path: root/drivers/s390/block/dasd_int.h
2018-07-02s390/dasd: reduce the default queue depth and nr of hardware queuesStefan Haberland
Reduce the default values for the number of hardware queues and queue depth to significantly reduce the memory footprint of a DASD device. The memory consumption per DASD device reduces from approximately 40MB to approximately 1.5MB. This is necessary to build systems with a large number of DASD devices and a reasonable amount of memory. Performance measurements showed that good performance results are possible with the new default values even on systems with lots of CPUs and lots of alias devices. Fixes: e443343e509a ("s390/dasd: blk-mq conversion") Reviewed-by: Jan Hoeppner <hoeppner@linux.ibm.com> Reviewed-by: Peter Oberparleiter <oberpar@linux.ibm.com> Signed-off-by: Stefan Haberland <sth@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2018-06-12s390/dasd: only use preallocated requestsSebastian Ott
Change the remaining users of dasd_kmalloc_request to use preallocated memory and remove this function. Signed-off-by: Sebastian Ott <sebott@linux.ibm.com> Reviewed-by: Stefan Haberland <sth@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2018-06-12s390/dasd: reshuffle struct dasd_ccw_reqSebastian Ott
Move some members of struct dasd_ccw_req to get rid of padding bytes. This saves 16 bytes per dasd request. Signed-off-by: Sebastian Ott <sebott@linux.ibm.com> Reviewed-by: Stefan Haberland <sth@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2018-06-12s390/dasd: remove dasd_kmalloc_set_cdaSebastian Ott
There is no user of this function. Just remove it. Signed-off-by: Sebastian Ott <sebott@linux.ibm.com> Reviewed-by: Stefan Haberland <sth@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2018-06-12s390/dasd: move dasd_ccw_req to per request dataSebastian Ott
Let the block layer allocate per request data to store struct dasd_ccw_req. We still need extra preallocated memory for usage by ccw programs (which vary in length) and for requests which don't originate from the block layer. Link: https://lkml.kernel.org/r/20180530074130.GA6927@infradead.org Signed-off-by: Sebastian Ott <sebott@linux.ibm.com> Reviewed-by: Stefan Haberland <sth@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2017-12-05s390/dasd: remove 'struct timespec' usageArnd Bergmann
getnstimeofday() and timespec are deprecated since they can overflow on 32-bit architectures. This simply changes to the explicitly typed timespec64 version that doesn't have that problem. It would be nice to also convert to monotonic timestamps and call ktime_get_ts64() rather than ktime_get_real_ts64(), but that would be a user-visible change. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2017-11-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Heiko Carstens: "Since Martin is on vacation you get the s390 pull request for the v4.15 merge window this time from me. Besides a lot of cleanups and bug fixes these are the most important changes: - a new regset for runtime instrumentation registers - hardware accelerated AES-GCM support for the aes_s390 module - support for the new CEX6S crypto cards - support for FORTIFY_SOURCE - addition of missing z13 and new z14 instructions to the in-kernel disassembler - generate opcode tables for the in-kernel disassembler out of a simple text file instead of having to manually maintain those tables - fast memset16, memset32 and memset64 implementations - removal of named saved segment support - hardware counter support for z14 - queued spinlocks and queued rwlocks implementations for s390 - use the stack_depth tracking feature for s390 BPF JIT - a new s390_sthyi system call which emulates the sthyi (store hypervisor information) instruction - removal of the old KVM virtio transport - an s390 specific CPU alternatives implementation which is used in the new spinlock code" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (88 commits) MAINTAINERS: add virtio-ccw.h to virtio/s390 section s390/noexec: execute kexec datamover without DAT s390: fix transactional execution control register handling s390/bpf: take advantage of stack_depth tracking s390: simplify transactional execution elf hwcap handling s390/zcrypt: Rework struct ap_qact_ap_info. s390/virtio: remove unused header file kvm_virtio.h s390: avoid undefined behaviour s390/disassembler: generate opcode tables from text file s390/disassembler: remove insn_to_mnemonic() s390/dasd: avoid calling do_gettimeofday() s390: vfio-ccw: Do not attempt to free no-op, test and tic cda. s390: remove named saved segment support s390/archrandom: Reconsider s390 arch random implementation s390/pci: do not require AIS facility s390/qdio: sanitize put_indicator s390/qdio: use atomic_cmpxchg s390/nmi: avoid using long-displacement facility s390: pass endianness info to sparse s390/decompressor: remove informational messages ...
