path: root/drivers/s390/cio
2013-11-15s390/scm_block: do not hide eadm subchannel dependencySebastian Ott
Stop hiding scm_block's dependency to the eadm subchannel driver (by using functions provided by the eadm subchannel instead of wrappers provided by the scm bus). This will help userspace recognizing module dependencies (e.g. for building a ramdisk). As a side effect we can get rid of some code reimplementing refcounting between those modules. Reported-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-10-24s390/eadm_sch: improve quiesce handlingSebastian Ott
When quiescing an eadm subchannel make sure that outstanding IO is cleared and potential timeout handlers are canceled. Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-10-24s390/bitops: rename find_first_bit_left() to find_first_bit_inv()Heiko Carstens
find_first_bit_left() and friends have nothing to do with the normal LSB0 bit numbering for big endian machines used in Linux (least significant bit has bit number 0). Instead they use MSB0 bit numbering, where the most signficant bit has bit number 0. So rename find_first_bit_left() and friends to find_first_bit_inv(), to avoid any confusion. Also provide inv versions of set_bit, clear_bit and test_bit. This also removes the confusing use of e.g. set_bit() in airq.c which uses a "be_to_le" bit number conversion, which could imply that instead set_bit_le() could be used. But that is entirely wrong since the _le bitops variant uses yet another bit numbering scheme. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-10-24s390/s390dbf: use debug_level_enabled() where applicableHendrik Brueckner
Refactor direct debug level comparisons with the (internal) s390db->level member. Use the debug_level_enabled() function instead. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-10-24s390/qdio: fix atomic_sub() misusageHeiko Carstens
get_inbound_buffer_frontier() makes use of the return value of atomic_sub() which shouldn't work, since atomic_sub() is supposed to return void. This only works on s390 because atomic_sub() gets mapped to atomic_sub_return() with a define without changing it's return value to void. So use atomic_sub_return() instead of atomic_sub() in qeth code before fixing atomic ops. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-10-22s390/time: correct use of store clock fastMartin Schwidefsky
The result of the store-clock-fast (STCKF) instruction is a bit fuzzy. It can happen that the value stored on one CPU is smaller than the value stored on another CPU, although the order of the stores is the other way around. This can cause deltas of get_tod_clock() values to become negative when they should not be. We need to be more careful with store-clock-fast, this patch partially reverts git commit e4b7b4238e666682555461fa52eecd74652f36bb "time: always use stckf instead of stck if available". The get_tod_clock() function now uses the store-clock-extended (STCKE) instruction. get_tod_clock_fast() can be used if the fuzziness of store-clock-fast is acceptable e.g. for wait loops local to a CPU. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-30s390/cio: fix unlocked access of global bitmapSebastian Ott
Access to the slow_subchannel_set has to be secured via the slow_subchannel_lock. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-30s390/hibernate: add early resume functionSebastian Ott
Some functions that do arch specific resume actions are called directly from swsusp_asm64.S . Before we add another function call provide a generic s390_early_resume function which can be used for this purpose. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-22s390: convert interrupt handling to use generic hardirqMartin Schwidefsky
With the introduction of PCI it became apparent that s390 should convert to generic hardirqs as too many drivers do not have the correct dependency for GENERIC_HARDIRQS. On the architecture level s390 does not have irq lines. It has external interrupts, I/O interrupts and adapter interrupts. This patch hard-codes all external interrupts as irq #1, all I/O interrupts as irq #2 and all adapter interrupts as irq #3. The additional information from the lowcore associated with the interrupt is stored in the pt_regs of the interrupt frame, where the interrupt handler can pick it up. For PCI/MSI interrupts the adapter interrupt handler scans the relevant bit fields and calls generic_handle_irq with the virtual irq number for the MSI interrupt. Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-22s390/airq: introduce adapter interrupt vector helperMartin Schwidefsky
The PCI code is the first user of adapter interrupts vectors. Add a set of helpers to airq.c to separate the adatper interrupt code from the PCI bits. The helpers allow for adapter interrupt vectors of any size. Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-22s390: replace strict_strtoul() with kstrtoul()Jingoo Han
The usage of strict_strtoul() is not preferred, because strict_strtoul() is obsolete. Thus, kstrtoul() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-16s390/qdio: remove unused variableSebastian Ott
Fix a "set but not used" warning found via make W=1. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/airq: simplify adapter interrupt codeMartin Schwidefsky
