This patch turns on RX checksum and GRO by default. To improve
receiving performance and reduce congestion in case of network
bursts we also increase the default number of inbound buffers.
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
If a qeth device is set offline, data and control subchannels are
cleared, which means removal of all IP Assist Primitive settings
implicitly. There is no need to delete those settings explicitly.
This patch removes all IP Assist invocations from offline.
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
This error was reported by cppcheck:
drivers/s390/net/smsgiucv.c:63: error: Using sizeof for array given as
function argument returns the size of pointer.
Although there is no runtime problem as long as sizeof(u8 *) == 8,
this misleading code should get fixed.
Signed-off-by: Stefan Weil <weil@mail.berlios.de>
drivers/s390/net/netiucv.c:568: error: Using sizeof for array given
as function argument returns the size of pointer.
sizeof(ipuser) did not result in 16 (as many programmers would have
expected) but sizeof(u8 *), so it is 4 or 8, too small here.
For OSA the CHPARM-definition determines the number of available
outbound queues.
A CHPARM-change may occur while a Linux system with probed
OSA device is in suspend state. This patch enables proper
resuming of an OSA device in this case.
Signed-off-by: Ursula braun <ursula.braun@de.ibm.com>
For HiperSockets the framesize-definition determines the selected
mtu-size and the size of the allocated qdio buffers.
A framesize-change may occur while a Linux system with probed
HiperSockets device is in suspend state. This patch enables proper
resuming of a HiperSockets device in this case.
HiperSockets and OSA hardware report a maximum MTU size. Add checking
to reject larger MTUs than allowed by hardware.
Setting of a MAC-address may fail because an already used MAC-address
is to bet set or because of authorization problems. In those cases
qeth issues a message, but the mentioned MAC-address is not the
new MAC-address to be set, but the actual MAC-address. This patch
chooses now the new MAC-address to be set for the error messages.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (41 commits)
sctp: user perfect name for Delayed SACK Timer option
net: fix can_checksum_protocol() arguments swap
Revert "netlink: test for all flags of the NLM_F_DUMP composite"
gianfar: Fix misleading indentation in startup_gfar()
net/irda/sh_irda: return to RX mode when TX error
net offloading: Do not mask out NETIF_F_HW_VLAN_TX for vlan.
USB CDC NCM: tx_fixup() race condition fix
ns83820: Avoid bad pointer deref in ns83820_init_one().
ipv6: Silence privacy extensions initialization
bnx2x: Update bnx2x version to 1.62.00-4
bnx2x: Fix AER setting for BCM57712
bnx2x: Fix BCM84823 LED behavior
bnx2x: Mark full duplex on some external PHYs
bnx2x: Fix BCM8073/BCM8727 microcode loading
bnx2x: LED fix for BCM8727 over BCM57712
bnx2x: Common init will be executed only once after POR
bnx2x: Swap BCM8073 PHY polarity if required
iwlwifi: fix valid chain reading from EEPROM
ath5k: fix locking in tx_complete_poll_work
ath9k_hw: do PA offset calibration only on longcal interval
Some OSA level have a bug in the hw tx csum logic. We can circumvent
this bug by turning on IP hw csum also.
The open function of qeth is not executed if the qeth device is in
state DOWN or HARDSETUP. A recovery switches from state SOFTSETUP to
HARDSETUP to DOWN to HARDSETUP and back to SOFTSETUP. If open and
recover are running concurrently, open fails if it hits the states
HARDSETUP or DOWN. This patch inserts waiting for recovery finish
in the qeth open functions to enable successful qeth device opening
in spite of a running recovery.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (65 commits)
[S390] prevent unneccesary loops_per_jiffy recalculation
[S390] cpuinfo: use get_online_cpus() instead of preempt_disable()
[S390] smp: remove cpu hotplug messages
[S390] mutex: enable spinning mutex on s390
[S390] mutex: Introduce arch_mutex_cpu_relax()
[S390] cio: fix ccwgroup unregistration race condition
[S390] perf: add DWARF register lookup for s390
[S390] cleanup ftrace backend functions
[S390] ptrace cleanup
[S390] smp/idle: call init_idle() before starting a new cpu
[S390] smp: delay idle task creation
[S390] dasd: Correct retry counter for terminated I/O.
[S390] dasd: Add support for raw ECKD access.
[S390] dasd: Prevent deadlock during suspend/resume.