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-18s390/dasd: remove unused debug macrosSebastian Ott
Get rid of unused wrapper macros around debug_sprintf_exception. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2017-09-08s390/dasd: blk-mq conversionStefan Haberland
Use new blk-mq interfaces. Use multiple queues and also use the block layer complete helper that finish the IO on the CPU that initiated it. Reviewed-by: Jan Hoeppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2017-08-29s390/dasd: Add discard support for FBA devicesJan Höppner
The z/VM hypervisor provides virtual disks (VDISK) which are backed by main memory of the hypervisor. Those devices are seen as DASD FBA disks within the Linux guest. Whenever data is written to such a device, memory is allocated on-the-fly by z/VM accordingly. This memory, however, is not being freed if data on the device is deleted by the guest OS. In order to make memory usable after deletion again, add discard support to the FBA discipline. While at it, update comments regarding the DASD_FEATURE_* flags. Reviewed-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Jan Höppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2017-08-23s390/dasd: Change unsigned long long to unsigned longJan Höppner
Unsigned long long and unsigned long were different in size for 31-bit. For 64-bit the size for both datatypes is 8 Bytes and since the support for 31-bit is long gone we can clean up a little and change everything to unsigned long. Change get_phys_clock() along the way to accept unsigned long as well so that the DASD code can be consistent. Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Jan Höppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2017-08-23s390/dasd: add average request times to dasd statisticsStefan Haberland
Add average times to the DASD statistics interface. Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2017-03-28s390/dasd: suppress command reject error for query host access commandStefan Haberland
On some z/VM systems the query host access command is not supported for temp disks, though the corresponding feature code is set. This does not have any impact beside that the information is not available. Suppress the full blown command reject error messages to not confuse the user. The error is still logged in the s390dbf. Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2017-01-31s390/dasd: Improve parameter list parsingJan Höppner
The function dasd_busid() still uses simple_strtoul() to convert a string to an integer value. This function is obsolete for quite some time already and should be replaced. The whole parameter parsing semantic still relies somewhat on the fact, that simple_strtoul() parses a string containing literals without complains and just returns the parsed integer value plus the residual string. kstrtoint(), however, would return -EINVAL in such a case. Since we want to get rid of simple_strtoul() and now have a nice dasd[] containing only single elements, we can clean up and simplify a few things. Replace simple_strtoul() with kstrtouint(), improve and simplify the overall parameter parsing by the following: - instead of residual strings return proper error codes - remove dasd_parse_next_element() and decide directly what sort of element is being parsed - if we parse a device or a range of devices, split that element into separate bits with a new function - remove warning about invalid ending as it doesn't apply anymore - annotate all parsing functions and data that can be freed after initialisation with __init and __initdata respectively - clean up bits and pieces while at it Reviewed-by: Stefan Haberland <sth@linux.vnet.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Jan Höppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-12s390/dasd: channel path aware error recoveryStefan Haberland
With this feature, the DASD device driver more robustly handles DASDs that are attached via multiple channel paths and are subject to constant Interface-Control-Checks (IFCCs) and Channel-Control-Checks (CCCs) or loss of High-Performance-FICON (HPF) functionality on one or more of these paths. If a channel path does not work correctly, it is removed from normal operation as long as other channel paths are available. All extended error recovery states can be queried and reset via user space interfaces. Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Jan Hoeppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-12-12s390/dasd: extend dasd path handlingStefan Haberland
Store flags and path_data per channel path. Implement get/set functions for various path masks. The patch does not add functional changes. Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Jan Hoeppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-09-26s390/dasd: fix panic during offline processingStefan Haberland
A DASD device consists of the device itself and a discipline with a corresponding private structure. These fields are set up during online processing right after the device is created and before it is processed by the state machine and made available for I/O. During offline processing the discipline pointer and the private data gets freed within the state machine and without protection of the existing reference count. This might lead to a kernel panic because a function might have taken a device reference and accesses the discipline pointer and/or private data of the device while this is already freed. Fix by freeing the discipline pointer and the private data after ensuring that there is no reference to the device left. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-04-15s390/dasd: Add new ioctl BIODASDCHECKFMTJan Höppner
Implement new DASD IOCTL BIODASDCHECKFMT to check a range of tracks on a DASD volume for correct formatting. The following characteristics are checked: - Block size - ECKD key length - ECKD record ID - Number of records per track Signed-off-by: Jan Höppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-04-15s390/dasd: add query host access to volume supportStefan Haberland
With this feature, applications can query if a DASD volume is online to another operating system instances by checking the online status of all attached hosts from the storage server. Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-03-17s390/dasd: reorder lcu and device lockStefan Haberland
