The dasd and dcssblk drivers gained the big
kernel lock in the recent pushdown from the
block layer, but they don't really need it,
so remove the calls without a replacement.
Cc: linux-s390@vger.kernel.org
The open and release block_device_operations are currently
called with the BKL held. In order to change that, we must
first make sure that all drivers that currently rely
on this have no regressions.
This blindly pushes the BKL into all .open and .release
operations for all block drivers to prepare for the
next step. The drivers can subsequently replace the BKL
with their own locks or remove it completely when it can
be shown that it is not needed.
The functions blkdev_get and blkdev_put are the only
remaining users of the big kernel lock in the block
layer, besides a few uses in the ioctl code, none
of which need to serialize with blkdev_{get,put}.
Most of these two functions is also under the protection
of bdev->bd_mutex, including the actual calls to
->open and ->release, and the common code does not
access any global data structures that need the BKL.
Acked-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
git commit f331c0296f2a9fee0d396a70598b954062603015 changed users of
->first_minor to devt. This broke device handling in dcssblk, so that
no additional devices could be added after the first one.
This patch reverts the devt conversion to the previous ->first_minor
handling.
Until now we have had a 1:1 mapping between storage device physical
block size and the logical block sized used when addressing the device.
With SATA 4KB drives coming out that will no longer be the case. The
sector size will be 4KB but the logical block size will remain
512-bytes. Hence we need to distinguish between the physical block size
and the logical ditto.
This patch renames hardsect_size to logical_block_size.
Replace s390_root_dev_register() with root_device_register() etc.
[Includes fix from Cornelia Huck]
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Hongjie Yang <hongjie@us.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
To keep the size of changesets sane we split the switch by drivers;
to keep the damn thing bisectable we do the following:
1) rename the affected methods, add ones with correct
prototypes, make (few) callers handle both. That's this changeset.
2) for each driver convert to new methods. *ALL* drivers
are converted in this series.
3) kill the old (renamed) methods.
Note that it _is_ a flagday; all in-tree drivers are converted and by the
end of this series no trace of old methods remain. The only reason why
we do that this way is to keep the damn thing bisectable and allow per-driver
debugging if anything goes wrong.
New methods:
open(bdev, mode)
release(disk, mode)
ioctl(bdev, mode, cmd, arg) /* Called without BKL */
compat_ioctl(bdev, mode, cmd, arg)
locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */
The DCSS block device driver is modified to add >2G DCSSs support and
allow a DCSS block device to map to a set of contiguous DCSSs. The
extmem code is also modified to use new Diagnose x'64' subcodes for
>2G DCSSs.
Convert most s390 users setting bus_id to dev_set_name().
css and ccw busses are deferred since they need some special
treatment.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
bus_id -> dev_name() conversions in s390 code.
[cornelia.huck@de.ibm.com: minor adaptions]
* Implement disk_devt() and part_devt() and use them to directly
access devt instead of computing it from ->major and ->first_minor.
Note that all references to ->major and ->first_minor outside of
block layer is used to determine devt of the disk (the part0) and as
->major and ->first_minor will continue to represent devt for the
disk, converting these users aren't strictly necessary. However,
convert them for consistency.
* Implement disk_max_parts() to avoid directly deferencing
genhd->minors.
* Update bdget_disk() such that it doesn't assume consecutive minor
space.
* Move devt computation from register_disk() to add_disk() and make it
the only one (all other usages use the initially determined value).
These changes clean up the code and will help disk->part dereference
fix and extended block device numbers.
Fix this compile bug:
CC drivers/s390/block/dcssblk.o
drivers/s390/block/dcssblk.c: In function 'dcssblk_add_store':
drivers/s390/block/dcssblk.c:387: error: implicit declaration of function 'dcssblk_get_segment_by_name'
drivers/s390/block/dcssblk.c:389: error: label 'release_gd' used but not defined
make[1]: *** [drivers/s390/block/dcssblk.o] Error 1
make: *** [drivers/s390/block/] Error 2
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Concurrently adding the same segment may lead to duplicate device_register()
calls, which will trigger an error in kobject code:
"... don't try to register things with the same name in the same directory".
This patch adds a check to avoid this.
Alter the block device ->direct_access() API to work with the new
get_xip_mem() API (that requires both kaddr and pfn are returned).
Some architectures will not do the right thing in their virt_to_page() for use
by XIP (to translate from the kernel virtual address returned by
direct_access(), to a user mappable pfn in XIP's page fault handler.
However, we can't switch it to just return the pfn and not the kaddr, because
we have no good way to get a kva from a pfn, and XIP requires the kva for its
read(2) and write(2) handlers. So we have to return both.
