We don't have to define an extra config symbol, IS_REACHABLE does
what we need. And having this config symbol just to save the few
bytes of hwmon support on non-DS3231 chips isn't worth it IMO
(especially as the symbol is set per default).
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Access to the control registers is mostly not needed and can cause runtime
issues (like missed interrupts). Remove this debugging interface.
Fix typo introduced for RTC_DRV_JZ4740 in commit 586655d278ba ("rtc:
jz4740: make the driver buildable as a module again").
Signed-off-by: Mathieu Malaterre <malat@debian.org>
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux
Pull RTC updates from Alexandre Belloni:
"This contains a few series that have been in preparation for a while
and that will help systems with RTCs that will fail in 2038, 2069 or
2100.
Subsystem:
- Add tracepoints
- Rework of the RTC/nvmem API to allow drivers to discard struct
nvmem_config after registration
- New range API, drivers can now expose the useful range of the RTC
- New offset API the core is now able to add an offset to the RTC
time, modifying the supported range.
- Multiple rtc_time64_to_tm fixes
- Handle time_t overflow on 32 bit platforms in the core instead of
letting drivers do crazy things.
- remove rtc_control API
New driver:
- Intersil ISL12026
Drivers:
- Drivers exposing the RTC non volatile memory have been converted to
use nvmem
- Removed useless time and date validation
- Removed an indirection pattern that was a cargo cult from ancient
drivers
- Removed VLA usage
- Fixed a possible race condition in probe functions
- AB8540 support is dropped from ab8500
- pcf85363 now has alarm support"
* tag 'rtc-4.17' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (128 commits)
rtc: snvs: Fix usage of snvs_rtc_enable
rtc: mt7622: fix module autoloading for OF platform drivers
rtc: isl12022: use true and false for boolean values
rtc: ab8500: Drop AB8540 support
rtc: remove a warning during scripts/kernel-doc step
rtc: 88pm860x: remove artificial limitation
rtc: 88pm80x: remove artificial limitation
rtc: st-lpc: remove artificial limitation
rtc: mrst: remove artificial limitation
rtc: mv: remove artificial limitation
rtc: hctosys: Ensure system time doesn't overflow time_t
parisc: time: stop validating rtc_time in .read_time
rtc: pcf85063: fix clearing bits in pcf85063_start_clock
rtc: at91sam9: Set name of regmap_config
rtc: s5m: Remove VLA usage
rtc: s5m: Move enum from rtc.h to rtc-s5m.c
rtc: remove VLA usage
rtc: Add useful timestamp definitions
rtc: Add one offset seconds to expand RTC range
rtc: Factor out the RTC range validation into rtc_valid_range()
The blackfin architecture is getting removed, so this one is
now obsolete.
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-by: Aaron Wu <aaron.wu@analog.com>
The tile architecture is getting removed, so this driver is
no longer needed.
A lot of Kconfig symbols have architecture specific dependencies.
In those cases that depend on architectures we have already removed,
they can be omitted.
Acked-by: Kalle Valo <kvalo@codeaurora.org>
This config select's MFD_SYSCON, but does not depend on HAS_IOMEM.
Compile testing on architecture without HAS_IOMEM causes "unmet
direct dependencies" in Kconfig phase.
Detected by "make ARCH=score allyesconfig".
The ISL12026 is a combination RTC and EEPROM device with I2C
interface. The standard RTC driver interface is provided. The EEPROM
is accessed via the NVMEM interface.
Reviewed-by: Rob Herring <robh@kernel.org>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: David Daney <david.daney@cavium.com>
Remove the MN10300 arch as the hardware is defunct.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
cc: Masahiro Yamada <yamada.masahiro@socionext.com>
cc: linux-am33-list@redhat.com
The rtc-tx4939 driver now compiles correctly on other architectures, add
COMPILE_TEST to improve code coverage.
Since PLATFORM_AT32AP is an AVR32 platform which was removed, the
rtc driver rtc-at32ap700x is useless.
This patch remove it.
Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Neither rtc-imxdi, rtc-mxc nor rtc-snvs are compatible with i.MX53.
This is driver enables support for the low power domain SRTC features:
- 32-bit MSB of non-rollover time counter
- 32-bit alarm register
Select the new config option RTC_DRV_MXC_V2 to build this driver
Based on:
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/drivers/rtc/rtc-mxc_v2.c?h=imx_2.6.35_11.09.01
Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
Acked-by: Philippe Ombredanne <pombredanne@nexb.com>
On platforms with a Chrome OS EC, the EC can function as a simple RTC.
Add a basic driver with this functionality.
Signed-off-by: Stephen Barber <smbarber@chromium.org>
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Benson Leung <bleung@chromium.org>
Reviewed-by: Brian Norris <briannorris@chromium.org>
Tested-by: Brian Norris <briannorris@chromium.org>
This patch adds the Spreadtrum RTC driver, which embedded in the
Spreadtrum SC27xx series PMICs.
