Make functions and data static to avoid sparse warnings.
Merge irq.c and s390_ext.c into irq.c. That way all external interrupt
related functions are together.
Interrupt sources like pfault, sclp, dasd_diag and virtio all use the
service signal external interrupt subclass mask in control register 0
to enable and disable the corresponding interrupt.
Because no reference counting is implemented each subsystem thinks it
is the only user of subclass and sets and clears the bit like it wants.
This leads to case that unloading the dasd diag module under z/VM
causes both sclp and pfault interrupts to be masked. The result will
be locked up system sooner or later.
Fix this by introducing a new way to set (register) and clear
(unregister) the service signal subclass mask bit in cr0.
Also convert all drivers.
pfault, dasd diag and virtio all use the same external interrupt number.
The respective interrupt handlers decide by the subcode if they are
meant to handle the interrupt.
Counting is currently done before looking at the subcode which means
each handler counts an interrupt even if it is not handling it.
Fix this by moving the kstat code after the code which looks at the
subcode.
Up to now /proc/interrupts only has statistics for external and i/o
interrupts but doesn't split up them any further.
This patch adds a line for every single interrupt source so that it
is possible to easier tell what the machine is/was doing.
Part of the output now looks like this;
CPU0 CPU2 CPU4
EXT: 3898 4232 2305
I/O: 782 315 245
CLK: 1029 1964 727 [EXT] Clock Comparator
IPI: 2868 2267 1577 [EXT] Signal Processor
TMR: 0 0 0 [EXT] CPU Timer
TAL: 0 0 0 [EXT] Timing Alert
PFL: 0 0 0 [EXT] Pseudo Page Fault
NMI: 0 1 1 [NMI] Machine Checks
Read external interrupts parameters from the lowcore in the first
level interrupt handler in entry[64].S.
The one big missing feature in s390-virtio was hotplugging. This is no more.
This patch implements hotplug add support, so you can on the fly add new devices
in the guest.
Keep in mind that this needs a patch for qemu to actually leverage the
functionality.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Currenty the ext_param field only distinguishes between "config change" and
"vring interrupt". We can do a lot more with it though, so let's enable a
full byte of possible values and constants to #defines while at it.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Use asm offsets to make sure the offset defines to struct _lowcore and
its layout don't get out of sync.
Also add a BUILD_BUG_ON() which checks that the size of the structure
is sane.
And while being at it change those sites which use odd casts to access
the current lowcore. These should use S390_lowcore instead.
Use a console_initcall() to initialize the s390 virtio console and
clean up s390 console initialization in setup.c.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
This replaces find_vq/del_vq with find_vqs/del_vqs virtio operations,
and updates all drivers. This is needed for MSI support, because MSI
needs to know the total number of vectors upfront.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (+ lguest/9p compile fixes)
Add a linked list of all virtqueues for a virtio device: this helps for
debugging and is also needed for upcoming interface change.
Also, add a "name" field for clearer debug messages.
Replace s390_root_dev_register() with root_device_register() etc.
[Includes fix from Cornelia Huck]
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
This patch implements config_changed for the s390 virtio transport.
We use the least significant bit of the interrupt parameter field
to decide, if this interrupt should call the virtio virtqueue callback
or the config_changed callback.
This method is compatible with old host and guest code. Old 64 bit guests
will not check the bit and trigger a harmless additional vring_interrupt
call. Old host code will never set this bit, this is also safe.
This patch also takes care of a potential future 31 bit virtio transport
for s390. On 31 bit _LC_PFAULT_INTPARM and __LC_EXT_PARAMS are identical.
We exploit the alignment of the token and fold the change bit into the
lsb of the token itself.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
This allows each virtio user to hand in the alignment appropriate to
their virtio_ring structures.
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
This doesn't really matter, since s390 pagesize is 4k anyway.
The current virtio model on s390 has the descriptor page above the main
memory. The guest virtio detection will oops if the mem= parameter is
used to reduce/change the memory size.
We have to use real_memory_size instead of max_pfn to detect the virtio
descriptor pages.
No need to define a static device for the kvm_s390 root device,
just use s390_root_dev_register().