Reorder lcu and device lock to get rid of the error-prone trylock mechanism. The locking order is lcu lock -> device lock. This protects against changes to the lcu device lists and enables us to iterate over the devices, take the cdev lock and make changes to the device structures. The complicated part is the summary unit check handler that gets an interrupt on one device of the lcu that leads to structural changes of the whole lcu itself. This work needs to be done even if devices on the lcu disappear. So a device independent worker is used. The old approach tried to update some lcu structures and set up the lcu worker in the interrupt context with the device lock held. But this forced the lock order "cdev lock -> lcu lock" that made it hard to have the lcu lock held and iterate over all devices and change them. The new approach is to schedule a device specific worker that gets out of the interrupt context and rid of the device lock for summary unit checks. This worker is able to take the lcu lock and schedule the lcu worker that updates all devices. The time between interrupt and worker execution is no problem because the devices in the lcu reject all I/O in this time with an appropriate error. The dasd driver can deal with this situation and re-drive the I/O later on. Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-03-07s390/dasd: remove casts to dasd_*_privateSebastian Ott
Convert dasd_device.private to be a void pointer to get rid of a lot of explicit casts. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Stefan Haberland <sth@linux.vnet.ibm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-03-07s390/dasd: Improve dasd format codeJan Höppner
- Make sure a calling function can rely on data in fdata by resetting to its initial values - Move special treatment for track 0 and 1 to dasd_eckd_build_format - Replace dangerous backward goto with a loop logic - Add define for number that specifies the maximum amount of CCWs per request and is used for format_step calculation - Remove unused variable Signed-off-by: Jan Höppner <hoeppner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2015-08-09s390/dasd: fix failing path verificationStefan Haberland
DASD path verification requires the usage of sleep_on_immediatly to ensure that no other I/O request is blocking the recovery of disconnected devices. But two concurrent path verification workers for the same device may kill each others requests due to the usage of the immediate sleep_on function. This may lead to unsuccessful path verifications. Prevent that two parallel path verification workers conflict with each other by implementing a device flag signalling a already running worker. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2015-01-29s390/dasd: cleanup profilingSebastian Ott
The dasd driver has a lot of duplicated code to handle dasd_global_profile. With this patch we use the same code for the global and the per device profiling data. Note that dasd_stats_write had to change slightly to maintain some odd differences between A) per device and global profile and B) proc and sysfs interface usage. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2015-01-29s390/dasd: add locking for global_profile accessSebastian Ott
Access to DASDs global statistics is done without locking which can lead to inconsistent data. Add locking to fix this. Also move the relevant structs in a global dasd_profile struct. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-10-09s390/dasd: add support for control unit initiated reconfigurationStefan Haberland
Add support for Control Unit Initiated Reconfiguration (CUIR) to Linux, a storage server interface to reconcile concurrent hardware changes between storage and host. Reviewed-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-08-01s390/dasd: fix camel caseStefan Haberland
Rename enable_PAV to enable_pav. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-07-22dasd: fix error recovery for alias devices during formatStefan Haberland
Kernel panic or a hanging device during format if an alias device is set offline or I/O errors occur. Omit the error recovery procedure for alias devices and do retries on the base device with full erp. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-07-22dasd: use aliases for formatted devices during formatStefan Haberland
Formatting of a previously formatted device is slower than newly format a device when alias devices are available. For already formatted devices the alias devices are not used for formatting. Fix the alias handling for already formatted devices. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: Fail all requests when DASD_FLAG_ABORTIO is setHannes Reinecke
Whenever a DASD request encounters a timeout we might need to abort all outstanding requests on this or even other devices. This is especially useful if one wants to fail all devices on one side of a RAID10 configuration, even though only one device exhibited an error. To handle this I've introduced a new device flag DASD_FLAG_ABORTIO. This flag is evaluated in __dasd_process_request_queue() and will invoke blk_abort_request() for all outstanding requests with DASD_CQR_FLAGS_FAILFAST set. This will cause any of these requests to be aborted immediately if the blk_timeout function is activated. The DASD_FLAG_ABORTIO is also evaluated in __dasd_process_request_queue to abort all new request which would have the DASD_CQR_FLAGS_FAILFAST bit set. The flag can be set with the new ioctls 'BIODASDABORTIO' and removed with 'BIODASDALLOWIO'. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: Add 'timeout' attributeHannes Reinecke
This patch adds a 'timeout' attibute to the DASD driver. When set to non-zero, the blk_timeout function will be enabled with the timeout specified in the attribute. Setting 'timeout' to '0' will disable block timeouts. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: make number of retries configurableHannes Reinecke
Instead of having the number of retries hard-coded in the various functions we should be using a default retry value, which can be modified via sysfs. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/dasd: improve speed of dasdfmtStefan Haberland
Reorganize format IO requests and enable usage of PAV. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-30s390/dasd: add safe offline interfaceStefan Haberland
The regular behavior of the DASD device driver when setting a device offline is to return all outstanding I/O as failed. This behavior is different from that of other System z operating systems and may lead to unexpected data loss. Adding an explicit 'safe' offline function will allow customers to use DASDs in the way they expect them to work. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-07-20s390/comments: unify copyright messages and remove file namesHeiko Carstens
