path: root/drivers/rtc/rtc-at32ap700x.c
2018-01-19rtc: remove rtc-at32ap700xCorentin Labbe
Since PLATFORM_AT32AP is an AVR32 platform which was removed, the rtc driver rtc-at32ap700x is useless. This patch remove it. Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-09-02rtc: constify rtc_class_ops structuresJulia Lawall
Check for rtc_class_ops structures that are only passed to devm_rtc_device_register, rtc_device_register, platform_device_register_data, all of which declare the corresponding parameter as const. Declare rtc_class_ops structures that have these properties as const. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable optional_qualifier@ identifier i; position p; @@ static struct rtc_class_ops i@p = { ... }; @ok@ identifier r.i; expression e1,e2,e3,e4; position p; @@ ( devm_rtc_device_register(e1,e2,&i@p,e3) | rtc_device_register(e1,e2,&i@p,e3) | platform_device_register_data(e1,e2,e3,&i@p,e4) ) @bad@ position p != {r.p,ok.p}; identifier r.i; @@ i@p @depends on !bad disable optional_qualifier@ identifier r.i; @@ static +const struct rtc_class_ops i = { ... }; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-25rtc: at32ap700x: update author emailHans-Christian Egtvedt
This patch updates the email address of the rtc-at32ap700x driver supported by me to an email account I will use on a more regular basis in the future. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2014-10-20rtc: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-04-03rtc: rtc-at32ap700x: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rtc: rtc-at32ap700x: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d063100 ("device-core: Ensure drvdata = NULL when no driver is bound"). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/rtc/rtc-at32ap700x.c: fix checkpatch errorSachin Kamat
Fixes the following error: ERROR: space required before the open parenthesis '(' Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/rtc/rtc-at32ap700x.c: use devm_* APIsSachin Kamat
devm_* functions are device managed and make cleanup code simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-at32ap700x: use module_platform_driver_probe()Jingoo Han
Use module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-03RTC: Convert rtc drivers to use the alarm_irq_enable methodJohn Stultz
Some rtc drivers use the ioctl method instead of the alarm_irq_enable method for enabling alarm interupts. With the new virtualized RTC rework, its important for drivers to use the alarm_irq_enable instead. This patch converts the drivers that use the AIE ioctl method to use the alarm_irq_enable method. Other ioctl cmds are left untouched. I have not been able to test or even compile most of these drivers. Any help to make sure this change is correct would be appreciated! CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Reported-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Tested-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Signed-off-by: John Stultz <john.stultz@linaro.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-16rtc: fix driver data issues in several rtc driversAlessandro Zummo
Herton Ronaldo Krzesinski recently raised up, and fixed, an issue with the rtc_cmos driver, which was referring to an inconsistent driver data. This patch ensures that driver data registration happens before rtc_device_register(). Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Thomas Hommel <thomas.hommel@gefanuc.com> Acked-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Andrew Sharp <andy.sharp@onstor.com> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alexander Bigga <ab@mycable.de> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Mark Zhan <rongkai.zhan@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: bunch of drivers: fix 'no irq' case handingAnton Vorontsov
This patch fixes a bunch of irq checking misuses. Most drivers were getting irq via platform_get_irq(), which returns -ENXIO or r->start. rtc-cmos.c is special. It is using PNP and platform bindings. Hopefully nobody is using PNP IRQ 0 for RTC. So the changes should be safe. rtc-sh.c is using platform_get_irq, but was storing a result into an unsigned type, then was checking for < 0. This is fixed now. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02rtc-at32ap700x: Enable wakeupHaavard Skinnemoen
Call device_init_wakeup() to signal that the RTC is capable of waking the system. This is needed for rtcwake to work. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Alessandro Zummo <a.zummo@towertech.it>
2008-06-12rtc-at32ap700x: fix bug in at32_rtc_readalarm()Haavard Skinnemoen
alarm->pending indicates whether there's an alarm that has actually been triggered, not whether we're waiting for it. alarm->enabled indicates that. Also add missing locking around reading the RTC registers. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11rtc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC platform drivers, to re-enable module auto loading. [dbrownell@users.sourceforge.net: more drivers, minor fix] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17rtc-at32ap700x: fix irq init oopsDavid Brownell
Reorder at32_rtc_probe() so that it's safe (no oopsing) to fire the IRQ handler the instant that it's registered. (Bug noted via "Debug shared IRQ handlers" kernel debug option.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: <hcegtvedt@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Driver for the Atmel on-chip RTC on AT32AP700x devicesHans-Christian Egtvedt
Tested on the AT32AP7000/ATSTK1000. Driver does only suport time, wake up and a very simple alarm, because of hardware limitations. Hardware documentation can be found in the AT32AP7000 data sheet, which can be downloaded from http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 From: David Brownell <david-b@pacbell.net> - Strike some alarm setup code that's no longer needed. (This patch seems to have gotten lost somewhere...) - Make the driver name (and its module alias) match what the platform setup code uses, so the driver can bind and hotplug. [akpm@linux-foundation.org: fix several checkpatch.pl warnings] Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
