path: root/drivers/s390/cio/css.h
2008-04-17[S390] cio: Fix race for "fast" path gone/path back situations.Cornelia Huck
Make sure we wait for previous evaluations triggered by path state changes to have settled before we manipulate path states again. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-01-26[S390] cio: reduce cpu utilization during device scanPeter Oberparleiter
Minimize calls to cpu intensive function get_subchannel_by_schid() by introducing function for_each_subchannel_staged() which temporarily caches the information about registered subchannels in a bitmap. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] cio: Set driver->owner on css, ccw and ccwgroup busses.Cornelia Huck
Set the owner field in the embedded struct device_driver to the value provided in the {css,ccw,ccwgroup}_driver. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] cio: I/O subchannel specific fields.Cornelia Huck
Some fields may be !0 only for I/O subchannels. Add some checks where required. Also adapt cio_enable_subchannel() to make the caller specify the intparm, which makes it more generic. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] cio: Introduce subchannel->private.Cornelia Huck
Introduce a private pointer in struct subchannel to store per-subchannel type data (cannot use dev->priv since this is already used for something else). Create a new header io_sch.h for I/O subchannel specific structures and instructions. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] cio: Add css_driver_{register,unregister}.Cornelia Huck
Add wrapper functions for driver_register and driver_unregister so that css drivers don't need to muck with struct device_driver directly. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] cio: css_driver: Use consistent parameters.Cornelia Huck
Make all callbacks in css_driver take a struct subchannel (and not a struct device). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] cio: Use helpers instead of container_of().Cornelia Huck
- Introduce to_cssdriver. - Use to_xxx instead of container_of where possible. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-10-12[S390] cio: remove subchannel_add_files()Cornelia Huck
subchannel_add_files() no longer exists, remove from header. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-10-12[S390] cio: rename css to channel_subsystemsCornelia Huck
Rename css[] to channel_subsystems[] to avoid name clashes. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-07-27[S390] cio: css_sch_device_register() can be made static.Cornelia Huck
2007-05-10[S390] cio: Make some structures and a function static.Cornelia Huck
2007-04-27[S390] cio: fix subchannel channel-path data usagePeter Oberparleiter
Ensure that channel-path related subchannel data is only retrieved and used when it is valid and that it is updated when it may have changed. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] cio: replace subchannel evaluation queue with bitmapPeter Oberparleiter
Use a bitmap for indicating which subchannels require evaluation instead of allocating memory for each evaluation request. This approach reduces memory consumption during recovery in case of massive evaluation request occurrence and removes the need for memory allocation failure handling. Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] cio: Channel-path configure function.Peter Oberparleiter
Add a new attribute to the channel-path sysfs directory through which channel-path configure operations can be triggered. Also listen for hardware events requesting channel-path configure operations and process them accordingly. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] cio: Introduce separate files for channel-path related code.Peter Oberparleiter
2007-02-05[S390] Get rid of a lot of sparse warnings.Heiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-08[S390] Use dev->groups for adding/removing the subchannel attribute group.Cornelia Huck
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-08[S390] Support for disconnected devices reappearing on another subchannel.Cornelia Huck
- create a 'pseudo_subchannel' per channel subsystem (the 'orphanage') - use the orphanage as a shelter for ccw_devices that can't remain on the same subchannel Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-08[S390] Some preparations for the dynamic subchannel mapping patch.Cornelia Huck
- Move adding subchannel attributes to css_register_subchannel(). - Don't call device_trigger_reprobe() for non-operational devices. - Introduce io_subchannel_create_ccwdev(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-08[S390] more workqueue fixes.Martin Schwidefsky
2006-12-04[S390] cio: Retry internal operations after vary off.Cornelia Huck
If I/O was running on a just varied off chpid, it will be terminated. If this was a common I/O layer internal I/O, it needs to be retried. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] cio: Use path verification for last path gone after vary off.Cornelia Huck
