path: root/drivers/rtc/rtc-s3c.c
2016-07-19rtc: s3c: Add s3c_rtc_{enable/disable}_clk in s3c_rtc_setfreq()Alim Akhtar
As per code flow s3c_rtc_setfreq() will get called with rtc clock disabled and in set_freq we perform h/w registers read/write, which results in a kernel crash on exynos7 platform while probing rtc driver. Below is code flow: s3c_rtc_probe() clk_prepare_enable(info->rtc_clk) // rtc clock enabled s3c_rtc_gettime() // will enable clk if not done, and disable it upon exit s3c_rtc_setfreq() //then this will be called with clk disabled This patch take cares of such issue by adding s3c_rtc_{enable/disable}_clk in s3c_rtc_setfreq(). Fixes: 24e1455493da ("drivers/rtc/rtc-s3c.c: delete duplicate clock control") Cc: <stable@vger.kernel.org> Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Pankaj Dubey <pankaj.dubey@samsung.com> Tested-by: Pankaj Dubey <pankaj.dubey@samsung.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-19rtc: s3c: Remove unnecessary call to disable already disabled clockAlim Akhtar
At the end of s3c_rtc_probe(), s3c_rtc_disable_clk() being called with rtc clock already disabled (by s3c_rtc_gettime()), which looks extra and unnecessary call. Lets clean it up. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Pankaj Dubey <pankaj.dubey@samsung.com> Tested-by: Pankaj Dubey <pankaj.dubey@samsung.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-09rtc: simplify implementations of read_alarmUwe Kleine-König
Since commit d68778b80dd7 ("rtc: initialize output parameter for read alarm to "uninitialized"") there is no need to explicitly set unsupported members to -1. So drop the respective assignments from drivers. Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-03-19rtc: s3c: Don't print an error on probe deferralJavier Martinez Canillas
The clock and source clock looked up by the driver may not be available just because the clock controller driver was not probed yet so printing an error in this case is not correct and only adds confusion to users. However, knowing that a driver's probe was deferred may be useful so it can be printed as a debug information. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-11-08rtc: s3c: Set year, month, day value for setting alarmKrzysztof Kozlowski
This patch sets year, month, day value for set_alarm function. The current driver omits to set the values. This fixes setting wake alarm for dates different than current day. Without the patch the alarm scheduled for tomorrow would fire today on chosen time. Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.kim@samsung.com> Signed-off-by: KyungMin Park <kyungmin.park@samsung.com> [k.kozlowski: Rebase and test the patch, update commit message] Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-09-05rtc: s3c: remove unnecessary NULL assignmentJoonyoung Shim
It's unnecessary the code that assigns info->rtc_clk to NULL in s3c_rtc_remove. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-09-05rtc: s3c: add missing clk controlJoonyoung Shim
It's missed to call clk_unprepare() about info->rtc_src_clk in s3c_rtc_remove and to call clk_disable_unprepare about info->rtc_clk in error routine of s3c_rtc_probe. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-09-05rtc: s3c: fix disabled clocks for alarmJoonyoung Shim
The clock enable/disable codes for alarm have been removed from commit 24e1455493da ("drivers/rtc/rtc-s3c.c: delete duplicate clock control") and the clocks are disabled even if alarm is set, so alarm interrupt can't happen. The s3c_rtc_setaie function can be called several times with 'enabled' argument having same value, so it needs to check whether clocks are enabled or not. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Cc: <stable@vger.kernel.org> # v4.1 Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: s3c: Integrate Exynos3250 into S3C6410Krzysztof Kozlowski
There are now no differences between RTC on Exynos3250 and S3C6410. Merge everything into one so duplicated code could be removed. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-04-17drivers/rtc/rtc-s3c.c: remove one superfluous rtc_valid_tm() checkKrzysztof Kozlowski
