: Recognize and act on iopriority info scsi: qla2xxx: Fix Target mode handling with Multiqueue changes. scsi: qla2xxx: Add Block Multi Queue functionality. scsi: qla2xxx: Add multiple queue pair functionality. scsi: qla2xxx: Utilize pci_alloc_irq_vectors/pci_free_irq_vectors calls. scsi: qla2xxx: Only allow operational MBX to proceed during RESET. scsi: hpsa: remove memory allocate failure message scsi: Update 3ware driver email addresses scsi: zfcp: fix rport unblock race with LUN recovery scsi: zfcp: do not trace pure benign residual HBA responses at default level scsi: zfcp: fix use-after-"free" in FC ingress path after TMF scsi: libcxgbi: return error if interface is not up scsi: cxgb4i: libcxgbi: add missing module_put() scsi: cxgb4i: libcxgbi: cxgb4: add T6 iSCSI completion feature scsi: cxgb4i: libcxgbi: add active open cmd for T6 adapters scsi: cxgb4i: use cxgb4_tp_smt_idx() to get smt_idx scsi: qedi: Add QLogic FastLinQ offload iSCSI driver framework. scsi: aacraid: remove wildcard for series 9 controllers scsi: ibmvscsi: add write memory barrier to CRQ processing ...
2016-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull m ore s390 updates from Martin Schwidefsky: "Over 95% of the changes in this pull request are related to the zcrypt driver. There are five improvements for zcrypt: the ID for the CEX6 cards is added, workload balancing and multi-domain support are introduced, the debug logs are overhauled and a set of tracepoints is added. Then there are several patches in regard to inline assemblies. One compile fix and several missing memory clobbers. As far as we can tell the omitted memory clobbers have not caused any breakage. A small change to the PCI arch code, the machine can tells us how big the function measurement blocks are. The PCI function measurement will be disabled for a device if the queried length is larger than the allocated size for these blocks. And two more patches to correct five printk messages. That is it for s390 in regard to the 4.10 merge window. Happy holidays" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (23 commits) s390/pci: query fmb length s390/zcrypt: add missing memory clobber to ap_qci inline assembly s390/extmem: add missing memory clobber to dcss_set_subcodes s390/nmi: fix inline assembly constraints s390/lib: add missing memory barriers to string inline assemblies s390/cpumf: fix qsi inline assembly s390/setup: reword printk messages s390/dasd: fix typos in DASD error messages s390: fix compile error with memmove_early() inline assembly s390/zcrypt: tracepoint definitions for zcrypt device driver. s390/zcrypt: Rework debug feature invocations. s390/zcrypt: Improved invalid domain response handling. s390/zcrypt: Fix ap_max_domain_id for older machine types s390/zcrypt: Correct function bits for CEX2x and CEX3x cards. s390/zcrypt: Fixed attrition of AP adapters and domains s390/zcrypt: Introduce new zcrypt device status API s390/zcrypt: add multi domain support s390/zcrypt: Introduce workload balancing s390/zcrypt: get rid of ap_poll_requests s390/zcrypt: header for the AP inline assmblies ...
2016-12-14scsi: zfcp: fix rport unblock race with LUN recoverySteffen Maier
It is unavoidable that zfcp_scsi_queuecommand() has to finish requests with DID_IMM_RETRY (like fc_remote_port_chkready()) during the time window when zfcp detected an unavailable rport but fc_remote_port_delete(), which is asynchronous via zfcp_scsi_schedule_rport_block(), has not yet blocked the rport. However, for the case when the rport becomes available again, we should prevent unblocking the rport too early. In contrast to other FCP LLDDs, zfcp has to open each LUN with the FCP channel hardware before it can send I/O to a LUN. So if a port already has LUNs attached and we unblock the rport just after port recovery, recoveries of LUNs behind this port can still be pending which in turn force zfcp_scsi_queuecommand() to unnecessarily finish requests with DID_IMM_RETRY. This also opens a time window with unblocked rport (until the followup LUN reopen recovery has finished). If a scsi_cmnd timeout occurs during this time window fc_timed_out() cannot work as desired and such command would indeed time out and trigger scsi_eh. This prevents a clean and timely path failover. This should not happen if the path issue can be recovered on FC transport layer such as path issues involving RSCNs. Fix this by only calling zfcp_scsi_schedule_rport_register(), to asynchronously trigger fc_remote_port_add(), after all LUN recoveries as children of the rport have finished and no new recoveries of equal or higher order were triggered meanwhile. Finished intentionally includes any recovery result no matter if successful or failed (still unblock rport so other successful LUNs work). For simplicity, we check after each finished LUN recovery if there is another LUN recovery pending on the same port and then do nothing. We handle the special case of a successful recovery of a port without LUN children the same way without changing this case's