If the last path to a device is gone after a chpid has been varied off, putting it on the slow queue doesn't prevent a device driver from still attempting to use it (it may stay on the slow queue for a long time). Instead, trigger a verify event which will prevent I/O attempts from the device driver immediately. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-10-11[S390] cio: Remove grace period for vary off chpid.Cornelia Huck
The grace period handling introduced needless complexity. It didn't help the dasd driver (which can handle terminated I/O just well), and it doesn't help for long running channel programs (which won't complete during the grace period anyway). Terminating I/O using a path that just disappeared immediately is much more consistent with what the user expects. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-10-11[S390] cio: Use ccw_dev_id and subchannel_id in ccw_device_privateCornelia Huck
Use the proper structures to identify device and subchannel. Change get_disc_ccwdev_by_devno() to get_disc_ccwdev_by_dev_id(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-12[S390] path grouping and path verifications fixes.Cornelia Huck
1. Multipath devices for which SetPGID is not supported are not handled well. Use NOP ccws for path verification (sans path grouping) when SetPGID is not supported. 2. Check for PGIDs already set with SensePGID on _all_ paths (not just the first one) and try to find a common one. Moan if no common PGID can be found (and use NOP verification). If no PGIDs have been set, use the css global PGID (as before). (Rationale: SetPGID will get a command reject if the PGID it tries to set does not match the already set PGID.) 3. Immediately before reboot, issue RESET CHANNEL PATH (rcp) on all chpids. This will remove the old PGIDs. rcp will generate solicited CRWs which can be savely ignored by the machine check handler (all other actions create unsolicited CRWs). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-12[S390] subchannel register/unregister mutex.Cornelia Huck
Add a reg_mutex to prevent unregistering a subchannel before it has been registered. Since 2.6.17, we've seen oopses in kslowcrw when a device is found to be not operational during sense id when doing initial device recognition; it is not clear yet why that particular problem was not (yet) observed with earlier kernels... Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-06-05[PATCH] s390: cio non-unique path group idsPeter Oberparleiter
From: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> The path grouping can fail due to non-unique pathgroup-IDs. The source for the CPU-ID part of the ID was incorrectly specified on 64 bit systems. Additionally, the length of the ID was too large due to incorrect data packing declaration. Fix CPU-ID lowcore address and add missing packing declaration. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s390: channel path measurementsCornelia Huck
Gather extended measurements for channel paths from the channel subsystem and expose them to userspace via a sysfs attribute. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] s390: chps[] array too shortCornelia Huck
The chps[] array in struct channel_subsystem is one too short; therefore the code doesn't realize the chpid ff is already known. When several devices on chpid ff become available, the message "new_channel_path: could not register ff" is displayed for every device but the first one. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-13[PATCH] Add {css,ccw}_bus_type probe, remove, shutdown methods.Cornelia Huck
The following patch converts css_bus_type and ccw_bus_type to use the new bus_type methods. Signed-off-by: Cornelia Huck <huckc@de.ibm.com> CC: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-06[PATCH] s390: multiple subchannel sets supportCornelia Huck
Add support for multiple subchannel sets. Works with arbitrary devices in subchannel set 1 and is transparent to device drivers. Although currently only two subchannel sets are available, this will work with the architectured maximum number of subchannel sets as well. Signed-off-by: Cornelia Huck <cohuck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: introduce struct channel_subsystemCornelia Huck
struct channel_subsystem encapsulates several per channel subsystem properties, like status of chpids or the global path group id. Signed-off-by: Cornelia Huck <cohuck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: introduce for_each_subchannelCornelia Huck
for_each_subchannel() is an iterator calling a function for every possible subchannel id until non-zero is returned. Convert the current iterating functions to it. Signed-off-by: Cornelia Huck <cohuck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: introduce struct subchannel_idCornelia Huck
This patch introduces a struct subchannel_id containing the subchannel number (formerly referred to as "irq") and switches code formerly relying on the subchannel number over to it. While we're touching inline assemblies anyway, make sure they have correct memory constraints. Signed-off-by: Cornelia Huck <cohuck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
