path: root/drivers/rtc
2013-06-20Merge tag 'imx-soc-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6 ↵Arnd Bergmann
into next/soc From Shawn Guo: imx soc changes for 3.11: * New SoCs i.MX6 Sololite and Vybrid VF610 support * imx5 and imx6 clock fixes and additions * Update clock driver to use of_clk_init() function * Refactor restart routine mxc_restart() to get it work for DT boot as well * Clean up mxc specific ulpi access ops * imx defconfig updates * tag 'imx-soc-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6: (29 commits) ARM: imx_v6_v7_defconfig: Enable Vybrid VF610 ARM: imx_v6_v7_defconfig: Enable imx-wm8962 by default ARM: clk-imx6qdl: Add clko1 configuration for imx6qdl-sabresd ARM: imx_v6_v7_defconfig: Enable PWM and backlight options ARM: imx: Remove mxc specific ulpi access ops ARM: imx: add initial support for VF610 ARM: imx: add VF610 clock support ARM: imx_v6_v7_defconfig: enable parallel display ARM: imx: clk: No need to initialize phandle struct ARM: imx: irq-common: Include header to avoid sparse warning ARM: imx: Enable mx6 solo-lite support ARM: imx6: use common of_clk_init() call to initialize clocks ARM: imx6q: call of_clk_init() to register fixed rate clocks ARM: imx: imx_v6_v7_defconfig: Select CONFIG_DRM_IMX_TVE ARM: i.MX6: clk: add different DualLite MLB clock config ARM i.MX5: Add S/PDIF clocks ARM i.MX53: Add SATA clock ARM: imx6q: clk: add the eim_slow clock ARM: imx: remove MLB PLL from pllv3 ARM: imx: disable pll8_mlb in mx6q_clks ... Conflicts: arch/arm/Kconfig.debug (simple add/add conflict) Includes an update to 3.10-rc6 Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-06-20Merge tag 'u300-multiplatform' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson into next/soc From Linus Walleij: Device Tree and Multiplatform support for U300: - Add devicetree support to timer, pinctrl (probe), I2C block, watchdog, DMA controller and clocks. - Piecewise add a device tree containing all peripherals. - Delete the ATAG boot path. - Delete redundant platform data and board files. - Convert to multiplatform. * tag 'u300-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson: (40 commits) ARM: u300: switch to using syscon regmap for board ARM: u300: Update MMC configs for u300 defconfig spi: pl022: use DMA by default when probing from DT pinctrl: get rid of all platform data for coh901 ARM: u300: convert MMC/SD clock to device tree ARM: u300: move the gated system controller clocks to DT i2c: stu300: do not request a specific clock name clk: move the U300 fixed and fixed-factor to DT ARM: u300: remove register definition file ARM: u300: add syscon node ARM: u300 use module_spi_driver to register driver ARM: u300: delete remnant machine headers ARM: u300: convert to multiplatform ARM: u300: localize <mach/u300-regs.h> ARM: u300: delete <mach/irqs.h> ARM: u300: delete <mach/hardware.h> ARM: u300: push down syscon registers ARM: u300: remove deps from debug macro ARM: u300: move debugmacro to debug includes ARM: u300: delete all static board data ... Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-06-17rtc: coh901331: add devicetree supportLinus Walleij
This add devicetree probe support to the COH 901 331 RTC driver. Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-12rtc-at91rm9200: use shadow IMR on at91sam9x5Johan Hovold
Add support for the at91sam9x5-family which must use the shadow interrupt mask due to a hardware issue (causing RTC_IMR to always be zero). Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12rtc-at91rm9200: add shadow interrupt maskJohan Hovold
Add shadow interrupt-mask register which can be used on SoCs where the actual hardware register is broken. Note that some care needs to be taken to make sure the shadow mask corresponds to the actual hardware state. The added overhead is not an issue for the non-broken SoCs due to the relatively infrequent interrupt-mask updates. We do, however, only use the shadow mask value as a fall-back when it actually needed as there is still a theoretical possibility that the mask is incorrect (see the code for details). Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12rtc-at91rm9200: refactor interrupt-register handlingJohan Hovold
Add accessors for the interrupt register. This will allow us to easily add a shadow interrupt-mask register to use on SoCs where the interrupt-mask register cannot be used. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12rtc-at91rm9200: add configuration supportJohan Hovold
Add configuration support which can be used to implement SoC-specific workarounds for broken hardware. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12rtc-at91rm9200: add match-table compile guardJohan Hovold
The members of Atmel's at91sam9x5 family (9x5) have a broken RTC interrupt mask register (AT91_RTC_IMR). It does not reflect enabled interrupts but instead always returns zero. The kernel's rtc-at91rm9200 driver handles the RTC for the 9x5 family. Currently when the date/time is set, an interrupt is generated and this driver neglects to handle the interrupt. The kernel complains about the un-handled interrupt and disables it henceforth. This not only breaks the RTC function, but since that interrupt is shared (Atmel's SYS interrupt) then other things break as well (e.g. the debug port no longer accepts characters). Tested on the at91sam9g25. Bug confirmed by Atmel. This patch (of 5): Add missing match-table compile guard. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12drivers/rtc/rtc-twl.c: fix missing device_init_wakeup() when booted with ↵Tony Lindgren
