commit 6fb392b1a63ae36c31f62bc3fc8630b49d602b62 upstream.
Check user-defined length in snmp ioctl request and allow request
only if it fits into a qeth command buffer.
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
Reviewed-by: Heiko Carstens <heicars2@linux.vnet.ibm.com>
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
qeth_hdr_chk_and_bounce() can possibly shift the skb->data
pointer. However, the existing code didn't update the hdr pointer,
which should point to skb->data, accordingly.
Symptoms of this issue are sporadic recoveries.
Signed-off-by: Stefan Raspl <raspl@linux.vnet.ibm.com>
Signed-off-by: Frank Blaschka <blaschka@linux.vnet.ibm.com>
remove unused variable
remove cast for kzalloc return value.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Any recovery thread will deadlock when calling qeth_wait_for_threads(), most
notably when triggering a recovery on an OSN device.
This patch will store the recovery thread's task pointer on recovery
invocation and check in qeth_wait_for_threads() respectively to avoid
deadlocks.
Reviewed-by: Ursula Braun <ursula.braun@de.ibm.com>
This patch fixes a scatter-gather regression introduced with
commit 5640f768 net: use a per task frag allocator
Now the qeth driver can cope with bigger framents and split a fragment in
sub framents if required.
Commit 46d3ceab "tcp: TCP Small Queues" has severly degraded
performance for single connection RR workloads on HiperSockets with
MTU >=16K due to a conflict of the TCP Small Queues approach with our
buffer scan threshold which releases buffers not frequently enough yet.
This fix restores performance to the same level as before cited commit.
As of now, s390dbf entries for the cards are discarded as soon as the
device is removed. However, this will also bar us of all chances of
getting valuable debug information after a device has been removed.
This patch will keep the s390dbf entries around until the qeth module
is removed.
The existing port isolation mode 'forward' will now verify that the adjacent
switch port supports the required reflective relay (RR) mode. This patch adds
the required error handling for the cases where enabling port isolation mode
'forward' can now fail.
Furthermore, once established, we never fall back from one of the port
isolation modes to a non-isolated mode without further user-interaction.
This includes cases where the isolation mode was enabled successfully, but
ceases to work e.g. due to configuration changes at the switch port.
Finally, configuring an isolation mode with the device being offline
will make onlining the device fail permanently upon errors encountered until
either errors are resolved or the isolation mode is changed by the user to a
different mode.
Remove exports that are not used anywhere else.
The previous code did never retry any idx setup unless retries were done
for device offline/online at the beginning of the function.
Use strlcpy where possible to ensure the string is \0 terminated.
Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN
and custom defines.
Use snprintf instead of sprint.
Remove unnecessary inits of ->fw_version
Remove unnecessary inits of drvinfo struct.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Remove BUG_ONs or convert to WARN_ON_ONCE/WARN_ONs since a failure within a
networking device driver is no reason to shut down the entire machine.
Trace all supported and enabled card features to s390dbf.
So far, virtual NICs whether attached to a VSWITCH or a guest LAN were always
displayed as guest LANs in the device driver attributes and messages, while
in fact it is a virtual NIC.
Eliminate a variable that is never modified.
Return codes of IPA_CMD_QIPASSIST are not checked, especially the ones which
indicate that the command is not supported. As a result, the device driver
would not enable all available features on older card generations.
This patch adds proper checking and sets the bare minimum in the supported
functions flags to avoid follow-on errors.
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
Change return code handling of the stsi() function:
In case function code 0 was specified the return value is the
current configuration level (already shifted). That way all
the code that actually copied the stsi_0() function can go
away.
Otherwise the return value is 0 (success) or negative to
indicate an error (currently only -EOPNOTSUPP).
Also stsi() is no longer an inline function. The function is
not performance critical, but every caller would generate an
exception table entry for this function.
removes unnecessary semicolon
Found by Coccinelle: http://coccinelle.lip6.fr/
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cleanup the qeth_get_channel_path_desc function and rename it
to qeth_update_from_chp_desc. No functional change.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Acked-by: Ursula Braun <ursula.braun@de.ibm.com>
Remove the file name from the comment at top of many files. In most
cases the file name was wrong anyway, so it's rather pointless.
