Update the channel path descriptor at the beginning of to the
vary_on operation.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Serialize access to members of struct channel_path with a mutex.
This allows bin_attr->read,write,mmap callbacks to check file specific data
(such as inode owner) as part of any privilege validation.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Move dev_set_name to when we know that the device will actually be
registered in order to avoid a memory leak if the allocated memory
for the channel path has to be freed.
Signed-off-by: Michael Ernst <mernst@de.ibm.com>
Don't use kfree directly after device registration started.
Split machine check handler code and move it to cio and kernel code
where it belongs to. No functional change.
Convert most s390 users setting bus_id to dev_set_name().
css and ccw busses are deferred since they need some special
treatment.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Fix cleanup on error in chp_new() and init_channel_subsystem()
(must not call kfree() on structures that had been registered).
Unnecessary dev_info, dev_warn and printk messages are removed.
Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Signed-off-by Heiko Carstens <heiko.carstens@de.ibm.com>
This patch adds a driver for subchannels of type chsc.
A device /dev/chsc is created which may be used to issue ioctls to:
- obtain information about the machine's I/O configuration
- dynamically change the machine's I/O configuration via
asynchronous chsc commands
Do not send CHP_ONLINE/CHP_OFFLINE events to subchannel drivers when a
channel-path configure request failed.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Passing the affected chpid in chp_event() worked only by
chance since chpid is the first element in res_acc_data.
Make it work properly by generalizing res_acc_data as
chp_link and always passing around a properly filled out
chp_link structure in chp_event().
Checking for the validity of the css_*_characteristics is
superfluous since they stay 0 for non-successful scsc.
Eliminate the need for the machine check handler to call into
the common I/O layer directly by introducing an interface to
register handlers for crws per rsc.
Rework the css driver methods to provide sane callbacks for
subchannels of all types.
As a bonus, this cleans up and simplyfies the machine check
handling for I/O subchannels a lot.
We already have a macro for that, so let's use it consistently...
Also removes a bunch of ^L in drivers/s390/cio/cmf.c
Rename css[] to channel_subsystems[] to avoid name clashes.
- Remove unneeded messages.
- Move some messages into the debug feature.
- Use dev_* where appropriate.
- Use "cio: " prefix consistently.
sysfs binary attributes
Well, first of all, I don't want to change so many files either.
What I do:
Adding a new parameter "struct bin_attribute *" in the
.read/.write methods for the sysfs binary attributes.
In fact, only the four lines change in fs/sysfs/bin.c and
include/linux/sysfs.h do the real work.
But I have to update all the files that use binary attributes
to make them compatible with the new .read and .write methods.
I'm not sure if I missed any. :(
Why I do this:
For a sysfs attribute, we can get a pointer pointing to the
struct attribute in the .show/.store method,
while we can't do this for the binary attributes.
I don't know why this is different, but this does make it not
so handy to use the binary attributes as the regular ones.
So I think this patch is reasonable. :)
Who benefits from it:
The patch that exposes ACPI tables in sysfs
requires such an improvement.
All the table binary attributes share the same .read method.
Parameter "struct bin_attribute *" is used to get
the table signature and instance number which are used to
distinguish different ACPI table binary attributes.
Without this parameter, we need to offer different .read methods
for different ACPI table binary attributes.
This is impossible as there are various ACPI tables on different
platforms, and we don't know what they are until they are loaded.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
sysfs is now completely out of driver/module lifetime game. After
deletion, a sysfs node doesn't access anything outside sysfs proper,
so there's no reason to hold onto the attribute owners. Note that
often the wrong modules were accounted for as owners leading to
accessing removed modules.
This patch kills now unnecessary attribute->owner. Note that with
this change, userland holding a sysfs node does not prevent the
backing module from being unloaded.
For more info regarding lifetime rule cleanup, please read the
following message.
http://article.gmane.org/gmane.linux.kernel/510293
(tweaked by Greg to not delete the field just yet, to make it easier to
merge things properly.)
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Use a bitmap for indicating which subchannels require evaluation
instead of allocating memory for each evaluation request. This
approach reduces memory consumption during recovery in case of
massive evaluation request occurrence and removes the need for
memory allocation failure handling.
Add a new attribute to the channel-path sysfs directory through which
channel-path configure operations can be triggered. Also listen for
hardware events requesting channel-path configure operations and
process them accordingly.
Check validity flag of CHPID description data before continuing with
channel-path initialization.