Signed-off-by: Baolin Wang <baolin.wang@spreadtrum.com>
Note that alarms are not currently implemented.
64 bytes of nvmem is supported and exposed in
sysfs (# is the instance number, starting with 0):
/sys/bus/nvmem/devices/pcf85363-#/nvmem
Signed-off-by: Eric Nelson <eric@nelint.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Rob Herring <robh@kernel.org>
Give a better description for original MediaTek RTC driver as PMIC based
RTC in order to distinguish SoC based RTC. Also turning all words with
Mediatek to MediaTek here.
Cc: Eddie Huang <eddie.huang@mediatek.com>
Signed-off-by: Sean Wang <sean.wang@mediatek.com>
Acked-by: Eddie Huang <eddie.huang@mediatek.com>
This patch introduces the driver for the RTC on MT7622 SoC.
Reviewed-by: Yingjoe Chen <yingjoe.chen@mediatek.com>
Based on QNAP's arch/arm/mach-rtk119x/driver/rtk_rtc_drv.c code and
mach-rtk119x/driver/dc2vo/fpga/include/mis_reg.h register definitions.
The base year 2014 was observed on all of Zidoo X9S, ProBox2 Ava and
Beelink Lake I.
Signed-off-by: Andreas Färber <afaerber@suse.de>
Add device driver for a virtual RTC device in Android emulator.
The compatible string used by OS for binding the driver is defined
as "google,goldfish-rtc".
Signed-off-by: Miodrag Dinic <miodrag.dinic@imgtec.com>
Signed-off-by: Goran Ferenc <goran.ferenc@imgtec.com>
Signed-off-by: Aleksandar Markovic <aleksandar.markovic@imgtec.com>
This adds support for reading and writing date/time from/to ds1341 chip.
ds1341 chip has other features - alarms, input clock (can be used instead
of intercal oscillator for better accuracy), output clock ("square wave
generation"). However, not all of that is available at the same time.
Same chip pins, CLKIN/nINTA and SQW/nINTB, can be used either for
input/output clocks, or for alarm interrupts. Role of these pins on
particular board depends on hardware wiring.
We can add device tree properties that describe if each of pins is wired
as clock, or as interrupt, or left unconnected, and enable support for
corresponding functionality based on that. But that is cumbersome, requires
hardware for testing, and has to deal with bit enabling/disabling output
clock also affects which pins alarm interrupts are routed to.
Another factor is that there are hardware setups (i.e. ZII RDU2) that
power DS1341 from SuperCap, which makes power saving critical. For such
setups, kernel driver should leave register bits that control mentioned
pins in the state configured by bootloader.
Given all that, it was decided to limit support to "only date/time" for
now. That is enough for common use case. Full (and cumbersome)
implementation can be added later if ever needed.
Signed-off-by: Nikita Yushchenko <nikita.yoush@cogentembedded.com>
Tested-by: Aleksander Morgado <aleksander@aleksander.es>
The RK808 and RK805 PMICs are using a similar register map.
We can reuse the rtc driver for the RK805 PMIC. So let's add
the RK805 in the Kconfig description.
Signed-off-by: Elaine Zhang <zhangqing@rock-chips.com>
Signed-off-by: Joseph Chen <chenjh@rock-chips.com>
Many RTCs have an on board non volatile storage. It can be battery backed
RAM or an EEPROM. Use the nvmem subsystem to export it to both userspace
and in-kernel consumers.
This stays compatible with the previous (non documented) ABI that was using
/sys/class/rtc/rtcx/device/nvram to export that memory. But will warn about
the deprecation.
DS3232/DS3234 has the temperature registers with a resolution of 0.25
degree celsius. This enables to get the value through hwmon.
# cat /sys/class/hwmon/hwmon0/temp1_input
37250
Signed-off-by: Kirill Esipov <yesipov@gmail.com>
The Gemini RTC is actually a generic IP block from Faraday
Technology names FTRTC010. Rename the driver file and all
symbols to match this IP name.
The relationship can be clearly seen in the U-Boot driver
posted by Po-Yu Chuang for the Faraday A320 board:
https://lists.denx.de/pipermail/u-boot/2009-September/061326.html
Remove the dependency on ARCH_GEMINI but select the driver
for ARCH_GEMINI so we get a smooth transition. The IP block
is synthsized on different silicon and architectures.
Cc: Po-Yu Chuang <ratbert@faraday-tech.com>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
This adds support for the Broadcom STB wake-timer which is a timer in
the chip's 27Mhz clock domain that offers the ability to wake the system
(wake-up source) from suspend states (S2, S3, S5). It is supported using
the rtc framework allowing us to configure alarms for system wake-up.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Markus Mayer <mmayer@broadcom.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
This same RTC is used in RZ/A series MPUs, therefore with some slight
changes, this driver can be reused. Additionally, since ARM architectures
require Device Tree configurations, device tree support has been added.