s3c_rtc_gettime() already returns the result of rtc_valid_tm() on the obtained time so get rid of another call to rtc_valid_tm(). Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17drivers/rtc/rtc-s3c.c: fix failed first read of RTC timeKrzysztof Kozlowski
Initialize the device time (if it is wrong) before registering RTC device to fix following error message during rtc-s3c probe: [ 2.215414] rtc (null): read_time: fail to read [ 2.216322] s3c-rtc 10070000.rtc: rtc core: registered s3c as rtc1 Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17drivers/rtc/rtc-s3c.c: delete duplicate clock controlChanwoo Choi
The current functions in s3c-rtc driver execute clk_enable/disable() to control clocks and some functions execute s3c_rtc_alarm_clk_enable() unnecessarily. So this patch deletes the duplicate clock control and spilts s3c_rtc_alarm_clk_enable() out as s3c_rtc_enable_clk()/s3c_rtc_disable_clk() to improve readability. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kukjin Kim <kgene@kernel.org> Cc: Inki Dae <inki.dae@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12drivers/rtc/rtc-s3c.c: add .needs_src_clk to s3c6410 RTC dataJavier Martinez Canillas
Commit df9e26d093d3 ("rtc: s3c: add support for RTC of Exynos3250 SoC") added an "rtc_src" DT property to specify the clock used as a source to the S3C real-time clock. Not all SoCs needs this so commit eaf3a659086e ("drivers/rtc/rtc-s3c.c: fix initialization failure without rtc source clock") changed to check the struct s3c_rtc_data .needs_src_clk to conditionally grab the clock. But that commit didn't update the data for each IP version so the RTC broke on the boards that needs a source clock. This is the case of at least Exynos5250 and Exynos5440 which uses the s3c6410 RTC IP block. This commit fixes the S3C rtc on the Exynos5250 Snow and Exynos5420 Peach Pit and Pi Chromebooks. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Chanwoo Choi <cw00.choi@samsung.com> Cc: Doug Anderson <dianders@chromium.org> Cc: Olof Johansson <olof@lixom.net> Cc: Kevin Hilman <khilman@linaro.org> Cc: Tyler Baker <tyler.baker@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-03Merge branch 'platform/remove_owner' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into driver-core-next Remove all .owner fields from platform drivers
2014-10-29drivers/rtc/rtc-s3c.c: fix initialization failure without rtc source clockMarek Szyprowski
Fix unconditional initialization failure on non-exynos3250 SoCs. Commit df9e26d093d3 ("rtc: s3c: add support for RTC of Exynos3250 SoC") introduced rtc source clock support, but also added initialization failure on SoCs, which doesn't need such clock. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-20rtc: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-14rtc: s3c: add support for RTC of Exynos3250 SoCChanwoo Choi
Add support for RTC of Exynos3250 SoC. The Exynos3250 needs source clock(32.768KHz) for RTC block. If source clock of RTC is registerd on clock list of common clk framework, Exynos RTC drvier have to control this clock. Clock list for s3c-rtc device: - rtc : CLK_RTC of CLK_GATE_IP_PERIR is gate clock for RTC. - rtc_src : XrtcXTI is 32.768.kHz source clock for RTC. (XRTCXTI: Specifies a clock from 32.768 kHz crystal pad with XRTCXTI and XRTCXTO pins. RTC uses this clock as the source of a real-time clock.) Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14rtc: s3c: add s3c_rtc_data structure to use variant data instead of s3c_cpu_typeChanwoo Choi
Add s3c_rtc_data structure to variant data according to SoC type. The s3c_rtc_data structure includes some functions to control RTC operation and specific data dependent on SoC type. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14rtc: s3c: remove warning message when checking coding style with checkpatch ↵Chanwoo Choi
