path: root/drivers/rtc
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: export length of os_hpmc vector parisc: fix kernel crash (protection id trap) when compiling ruby1.9 parisc: Use DEFINE_SPINLOCK parisc: add uevent helper for parisc bus parisc: fix ipv6 checksum parisc: quiet palo not-found message from "which" parisc: Replace NR_CPUS in parisc code parisc: trivial fixes parisc: fix braino in commit adding __space_to_prot parisc: factor out sid to protid conversion parisc: use leX_to_cpu in place of __fswabX parisc: fix GFP_KERNEL use while atomic in unwinder parisc: remove dead BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitions parisc: set_time() catch errors parisc: use the new byteorder headers parisc: drivers/parisc/: make code static parisc: lib/: make code static
2009-01-08rtc-ds1307: remove legacy probe() checksJüri Reitel
Remove RTC register value checks from the rtc-ds1307 probe() function. They were left over from the legacy style I2C driver, which had to defend against finding a non-RTC chip when the driver was probed. Also fix a minor glitch in the alarm support: DS1307 chips don't have alarms, so name those methods after one of the chips which actually *do* have alarms (DS1337). Signed-off-by: Jüri Reitel <juri.reitel@liewenthal.ee> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Sebastien Barre <sbarre@sdelcc.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08rtc-ds1307: SMBus compatibilityBARRE Sebastien
Change i2c access functions to SMBus access functions in order to use the ds1307 with SMBus adapter. Signed-off-by: Sebastien Barre <sbarre@sdelcc.com> Acked-by: David Brownell <david-b@pacbell.net> Tested-by: David Brownell <david-b@pacbell.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Rodolfo Giometti <giometti@enneenne.com> Tested-by: Sebastien Barre <sbarre@sdelcc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) trivial: chack -> check typo fix in main Makefile trivial: Add a space (and a comma) to a printk in 8250 driver trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx trivial: Fix misspelling of "firmware" in powerpc Makefile trivial: Fix misspelling of "firmware" in usb.c trivial: Fix misspelling of "firmware" in qla1280.c trivial: Fix misspelling of "firmware" in a100u2w.c trivial: Fix misspelling of "firmware" in megaraid.c trivial: Fix misspelling of "firmware" in ql4_mbx.c trivial: Fix misspelling of "firmware" in acpi_memhotplug.c trivial: Fix misspelling of "firmware" in ipw2100.c trivial: Fix misspelling of "firmware" in atmel.c trivial: Fix misspelled firmware in Kconfig trivial: fix an -> a typos in documentation and comments trivial: fix then -> than typos in comments and documentation trivial: update Jesper Juhl CREDITS entry with new email trivial: fix singal -> signal typo trivial: Fix incorrect use of "loose" in event.c trivial: printk: fix indentation of new_text_line declaration trivial: rtc-stk17ta8: fix sparse warning ...
2009-01-06drivers/rtc: correct an error testJulia Lawall
rtc is clearly does not satisfy IS_ERR at the point where it is tested, so I have changed the test to consider the just initialized rtc->rtc_dev. The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @match exists@ expression x, E; identifier fld; position p1,p2; @@ ( x = E; | x = E | x@p1->fld ... when != x = E IS_ERR(x@p2) ... when any ) @other_match exists@ expression match.x, E1, E2; position match.p1,match.p2; @@ x = E1 ... when != x = E2 when != x@p1 x@p2 @ script:python depends on !other_match@ p1 << match.p1; p2 << match.p2; @@ print "* file %s dereference %s test %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: driver for Marvell's SoCs 88F6281 and 88F6192Saeed Bishara
Driver for the on-chip RTC found in some of Marvell's SoCs such as the Kirkwood 88F6281 and 88F6192 devices. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: rtc-ds1216 fixesAlessandro Zummo
Fixes a few issues with the rtc-ds1216 driver - use rtc_valid_tm - use platform_driver_probe - fix init sequence - it was using rtc_unregister_driver where not needed. I also added resource_size and removed an useless pointer assignment. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Tested-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: add rtc-tx4939 driverAtsushi Nemoto
Add support for RTC in TX4939 SoC. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: use set_mmss when set_time is not availableAlessandro Zummo
Drivers should only need to implement either set_mmss (counter based RTCs) or set_time (most RTCs). The RTC subsystem will handle them appropriately. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: David Brownell <david-b@pacbell.net> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: rtc-ds3234 fixesAlessandro Zummo
- no changelogs in code - no banners - use local buffers - fix probe sequence - do not init .driver.bus Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Dennis Aberilla <denzzzhome@yahoo.com> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: rtc-max6902 fixesAlessandro Zummo