device tree When booted in legacy mode device_init_wakeup() gets called by drivers/mfd/twl-core.c when the children are initialized. However, when booted using device tree, the children are created with of_platform_populate() instead add_children(). This means that the RTC driver will not have device_init_wakeup() set, and we need to call it from the driver probe like RTC drivers typically do. Without this we cannot test PM wake-up events on omaps for cases where there may not be any physical wake-up event. Signed-off-by: Tony Lindgren <tony@atomide.com> Reported-by: Kevin Hilman <khilman@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Jingoo Han <jg1.han@samsung.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12drivers/rtc/rtc-cmos.c: fix accidentally enabling rtc channelDerek Basehore
During resume, we call hpet_rtc_timer_init after masking an irq bit in hpet. This will cause the call to hpet_disable_rtc_channel to be undone if RTC_AIE is the only bit not masked. Allowing the cmos interrupt handler to run before resuming caused some issues where the timer for the alarm was not removed. This would cause other, later timers to not be cleared, so utilities such as hwclock would time out when waiting for the update interrupt. [akpm@linux-foundation.org: coding-style tweak] Signed-off-by: Derek Basehore <dbasehore@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12drivers/rtc/rtc-tps6586x.c: device wakeup flags correctionDmitry Osipenko
Use device_init_wakeup() instead of device_set_wakeup_capable() and move it before rtc dev registering. This fixes alarmtimer not registered when tps6586x rtc is the only wakeup compatible rtc in the system. Signed-off-by: Dmitry Osipenko <digetx@gmail.com> Cc: Laxman Dewangan <ldewangan@nvidia.com> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24drivers/rtc/rtc-max8998.c: check for pdata presence before dereferencingTomasz Figa
Currently the driver can crash with a NULL pointer dereference if no pdata is provided, despite of successful registration of the MFD part. This patch fixes the problem by adding a NULL check before dereferencing the pdata pointer. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Sachin Kamat <sachin.kamat@linaro.org> Reviewed-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24drivers/rtc/rtc-pl031.c: pass correct pointer to free_irq()Lars-Peter Clausen
free_irq() expects the same pointer that was passed to request_irq(), otherwise the IRQ is not freed. The issue was found using the following coccinelle script: <smpl> @r1@ type T; T devid; @@ request_irq(..., devid) @r2@ type r1.T; T devid; position p; @@ free_irq@p(..., devid) @@ position p != r2.p; @@ *free_irq@p(...) </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-18Merge branch 'devm_no_resource_check' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull devm usage cleanup from Wolfram Sang: "Lately, I have been experimenting how to improve the devm interface to make writing device drivers easier and less error prone while also getting rid of its subtle issues. I think it has more potential but still needs work and definately conistency, especiall in its usage. The first thing I come up with is a low hanging fruit regarding devm_ioremap_resouce(). This function already checks if the passed resource is valid and gives an error message if not. So, we can remove similar checks from the drivers and get rid of a bit of code and a number of inconsistent error strings. This series only removes the unneeded check iff devm_ioremap_resource follows platform_get_resource directly. The previous version tried to shuffle code if needed, too, what lead to an embarrasing bug. It turned out to me that shuffling code for all cases found will make the automated script too complex, so I am unsure if an automated cleanup is the proper tool for this case. Removing the easy stuff seems worthwhile to me, though. Despite various architectures and platform dependencies, I managed to compile test 45 out of 57 modified files locally using heuristics and defconfigs." Pulled because: 296 deletions, 0 additions. * 'devm_no_resource_check' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (33 commits) sound/soc/kirkwood: don't check resource with devm_ioremap_resource sound/soc/fsl: don't check resource with devm_ioremap_resource arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource arch/arm/plat-samsung: don't check resource with devm_ioremap_resource arch/arm/mach-tegra: don't check resource with devm_ioremap_resource drivers/watchdog: don't check resource with devm_ioremap_resource drivers/w1/masters: don't check resource with devm_ioremap_resource drivers/video/omap2/dss: don't check resource with devm_ioremap_resource drivers/video/omap2: don't check resource with devm_ioremap_resource drivers/usb/phy: don't check resource with devm_ioremap_resource drivers/usb/host: don't check resource with devm_ioremap_resource drivers/usb/gadget: don't check resource with devm_ioremap_resource drivers/usb/chipidea: don't check resource with devm_ioremap_resource drivers/thermal: don't check resource with devm_ioremap_resource drivers/staging/nvec: don't check resource with devm_ioremap_resource drivers/staging/dwc2: don't check resource with devm_ioremap_resource drivers/spi: don't check resource with devm_ioremap_resource drivers/rtc: don't check resource with devm_ioremap_resource drivers/pwm: don't check resource with devm_ioremap_resource drivers/pinctrl: don't check resource with devm_ioremap_resource ...
