path: root/drivers/rtc/rtc-twl.c
2015-04-17rtc: use more standard kernel logging stylesJoe Perches
Neaten the logging a bit by adding #define pr_fmt Miscellanea: o Remove __FILE__/__func__ uses o Coalesce formats adding missing spaces o Align arguments o (rtc-cmos) Integrated 2 consecutive messages Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Joshua Kinard <kumba@gentoo.org> Cc: Chanwoo Choi <cw00.choi@samsung.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Cc: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-20rtc: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-01-23drivers/rtc/rtc-twl.c: use devm_*() functionsJingoo Han
Use devm_*() functions to make cleanup paths simpler, and remove unnecessary remove(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Yoichi Yuasa <yuasa@linux-mips.org> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-31drivers/rtc/rtc-twl.c: fix: rtcX/wakealarm attribute isn't createdGrygorii Strashko
The device_init_wakeup() should be called before rtc_device_register(). Otherwise, sysfs "sys/class/rtc/rtcX/wakealarm" attribute will not be seen from User space. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Kevin Hilman <khilman@linaro.org> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/rtc/rtc-twl.c: cleanup with module_platform_driver() conversionPeter Ujfalusi
Use module_platform_driver() to register the platform driver. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/rtc/rtc-twl.c: fix rtc_reg_map initializationPeter Ujfalusi
Initialize the rtc_reg_map in platform_driver's probe function instead at module_init time. This way we can make sure that the twl-core has been already probed and initialized (twl_priv->twl_id is valid) since the platform device for the RTC driver will be created by the twl-core after it finished its init. Reported-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Kevin Hilman <khilman@linaro.org> Tested-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/rtc/rtc-twl.c: ensure IRQ is wakeup enabledKevin Hilman
Currently, the RTC IRQ is never wakeup-enabled so is not capable of bringing the system out of suspend. On OMAP platforms, we have gotten by without this because the TWL RTC is on an I2C-connected chip which is capable of waking up the OMAP via the IO ring when the OMAP is in low-power states. However, if the OMAP suspends without hitting the low-power states (and the IO ring is not enabled), RTC wakeups will not work because the IRQ is not wakeup enabled. To fix, ensure the RTC IRQ is wakeup enabled whenever the RTC alarm is set. Signed-off-by: Kevin Hilman <khilman@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Tony Lindgren <tony@atomide.com> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rtc: rtc-twl: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d063100 ("device-core: Ensure drvdata = NULL when no driver is bound"). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12drivers/rtc/rtc-twl.c: fix missing device_init_wakeup() when booted with ↵Tony Lindgren
device tree When booted in legacy mode device_init_wakeup() gets called by drivers/mfd/twl-core.c when the children are initialized. However, when booted using device tree, the children are created with of_platform_populate() instead add_children(). This means that the RTC driver will not have device_init_wakeup() set, and we need to call it from the driver probe like RTC drivers typically do. Without this we cannot test PM wake-up events on omaps for cases where there may not be any physical wake-up event. Signed-off-by: Tony Lindgren <tony@atomide.com> Reported-by: Kevin Hilman <khilman@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Jingoo Han <jg1.han@samsung.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-twl: convert twl4030rtc_driver to dev_pm_opsJingoo Han
Instead of using legacy suspend/resume methods, using newer dev_pm_ops structure allows better control over power management. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/rtc: use of_match_ptr() macroSachin Kamat
This eliminates having an #ifdef returning NULL for the case when OF is disabled. Maintains consistency in cases where OF is always selected. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-03Drivers: rtc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21mfd/rtc/gpio: twl: No need to allocate bigger buffer for writePeter Ujfalusi
Since the twl-core has been converted to use regmap it is no longer needed to allocate bigger buffer for data when writing to twl. CC: Grant Likely <grant.likely@secretlab.ca> CC: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-17drivers/rtc/rtc-twl.c: ensure all interrupts are disabled during probeKevin Hilman
On some platforms, bootloaders are known to do some interesting RTC programming. Without going into the obscurities as to why this may be the case, suffice it to say the the driver should not make any assumptions about the state of the RTC when the driver loads. In particular, the driver probe should be sure that all interrupts are disabled until otherwise programmed. This was discovered when finding bursty I2C traffic every second on Overo platforms. This I2C overhead was keeping the SoC from hitting deep power states. The cause was found to be the RTC firing every second on the I2C-connected TWL PMIC. Special thanks to Felipe Balbi for suggesting to look for a rogue driver as the source of the I2C traffic rather than the I2C driver itself. Special thanks to Steve Sakoman for helping track down the source of the continuous RTC interrups on the Overo boards. Signed-off-by: Kevin Hilman <khilman@ti.com> Cc: Felipe Balbi <balbi@ti.com> Tested-by: Steve Sakoman <steve@sakoman.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Tested-by: Shubhrajyoti Datta <omaplinuxkernel@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-11drivers/rtc/rtc-twl.c: fix threaded IRQ to use IRQF_ONESHOTKevin Hilman
Requesting a threaded interrupt without a primary handler and without IRQF_ONESHOT is dangerous, and after commit 1c6c6952 ("genirq: Reject bogus threaded irq requests"), these requests are rejected. This causes ->probe() to fail, and the RTC driver not to be availble. To fix, add IRQF_ONESHOT to the IRQ flags. Tested on OMAP3730/OveroSTORM and OMAP4430/Panda board using rtcwake to wake from system suspend multiple times. Signed-off-by: Kevin Hilman <khilman@ti.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-12drivers/rtc/rtc-twl.c: use static register while reading timeKonstantin Shlyakhovoy