semantics. For debugging we introduce 2 new trace records written if the rport unblock attempt was aborted due to still unfinished or freshly triggered recovery. The records are only written above the default trace level. Benjamin noticed the important special case of new recovery that can be triggered between having given up the erp_lock and before calling zfcp_erp_action_cleanup() within zfcp_erp_strategy(). We must avoid the following sequence: ERP thread rport_work other context ------------------------- -------------- -------------------------------- port is unblocked, rport still blocked, due to pending/running ERP action, so ((port->status & ...UNBLOCK) != 0) and (port->rport == NULL) unlock ERP zfcp_erp_action_cleanup() case ZFCP_ERP_ACTION_REOPEN_LUN: zfcp_erp_try_rport_unblock() ((status & ...UNBLOCK) != 0) [OLD!] zfcp_erp_port_reopen() lock ERP zfcp_erp_port_block() port->status clear ...UNBLOCK unlock ERP zfcp_scsi_schedule_rport_block() port->rport_task = RPORT_DEL queue_work(rport_work) zfcp_scsi_rport_work() (port->rport_task != RPORT_ADD) port->rport_task = RPORT_NONE zfcp_scsi_rport_block() if (!port->rport) return zfcp_scsi_schedule_rport_register() port->rport_task = RPORT_ADD queue_work(rport_work) zfcp_scsi_rport_work() (port->rport_task == RPORT_ADD) port->rport_task = RPORT_NONE zfcp_scsi_rport_register() (port->rport == NULL) rport = fc_remote_port_add() port->rport = rport; Now the rport was erroneously unblocked while the zfcp_port is blocked. This is another situation we want to avoid due to scsi_eh potential. This state would at least remain until the new recovery from the other context finished successfully, or potentially forever if it failed. In order to close this race, we take the erp_lock inside zfcp_erp_try_rport_unblock() when checking the status of zfcp_port or LUN. With that, the possible corresponding rport state sequences would be: (unblock[ERP thread],block[other context]) if the ERP thread gets erp_lock first and still sees ((port->status & ...UNBLOCK) != 0), (block[other context],NOP[ERP thread]) if the ERP thread gets erp_lock after the other context has already cleard ...UNBLOCK from port->status. Since checking fields of struct erp_action is unsafe because they could have been overwritten (re-used for new recovery) meanwhile, we only check status of zfcp_port and LUN since these are only changed under erp_lock elsewhere. Regarding the check of the proper status flags (port or port_forced are similar to the shown adapter recovery): [zfcp_erp_adapter_shutdown()] zfcp_erp_adapter_reopen() zfcp_erp_adapter_block() * clear UNBLOCK ---------------------------------------+ zfcp_scsi_schedule_rports_block() | write_lock_irqsave(&adapter->erp_lock, flags);-------+ | zfcp_erp_action_enqueue() | | zfcp_erp_setup_act() | | * set ERP_INUSE -----------------------------------|--|--+ write_unlock_irqrestore(&adapter->erp_lock, flags);--+ | | .context-switch. | | zfcp_erp_thread() | | zfcp_erp_strategy() | | write_lock_irqsave(&adapter->erp_lock, flags);------+ | | ... | | | zfcp_erp_strategy_check_target() | | | zfcp_erp_strategy_check_adapter() | | | zfcp_erp_adapter_unblock() | | | * set UNBLOCK -----------------------------------|--+ | zfcp_erp_action_dequeue() | | * clear ERP_INUSE ---------------------------------|-----+ ... | write_unlock_irqrestore(&adapter->erp_lock, flags);-+ Hence, we should check for both UNBLOCK and ERP_INUSE because they are interleaved. Also we need to explicitly check ERP_FAILED for the link down case which currently does not clear the UNBLOCK flag in zfcp_fsf_link_down_info_eval(). Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Fixes: 8830271c4819 ("[SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport") Fixes: a2fa0aede07c ("[SCSI] zfcp: Block FC transport rports early on errors") Fixes: 5f852be9e11d ("[SCSI] zfcp: Fix deadlock between zfcp ERP and SCSI") Fixes: 338151e06608 ("[SCSI] zfcp: make use of fc_remote_port_delete when target port is unavailable") Fixes: 3859f6a248cb ("[PATCH] zfcp: add rports to enable scsi_add_device to work again") Cc: <stable@vger.kernel.org> #2.6.32+ Reviewed-by: Benjamin Block <bblock@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-12-14scsi: zfcp: do not trace pure benign residual HBA responses at default levelSteffen Maier
Since quite a while, Linux issues enough SCSI commands per scsi_device which successfully return with FCP_RESID_UNDER, FSF_FCP_RSP_AVAILABLE, and SAM_STAT_GOOD. This floods the HBA trace area and we cannot see other and important HBA trace records long enough. Therefore, do not trace HBA response errors for pure benign residual under counts at the default trace level. This excludes benign residual under count combined with other validity bits set in FCP_RSP_IU, such as FCP_SNS_LEN_VAL. For all those other cases, we still do want to see both the HBA record and the corresponding SCSI record by default. Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Fixes: a54ca0f62f95 ("[SCSI] zfcp: Redesign of the debug tracing for HBA records.") Cc: <stable@vger.kernel.org> #2.6.37+ Reviewed-by: Benjamin Block <bblock@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-12-14scsi: zfcp: fix use-after-"free" in FC ingress path after TMFBenjamin Block