There are three users of adapter interrupts: AP, QDIO and PCI. Each registers a single adapter interrupt with independent ISCs. Define a "struct airq" with the interrupt handler, a pointer and a mask for the local summary indicator and the ISC for the adapter interrupt source. Convert the indicator array with its fixed number of adapter interrupt sources per ISE to an array of hlists. This removes the limitation to 32 adapter interrupts per ISC and allows for arbitrary memory locations for the local summary indicator. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/irq: store interrupt information in pt_regsMartin Schwidefsky
Copy the interrupt parameters from the lowcore to the pt_regs structure in entry[64].S and reduce the arguments of the low level interrupt handler to the pt_regs pointer only. In addition move the test-pending-interrupt loop from do_IRQ to entry[64].S to make sure that interrupt information is always delivered via pt_regs. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/chsc: Use snprintf instead of sprintfMichael Holzheu
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/qdio: cleanup chsc SADC usageSebastian Ott
Move the code to issue the set adapter device controls command to chsc.c and make it accessible for the qdio code via the wrapper chsc_sadc. Reviewed-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/qdio: cleanup chsc SSQD usageSebastian Ott
Cleanup the function qdio_setup_get_ssqd. Fix some possible memleaks and an unchecked allocation and create a wrapper for SSQD in chsc.c . Reviewed-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/cio: Introduce on-close CHSC IOCTLsMichael Holzheu
Introduce two new ioctls CHSC_ON_CLOSE_SET and CHSC_ON_CLOSE_REMOVE that allow to add and remove one CHSC that is unconditionally executed when the CHSC device node is closed. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/cio: Make /dev/chsc a single-open deviceMichael Holzheu
In order to allow serialization of dynamic I/O with this patch the /dev/chsc character device can only be accessed by one single opener. Any subsequent open calls are rejected with EBUSY. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/cio: Introduce generic synchronous CHSC IOCTLMichael Holzheu
This patch adds a new ioctl CHSC_START_SYNC that allows to execute any synchronous CHSC that is provided by user space. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/qdio: remove unused functionSebastian Ott
Remove the unused function qdio_trace_aob. Acked-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-05-15s390/cio: add channel ID sysfs attributePeter Oberparleiter
Add new attributes "chid" and "chid_external" to the channel-path sysfs directory. These attributes contain information related to the channel-ID of the channel-path. Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-05-02s390/cio: add condev keyword to cio_ignoreSebastian Ott
Provide a 'condev' keyword to cio_ignore to (un)ignore the CCW console device. Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-05-02s390/cio: add ipldev keyword to cio_ignoreSebastian Ott
Provide an 'ipldev' keyword to cio_ignore to (un)ignore the CCW or FCP based boot device. Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-26s390/cio: fix irq statisticsSebastian Ott
When we fetch an interrupt on the CCW console using tsch (via ccw_device_wait_idle formerly known as wait_cons_dev) we increment the irq count for the affected interruption class but it is not accounted as an IO interrupt. This is broken since commit b603d258a43b4e7339660bdd3b5c25eacd603e54 "s390: remove superfluous tpi from wait_cons_dev" Fix it so that the sum of the individual interrupts per class matches the number of IO interrupts again. Reported-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/css: move subchannel lock allocationSebastian Ott
cio_validate_subchannel is used to do some basic checks to find out if it's worth to further investigate a subchannel. Move the allocation and initialization of the subchannels locks to css_alloc_subchannel. Clean up the functions involved while at it. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/cio: fix early init counter usageSebastian Ott
Via ccw_device_init_count we keep track of how many devices are in asynchronous device recognition/initialization. For early devices this variable was not only used prior to its initialization but used incorrectly (incremented but never decremented). Fix this by using static initialization for this variable (and friends), make them visible to device.c only, and decrement the counter after recognition of early devices is finished. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/css: remove unused function definitionsSebastian Ott
Make css_probe_device static and remove an unimplemented prototype. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/css: introduce cio_register_early_subchannelsSebastian Ott
Use cio_register_early_subchannels to register early subchannels which are already in use. Call this function before we do the actual subchannel scanning loop. This helps us to get rid of some more special cases regarding the console subchannel. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/cio: get rid of static console deviceSebastian Ott