2013-05-18drivers/rtc: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Stephen Warren <swarren@nvidia.com>
2013-05-15Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: - Cure for not using zalloc in the first place, which leads to random crashes with CPUMASK_OFF_STACK. - Revert a user space visible change which broke udev - Add a missing cpu_online early return introduced by the new full dyntick conversions - Plug a long standing race in the timer wheel cpu hotplug code. Sigh... - Cleanup NOHZ per cpu data on cpu down to prevent stale data on cpu up. * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: time: Revert ALWAYS_USE_PERSISTENT_CLOCK compile time optimizaitons timer: Don't reinitialize the cpu base lock during CPU_UP_PREPARE tick: Don't invoke tick_nohz_stop_sched_tick() if the cpu is offline tick: Cleanup NOHZ per cpu data on cpu down tick: Use zalloc_cpumask_var for allocating offstack cpumasks
2013-05-14time: Revert ALWAYS_USE_PERSISTENT_CLOCK compile time optimizaitonsJohn Stultz
Kay Sievers noted that the ALWAYS_USE_PERSISTENT_CLOCK config, which enables some minor compile time optimization to avoid uncessary code in mostly the suspend/resume path could cause problems for userland. In particular, the dependency for RTC_HCTOSYS on !ALWAYS_USE_PERSISTENT_CLOCK, which avoids setting the time twice and simplifies suspend/resume, has the side effect of causing the /sys/class/rtc/rtcN/hctosys flag to always be zero, and this flag is commonly used by udev to setup the /dev/rtc symlink to /dev/rtcN, which can cause pain for older applications. While the udev rules could use some work to be less fragile, breaking userland should strongly be avoided. Additionally the compile time optimizations are fairly minor, and the code being optimized is likely to be reworked in the future, so lets revert this change. Reported-by: Kay Sievers <kay@vrfy.org> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: stable <stable@vger.kernel.org> #3.9 Cc: Feng Tang <feng.tang@intel.com> Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Link: http://lkml.kernel.org/r/1366828376-18124-1-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-05-09Merge branch 'stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull tile update from Chris Metcalf: "The interesting bug fix is support for the upcoming "4.2" release of the Tilera hypervisor, which by default launches Linux at privilege level 2 instead of 1. The fix lets new and old hypervisors and Linuxes interoperate more smoothly, so I've tagged it for stable@kernel.org so that older Linuxes will be able to boot under the newer hypervisor." * 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: usb: tilegx: fix memleak when create hcd fail arch/tile: remove inline marking of EXPORT_SYMBOL functions rtc: rtc-tile: add missing platform_device_unregister() when module exit tile: support new Tilera hypervisor
2013-05-08rtc: rtc-tile: add missing platform_device_unregister() when module exitWei Yongjun
We have registered platform device when module init, and need unregister it when module exit. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-05-07drivers/rtc/rtc-rs5c372.c: add R2221T/L variant to the driverLucas Stach
Register layout is the same, so just add the variant to the appropriate places. Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Jan Luebbe <jlu@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-02Merge tag 'multiplatform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform updates from Olof Johansson: "More multiplatform enablement for ARM platforms. The ones converted in this branch are: - bcm2835 - cns3xxx - sirf - nomadik - msx - spear - tegra - ux500 We're getting close to having most of them converted! One of the larger platforms remaining is Samsung Exynos, and there are a bunch of supporting patches in this merge window for it. There was a patch in this branch to a early version of multiplatform conversion, but it ended up being reverted due to need of more bake time. The revert commit is part of the branch since it would have required rebasing multiple dependent branches and they were stable by then" * tag 'multiplatform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits) mmc: sdhci-s3c: Fix operation on non-single image Samsung platforms clocksource: nomadik-mtu: fix up clocksource/timer Revert "ARM: exynos: enable multiplatform support" ARM: SPEAr13xx: Fix typo "ARCH_HAVE_CPUFREQ" ARM: exynos: enable multiplatform support rtc: s3c: make header file local mtd: onenand/samsung: make regs-onenand.h file local thermal/exynos: remove unnecessary header inclusions mmc: sdhci-s3c: remove platform dependencies ARM: samsung: move mfc device definition to s5p-dev-mfc.c ARM: exynos: move debug-macro.S to include/debug/ ARM: exynos: prepare for sparse IRQ ARM: exynos: introduce EXYNOS_ATAGS symbol ARM: tegra: build assembly files with -march=armv7-a ARM: Push selects for TWD/SCU into machine entries ARM: ux500: build hotplug.o for ARMv7-a ARM: ux500: move to multiplatform ARM: ux500: make remaining headers local ARM: ux500: make irqs.h local to platform ARM: ux500: get rid of <mach/[hardware|db8500-regs].h> ...