When SCSI EH invokes zFCP's callbacks for eh_device_reset_handler() and eh_target_reset_handler(), it expects us to relent the ownership over the given scsi_cmnd and all other scsi_cmnds within the same scope - LUN or target - when returning with SUCCESS from the callback ('release' them). SCSI EH can then reuse those commands. We did not follow this rule to release commands upon SUCCESS; and if later a reply arrived for one of those supposed to be released commands, we would still make use of the scsi_cmnd in our ingress tasklet. This will at least result in undefined behavior or a kernel panic because of a wrong kernel pointer dereference. To fix this, we NULLify all pointers to scsi_cmnds (struct zfcp_fsf_req *)->data in the matching scope if a TMF was successful. This is done under the locks (struct zfcp_adapter *)->abort_lock and (struct zfcp_reqlist *)->lock to prevent the requests from being removed from the request-hashtable, and the ingress tasklet from making use of the scsi_cmnd-pointer in zfcp_fsf_fcp_cmnd_handler(). For cases where a reply arrives during SCSI EH, but before we get a chance to NULLify the pointer - but before we return from the callback -, we assume that the code is protected from races via the CAS operation in blk_complete_request() that is called in scsi_done(). The following stacktrace shows an example for a crash resulting from the previous behavior: Unable to handle kernel pointer dereference at virtual kernel address fffffee17a672000 Oops: 0038 [#1] SMP CPU: 2 PID: 0 Comm: swapper/2 Not tainted task: 00000003f7ff5be0 ti: 00000003f3d38000 task.ti: 00000003f3d38000 Krnl PSW : 0404d00180000000 00000000001156b0 (smp_vcpu_scheduled+0x18/0x40) R:0 T:1 IO:0 EX:0 Key:0 M:1 W:0 P:0 AS:3 CC:1 PM:0 EA:3 Krnl GPRS: 000000200000007e 0000000000000000 fffffee17a671fd8 0000000300000015 ffffffff80000000 00000000005dfde8 07000003f7f80e00 000000004fa4e800 000000036ce8d8f8 000000036ce8d9c0 00000003ece8fe00 ffffffff969c9e93 00000003fffffffd 000000036ce8da10 00000000003bf134 00000003f3b07918 Krnl Code: 00000000001156a2: a7190000 lghi %r1,0 00000000001156a6: a7380015 lhi %r3,21 #00000000001156aa: e32050000008 ag %r2,0(%r5) >00000000001156b0: 482022b0 lh %r2,688(%r2) 00000000001156b4: ae123000 sigp %r1,%r2,0(%r3) 00000000001156b8: b2220020 ipm %r2 00000000001156bc: 8820001c srl %r2,28 00000000001156c0: c02700000001 xilf %r2,1 Call Trace: ([<0000000000000000>] 0x0) [<000003ff807bdb8e>] zfcp_fsf_fcp_cmnd_handler+0x3de/0x490 [zfcp] [<000003ff807be30a>] zfcp_fsf_req_complete+0x252/0x800 [zfcp] [<000003ff807c0a48>] zfcp_fsf_reqid_check+0xe8/0x190 [zfcp] [<000003ff807c194e>] zfcp_qdio_int_resp+0x66/0x188 [zfcp] [<000003ff80440c64>] qdio_kick_handler+0xdc/0x310 [qdio] [<000003ff804463d0>] __tiqdio_inbound_processing+0xf8/0xcd8 [qdio] [<0000000000141fd4>] tasklet_action+0x9c/0x170 [<0000000000141550>] __do_softirq+0xe8/0x258 [<000000000010ce0a>] do_softirq+0xba/0xc0 [<000000000014187c>] irq_exit+0xc4/0xe8 [<000000000046b526>] do_IRQ+0x146/0x1d8 [<00000000005d6a3c>] io_return+0x0/0x8 [<00000000005d6422>] vtime_stop_cpu+0x4a/0xa0 ([<0000000000000000>] 0x0) [<0000000000103d8a>] arch_cpu_idle+0xa2/0xb0 [<0000000000197f94>] cpu_startup_entry+0x13c/0x1f8 [<0000000000114782>] smp_start_secondary+0xda/0xe8 [<00000000005d6efe>] restart_int_handler+0x56/0x6c [<0000000000000000>] 0x0 Last Breaking-Event-Address: [<00000000003bf12e>] arch_spin_lock_wait+0x56/0xb0 Suggested-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: Benjamin Block <bblock@linux.vnet.ibm.com> Fixes: ea127f9754 ("[PATCH] s390 (7/7): zfcp host adapter.") (tglx/history.git) Cc: <stable@vger.kernel.org> #2.6.32+ Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-12-14Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This update includes the usual round of major driver updates (ncr5380, lpfc, hisi_sas, megaraid_sas, ufs, ibmvscsis, mpt3sas). There's also an assortment of minor fixes, mostly in error legs or other not very user visible stuff. The major change is the pci_alloc_irq_vectors replacement for the old pci_msix_.. calls; this effectively makes IRQ mapping generic for the drivers and allows blk_mq to use the information" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (256 commits) scsi: qla4xxx: switch to pci_alloc_irq_vectors scsi: hisi_sas: support deferred probe for v2 hw scsi: megaraid_sas: switch to pci_alloc_irq_vectors scsi: scsi_devinfo: remove synchronous ALUA for NETAPP devices scsi: be2iscsi: set errno on error path scsi: be2iscsi: set errno on error path scsi: hpsa: fallback to use legacy REPORT PHYS command scsi: scsi_dh_alua: Fix RCU annotations scsi: hpsa: use %phN for short hex dumps scsi: hisi_sas: fix free'ing in probe and remove scsi: isci: switch to pci_alloc_irq_vectors scsi: ipr: Fix runaway IRQs when falling back from MSI to LSI scsi: dpt_i2o: double free on error path scsi: cxlflash: Migrate scsi command pointer to AFU command scsi: cxlflash: Migrate IOARRIN specific routines to function pointers scsi: cxlflash: Cleanup queuecommand() scsi: cxlflash: Cleanup send_tmf() scsi: cxlflash: Remove AFU command lock scsi: cxlflash: Wait for active AFU commands to timeout upon tear down scsi: cxlflash: Remove private command pool ...