script Remove warning message when checking codeing style with checkpatch script and reduce un-necessary i2c read operation on s3c_rtc_enable. WARNING: line over 80 characters #406: FILE: drivers/rtc/rtc-s3c.c:406: + if ((readw(info->base + S3C2410_RTCCON) & S3C2410_RTCCON_RTCEN) == 0) { WARNING: line over 80 characters #414: FILE: drivers/rtc/rtc-s3c.c:414: + if ((readw(info->base + S3C2410_RTCCON) & S3C2410_RTCCON_CNTSEL)) { WARNING: line over 80 characters #422: FILE: drivers/rtc/rtc-s3c.c:422: + if ((readw(info->base + S3C2410_RTCCON) & S3C2410_RTCCON_CLKRST)) { WARNING: Missing a blank line after declarations #451: FILE: drivers/rtc/rtc-s3c.c:451: + struct s3c_rtc_drv_data *data; + if (pdev->dev.of_node) { WARNING: Missing a blank line after declarations #453: FILE: drivers/rtc/rtc-s3c.c:453: + const struct of_device_id *match; + match = of_match_node(s3c_rtc_dt_match, pdev->dev.of_node); WARNING: DT compatible string "samsung,s3c2416-rtc" appears un-documented -- check ./Documentation/devicetree/bindings/ #650: FILE: drivers/rtc/rtc-s3c.c:650: + .compatible = "samsung,s3c2416-rtc", WARNING: DT compatible string "samsung,s3c2443-rtc" appears un-documented -- check ./Documentation/devicetree/bindings/ #653: FILE: drivers/rtc/rtc-s3c.c:653: + .compatible = "samsung,s3c2443-rtc", Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14rtc: s3c: define s3c_rtc structure to remove global variables.Chanwoo Choi
Define s3c_rtc structure including necessary variables for S3C RTC device instead of global variables. This patch improves the readability by removing global variables. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03drivers/rtc/rtc-s3c.c: remove NO_IRQ macroPankaj Dubey
NO_IRQ may be defined as '(unsigned int) -1' in some architectures (arm, sh ...), and either may not be defined in some architectures (arm64) which can enable RTC_DRV_S3C. Also since platform_get_irq returns err-code in case of any error, we do not need to intialize s3c_rtc_alarmno and s3c_rtc_tickno. Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-04drivers/rtc/rtc-s3c.c: fix incorrect way of save/restore of S3C2410_TICNT ↵Vikas Sajjan
for TYPE_S3C64XX On exynos5250, exynos5420 and exynos5260 it was observed that, after 1 cycle of S2R, the rtc-tick occurs at a very fast rate as compared to the rtc-tick occuring before S2R. This patch fixes the above issue by correcting the wrong way of save/restore of S3C2410_TICNT for TYPE_S3C64XX. Signed-off-by: Vikas Sajjan <vikas.sajjan@samsung.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rtc: rtc-s3c: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d063100 ("device-core: Ensure drvdata = NULL when no driver is bound"). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-18drivers/rtc: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Stephen Warren <swarren@nvidia.com>
2013-05-02Merge tag 'multiplatform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform updates from Olof Johansson: "More multiplatform enablement for ARM platforms. The ones converted in this branch are: - bcm2835 - cns3xxx - sirf - nomadik - msx - spear - tegra - ux500 We're getting close to having most of them converted! One of the larger platforms remaining is Samsung Exynos, and there are a bunch of supporting patches in this merge window for it. There was a patch in this branch to a early version of multiplatform conversion, but it ended up being reverted due to need of more bake time. The revert commit is part of the branch since it would have required rebasing multiple dependent branches and they were stable by then" * tag 'multiplatform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits) mmc: sdhci-s3c: Fix operation on non-single image Samsung platforms clocksource: nomadik-mtu: fix up clocksource/timer Revert "ARM: exynos: enable multiplatform support" ARM: SPEAr13xx: Fix typo "ARCH_HAVE_CPUFREQ" ARM: exynos: enable multiplatform support rtc: s3c: make header file local mtd: onenand/samsung: make regs-onenand.h file local thermal/exynos: remove unnecessary header inclusions mmc: sdhci-s3c: remove platform dependencies ARM: samsung: move mfc device definition to s5p-dev-mfc.c ARM: exynos: move debug-macro.S to include/debug/ ARM: exynos: prepare for sparse IRQ ARM: exynos: introduce EXYNOS_ATAGS symbol ARM: tegra: build assembly files with -march=armv7-a ARM: Push selects for TWD/SCU into machine entries ARM: ux500: build hotplug.o for ARMv7-a ARM: ux500: move to multiplatform ARM: ux500: make remaining headers local ARM: ux500: make irqs.h local to platform ARM: ux500: get rid of <mach/[hardware|db8500-regs].h> ...