2013-05-02Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanup from Olof Johansson: "Here is a collection of cleanup patches. Among the pieces that stand out are: - The deletion of h720x platforms - Split of at91 non-dt platforms to their own Kconfig file to keep them separate - General cleanups and refactoring of i.MX and MXS platforms - Some restructuring of clock tables for OMAP - Convertion of PMC driver for Tegra to dt-only - Some renames of sunxi -> sun4i (Allwinner A10) - ... plus a bunch of other stuff that I haven't mentioned" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: i.MX: remove unused ARCH_* configs ARM i.MX53: remove platform ahci support ARM: sunxi: Rework the restart code irqchip: sunxi: Rename sunxi to sun4i irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro clocksource: sunxi: Rename sunxi to sun4i clocksource: sunxi: make use of CLKSRC_OF clocksource: sunxi: Cleanup the timer code ARM: at91: remove trailing semicolon from macros ARM: at91/setup: fix trivial typos ARM: EXYNOS: remove "config EXYNOS_DEV_DRM" ARM: EXYNOS: change the name of USB ohci header ARM: SAMSUNG: Remove unnecessary code for dma ARM: S3C24XX: Remove unused GPIO drive strength register definitions ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412 ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410 ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC" ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI" ...
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-29drivers/rtc/rtc-pcf2123.c: fix error return code in pcf2123_probe()Wei Yongjun
Fix to return -ENODEV in the chip not found error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/rtc/rtc-isl12022.c: Remove rtc8564 from isl12022_idAxel Lin
rtc8564 appears in i2c_device_id table of both rtc-isl12022.c and rtc-pcf8563.c. Commit 8ea9212cbd65 "rtc-pcf8563: add chip id" added the rtc8564 chip entry to pcf8563. isl12022 driver is modified from pcf8563 driver, so this looks like a copy-paste bug. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Roman Fietze <roman.fietze@telemotive.de> Cc: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/rtc/rtc-at91rm9200.c: fix missing iounmapJohan Hovold
Add missing iounmap to probe error path and remove. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-twl: convert twl4030rtc_driver to dev_pm_opsJingoo Han
Instead of using legacy suspend/resume methods, using newer dev_pm_ops structure allows better control over power management. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-stmp3xxx: convert stmp3xxx_rtcdrv to dev_pm_opsJingoo Han
2013-04-29rtc: rtc-spear: convert spear_rtc_driver to dev_pm_opsJingoo Han
2013-04-29rtc: rtc-puv3: convert puv3_rtc_driver to dev_pm_opsJingoo Han
2013-04-29rtc: rtc-omap: convert omap_rtc_driver to dev_pm_opsJingoo Han
2013-04-29rtc: rtc-coh901331: convert coh901331_driver to dev_pm_opsJingoo Han
2013-04-29rtc: rtc-bfin: convert bfin_rtc_driver to dev_pm_opsJingoo Han
2013-04-29rtc: rtc-at91sam9: convert at91_rtc_driver to dev_pm_opsJingoo Han
2013-04-29drivers/rtc/rtc-max6902.c: use register defines instead of magic numbersAxel Lin
Current code has defines for registers, use the defines rather than magic numbers. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Raphael Assenat <raph@raphnet.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-v3020: use devm_*() functionsJingoo Han
Use devm_*() functions to make cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-stmp3xxx: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-sa1100: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-s35390a: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-rs5c372: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-rs5c348: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-rp5c01: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-pcf8583: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-pcf8563: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-pcf50633: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-pcf2123: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-pcap: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-nuc900: use devm_*() functionsJingoo Han
2013-04-29rtc: rtc-msm6242: use devm_*() functionsJingoo Han
