path: root/drivers/s390/net/claw.c
2011-10-30[S390] fix mismatch in summation of I/O IRQ statisticsPeter Oberparleiter
Current IRQ statistics support does not show detail counts for I/O interrupts which are processed internally only. The result is a summation count which is way off such as this one: CPU0 CPU1 CPU2 I/O: 1331 710 442 [...] QAI: 15 16 16 [I/O] QDIO Adapter Interrupt QDI: 1 0 0 [I/O] QDIO Interrupt DAS: 706 645 381 [I/O] DASD C15: 26 10 0 [I/O] 3215 C70: 0 0 0 [I/O] 3270 TAP: 0 0 0 [I/O] Tape VMR: 0 0 0 [I/O] Unit Record Devices LCS: 0 0 0 [I/O] LCS CLW: 0 0 0 [I/O] CLAW CTC: 0 0 0 [I/O] CTC APB: 0 0 0 [I/O] AP Bus Fix this by moving I/O interrupt accounting into the common I/O layer. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-13claw: remove unused return code handlingHeiko Carstens
Remove unused return code handling. The claw driver is mostly dead, so just make sure it keeps compiling without warnings. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-23[S390] ccwgroup_driver: remove duplicate membersSebastian Ott
Remove the owner and name members of struct ccwgroup_driver and convert all drivers to store this data in the embedded struct device_driver. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-23[S390] ccw_driver: remove duplicate membersSebastian Ott
Remove the owner and name members of struct ccw_driver and convert all drivers to store this data in the embedded struct device_driver. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] claw: add support for irq statisticsHeiko Carstens
Add support for CLAW I/O interrupt statistics in /proc/interrupts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-08-12claw: rename READ/WRITE defines to avoid redefinitionsHeiko Carstens
READ/WRITE seems to be a bit too generic for defines in a device driver. Just rename them to READ_CHANNEL/WRITE_CHANNEL which should suffice. Fixes this: In file included from drivers/s390/net/claw.c:93: drivers/s390/net/claw.h:78:1: warning: "WRITE" redefined In file included from /home2/heicarst/linux-2.6/arch/s390/include/asm/debug.h:12, from drivers/s390/net/claw.c:68: include/linux/fs.h:156:1: warning: this is the location of the previous definition Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-23claw: A claw device is a group of just 2 ccw devicesUrsula Braun
When creating a claw device, just 2 subchannels have to be grouped. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07claw: use "claw" as root device nameUrsula Braun
Claw module cannot be loaded together with qeth, because "qeth" has been errorneously used as root device name. It is changed into "claw". Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17net/s390 drivers: add missing 'const' attributeHeiko Carstens
Add missing 'const' attribute to avoid the following compile warnings: drivers/s390/net/ctcm_main.c: In function 'ctcm_init': drivers/s390/net/ctcm_main.c:1864: warning: assignment from incompatible pointer type drivers/s390/net/lcs.c: In function 'lcs_init_module': drivers/s390/net/lcs.c:2468: warning: assignment from incompatible pointer type drivers/s390/net/claw.c: In function 'claw_init': drivers/s390/net/claw.c:3408: warning: assignment from incompatible pointer type Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13s390: remove cu3088 layer for lcs and ctcmUrsula Braun
The cu3088-driver used as common base for lcs- and ctcm-devices makes it difficult to assign the appropriate driver to an lcs-device or a ctcm-device. This patch eliminates the cu3088-driver and thus the root device "cu3088". Path /sys/devices/cu3088 is replaced with the pathes /sys/devices/lcs and /sys/devices/ctcm. Patch is based on a proposal from Cornelia Huck. Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: convert remaining non-symbolic return values in ndo_start_xmit() functionsPatrick McHardy
This patch converts the remaining occurences of raw return values to their symbolic counterparts in ndo_start_xmit() functions that were missed by the previous automatic conversion. Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero is changed to explicitly use NETDEV_TX_OK. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (64 commits) debugfs: use specified mode to possibly mark files read/write only debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem. xen: remove driver_data direct access of struct device from more drivers usb: gadget: at91_udc: remove driver_data direct access of struct device uml: remove driver_data direct access of struct device block/ps3: remove driver_data direct access of struct device s390: remove driver_data direct access of struct device parport: remove driver_data direct access of struct device parisc: remove driver_data direct access of struct device of_serial: remove driver_data direct access of struct device mips: remove driver_data direct access of struct device ipmi: remove driver_data direct access of struct device infiniband: ehca: remove driver_data direct access of struct device ibmvscsi: gadget: at91_udc: remove driver_data direct access of struct device hvcs: remove driver_data direct access of struct device xen block: remove driver_data direct access of struct device thermal: remove driver_data direct access of struct device scsi: remove driver_data direct access of struct device pcmcia: remove driver_data direct access of struct device PCIE: remove driver_data direct access of struct device ... Manually fix up trivial conflicts due to different direct driver_data direct access fixups in drivers/block/{ps3disk.c,ps3vram.c}
2009-06-16[S390] pm: claw driver power management callbacksFrank Blaschka
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-15s390: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Thanks to Sebastian Ott <sebott@linux.vnet.ibm.com> for fixing a few typos in my original version of this patch. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: linux-s390@vger.kernel.org Cc: linux390@de.ibm.com Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-13net: fix network drivers ndo_start_xmit() return values (part 5)Patrick McHardy
Fix up s390 drivers that return an errno value to qdisc_restart(), causing qdisc_restart() to print a warning an requeue/retransmit the skb. - claw: impossible condition, simply remove it Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-24claw: fix minor findings from code analysis toolAndrew H. Richter
This patch fixes two problems in the claw driver identified by static code analysis: o Change in case differentiation of received sense codes o Use correct data length in claw hard_start_xmit routine Signed-off-by: Andrew H. Richter <richtera@us.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-24claw: invalid return codes from hard_start_xmitUrsula Braun