2016-12-14s390/zcrypt: add missing memory clobber to ap_qci inline assemblyHeiko Carstens
The ap_qci() inline assembly writes to memory (*config) but misses to tell the compiler about it. Add the missing memory clobber to fix this. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/dasd: fix typos in DASD error messagesStefan Haberland
2016-12-14s390/zcrypt: tracepoint definitions for zcrypt device driver.Harald Freudenberger
This patch introduces tracepoint definitions and tracepoint event invocations for the s390 zcrypt device. Currently there are just two tracepoint events defined. An s390_zcrypt_req request event occurs as soon as the request is recognized by the zcrypt ioctl function. This event may act as some kind of request-processing-starts-now indication. As late as possible within the zcrypt ioctl function there occurs the s390_zcrypt_rep event which may act as the point in time where the request has been processed by the kernel and the result is about to be transferred back to userspace. The glue which binds together request and reply event is the ptr parameter, which is the local buffer address where the request from userspace has been stored by the ioctl function. The main purpose of this zcrypt tracepoint patch is to get some data for performance measurements together with information about the kind of request and on which card and queue the request has been processed. It is not an ffdc interface as there is already code in the zcrypt device driver to serve the s390 debug feature interface. Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: Rework debug feature invocations.Harald Freudenberger
Rework the debug feature calls and initialization. There are now two debug feature entries used by the zcrypt code. The first is 'ap' with all the AP bus related stuff and the second is 'zcrypt' with all the zcrypt and devices and driver related entries. However, there isn't much traffic on both debug features. The ap bus code emits only some debug info and for zcrypt devices on appearance and disappearance there is an entry written. The new dbf invocations use the sprintf buffer layout, whereas the old implementation used the ascii dbf buffer. There are now 5*8=40 bytes used for each entry, resulting in 5 parameters per call. As the sprintf buffer needs a format string the first parameter provides this and so up to 4 more parameters can be used. Alltogehter the new layout should be much more human readable for customers and test. Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: Improved invalid domain response handling.Harald Freudenberger
Add defines and switch case code to handle the two invalid domain response codes better. Until now these two response codes are handled via default resulting in -EAGAIN and switching the processed queue to offline. So this kind of malformed request bounced through all suitable queues and switched them off. Now this kind of malformed request is just rejected with EINVAL without switching off the queue. Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: Fix ap_max_domain_id for older machine typesIngo Tuchscherer
According to the system architecture the current implementation requires the presence of the N bit in GR2 in the TAPQ response field to validate the max. number of domains (Nd). Older machine types don't have this N bit, hence the max. domain field was ignored. Before the N bit was introduced the maximum number of domain was a constant value of 15. So set this value in case of N bit absence. Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@linux.vnet.ibm.com> Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: Correct function bits for CEX2x and CEX3x cards.Harald Freudenberger
For the older CEX2x and CEX3x cards the function bits returned by TAPQ do not reflect the functions of the card. Instead the functionality is implicit by the type of the card. The reworked zcrypt requires to have the function bits set correct, so this patch fixes this. The queue selection is not only based on these function bits but also on function pointers set by the individual drivers. Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com> Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: Fixed attrition of AP adapters and domainsIngo Tuchscherer
Currently the first eligible AP adapter respectively domain will be selected to service requests. In case of sequential workload, the very same adapter/domain will be used. The adapter/domain selection algorithm now considers the completed transactions per adaper/domain and therefore ensures a homogeneous utilization. Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: Introduce new zcrypt device status APIIngo Tuchscherer