2013-04-29drivers/rtc/rtc-s3c.c: use clk_prepare_enable and clk_disable_unprepareThomas Abraham
Convert clk_enable/clk_disable to clk_prepare_enable/clk_disable_unprepare calls as required by common clock framework. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Reviewed-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/rtc/rtc-s3c.c: convert s3c_rtc to dev_pm_opsJingoo Han
Instead of using legacy suspend/resume methods, using newer dev_pm_ops structure allows better control over power management. Also, 'wake_en' variable is moved, because it is only used when CONFIG_PM_SLEEP is enabled. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-s3c: use devm_rtc_device_register()Jingoo Han
devm_rtc_device_register() is device managed and makes cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-19rtc: s3c: make header file localArnd Bergmann
Nothing outside of the rtc driver includes plat/regs-rtc.h, so we can simply move the file into the same directory, which allows us to build the file as platform-independent code. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: rtc-linux@googlegroups.com Cc: Alessandro Zummo <a.zummo@towertech.it>
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21drivers/rtc/rtc-s3c.c: use dev_dbg() instaed of pr_debug()Jingoo Han
Use dev_dbg() instaed of pr_debug() to be consistent. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-22rtc: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03Drivers: rtc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17drivers/rtc/rtc-s3c: use of_match_ptr() macroSachin Kamat
This eliminates having an #ifdef returning NULL for the case when OF is disabled. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17drivers/rtc/rtc-s3c.c: convert to use devm_* APITushar Behera
rtc-s3c driver is modified to use devm_request_and_ioremap() (combining request_mem_region and ioremap), devm_clk_get() and devm_request_irq() APIs. Since this removes the necessity of freeing the related resources the return path is also simplified. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17drivers/rtc/rtc-s3c.c: remove unnecessary err_nores labelTushar Behera
err_nores label redirects to a simple return statement. Move the return statement to caller location and remove the label. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-06drivers/rtc/rtc-s3c.c: fix return value in s3c_rtc_probe()Sachin Kamat
Return the value returned by platform_get_irq() instead of -ENOENT; Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30drivers/rtc/rtc-s3c.c: replace #include header files from asm/* to linux/*Sachin Kamat
Fixes the following checkpatch warnings: WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h> WARNING: Use #include <linux/io.h> instead of <asm/io.h> Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29drivers/rtc/rtc-s3c.c: fix compiler warningSachin Kamat
rtc-s3c.c:673:32: warning: `s3c_rtc_drv_data_array' defined but not used [-Wunused-variable] Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-12drivers/rtc/rtc-s3c.c: add placeholder for driver private dataTushar Behera
Driver data field is a pointer, hence assigning that to an integer results in compilation warnings. Fixes following compilation warnings: drivers/rtc/rtc-s3c.c: In function `s3c_rtc_get_driver_data': drivers/rtc/rtc-s3c.c:452:3: warning: return makes integer from pointer without a cast [enabled by default] drivers/rtc/rtc-s3c.c: At top level: drivers/rtc/rtc-s3c.c:674:3: warning: initialization makes pointer from integer without a cast [enabled by default] drivers/rtc/rtc-s3c.c:674:3: warning: (near initialization for `s3c_rtc_dt_match[1].data') [enabled by default] drivers/rtc/rtc-s3c.c:677:3: warning: initialization makes pointer from integer without a cast [enabled by default] drivers/rtc/rtc-s3c.c:677:3: warning: (near initialization for `s3c_rtc_dt_match[2].data') [enabled by default] drivers/rtc/rtc-s3c.c:680:3: warning: initialization makes pointer from integer without a cast [enabled by default] drivers/rtc/rtc-s3c.c:680:3: warning: (near initialization for `s3c_rtc_dt_match[3].data') [enabled by default] Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-12drivers/rtc/rtc-s3c.c: fix compilation errorTushar Behera