[S390] dasd: Improve handling of stolen DASD reservation
[S390] dasd: do path verification for paths added at runtime
[S390] dasd: add High Performance FICON multitrack support
[S390] cio: reduce memory consumption of itcw structures
[S390] nmi: enable machine checks early
[S390] qeth: buffer count imbalance
The used buffers counter is not incremented in case of an error so
the counter can become negative. Increment the used buffers counter
before checking for errors.
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
Introduce a scan treshold for the qdio outbound queues. By setting the
threshold the driver can tell qdio after how much used SBALs qdio
should schedule the outbound tasklet that scans the queue for finished
SBALs. The threshold is specific by the drivers because a
Hipersockets device is much faster in utilizing outbound buffers than a
ZFCP or OSA device.
The default values after how many used SBALs the tasklet should run are:
OSA: > 31 SBALs
Hipersockets: > 7 SBALs
zfcp: > 55 SBALs
Add support for CTC I/O interrupt statistics in /proc/interrupts.
Add support for CLAW I/O interrupt statistics in /proc/interrupts.
Add support for LCS I/O interrupt statistics in /proc/interrupts.
Make use of def_bool and def_tristate where possible and add sensible
defaults to the config symbols where applicable. This shortens the
defconfig file by another ~40 lines.
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
OSA l3 mode is hw accelerated VLAN only for IPv4. Take care we
add the vlan hdr to a passthru frame in the device driver.
Only work through the IP adddress to do list if the card is UP or
SOFTSETUP. Enables to configure VIPA add/del in offline mode.
Signed-off-by: Einar Lueck <elelueck@de.ibm.com>
Function qeth_l3_arp_query now queries for IPv6 addresses, too, if
QETH_QARP_WITH_IPV6 is passed as parameter to the ioctl. HiperSockets
and GuestLAN in HiperSockets mode provide corresponding entries.
The tso hdr is longer then the regular l3 hdr. Fix the calculation
of the total len by accounting the size of the tso hdr.
Device initialization of a qeth device contains a STARTLAN step.
This step may fail, if cable is not yet plugged in. The qeth device
stays in state HARDSETUP until cable is plugged in. This prevents
further preparational initialization steps of the qeth device and
its network interface. This patch makes sure initialization of qeth
device continues, even though cable is not yet plugged in.
Once carrier is available, qeth is notified, triggers a recovery
which results in a working network interface.
Commit 1d7138de878d1d4210727c1200193e69596f93b3
igmp: RCU conversion of in_dev->mc_list
converted rwlock to RCU.
Update the s390 network drivers(qeth & lcs) code to adapt to this change.
V2 : Changes based on suggestions given by Eric Dumazet
Signed-off-by: Sachin Sant <sachinp@in.ibm.com>
QDIO is running independent from netdevice state. We are not
allowed to schedule NAPI in case the netdevice is not open.
For a certain Hipersockets specific error code in the xmit path, the
qeth driver tries to invoke dev_queue_xmit again.
Commit 79640a4ca6955e3ebdb7038508fa7a0cd7fa5527 introduces a busylock
causing locking problems in case of re-invoked dev_queue_xmit by qeth.
This patch removes the attempts to retry packet sending with
dev_queue_xmit from the qeth driver.
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
VLAN_GROUP_ARRAY_LEN is simply the number of possible vlan VIDs.
Since vlan groups will soon be more of an implementation detail
for vlan devices, rename the constant to be descriptive of its
actual purpose.
Signed-off-by: Jesse Gross <jesse@nicira.com>
Reported-by: Sachin Sant <sachinp@in.ibm.com>
This patch adapts qeth to handle tagged frames with VLAN-ID 0 and
with or without priority information in the tag. It enables qeth to
receive priority-tagged frames on a base interface, for example from
z/OS, without configuring an additional VLAN interface.
drivers/net/qlcnic/qlcnic_init.c
net/ipv4/ip_output.c
Freeing netdev without free_netdev() leads to net, tx leaks.
I might lead to dereferencing freed pointer.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
struct net_device* dev;
-kfree(dev)
+free_netdev(dev)
This patch adds NAPI support to the qeth layer 2 and layer 3
discipline. It is important to understand that we can not enable/disable
IRQs as usual, we have to use the corresponding new QDIO interface.
Also to not overdraw the budget we have to stop and restart buffer
processing at any point during processing a bulk of QDIO buffers.
Having the driver NAPI enabled it is possible to turn on GRO for the
layer 3 discipline.