Introduce new ioctl (ZDEVICESTATUS) to provide detailed information, like hardware type, domains, status and functionality of available crypto devices. Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: add multi domain supportIngo Tuchscherer
Currently the ap infrastructure only supports one domain at a time. This feature extends the generic cryptographic device driver to support multiple cryptographic domains simultaneously. There are now card and queue devices on the AP bus with independent card and queue drivers. The new /sys layout is as follows: /sys/bus/ap devices <xx>.<yyyy> -> ../../../devices/ap/card<xx>/<xx>.<yyyy> ... card<xx> -> ../../../devices/ap/card<xx> ... drivers <drv>card card<xx> -> ../../../../devices/ap/card<xx> <drv>queue <xx>.<yyyy> -> ../../../../devices/ap/card<xx>/<xx>.<yyyy> ... /sys/devices/ap card<xx> <xx>.<yyyy> driver -> ../../../../bus/ap/drivers/<zzz>queue ... driver -> ../../../bus/ap/drivers/<drv>card ... The two digit <xx> field is the card number, the four digit <yyyy> field is the queue number and <drv> is the name of the device driver, e.g. "cex4". For compatability /sys/bus/ap/card<xx> for the old layout has to exist, including the attributes that used to reside there. With additional contributions from Harald Freudenberger and Martin Schwidefsky. Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: Introduce workload balancingIngo Tuchscherer
Crypto requests are very different in complexity and thus runtime. Also various crypto adapters are differ with regard to the execution time. Crypto requests can be balanced much better when the request type and eligible crypto adapters are rated in a more precise granularity. Therefore, request weights and adapter speed rates for dedicated requests will be introduced. Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: get rid of ap_poll_requestsMartin Schwidefsky
The poll thread of the AP bus is burning CPU while waiting for crypto requests to complete. We can as well burn a few more cycles in the poll thread to check if there are pending requests and remove the atomic operations with the ap_poll_requests. This improves the code if the machine has adapter interrupts. Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: header for the AP inline assmbliesMartin Schwidefsky
Move the inline assemblies for the AP bus into a separate header file. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: simplify message type handlingMartin Schwidefsky
Now that the message type modules are linked with the zcrypt_api into a single module the zcrypt_ops_list is initialized by the module init function of the zcyppt.ko module. After that the list is static and all message types are present. Drop the zcrypt_ops_list_lock spinlock and the module handling in regard to the message types. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: Move the ap bus into kernelIngo Tuchscherer
Move the ap bus into the kernel and make it general available. Additionally include the message types and the API layer as a preparation for the workload management facility. Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-14s390/zcrypt: Introduce CEX6 tolerationHarald Freudenberger
2016-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "The main bulk of the s390 patches for the 4.10 merge window: - Add support for the contiguous memory allocator. - The recovery for I/O errors in the dasd device driver is improved, the driver will now remove channel paths that are not working properly. - Additional fields are added to /proc/sysinfo, the extended partition name and the partition UUID. - New naming for PCI devices with system defined UIDs. - The last few remaining alloc_bootmem calls are converted to memblock. - The thread_info structure is stripped down and moved to the task_struct. The only field left in thread_info is the flags field. - Rework of the arch topology code to fix a fake numa issue. - Refactoring of the atomic primitives and add a new preempt_count implementation. - Clocksource steering for the STP sync check offsets. - The s390 specific headers are changed to make them usable with CLANG. - Bug fixes and cleanup" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (70 commits) s390/cpumf: Use configuration level indication for sampling data s390: provide memmove implementation s390: cleanup arch/s390/kernel Makefile s390: fix initrd corruptions with gcov/kcov instrumented kernels s390: exclude early C code from gcov profiling s390/dasd: channel path aware error recovery s390/dasd: extend dasd path handling s390: remove unused labels from entry.S s390/vmlogrdr: fix IUCV buffer allocation s390/crypto: unlock on error in prng_tdes_read() s390/sysinfo: show partition extended name and UUID if available s390/numa: pin all possible cpus to nodes early s390/numa: establish cpu to node mapping early s390/topology: use cpu_topology array instead of per cpu variable s390/smp: initialize cpu_present_mask in setup_arch s390/topology: always use s390 specific sched_domain_topology_level s390/smp: use smp_get_base_cpu() helper function s390/numa: always use logical cpu and core ids s390: Remove VLAIS in ptff() and clear_table() s390: fix machine check panic stack switch ...