- no changelogs in code - no banners - use local buffers - fix probe sequence - fixed style issues - fix spi_write call - removed old debug code replaces http://patchwork.ozlabs.org/patch/9421/ and http://patchwork.ozlabs.org/patch/9455/ Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: David Brownell <david-b@pacbell.net> Cc: Raphael Assenat <raph@raphnet.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: Au1000 On-Chip Counter0-as-RTC driver.Manuel Lauss
Simple driver which uses the Au1xxx Time-Of-Year counter (counter0) as a 1Hz RTC. [akpm@linux-foundation.org: repair Kconfig] Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: kconfig cleanupAlessandro Zummo
Remove double spaces and adds some suggestions. It also fixes the descriptions of options that are no more available as modules. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: rtc-ds1390 probe sequence and misc fixesAlessandro Zummo
Small fixes for the ds1390 driver - fixed initialization of the spi device - added missing includes - removed printks - removed useless wrappers for rtc ops - removed dead code Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Mark Jackson <mpfj@mimc.co.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: pxa27x/pxa3xx driver fixes, revisedAlessandro Zummo
Small fixes for the pxa27x/pxa3xx driver - use platform_driver_probe - fixed exit paths - fixed probe sequence - added missing include - using linux/io.h instead of asm/io.h Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Jonathan Cameron <jic23@cam.ac.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: driver for pxa27x and pxa3xx SoCRobert Jarzmik
With PXA27x and above, a new RTC hardware block was added in addition to the legacy one which is also found on the SA1100 SOC family. This second RTC block is called "wristwatch" and "periodic interrupt" and works independently from the other RTC block. The driver offers provides : - a 1Hz ticking clock - a periodic alarm, in the 1Hz to 1000Hz range - a one shot alarm Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: move power of 2 periodic frequency check down into driversJonathan Cameron
Move the power of 2 check on frequencies down into individual rtc drivers This is to allow for non power of 2 real time clock periodic interrupts such as those on the pxa27x to be found in the new pxa27x-rtc driver Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: bunch of drivers: fix 'no irq' case handingAnton Vorontsov
This patch fixes a bunch of irq checking misuses. Most drivers were getting irq via platform_get_irq(), which returns -ENXIO or r->start. rtc-cmos.c is special. It is using PNP and platform bindings. Hopefully nobody is using PNP IRQ 0 for RTC. So the changes should be safe. rtc-sh.c is using platform_get_irq, but was storing a result into an unsigned type, then was checking for < 0. This is fixed now. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: struct device: replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-By: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06trivial: rtc-stk17ta8: fix sparse warningHannes Eder
Fix this sparse warning: drivers/rtc/rtc-stk17ta8.c:403:2: warning: returning void-valued expression Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-06trivial: rtc-ds1511: fix sparse warningHannes Eder
Fix this sparse warning: drivers/rtc/rtc-ds1511.c:634:2: warning: returning void-valued expression Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-05parisc: set_time() catch errorsRoel Kluin
set_rtc_time returns negative on error, ret should be signed to catch those Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-04rtc: add alarm/update irq interfacesAlessandro Zummo
Add standard interfaces for alarm/update irqs enabling. Drivers are no more required to implement equivalent ioctl code as rtc-dev will provide it. UIE emulation should now be handled correctly and will work even for those RTC drivers who cannot be configured to do both UIE and AIE. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-30Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (407 commits) [ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devices [ARM] pxafb: cleanup of the timing checking code [ARM] pxafb: cleanup of the color format manipulation code [ARM] pxafb: add palette format support for LCCR4_PAL_FOR_3 [ARM] pxafb: add support for FBIOPAN_DISPLAY by dma braching [ARM] pxafb: allow pxafb_set_par() to start from arbitrary yoffset [ARM] pxafb: allow video memory size to be configurable [ARM] pxa: add document on the MFP design and how to use it [ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constant [ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant [ARM] pxa/tavorevb: update board support (smartpanel LCD + keypad) [ARM] pxa: Update eseries defconfig [ARM] 5352/1: add w90p910-plat config file [ARM] s3c: S3C options should depend on PLAT_S3C [ARM] mv78xx0: implement GPIO and GPIO interrupt support [ARM] Kirkwood: implement GPIO and GPIO interrupt support [ARM] Orion: share GPIO IRQ handling code [ARM] Orion: share GPIO handling code [ARM] s3c: define __io using the typesafe version [ARM] S3C64XX: Ensure CPU_V6 is selected ...
