Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Convert the uses of pr_warning to pr_warn so there are fewer
uses of the old pr_warning.
Miscellanea:
o Align arguments
o Coalesce formats
Use this_cpu_ptr() instead of &__get_cpu_var()
Signed-off-by: Christoph Lameter <cl@linux.com>
Remove the 96-byte irb array from the lowcore and create a per-cpu
variable instead. That way we will pick up any change in the definition
of the struct irb automatically.
Acked-By: Sebastian Ott <sebott@linux.vnet.ibm.com>
Get rid of a useless assignment during argument evaluation.
No functional change.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Print a message in case we do not receive an IRQ in time (for internal
I/O). Also print the ID of the last used channel path, since it is
possible that not the device itself but this specific path might have
a defect.
Change the ccwrequest infrastructure to use more than one channel
path per start I/O. A flag "singlepath" is added to struct
ccw_request - if set, the old behavior is used. This flag is set
for all exploiters of the ccwrequest infrastructure - so there
is no functional change through this patch.
Log the response from the unit check handler which triggers further
cio internal i/o processing.
Signed-off-by: Michael Ernst <mernst@de.ibm.com>
Send unit checks that occur during internal I/O to the device driver
and react according to its return code.
Use asm offsets to make sure the offset defines to struct _lowcore and
its layout don't get out of sync.
Also add a BUILD_BUG_ON() which checks that the size of the structure
is sane.
And while being at it change those sites which use odd casts to access
the current lowcore. These should use S390_lowcore instead.
Channel path vary is currently broken: channel paths which are varied
offline are still used by Linux. The reason for this is that:
* the path mask indicating which paths of an I/O device can be used
is reset by each internal I/O request
* the logic that checks if a path group is already in its designated
target state incorrectly interprets the result "is correctly set"
as "is correctly set and available"
Fix this by resetting the path mask only for internal I/O requests
which affect the path mask and by correcting the pgid check logic.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Improve error recovery for internal I/Os by repeating each I/O
256 times per path to cope with long-running non-permanent error
conditions. Also retry each path twice to cope with link flapping,
i.e. single paths becoming unavailable in the order in which they
are tried.
Reduce code duplication by introducing a central infrastructure to
perform an internal I/O operation on a CCW device.
