path: root/drivers/rtc/rtc-rs5c313.c
2013-07-03drivers/rtc/rtc-rs5c313.c: remove empty functionSachin Kamat
After the switch to devm_* functions and the removal of rtc_device_unregister(), the 'remove' function does not do anything. Delete it. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/rtc/rtc-rs5c313.c: fix spacing related issuesSachin Kamat
Fixes the following types of checkpatch issues: WARNING: please, no space before tabs ERROR: space prohibited after that open parenthesis '(' ERROR: space prohibited before that close parenthesis ')' ERROR: need consistent spacing around '>>' (ctx:VxW) Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/rtc/rtc-rs5c313.c: include <linux/io.h> instead of <asm/io.h>Sachin Kamat
Use #include <linux/io.h> instead of <asm/io.h> as pointed out by checkpatch. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-rs5c313: use devm_rtc_device_register()Jingoo Han
devm_rtc_device_register() is device managed and makes cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21rtc: rtc-rs5c313: use pr_err() instead of printk()Jingoo Han
Fix the checkpatch warning as below: WARNING: Prefer netdev_err(netdev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ... Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-03Drivers: rtc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2010-10-27rtc: rtc-rs5c313: ctrl_in/outX to __raw_read/writeX conversion.Paul Mundt
The ctrl_xxx routines are deprecated, switch over to the __raw_xxx versions. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-10-20drivers/rtc/: use bcd2bin/bin2bcdAdrian Bunk
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28rtc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11rtc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC platform drivers, to re-enable module auto loading. [dbrownell@users.sourceforge.net: more drivers, minor fix] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11rtc-rs5c313.c: add error handling to avoid hardware hangupkogiidena
Add error processing. Hanging up by an infinite loop is evaded. Signed-off-by: kogiidena <kogiidena@eggplant.ddo.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11rtc-rs5c313.c: rtc_time value are fixedkogiidena
Correct an initial value of suruct rtc_ time. Signed-off-by: kogiidena <kogiidena@eggplant.ddo.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11rtc-rs5c313.c: error and warning are fixedkogiidena
Correct a compile error and warning. Signed-off-by: kogiidena <kogiidena@eggplant.ddo.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08RTC: add rtc-rs5c313 driverNobuhiro Iwamatsu
Add an RTC driver for Ricoh RS5C313 RTC chip. [akpm@linux-foundation.org: Zillions of coding-style fixes] [akpm@linux-foundation.org: build fixes] Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