2008-12-29Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
2008-12-29[ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constantEric Miao
As Nicolas and Russell pointed out, CLOCK_TICK_RATE is no more a constant on PXA when multiple processors and platforms are selected, change TIMER_FREQ in rtc-sa1100.c into a variable. Since the code to decide the clock tick rate is re-used from timer.c, introduce a common get_clock_tick_rate() for this. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@marvell.com>
2008-12-23rtc: rtc-isl1208: reject invalid datesChris Elston
This patch for the rtc-isl1208 driver makes it reject invalid dates. Signed-off-by: Chris Elston <celston@katalix.com> [a.zummo@towertech.it: added comment explaining the check] Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Hebert Valerio Riedel <hvr@gnu.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-15Merge branch 'omap3-upstream' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
2008-12-10rtc twl4030: rename ioctl function when RTC_INTF_DEV=nRandy Dunlap
Fix build error when RTC_INTF_DEV=n: drivers/rtc/rtc-twl4030.c:402: error: 'twl4030_rtc_ioctl' undeclared here (not in a function) make[3]: *** [drivers/rtc/rtc-twl4030.o] Error 1 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Tony Lindgren <tony@atomide.com> Cc: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10rtc: fix missing id_table in rtc-ds1672 and rtc-max6900 driversAlessandro Zummo
Add missing id_table to the drivers in subject. Patch is against the latest git. It should go in with 2.6.28 if possible, the drivers won't work without the id_table bits. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Reported-by: Imre Kaloz <kaloz@openwrt.org> Tested-by: Imre Kaloz <kaloz@openwrt.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Fix offset calculation in compute_size() rtc: rtc-starfire fixes
2008-12-01[ARM] 5319/1: AT91: support AT91CAP9 revC CPUsStelian Pop
The AT91CAP9 revC CPU has a few differences over the previous, revB CPU which was distributed in small quantities only (revA was an internal Atmel product only). This patch adds the detection routines to recognize the different AT91CAP9 revisions (based on the PMC subsystem version number), and uses them to: - activate a workaround for the external interrupts levels (on revB CPUs) - set the UDPHS_BYPASS bit (on revB CPUs) - set AT91_GPBR register address to the correct offset (0xfffffd50 on revB, 0xfffffd60 on revC) For debugging usage, the CPU revision can be found in /proc/cpuinfo on the 'Revision' line. This patch is extracted from Andrew Victor's -at91 patch (2.6.27-at91.patch) where it has been tested for the last 6 months. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29Merge branch 's3c-moves2' of git://aeryn.fluff.org.uk/bjdooks/linux into develRussell King
2008-11-21rtc: rtc-starfire fixesAlessandro Zummo
Changes: - remove locks, rtc class provides them - remove unused include - if the rtc can't handle set_time, the driver should not fake it Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: rtc: rtc-sun4v fixes, revised sparc: Fix tty compile warnings. sparc: struct device - replace bus_id with dev_name(), dev_set_name()
2008-11-14rtc: rtc-sun4v fixes, revisedAlessandro Zummo
- simplified code - use platform_driver_probe - removed locking: it's provided by rtc subsystem Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12rtc: add Dallas DS1390/93/94 RTC chipsMark Jackson
Add support for the Dallas DS1390/93/94 SPI RTC chip. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12rtc: basic implementation of Epson RX-8581 I2C Real Time ClockMartyn Welch
Provide the basic "get" and "set" functionality for the Epson RX-8581 I2C RTC. It currently does not support the RTC's Alarm or Fixed-cycle timer. [akpm@linux-foundation.org: need log2.h for ilog2(), remove unneeded initialisation] Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12rtc: rtc-wm8350: add support for WM8350 RTCMark Brown