Signed-off-by: Jared Hulbert <jaredeh@gmail.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: linux-mm@kvack.org
Move the function that prints the segment warning messages found in the
monreader driver and the dcssblk driver to the extmem base code.
Fix Unlikely(x) != y
Cc: Gerald Schaefer <geraldsc@de.ibm.com>
Cc: Stefan Weinhuber <wein@de.ibm.com>
Signed-off-by: Roel Kluin <12o3l@tiscali.nl>
In case a dcss segment cannot be loaded blk_cleanup_queue
will be called before blk_queue_make_request, leaving the
struct work unplug_work of the request queue uninitialized
before it is used.
That leads also to the lockdep message below.
To avoid that call blk_queue_make_request right after the
request_queue has been allocated.
This makes sure that the struct work is always initialized
before it is used.
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 2 Not tainted 2.6.24 #6
Process swapper (pid: 1, task: 000000000f854038, ksp: 000000000f85f980)
040000000f85f860 000000000f85f880 0000000000000002 0000000000000000
000000000f85f920 000000000f85f898 000000000f85f898 000000000001622e
0000000000000000 000000000f85f980 0000000000000000 0000000000000000
000000000f85f880 000000000000000c 000000000f85f880 000000000f85f8f0
0000000000342908 000000000001622e 000000000f85f880 000000000f85f8d0
Call Trace:
([<000000000001619e>] show_trace+0xda/0x104)
[<0000000000016288>] show_stack+0xc0/0xf8
[<00000000000163d0>] dump_stack+0xb0/0xc0
[<000000000006e4ea>] __lock_acquire+0x47e/0x1160
[<000000000006f27c>] lock_acquire+0xb0/0xd8
[<000000000005a522>] __cancel_work_timer+0x9e/0x240
[<000000000005a72e>] cancel_work_sync+0x2a/0x3c
[<0000000000165c46>] kblockd_flush_work+0x26/0x34
[<0000000000169034>] blk_sync_queue+0x38/0x48
[<0000000000169080>] blk_release_queue+0x3c/0xa8
[<000000000017bce8>] kobject_cleanup+0x58/0xac
[<000000000017bd66>] kobject_release+0x2a/0x38
[<000000000017d28e>] kref_put+0x6e/0x94
[<000000000017bc80>] kobject_put+0x38/0x48
[<00000000001653be>] blk_put_queue+0x2a/0x38
[<0000000000168fee>] blk_cleanup_queue+0x82/0x90
[<0000000000213e7e>] dcssblk_add_store+0x34e/0x700
[<00000000005243b8>] dcssblk_init+0x1a0/0x308
[<000000000050a3c2>] kernel_init+0x1b2/0x3a4
[<000000000001ac82>] kernel_thread_starter+0x6/0xc
[<000000000001ac7c>] kernel_thread_starter+0x0/0xc
INFO: lockdep is turned off.
single list_head variable initialized with LIST_HEAD_INIT could almost
always can be replaced with LIST_HEAD declaration, this shrinks the code
and looks better.
Signed-off-by: Denis Cheng <crquan@gmail.com>
When loading a dcss segment with the dcssblk driver, sometimes the
following kind of message appears:
bio too big device dcssblk0 (8 > 0)
Buffer I/O error on device dcssblk0, logical block 172016
The fix is to move the disk registration after setting the
make_request function, to avoid calls into generic_make_request
for dcssblock without having the make_request function set up
properly.
Unregistering a device from within a device attribute handler leads to
a deadlock. Need to use device_schedule_callback() to unregister device
in error path.
Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com>
As bi_end_io is only called once when the reqeust is complete,
the 'size' argument is now redundant. Remove it.
Now there is no need for bio_endio to subtract the size completed
from bi_size. So don't do that either.
While we are at it, change bi_end_io to return void.
Signed-off-by: Neil Brown <neilb@suse.de>
Some of the code has been gradually transitioned to using the proper
struct request_queue, but there's lots left. So do a full sweet of
the kernel and get rid of this typedef and replace its uses with
the proper type.
No need to warn unregister_blkdev() failure by the callers. (The previous
patch makes unregister_blkdev() print error message in error case)
Currently loaded DCSS segments are now listed in /proc/iomem with
their name followed by a trailing "(DCSS)".
Convert all kmalloc + memset sequences in drivers/s390 to kzalloc usage.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Extract the s390_root_dev_* functions from the common I/O layer as they are
also used by non-ccw device drivers.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Fix compile breakage in the dcss block driver introduced by the attribute
changes.
Signed-off-by: Cornelia Huck <cohuck@de.ibm.com>
This is the block device related part. The block device operation
direct_access now has a struct block_device as first parameter.
drivers/s390/block/dcssblk.c: update device attribute callbacks
Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com>
infrastructure for it.
Let it rip!