2016-12-13Merge tag 'char-misc-4.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver patches for 4.10-rc1. Lots of tiny changes over lots of "minor" driver subsystems, the largest being some new FPGA drivers. Other than that, a few other new drivers, but no new driver subsystems added for this kernel cycle, a nice change. All of these have been in linux-next with no reported issues" * tag 'char-misc-4.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (107 commits) uio-hv-generic: store physical addresses instead of virtual Tools: hv: kvp: configurable external scripts path uio-hv-generic: new userspace i/o driver for VMBus vmbus: add support for dynamic device id's hv: change clockevents unbind tactics hv: acquire vmbus_connection.channel_mutex in vmbus_free_channels() hyperv: Fix spelling of HV_UNKOWN mei: bus: enable non-blocking RX mei: fix the back to back interrupt handling mei: synchronize irq before initiating a reset. VME: Remove shutdown entry from vme_driver auxdisplay: ht16k33: select framebuffer helper modules MAINTAINERS: add git url for fpga fpga: Clarify how write_init works streaming modes fpga zynq: Fix incorrect ISR state on bootup fpga zynq: Remove priv->dev fpga zynq: Add missing \n to messages fpga: Add COMPILE_TEST to all drivers uio: pruss: add clk_disable() char/pcmcia: add some error checking in scr24x_read() ...
2016-12-12s390/dasd: channel path aware error recoveryStefan Haberland
With this feature, the DASD device driver more robustly handles DASDs that are attached via multiple channel paths and are subject to constant Interface-Control-Checks (IFCCs) and Channel-Control-Checks (CCCs) or loss of High-Performance-FICON (HPF) functionality on one or more of these paths. If a channel path does not work correctly, it is removed from normal operation as long as other channel paths are available. All extended error recovery states can be queried and reset via user space interfaces. Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Jan Hoeppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-12s390/dasd: extend dasd path handlingStefan Haberland
Store flags and path_data per channel path. Implement get/set functions for various path masks. The patch does not add functional changes. Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Jan Hoeppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-12s390/vmlogrdr: fix IUCV buffer allocationGerald Schaefer
The buffer for iucv_message_receive() needs to be below 2 GB. In __iucv_message_receive(), the buffer address is casted to an u32, which would result in either memory corruption or an addressing exception when using addresses >= 2 GB. Fix this by using GFP_DMA for the buffer allocation. Cc: stable@vger.kernel.org Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-07s390/smp: initialize cpu_present_mask in setup_archHeiko Carstens
In order to be able to setup the cpu to node mappings early it is a prerequisite to know which cpus are present. Therefore cpus must be detected much earlier than before. For sclp based cpu detection this requires yet another early sclp call, since the system is not ready to use the regular interrupt and memory allocations. Reviewed-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-02s390/zcrypt: Convert to PM opsLars-Peter Clausen
Switch the zcrypt bus from legacy suspend/resume callbacks to dev_pm_ops. The conversion is straight forward with the help of SIMPLE_DEV_PM_OPS(). The new dev_pm_ops based version is functionally equivalent to the legacy callbacks version. This will allow to eventually remove support for legacy suspend/resume callbacks from the kernel altogether. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-11-17scsi: fc: use bsg_job_doneJohannes Thumshirn
fc_bsg_jobdone() and bsg_job_done() are 1:1 copies now so use the bsg-lib one instead of the FC private implementation. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Acked-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-17scsi: change FC drivers to use 'struct bsg_job'Johannes Thumshirn
Change FC drivers to use 'struct bsg_job' from bsg-lib.h instead of 'struct fc_bsg_job' from scsi_transport_fc.h and remove 'struct fc_bsg_job'. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Acked-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-17scsi: fc: provide fc_bsg_to_rport() helperJohannes Thumshirn
Provide fc_bsg_to_rport() helper that will become handy when we're moving from struct fc_bsg_job to a plain struct bsg_job. Also move all LLDDs to use the new helper. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Acked-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-17scsi: fc: provide fc_bsg_to_shost() helperJohannes Thumshirn