RTC stores time and date in several registers. Due to the fact that these registers can't be read instantaneously, there is a chance that reading from counting registers gives an error of one minute, one hour, one day, etc. To address this issue, the RTC has hardware support to copy the RTC counting registers to static shadowed registers. The current implementation does not use this feature, and in a stress test, we can reproduce this error at a rate of around two times per 300000 readings. Fix the implementation to ensure that the right snapshot of time is captured. Signed-off-by: Konstantin Shlyakhovoy <x0155534@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Benoit Cousson <b-cousson@ti.com> Cc: linux-omap <linux-omap@vger.kernel.org> Acked-by: Mykola Oleksiienko <x0174904@ti.com> Acked-by: Oleksandr Dmytryshyn <oleksandr.dmytryshyn@ti.com> Acked-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23drivers/rtc/rtc-twl.c: return correct RTC event from ISRVenu Byravarasu
Following changes are made as part of this change: 1. As TWL RTC supports periodic interrupt, the correct event should be RTC_PF instead of RTC_UF. 2. No need to initialize variable "events" to 0 & then OR it with the event values. Hence fixing it. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23drivers/rtc/rtc-twl.c: simplify RTC interrupt clearingVenu Byravarasu
For clearing RTC interrupt, programming ALARM bit only is sufficient, as all other bits are any way not affected by writing 0 to them. Hence removed unwanted OR operation. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23drivers/rtc/rtc-twl.c: enable RTC irrespective of its prior stateVenu Byravarasu
As part of probe, before enabling RTC, RTC_CTRL register is read to check if it is already running. If RTC is used by kernel alone, then this read is not required. Even if RTC was enabled already by boot loader, setting STOP_RTC bit again should not harm. Hence removed unwanted read operation. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23drivers/rtc/rtc-twl.c: optimize IRQ bit accessVenu Byravarasu
As the TWL RTC driver has a cached copy of enabled RTC interrupt bits in variable rtc_irq_bits, that can be checked before really setting or masking any of the interrupt bits. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10drivers/rtc/rtc-twl.c: add DT support for RTC inside twl4030/twl6030Benoit Cousson
Add the DT support for the TI rtc-twl present in the twl4030 and twl6030 devices. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-26rtc: twl: Fix registration vs. init orderTodd Poynor
Only register as an RTC device after the hardware has been successfully initialized. The RTC class driver will call back to this driver to read a pending alarm, and other drivers watching for new devices on the RTC class may read the RTC time upon registration. Such access might occur while the RTC is stopped, prior to clearing pending alarms, etc. The new ordering also avoids leaving the platform device drvdata set to an unregistered struct rtc_device * on probe errors. Signed-off-by: Todd Poynor <toddpoynor@google.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-08-10rtc: rtc-twl: Remove lockdep related local_irq_enable()Sebastian Reichel
Now that the irq is properly threaded (due to it needing i2c access) we should also remove the local_irq_enable() call in twl_rtc_interrupt. Testing this with Pandaboard, the RTC is still working. [Reworked commit message -jstultz] Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-08-10rtc: rtc-twl: Switch to using threaded irqIlkka Koskinen
The driver is accessing to i2c bus in interrupt handler. Therefore, it should use threaded irq. Signed-off-by: Ilkka Koskinen <ilkka.koskinen@nokia.com> Acked-by: Balaji T K <balajitk@ti.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-07-25drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in ↵Jesper Juhl
twl_rtc_set_time() We forget to save the return value of the call to twl_rtc_write_u8(save_control, REG_RTC_CTRL_REG); in 'ret', making the test of 'ret < 0' dead code since 'ret' then couldn't possibly have changed since the last test just a few lines above. It also makes us not detect failures from that specific twl_rtc_write_u8() call. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Alexandre Rusev <source@mvista.com> Cc: "George G. Davis" <gdavis@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-09RTC: Cleanup rtc_class_ops->update_irq_enable()John Stultz
Now that the generic code handles UIE mode irqs via periodic alarm interrupts, no one calls the rtc_class_ops->update_irq_enable() method anymore. This patch removes the driver hooks and implementations of update_irq_enable if no one else is calling it. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2010-03-06rtc-twl: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14rtc: Add twl6030 RTC supportBalaji T K
This patch adds support for RTC in phoenix TWL6030. Register offset addresses have changed in TWL6030 rtc-twl.c will hence forth support all twl RTC (4030, 5030, 6030 ..) Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Rename twl4030_ routines in rtc-twl.cBalaji T K
This patch renames all twl4030_ functions to twl_ so that RTC driver can be shared between Triton and Phoenix. Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Nayak Rajendra <rnayak@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Rename all twl4030_i2c*Balaji T K
This patch renames function names like twl4030_i2c_write_u8, twl4030_i2c_read_u8 to twl_i2c_write_u8, twl_i2c_read_u8 and also common variable in twl-core.c Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Rename twl4030* driver files to enable re-useSantosh Shilimkar
The upcoming TWL6030 is companion chip for OMAP4 like the current TWL4030 for OMAP3. The common modules like RTC, Regulator creates opportunity to re-use the most of the code from twl4030. This patch renames few common drivers twl4030* files to twl* to enable the code re-use. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