Avoid kernel warnings by using the correct hard_start_xmit return code NETDEV_TX_BUSY for skb requeuing. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-25kmsg: convert claw printk messagesAndy Richter
claw printks are converted to dev_xxx and pr_xxx macros. Signed-off-by: Andy Richter <richtera@us.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21claw: convert to net_device_opsFrank Blaschka
claw convert to net_device_ops. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13s390: claw compile fixletAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-10[S390] more bus_id -> dev_name conversionsCornelia Huck
Some further bus_id -> dev_name() conversions in s390 code. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] bus_id -> dev_name conversionsKay Sievers
bus_id -> dev_name() conversions in s390 code. [cornelia.huck@de.ibm.com: minor adaptions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-27claw: netdev->priv vs. netdev->ml_privPeter Tiedemann
Use netdev->ml_priv instead of netdev->priv Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-27claw: fix memory leak in claw_probe.Martin Schwidefsky
probe_error() frees memory only, if cgdev->dev.driver_data refers to the claw_privbk structure. Move forward its setting in claw_probe() to ensure proper freeing of claw_privbk allocations. Cc: Daniel <danielm77@spray.se> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22s390/net: Cleanup claw printk messages.Andy Richter
Cc: Martin Schwidefsky <schwidefska@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andy Richter <richtera@us.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-14[S390] cio: introduce fcx enabled scsw formatPeter Oberparleiter
Extend the scsw data structure to the format required by fcx. Also provide helper functions for easier access to fields which are present in both the traditional as well as the modified format. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-02-23claw: make use of DIV_ROUND_UPJulia Lawall
The kernel.h macro DIV_ROUND_UP performs the computation (((n) + (d) - 1) / (d)) but is perhaps more readable. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-26[S390] drivers/s390: Add missing "space"Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-20s390: Use ccw_device_get_id() in qeth/claw driversCornelia Huck
Use ccw_device_get_id() to get a device number instead of parsing the ccw device's bus id. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[SK_BUFF]: Introduce skb_mac_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the mac header, it is still legal to touch skb->mac.raw directly if just adding to, subtracting from or setting it to another layer header. This one also converts some more cases to skb_reset_mac_header() that my regex missed as it had no spaces before nor after '=', ugh. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-05[S390] Avoid excessive inlining.Heiko Carstens
2007-02-05[S390] Get rid of a lot of sparse warnings.Heiko Carstens
2006-07-10[PATCH] s390: broken null test in claw driverDave Jones
Whoops, better hope this never gets passed a null dev in its current state. Signed-off-by: Dave Jones <davej@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Michael Holzheu <holzheu@de.ibm.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s390: kzalloc() conversion in drivers/s390Eric Sesterhenn
Convert all kmalloc + memset sequences in drivers/s390 to kzalloc usage. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22Fix "frist", "fisrt", typosUwe Zeisberger
Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-02-01[PATCH] s390: Remove CVS generated informationHeiko Carstens
- Remove all CVS generated information like e.g. revision IDs from drivers/s390 and include/asm-s390 (none present in arch/s390). - Add newline at end of arch/s390/lib/Makefile to avoid diff message. Acked-by: Andreas Herrmann <aherrman@de.ibm.com> Acked-by: Frank Pavlic <pavlic@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: drivers/s390Jesper Juhl
This is the drivers/s390/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/s390/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Cornelia Huck <cohuck@de.ibm.com> Acked-by: Stefan Bader <Stefan.Bader@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-06[PATCH] s390: claw driver fixesFrank Pavlic
[patch 1/4] s390: claw driver fixes From: Andy Richter <richtera@us.ibm.com> - change memory allocation and move dbf from proc to debugfs - use dev_kfree_skb_any instead of dev_kfree_skb_irq Signed-off-by: Frank Pavlic <pavlic@de.ibm.com> diffstat: claw.c | 20 ++++++++++---------- 1 files changed, 10 insertions(+), 10 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-08[NET]: Transform skb_queue_len() binary tests into skb_queue_empty()David S. Miller
This is part of the grand scheme to eliminate the qlen member of skb_queue_head, and subsequently remove the 'list' member of sk_buff. Most users of skb_queue_len() want to know if the queue is empty or not, and that's trivially done with skb_queue_empty() which doesn't use the skb_queue_head->qlen member and instead uses the queue list emptyness as the test. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-25[PATCH] s390: debug feature changesMichael Holzheu
This patch changes the memory allocation method for the s390 debug feature. Trace buffers had been allocated using the get_free_pages() function before. Therefore it was not possible to get big memory areas in a running system due to memory fragmentation. Now the trace buffers are subdivided into several subbuffers with pagesize. Therefore it is now possible to allocate more memory for the trace buffers and more trace records can be written. In addition to that, dynamic specification of the size of the trace buffers is implemented. It is now possible to change the size of a trace buffer using a new debugfs file instance. When writing a number into this file, the trace buffer size is changed to 'number * pagesize'. In the past all the traces could be obtained from userspace by accessing files in the "proc" filesystem. Now with debugfs we have a new filesystem which should be used for debugging purposes. This patch moves the debug feature from procfs to debugfs. Since the interface of debug_register() changed, all device drivers, which use the debug feature had to be adjusted. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/char/raw3270.c - drivers/net/netiucv.c: update ↵Yani Ioannou
device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