Since the claw code calls ccwgroup_remove_ccwdev(), we need to make sure
CCWGROUP is enabled when CLAW is enabled. Otherwise we hit fun undefined
references at build time:
ERROR: "ccwgroup_remove_ccwdev" [drivers/s390/net/claw.ko] undefined!
ERROR: "ccwgroup_probe_ccwdev" [drivers/s390/net/claw.ko] undefined!
ERROR: "ccwgroup_driver_register" [drivers/s390/net/claw.ko] undefined!
ERROR: "ccwgroup_driver_unregister" [drivers/s390/net/claw.ko] undefined!
ERROR: "ccwgroup_create_from_string" [drivers/s390/net/claw.ko] undefined!
Format an ipv6 address using vsprintf extensions.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
ctcm: rename READ/WRITE defines to avoid redefinitions
claw: rename READ/WRITE defines to avoid redefinitions
phylib: available for any speed ethernet
can: add limit for nframes and clean up signed/unsigned variables
pkt_sched: Check .walk and .leaf class handlers
pkt_sched: Fix sch_sfq vs tc_modify_qdisc oops
caif-spi: Bugfix SPI_DATA_POS settings were inverted.
caif: Bugfix - Increase default headroom size for control channel.
net: make netpoll_rx return bool for !CONFIG_NETPOLL
Bluetooth: Use 3-DH5 payload size for default ERTM max PDU size
Bluetooth: Fix incorrect setting of remote_tx_win for L2CAP ERTM
Bluetooth: Change default L2CAP ERTM retransmit timeout
Bluetooth: Fix endianness issue with L2CAP MPS configuration
net: Use NET_XMIT_SUCCESS where possible.
isdn: mISDN: call pci_disable_device() if pci_probe() failed
isdn: avm: call pci_disable_device() if pci_probe() failed
usbnet: rx_submit() should return an error code.
pkt_sched: Add some basic qdisc class ops verification. Was: [PATCH] sfq: add dummy bind/unbind handles
pkt_sched: sch_sfq: Add dummy unbind_tcf and put handles. Was: [PATCH] sfq: add dummy bind/unbind handles
READ/WRITE seems to be a bit too generic for defines in a device
driver. Just rename them to CTCM_READ/CTCM_WRITE to avoid warnings.
READ/WRITE seems to be a bit too generic for defines in a device driver.
Just rename them to READ_CHANNEL/WRITE_CHANNEL which should suffice.
Fixes this:
In file included from drivers/s390/net/claw.c:93:
drivers/s390/net/claw.h:78:1: warning: "WRITE" redefined
In file included from /home2/heicarst/linux-2.6/arch/s390/include/asm/debug.h:12,
from drivers/s390/net/claw.c:68:
include/linux/fs.h:156:1: warning: this is the location of the previous definition
The sender kernel parameter contains a z/VM user ID where
alphabetic characters must be specified in uppercase.
Allow users to specify lowercase characters and convert the
sender string to uppercase at module initialization.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Function qeth_l2_remove_device invokes qeth_l2_del_all_mc at the end.
This is needless, because it is already called in the offline function.
And even more this is invalid, because multicast addresses cannot be
removed in DOWN state. Thus this patch deletes invocation of
qeth_l2_del_all_mc in function qeth_l2_remove_device.
allocated region.
The semantic patch that makes this change is as follows:
// <smpl>
expression from,to,size,flag;
position p;
identifier l1,l2;
- to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+ to = memdup_user(from,size);
if (
- to==NULL
+ IS_ERR(to)
<+... when != goto l1;
- -ENOMEM
+ PTR_ERR(to)
- if (copy_from_user(to, from, size) != 0) {
- <+... when != goto l2;
- -EFAULT
// </smpl>
Reply callback functions in qeth should return zero if command
response consists of one part only, otherwise qeth continues
waiting for further parts of the command response.
When creating a claw device, just 2 subchannels have to be grouped.
If qeth issues an ipa command, but for some reasons the response
never comes back, qeth reaches a timeout.
Reset the irq_pending flag of the write channel in timeout handling
code and trigger a recovery to avoid endless looping for the following
ipa command.
This patch serializes device removal and other sysfs-triggered
configurations by moving removal of sysfs-attributes to the beginning
of the remove functions. And it serializes online/offline setting
and discipline-switching (causing reestablishing of the net_device)
by making use of a new discipline mutex.
This patch fixes a problem that occurs when switching from layer 3 to layer 2
mode. Resetting this mac_bits makes sure that we retrieve our mac address from
the card, otherwise the interface simply would'nt work.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