Remove the file name from the comment at top of many files. In most cases the file name was wrong anyway, so it's rather pointless. Also unify the IBM copyright statement. We did have a lot of sightly different statements and wanted to change them one after another whenever a file gets touched. However that never happened. Instead people start to take the old/"wrong" statements to use as a template for new files. So unify all of them in one go. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2012-07-16s390/dasd: add shutdown actionStefan Haberland
Add a mechanism to wait for outstanding IO during shutdown. Schedule the block_bh and device_bh and wait until our request queues are empty. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2012-05-24s390/headers: remove #ifdef __KERNEL__ from not exported headersHeiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-01-18[S390] dasd: revalidate server for new pathgroupStefan Haberland
If a pathgroup is established we get an event and have to revalidate the server to propagate supported features like PAV and enable them. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] dasd: prevent path verification before resumeStefan Haberland
Mark the device as suspended and delay execution of the path verification worker to prevent mix-up. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] dasd: re-initialize read_conf buffer for retriesStefan Haberland
The buffer for read configuration data has to be initialized with an EBCDIC string to show support for extended UIDs to z/VM. If this read configuration data CQR needs to be retried, the buffer may have changed in between. So re-initialize the buffer to get a correct extended UID under z/VM. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-07-24[S390] dasd: add enhanced DASD statistics interfaceStefan Weinhuber
This patch extends the DASD statistics to allow for a more detailed analysis of DASD I/O operations. In particular we want the statistics to provide answers to the following questions: - How many requests used a PAV alias? - How many requests used High Performance FICON? - How do read request perform versus write requests? The existing DASD statistics interface has several shortcomings - The interface for global data is a formatted text table in procfs (/proc/dasd/statistics). The layout is meant for human readers and is not to easy to parse. If values get to large for the table layout, they get scaled down. - The statistics which are collected per block device can be accessed via an ioctl interface, which can only be extended by defining a new ioctl. - There is no statistics interface for individual PAV base and alias devices. To overcome theses shortcomings we create a new DASD statistics interface in debugfs. This interface will contain one entry for global data, one per DASD block device, and one per DASD base and alias device. Each file contains the statistic data in easy to parse name/value and name/array pairs. The existing interfaces will remain functional, but they will not be extended. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-20[S390] dasd: fix race between open and offlineStefan Weinhuber
The dasd_open function uses the private_data pointer of the gendisk to find the dasd_block structure that matches the gendisk. When a DASD device is set offline, we set the private_data pointer of the gendisk to NULL and later remove the dasd_block structure, but there is still a small race window, in which dasd_open could first read a pointer from the private_data field and then try to use it, after the structure has already been freed. To close this race window, we will store a pointer to the dasd_devmap structure of the base device in the private_data field. The devmap entries are not deleted, and we already have proper locking and reference counting in place, so that we can safely get from a devmap pointer to the dasd_device and dasd_block structures of the device. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] dasd: Improve handling of stolen DASD reservationStefan Weinhuber
If a DASD device has been reserved by a Linux system, and later this reservation is ‘stolen’ by a second system by means of an unconditional reserve, then the first system receives a notification about this fact. With this patch such an event can be either ignored, as before, or it can be used to let the device fail all I/O request, so that the device will not block anymore. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] dasd: do path verification for paths added at runtimeStefan Weinhuber
When a new path is added at runtime, the CIO layer will call the drivers path_event callback. The DASD device driver uses this callback to trigger a path verification for the new path. The driver will use only those paths for I/O, which have been successfully verified. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-08-09[S390] dasd: tunable missing interrupt handlerStefan Haberland
This feature provides a user interface to specify the timeout for missing interrupts for standard I/O operations. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-05-26[S390] dasd: unit check handling during internal cio I/OStefan Haberland
React on unit checks during cio internal I/O. Handle as unsolicited interrupt and advice cio to retry. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-05-17[S390] dasd: remove uid from devmapStefan Haberland
Remove the duplicate of the DASD uid from the devmap structure. Use the uid from the device private structure instead. This also removes a lockdep warning complaining about a possible SOFTIRQ-safe -> SOFTIRQ-unsafe lock order. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-05-17[S390] dasd: add dynamic pav tolerationStefan Haberland
For base Parallel Access Volume (PAV) there is a fixed mapping of base and alias devices. With dynamic PAV this mapping can be changed so that an alias device is used with another base device. This patch enables the DASD device driver to tolerate dynamic PAV changes. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-08[S390] dasd: automatic recognition of read-only devicesStefan Weinhuber
In z/VM it is possible to attach a device as read-only. To prevent unintentional write requests and subsequent I/O errors, we can detect this configuration using the z/VM DIAG 210 interface and set the respective linux block device to read-only as well. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