Fix this error: drivers/rtc/rtc-s3c.c: At top level: drivers/rtc/rtc-s3c.c:671:3: error: request for member `data' in something not a structure or union drivers/rtc/rtc-s3c.c:674:3: error: request for member `data' in something not a structure or union drivers/rtc/rtc-s3c.c:677:3: error: request for member `data' in something not a structure or union drivers/rtc/rtc-s3c.c:680:3: error: request for member `data' in something not a structure or union Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-27Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: driver specific updates" from Arnd Bergmann: "These are all specific to some driver. They are typically the platform side of a change in the drivers directory, such as adding a new driver or extending the interface to the platform. In cases where there is no maintainer for the driver, or the maintainer prefers to have the platform changes in the same branch as the driver changes, the patches to the drivers are included as well. A much smaller set of driver updates that depend on other branches getting merged first will be sent later. The new export of tegra_chip_uid conflicts with other changes in fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED conflicts with the cleanup of the interrupt handling of that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up aforementioned trivial conflicts. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci mmc: sdhci-s3c: add platform data for the second capability ARM: SAMSUNG: support the second capability for samsung-soc ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1 ARM: EXYNOS: Enable MDMA driver regulator: Remove bq24022 regulator driver rtc: sa1100: add OF support pxa: magician/hx4700: Convert to gpio-regulator from bq24022 ARM: OMAP3+: SmartReflex: fix error handling ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API ARM: OMAP3+: SmartReflex: micro-optimization for sanity check ARM: OMAP3+: SmartReflex: misc cleanups ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata() ARM: OMAP3+: hwmod: add SmartReflex IRQs ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register ARM: OMAP3+: SmartReflex: Add a shutdown hook ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP ... Conflicts: arch/arm/mach-tegra/Makefile arch/arm/mach-tegra/fuse.c drivers/rtc/rtc-sa1100.c
2012-03-23drivers/rtc: remove IRQF_DISABLEDYong Zhang
Since commit e58aa3d2d0cc ("genirq: run irq handlers with interrupts disabled") we run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled - see commit b738a50a2026 ("genirq: warn when handler enables interrupts"). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-07rtc-s3c: add variants for S3C2443 and S3C2416Heiko Stuebner
Especially the TICNT registers are different from the two rtc types that currently exists. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-02-07rtc-s3c: make room for more variants in devicetree blockHeiko Stuebner
Use the data field of of_device_id to hold the type for s3c_cpu_type. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-01-10rtc: convert drivers/rtc/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/rtc/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Ben Dooks <ben@simtec.co.uk> Cc: John Stultz <john.stultz@linaro.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-23rtc: rtc-s3c: Add device tree supportThomas Abraham
Add device tree based discovery support for Samsung's rtc controller. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-12-09drivers/rtc/rtc-s3c.c: fix driver clock enable/disable balance issuesJonghwan Choi
If an error occurs after the clock is enabled, the enable/disable state can become unbalanced. Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14drivers/rtc/rtc-s3c.c: fix no occurrence of alarm interruptDonggeun Kim
The driver does not generate an alarm interrupt even though a time for an alarm is set. This results from disabling rtc_clk after setting the alarm time. To generate an alarm interrupt the driver should maintain its enabled state for rtc_clk the until alarm interrupt occurs. This patch permits generation of an alarm interrupt. [akpm@linux-foundation.org: make s3c_rtc_alarm_clk_lock local to s3c_rtc_alarm_clk_enable()] Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