Also unify the IBM copyright statement. We did have a lot of sightly
different statements and wanted to change them one after another
whenever a file gets touched. However that never happened. Instead
people start to take the old/"wrong" statements to use as a template
for new files.
So unify all of them in one go.
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"Just a random collection of bug-fixes and cleanups, nothing new in
this merge request."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (46 commits)
s390/ap: Fix wrong or missing comments
s390/ap: move receive callback to message struct
s390/dasd: re-prioritize partition detection message
s390/qeth: reshuffle initialization
s390/qeth: cleanup drv attr usage
s390/claw: cleanup drv attr usage
s390/lcs: cleanup drv attr usage
s390/ctc: cleanup drv attr usage
s390/ccwgroup: remove ccwgroup_create_from_string
s390/qeth: stop using struct ccwgroup driver for discipline callbacks
s390/qeth: switch to ccwgroup_create_dev
s390/claw: switch to ccwgroup_create_dev
s390/lcs: switch to ccwgroup_create_dev
s390/ctcm: switch to ccwgroup_create_dev
s390/ccwgroup: exploit ccwdev_by_dev_id
s390/ccwgroup: introduce ccwgroup_create_dev
s390: fix race on TIF_MCCK_PENDING
s390/barrier: make use of fast-bcr facility
s390/barrier: cleanup barrier functions
s390/claw: remove "eieio" calls
Commit 1abd2296b4a1ee7b6a883541c3ede52042a09521 starts removing
token ring from qeth_l3. This patch removes the rest of token
ring related code from the driver.
Reshuffle the init function of the qeth driver to ensure
that the driver is usable at the time it is registered.
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Cleanup attributes of the qeth ccwgroup driver. Ensure availability
of driver attributes by the time the driver is registered.
Remove the old ccwgroup_create_from_string interface since all
drivers have been converted to ccwgroup_create_dev. Also remove
now unused members of ccwgroup_driver.
The interface between qeth and its disciplines should not depend on
struct ccwgroup_driver, as a qeth discipline is not a ccwgroup
driver on its own. Instead provide the particular callbacks in struct
qeth_discipline.
Switch to the new ccwgroup_create_dev interface. Also wrap device
attributes in a struct device_type and let the driver core create
these attributes automagically.
Various improvements of qdio error reporting to the
upper-layer drivers (qeth, zfcp):
- Split QDIO_ERROR_ACTIVATE_CHECK_CONDITION into:
QDIO_ERROR_ACTIVATE: qdio termination interrupt
QDIO_ERROR_GET_BUF_STATE: QIOASSIST eqbs error
QDIO_ERROR_SET_BUF_STATE: QIOASSIST sqbs error
Add QDIO_ERROR_FATAL / QDIO_ERROR_TEMPORARY masks
to ease recovery decision in upper-layer drivers.
- Don't (ab-)use qdio handler errors as return codes
for do_QDIO but use standard error codes:
-ENOBUFS: temporary target CC=2 condition
-EBUSY: unresolved SIGA-W CC=2 busy condition
-EIO: I/O error (CC=1, CC=3)
- Remove unneeded memory clobber from SIGA-R
- Remove EX_TABLE entry on SIGA-W, we want to see these errors
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
The token ring support is going away from the core kernel.
Divorce the S390 drivers from it in advance.
Cc: linux390@de.ibm.com
Cc: linux-s390@vger.kernel.org
The previous blkt defaults for OSA Express 4 cards produced inadequate
performance for streaming workloads. The present patch will apply a
set of more appropriate defaults.
There exist qeth sysfs blkt attributes to change the default blkt
values. But blkt changes are reset during online setting due to a 2nd
invocation of qeth_determine_capabilites(). This patch makes sure
blkt default values are configured during 1st run of
qeth_determine_capabilities() only. Thus blkt changes are kept
during online setting.
Reported-by: Horst Hartmann <horst.hartmann@de.ibm.com>
Setting an invalid mac-address for a qeth layer2 device returns
with a strange error code:
# ip link set hsi1 address 00:00:00:00:00:01
RTNETLINK answers: Unknown error 18446744073709486085
Problem is caused by wrong usage of the return_code field within
structure qeth_ipa_cmd.
With this patch the ip command above returns
SIOCSIFHWADDR: Invalid argument
During system startup udev may try to configure devices in
parallel so we have to synchronize discipline module
loading.