Provide fc_bsg_to_shost() helper that will become handy when we're moving from struct fc_bsg_job to a plain struct bsg_job. Also use this little helper in the LLDDs. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Acked-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-17scsi: fc: Export fc_bsg_jobdone and use it in FC driversJohannes Thumshirn
Export fc_bsg_jobdone so drivers can use it directly instead of doing the round-trip via struct fc_bsg_job::job_done() and use it in the LLDDs. That way we can also unify the interfaces of fc_bsg_jobdone and bsg_job_done. As we've converted all LLDDs over to use fc_bsg_jobdone() directly, we can remove the function pointer from struct fc_bsg_job as well. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Acked-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-17scsi: don't use fc_bsg_job::request and fc_bsg_job::reply directlyJohannes Thumshirn
Don't use fc_bsg_job::request and fc_bsg_job::reply directly, but use helper variables bsg_request and bsg_reply. This will be helpful when transitioning to bsg-lib. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-17zcore: Improve startup-message textMichael Holzheu
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-11-10s390: char: make slp_ctl explicitly non-modularPaul Gortmaker
The Makefile currently controlling compilation of this code is obj-y, meaning that it currently is not being built as a module by anyone. Lets remove the couple traces of modular usage, so that when reading the driver there is no doubt it is builtin-only. Since module_misc_device translates to device_initcall in the non-modular case, the init ordering remains unchanged with this commit. Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: linux-s390@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31s390: virtio: make ccw explicitly non-modularPaul Gortmaker
The Kconfig currently controlling compilation of this code is: arch/s390/Kconfig:config S390_GUEST arch/s390/Kconfig: def_bool y ...meaning that it currently is not being built as a module by anyone. Lets remove the modular code that is essentially orphaned, so that when reading the driver there is no doubt it is builtin-only. Since module_init translates to device_initcall in the non-modular case, the init ordering remains unchanged with this commit. Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code. We replace module.h with moduleparam.h since the file does declare some module_param() and leaving that as-is is currently the easiest way to remain compatible with existing boot arg use cases. Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: linux-s390@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-10-31s390: char: make slcp_quiesce explicitly non-modularPaul Gortmaker
The Makefile currently controlling compilation of this code is obj-y, meaning that it currently is not being built as a module by anyone. Lets remove the couple traces of modular infrastructure, so that when reading the driver there is no doubt it is builtin-only. Since module_init translates to device_initcall in the non-modular case, the init ordering remains unchanged with this commit. Cc: linux-s390@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-10-31s390: char: make sclp_tty explicitly non-modularPaul Gortmaker
The Kconfig currently controlling compilation of this code is: drivers/s390/char/Kconfig:config SCLP_TTY drivers/s390/char/Kconfig: def_bool y ...meaning that it currently is not being built as a module by anyone. Lets remove the couple traces of modular infrastructure use, so that when reading the driver there is no doubt it is builtin-only. Since module_init translates to device_initcall in the non-modular case, the init ordering remains unchanged with this commit. We don't replace module.h with init.h since the file already has that. Cc: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: linux-s390@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-10-31s390: char: make con3215 explicitly non-modularPaul Gortmaker
The Kconfig currently controlling compilation of this code is: drivers/s390/char/Kconfig:config TN3215 drivers/s390/char/Kconfig: def_bool y ...meaning that it currently is not being built as a module by anyone. Lets remove the modular code that is essentially orphaned, so that when reading the driver there is no doubt it is builtin-only. Since module_init translates to device_initcall in the non-modular case, the init ordering remains unchanged with this commit. We don't replace module.h with init.h since the file already has that. Cc: linux-s390@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-10-31s390: char: make zcore explicitly non-modularPaul Gortmaker
The Kconfig currently controlling compilation of this code is: arch/s390/Kconfig:config CRASH_DUMP arch/s390/Kconfig: bool "kernel crash dumps" ...meaning that it currently is not being built as a module by anyone. Lets remove the modular code that is essentially orphaned, so that when reading the driver there is no doubt it is builtin-only. Since module_init wasn't even being used by this file, the init ordering remains unchanged with this commit. We also delete the MODULE_LICENSE tag etc. since all that information was (or is now) contained at the top of the file in the comments. We don't replace module.h with init.h since the file already has that. Cc: linux-s390@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-10-31s390: cio: make it explicitly non-modularPaul Gortmaker