This is needed for the bus_id rework
Acked-by: Carsten Otte <cotte@de.ibm.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Fix these two false positive warnings:
WARNING: vmlinux.o(.text+0x2e1cc4): Section mismatch in reference from the function s390_virtio_console_init() to the function .init.text:early_put_chars()
The function s390_virtio_console_init() references
the function __init early_put_chars().
This is often because s390_virtio_console_init lacks a __init
annotation or the annotation of early_put_chars is wrong.
WARNING: vmlinux.o(.text+0x2e1cd0): Section mismatch in reference from the function s390_virtio_console_init() to the function .init.text:virtio_cons_early_init()
the function __init virtio_cons_early_init().
annotation or the annotation of virtio_cons_early_init is wrong.
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cornelia Huck noticed that a modular virtio without kvm guest support
leads to a build error in the s390 virtio transport:
CONFIG_VIRTIO=m leads to
ERROR: "vmem_add_mapping" [drivers/s390/kvm/kvm_virtio.ko] undefined!
ERROR: "max_pfn" [drivers/s390/kvm/kvm_virtio.ko] undefined!
ERROR: "vmem_remove_mapping" [drivers/s390/kvm/kvm_virtio.ko] undefined!
The virtio transport only works with kvm guest support and only as a
builtin. Lets change the build process of drivers/s390/kvm/kvm_virtio.c
to depend on kvm guest support, which is also a bool.
CONFIG_S390_GUEST already selects CONFIG_VIRTIO, that should prevent
CONFIG_S390_GUEST=y CONFIG_VIRTIO=n situations.
CC: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
To prepare for virtio_ring transport feature bits, hook in a call in
all the users to manipulate them. This currently just clears all the
bits, since it doesn't understand any features.
Rather than explicitly handing the features to the lower-level, we just
hand the virtio_device and have it set the features. This make it clear
that it has the chance to manipulate the features of the device at this
point (and that all feature negotiation is already done).
This patch enables virtio_console as the default console on kvm for
s390. We currently use the same notify hack as lguest for early
console output. I will try to address this for lguest and s390 later.
Anthony Liguori points out that three different transports use the virtio code,
but each one keeps its own counter to set the virtio_device's index field. In
theory (though not in current practice) this means that names could be
duplicated, and that risk grows as more transports are created.
So we move the selection of the unique virtio_device.index into the common code
in virtio.c, which has the side-benefit of removing duplicate code.
The only complexity is that lguest and S/390 use the index to uniquely identify
the device in case of catastrophic failure before register_virtio_device() is
called: now we use the offset within the descriptor page as a unique identifier
for the printks.
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Chris Lalancette <clalance@redhat.com>
Cc: Anthony Liguori <anthony@codemonkey.ws>
Fix kvm compile error:
Commit c45a6816c19dee67b8f725e6646d428901a6dc24
(virtio: explicit advertisement of driver features)
and commit e976a2b997fc4ad70ccc53acfe62811c4aaec851
(s390: KVM guest: virtio device support, and kvm hypercalls)
don't like each other:
CC drivers/s390/kvm/kvm_virtio.o
drivers/s390/kvm/kvm_virtio.c:224: error: unknown field 'feature' specified in initializer
drivers/s390/kvm/kvm_virtio.c:224: warning: initialization from incompatible pointer type
make[3]: *** [drivers/s390/kvm/kvm_virtio.o] Error 1
Cc: Adrian Bunk <bunk@kernel.org>
Convert s390 to SPARSEMEM and SPARSEMEM_VMEMMAP. We do a select
of SPARSEMEM_VMEMMAP since it is configurable. This is because
SPARSEMEM without SPARSEMEM_VMEMMAP gives us a hell of broken
include dependencies that I don't want to fix.
This patch implements kvm guest kernel support for paravirtualized devices
and contains two parts:
o a basic virtio stub using virtio_ring and external interrupts and hypercalls
o full hypercall implementation in kvm_para.h
Currently we dont have PCI on s390. Making virtio_pci usable for s390 seems
more complicated that providing an own stub. This virtio stub is similar to
the lguest one, the memory for the descriptors and the device detection is made
via additional mapped memory on top of the guest storage. We use an external
interrupt with extint code 0x2603 for host->guest notification.
The hypercall definition uses the diag instruction for issuing a hypercall. The
parameters are written in R2-R7, the hypercall number is written in R1. This is
similar to the system call ABI (svc) which can use R1 for the number and R2-R6
for the parameters.
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