Remove the static console ccw device (and friends) and use dynamic allocation for these structures. With this change the console device is treated (mostly) like any other ccw device and we can remove some special cases. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/cio: get rid of static console subchannelSebastian Ott
Remove the static console subchannel (and friends) and use dynamic allocation for these structures. With this change the console subchanel is treated (mostly) like any other subchannel and we can remove some special cases. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/cio: split subchannel registrationSebastian Ott
Split the subchannel registration in device_initialize and device_add and move the initialization part inside the allocation function. With this change we can use refcounting during the complete lifespan of a subchannel which is important for devices where we do the actually registration at a later time. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/cio: ccw_device_force_console don't use static variableSebastian Ott
force_console is used to wake up the CCW based console device to print a panic message in case something goes wrong in a suspend or resume cycle. Stop using the static console_subchannel and add a parameter to this function to specify which ccw device we have to wake up. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/cio: wait_cons_dev don't use static variableSebastian Ott
wait_cons_dev is used to busy wait for an interrupt on the console ccw device. Stop using the static console_subchannel and add a parameter to this function to specify on which ccw device/subchannel we have to do the polling. While at it rename the function to ccw_device_wait_idle and move it to device.c Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/cio: Use BITS_TO_LONGS() instead of __BITOPS_WORDS()Akinobu Mita
Use BITS_TO_LONGS() instead of __BITOPS_WORDS() that is considered to be private macro in asm/bitops.h for s390. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/cio: make use of newly added format 1 channel-path dataPeter Oberparleiter
Make use of the stored copy of format 1 channel-path data instead of querying the information every time the corresponding function is called. Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/cio: collect format 1 channel-path description dataPeter Oberparleiter
Collect format 1 channel-path description data for each CHPID and update the information in one place. Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-09constify a bunch of struct file_operations instancesAl Viro
2013-03-07s390/scm: process availabilitySebastian Ott
Let the bus code process scm availability information and notify scm device drivers about the new state. Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-03-07s390/scm_drv: extend notify callbackSebastian Ott
Extend the notify callback of scm_driver by an event parameter to allow to distinguish between different notifications. Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-28qdio: remove unused parametersStefan Raspl
Remove unused function parameters. Signed-off-by: Stefan Raspl <raspl@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-14s390/time: rename tod clock access functionsHeiko Carstens
Fix name clash with some common code device drivers and add "tod" to all tod clock access function names. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-14s390/scm: use inline dummy functionsSebastian Ott
Convert the defines for the !CONFIG_SCM* stuff to static inline functions. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-14s390/cio: handle unknown pgroup stateSebastian Ott
When an attempt to query or modify the grouping state of a channel path fails due to a timeout, we cannot be sure about its state. To get back to a defined state, disband the whole path group and try again while excluding the offending path. Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-14s390/cio: export vpm via sysfsSebastian Ott
Add new attribute "vpm" to the subchannel sysfs directory of I/O subchannels. This attribute contains a path mask indicating which channel paths were successfully verified to be usable for I/O. Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-14s390/cio: skip broken pathsSebastian Ott
Omit known to be broken paths (those set in path_noirq_mask) for the sense/set PGID and nop IO commands. Note: path_noirq_mask will be reset in ccw_device_verify_start (the paths could be healthy again). However if we restart a path verification via verify_start this mask will not be reset (there is no need to let the wait for an interrupt time out again - plus we do not want to loop once we deal with the paths in unknown path group state). Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-14s390/cio: dont abort verification after missing irqSebastian Ott
Do not abort path verification when waiting for an interrupt timed out. Use path_noirq_mask to keep track of the paths used for this (also maintain a path_notoper_mask for debugging purposes). If the timeout happend to be during an operation where we query or alter the state of path groups set the pgid_unknown flag. With this change we allow usage of devices which have such ill-behaved paths (if at least one path is operational). Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