The Makefile currently controlling compilation of this code is: obj-y += airq.o blacklist.o chsc.o cio.o css.o chp.o idset.o isc.o \ fcx.o itcw.o crw.o ccwreq.o trace.o ioasm.o ccw_device-objs += device.o device_fsm.o device_ops.o ccw_device-objs += device_id.o device_pgid.o device_status.o obj-y += ccw_device.o cmf.o ...meaning that the files here are not being built as modular. Lets remove the couple traces of modular infrastructure use, so that when reading the code there is no doubt it is builtin-only. Since module_init translates to device_initcall in the non-modular case, the init ordering remains unchanged with this commit. Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code. We delete the MODULE_LICENSE tag etc. since all that information was (or is now) contained at the top of the file in the comments. We replace module.h with export.h where the file does export some symbols. Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Arnd Bergmann <arndb@de.ibm.com> Cc: linux-s390@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-10-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Mostly simple overlapping changes. For example, David Ahern's adjacency list revamp in 'net-next' conflicted with an adjacency list traversal bug fix in 'net'. Signed-off-by: David S. Miller <davem@davemloft.net>
2016-10-28s390/dasd: Fix locking issue when changing RO attributeJan Höppner
The function dasd_ro_store() calls set_disk_ro() to set the device in question read-only. Since set_disk_ro() might sleep, we can't call it while holding a lock. However, we also can't simply check if the device, block, and gdp references are valid before we call set_disk_ro() because an offline processing might have been started in the meanwhile which will destroy those references. In order to reliably call set_disk_ro() we have to ensure several things: - Still check validity of the mentioned references but additionally check if offline processing is running and bail out accordingly. Also, do this while holding the device lock. - To ensure that the block device is still safe after the lock, increase the open_count while still holding the device lock. Reviewed-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Jan Höppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-10-28s390/dasd: Fix locking issue when changing EER attributeJan Höppner
The reference to a device in question may get lost when the extended error reporting (EER) attribute is being enabled/disabled while the device is set offline at the same time. This is due to missing refcounting and incorrect locking. Fix this by the following: - In dasd_eer_store() get the device directly and handle the refcount accordingly. - Move the lock in dasd_eer_enable() up so we can ensure safe processing. - Check if the device is being set offline and return with -EBUSY if so. - While at it, change the return code from -EPERM to -EMEDIUMTYPE as suggested by a FIXME, since that is what we're actually checking. Reviewed-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Jan Höppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-10-28s390/dasd: Eliminate race condition in dasd_generic_set_offline()Jan Höppner
Before we set a device offline, the open_count for the block device is checked and certain flags are checked and set as well. However, this is all done without holding any lock. Potentially, if the open_count was checked but the DASD_FLAG_OFFLINE wasn't set yet, a different process might want to increase the open_count depending on whether DASD_FLAG_OFFLINE is set or not in the meanwhile. This is quite racy and can lead to the loss of the device for that process and subsequently lead to a panic. Fix this by checking the open_count and setting the offline flags while holding the ccwdev lock. Reviewed-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Jan Höppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-10-28s390/dasd: Make use of dasd_set_feature() more oftenJan Höppner
When setting certain attributes, we actually set the according feature flag. Do this by using dasd_set_feature() at a few occurrences and remove duplicate code. In dasd_set_feature() dasd_find_busid() is used to retrieve the devmap for the device in question. Combined with the change above, this would require the device to be set online at least once so that a devmap is being created. Change that by using dasd_devmap_from_cdev() instead, which uses dasd_find_busid() first and will create a devmap accordingly if there is none yet. Reviewed-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Jan Höppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