This adds support for the RTC provided by the Wolfson Microelectronics WM8350. This driver was originally written by Graeme Gregory and Liam Girdwood, though it has been modified since then to update it to current mainline coding standards and for API completeness. [akpm@linux-foundation.org: s/schedule_timeout_interruptible/schedule_timeout_uninterruptible/ to prevent bogus timeout when signal_pending()] Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Liam Girdwood <linux@wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06rtc-cmos: fix boot log messageFrans Pop
-rtc0: alarms up to one month, y3k, 114 bytes nvram, , hpet irqs irqs +rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs Signed-off-by: Frans Pop <elendil@planet.nl> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06rtc: fix handling of missing tm_year data when reading alarmsMark Brown
When fixing up invalid years rtc_read_alarm() was calling rtc_valid_tm() as a boolean but rtc_valid_tm() returns zero on success or a negative number if the time is not valid so the test was inverted. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-03Merge branch 'master' of ↵Ben Dooks
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into s3c-moves2
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Add missing null terminating entry to bq4802_match[]. sparc: use the new byteorder headers rtc-m48t59: shift zero year to 1968 on sparc (rev 2) dbri: check dma_alloc_coherent errors sparc64: remove byteshifting from out* helpers
2008-10-30rtc S3C: add device_init_wakeup() invokationYauhen Kharuzhy
tAdd adds device_init_wakeup() ivokation to probe function of s3c2410_rtc_driver. Without of this wakealarm sysfs attribute does not initialise. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30rtc: ds3234 doesn't link when built-inGeert Uytterhoeven
When ds3234 is built-in, the final links fails with the following vague error message: `.exit.text' referenced in section `.data' of drivers/built-in.o: defined in discarded section `.exit.text' of drivers/built-in.o ds3234_remove() cannot be marked __exit, as it's accessed via __devexit_p(). In addition, mark ds3234_probe() __devinit while we're at it. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30rtc-s3c: fix section mismatch warningsYauhen Kharuzhy
Warnings was appeared when compile rtc-s3c.c because platform_driver structure s3c2410_rtcdrv has wrong name. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30[ARM] S3C: Move regs-rtc.h to arch/arm/plat-s3c/include/platBen Dooks
Move regs-rtc.h to arch/arm/plat-s3c/include/plat ready to clean out old include directories. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-29rtc-m48t59: shift zero year to 1968 on sparc (rev 2)Krzysztof Helt
Shift the first year to 1968 for Sun SPARC machines. Move this logic from platform specific files to rtc driver as this fixes problems with calculating a century bit. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Tested-by: Alexander Beregalov Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (23 commits) sh: asm/gpio.h needs linux/kernel.h for might_sleep()/WARN_ON(). sh: mach-highlander: Handle SCIF pinmuxing on R7785RP. sh: sh7785 pinmux support sh: update defconfigs. sh: Kill off unused p1fc divisors from SH7763 clk fwk. sh: improve pinmux support for single direction pins sh: use 10MHz VIO_CLK for ov772x on Migo-R sh: Update gpio_set_value() pin value handling sh: update ov772x byte order on Migo-R rtc: Add R2025S/D comment to rs5c372 Kconfig entry. sh: Export cache flush routines needed by sh_eth on SH7619. sh: Wire up oops reporting in the die notifier chain. sh: ap325rxa: Kill off unused port definitions. sh: Hook up PB0->PB7 input-only pins in SH7203 PFC. sh: ap325rxa: Move off of hardcoded pinmux for flctl initialization. sh: add support FLCTL for ap325rxa board sh: gpio: Stub in dummy GPIO<->IRQ mapping routines. sh: rsk7203: leds-gpio support for RSK+ LEDs. sh: gpio: Include asm-generic/gpio.h for non-gpiolib stubs. sh: fix soc-camera compile breakage on Migo-R. ...