To send commands on the write channel 8 buffers exist. If all
8 buffers are used, a wait is triggered on the write channel. When
such buffer are freed, a wake_up is needed. This patch adds the
missing wake_up in qeth_release_buffer().
This fix is especially important when running Communications
Controller for Linux on System z.
Add qeth device private ioctl to query the OSA address table.
This helps debugging hw related problems.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (31 commits)
[S390] disassembler: mark exception causing instructions
[S390] Enable exception traces by default
[S390] return address of compat signals
[S390] sysctl: get rid of dead declaration
[S390] dasd: fix fixpoint divide exception in define_extent
[S390] dasd: add sanity check to detect path connection error
[S390] qdio: fix kernel panic for zfcp 31-bit
[S390] Add s390x description to Documentation/kdump/kdump.txt
[S390] Add VMCOREINFO_SYMBOL(high_memory) to vmcoreinfo
[S390] dasd: fix expiration handling for recovery requests
[S390] outstanding interrupts vs. smp_send_stop
[S390] ipc: call generic sys_ipc demultiplexer
[S390] zcrypt: Fix error return codes.
[S390] zcrypt: Rework length parameter checking.
[S390] cleanup trap handling
[S390] Remove Kerntypes leftovers
[S390] topology: increase poll frequency if change is anticipated
[S390] entry[64].S improvements
[S390] make arch/s390 subdirectories depend on config option
[S390] kvm: move cmf host id constant out of lowcore
Fix up conflicts in arch/s390/kernel/{smp.c,topology.c} due to the
sysdev removal clashing with "topology: get rid of ifdefs" which moved
some of that code around.
The queue_start_poll function pointer field in struct qdio_initialize
had to change its type and become a vector of function pointers to
support asynchronous delivery of storage blocks so rename the field to
make the type change explicit and ensure no other user of qdio tries
to use the field the old way. During setting up the qdio queues, only
dereference vector elements if the vector is actually allocated.
Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com>
Signed-off-by: Einar Lueck <elelueck@de.ibm.com>
If recovery is triggered in presence of pending asynchronous
deliveries of storage blocks we do a forced cleanup after
the corresponding tasklets are completely stopped and trigger
appropriate notifications for the correspondingerror state.
In case there are no system resources to run a recovery we have to clear
recovery bitmasks so a further automatic or manual driven recovery can
fix up the device.
The patch "qeth: exploit asynchronous delivery of storage blocks"
added a WARN_ON in qeth_schedule_recovery. A device recovery should
not cause a kernel warning. This is obviously a debugging left-over
that we forgot to remove.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Ursula Braun <ursula.braun@de.ibm.com>
Cc: Frank Blaschka <blaschka@linux.vnet.ibm.com>
Cc: netdev@vger.kernel.org
This patch extends the HiperSockets device driver to send and receive
af_iucv traffic over HiperSockets transport.
TX: Driver uses new asynchronous delivery of storage blocks to pass
flow control/congestion information from the HiperSockets microcode
to the af_iucv socket.
RX: Memory for incoming traffic is preallocated and passed to
HiperSockets layer. If receiver is not capable to clean its buffers
shared with HiperSockets and pass new memory to the HiperSockets
layer this will cause flow control/congestion events on the
sender.
This patch exploits the QDIO support for asynchronous delivery of storage
blocks for Hipersockets. The exploitation is not configured per default and
may be enabled via the function qeth_configure_cq.
This patch introduces support for asynchronous delivery of storage blocks for
Hipersockets. Upper layers may exploit this functionality to reuse SBALs for
which the delivery status is still pending.
OSA cards can be configured to support 1 or 4 output queues. This
does not apply to HiperSockets. This patch limits determination of
the configured number of output queues to OSA cards only, but excludes
HiperSockets.
- unify vlan and nonvlan rx path
- kill card->vlangrp and qeth_l3_vlan_rx_register
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
The qdio SBAL entry flag is made-up of four different values that are
independent of one another. Some of the bits are reserved by the
hardware and should not be changed by qdio. Currently all four values
are overwritten since the SBAL entry flag is defined as an u32.
Split the SBAL entry flag into four u8's as defined by the hardware
and don't touch the reserved bits.