Signed-off-by: Chris Brandt <chris.brandt@renesas.com>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
This driver supports the Motorola CPCAP PMIC found on
some of Motorola's mobile phones, such as the Droid 4.
Tested-by: Tony Lindgren <tony@atomide.com>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
"Subsystem:
- constify rtc_class_ops structures
New driver:
- STM32
Drivers:
- armada38x: fix errata, Armada 7K/8K support
- ds3232: fix wakeup support
- gemini: DT support
- m48t86: huge cleanup and platform_data removal
- mcp795: alarm support
- sun6i: proper oscillator handling
- tegra: proper clock handling
- tps65910: calibration support"
* tag 'rtc-4.11' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (44 commits)
rtc: ds3232: Call device_init_wakeup before device_register
rtc: pcf2127: bulk read only date and time registers.
rtc: armada38x: Add support for Armada 7K/8K
rtc: armada38x: Prepare driver to manage different versions
rtc: ds3232: Add regmap max_register definition.
rtc: ds3232: Cleanup whitespace around register and bit definitions.
rtc: m48t86: remove unused platform_data
ARM: Orion5x: ts78xx: allow rtc-m48t86 to manage it's own resources
ARM: Orion5x: ts78xx: remove RTC detection
ARM: ep93xx: ts72xx: allow rtc-m48t86 to manage its own resources
rtc: m48t86: verify that the RTC is actually present
rtc: m48t86: add NVRAM support
rtc: m48t86: allow driver to manage its resources
rtc: m48t86: shorten register name defines
bindings: rtc: correct wrong reference in required properties
rtc: sun6i: Fix return value check in sun6i_rtc_clk_init()
rtc: sun6i: extend test coverage
rtc: sun6i: Fix compatibility with old DT binding
rtc: snvs: add a missing write sync
rtc: bq32000: add support to enable disable the trickle charge FET bypass
COMPILE_TEST was wrongly placed, move it to the "depends on" line.
Also depend on COMMON_CLK as the driver now needs it to be properly
compiled.
By using kernel_halt() instead of machine_halt(), we can make the driver
build as a module.
However, jz4740 platforms not loading this module will not be able to power
off.
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Revert "rtc: jz4740: make the driver builtin only"
This reverts commit b9168c539c0b2de756aaffd380384dbde8adbe07.
Since we have to provide the clock very early on, the RTC driver cannot be
built as a module. Make sure that won't happen.
Cc: stable@vger.kernel.org
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This patch adds support for the STM32 RTC.
Signed-off-by: Amelie Delaunay <amelie.delaunay@st.com>
Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org>
This adds support for EPSON TOYOCOM RTC-7301SF/DG which has parallel
interface compatible with SRAM.
This driver supports basic clock, calendar and alarm functionality.
Tested with Microblaze linux running on Artix7 FPGA board with my own
custom IP for RTC-7301.
Since there are no platform based users and all users
of this code are TI OMAP-based which is DT only, it makes
sense to remove unused code.
Signed-off-by: Nicolae Rosia <Nicolae_Rosia@mentor.com>
s/buillt/built/g
Since the driver is now calling machine_halt() that is not exported, it has
to be built in the kernel. Building it as a module will fail at linking
time.
max8907, max77686 and s5m RTC drivers can be compile tested to increase
build coverage. The s5m-rtc uses REGMAP_IRQ so add this as explicit
dependency.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
The RTC unit present in the JZ4780 works mostly the same as the one in
the JZ4740. The major difference is that register writes need to be
explicitly enabled, by writing a magic code (0xA55A) to a "write
enable" register before each access.
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
Acked-by: Maarten ter Huurne <maarten@treewalker.org>
That header has been gone for a while. I've fixed up the Kconfig
comment, but the one in rtc-cmos.c doesn't make any sense to me
even looking at its history.
"RTC for 4.9
Subsystem:
- delete owner assignment in multiple drivers
Drivers:
- ac100: support clock-output-names
- cmos: properly handle ACPI alarms and quirky BIOSes and other fixes
- ds1307: fix century bit support while staying comaptible with
previous behaviour by default
- ds1347: switch to regmap
- isl12057 is now handled by ds1307
- omap: support external wakeup
- rv8803: allow to disable voltage drop detection"
* tag 'rtc-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (25 commits)
rtc: rv8803: set VDETOFF and SWOFF via device tree
dt/bindings: Add bindings for Micro Crystal rv8803
devicetree: Add Micro Crystal AG vendor id
rtc: cmos: avoid unused function warning
rtc: ac100: Add NULL checking for devm_kzalloc call
rtc: ds1347: changed raw spi calls to register map calls
rtc: cmos: Restore alarm after resume
rtc: cmos: Clear ACPI-driven alarms upon resume
rtc: omap: Support ext_wakeup configuration
rtc: cmos: Initialize hpet timer before irq is registered
rtc: asm9260: rework locking
rtc: asm9260: allow COMPILE_TEST
rtc: constify rtc_class_ops structures
rtc: ac100: support clock-output-names in device tree binding
rtc: rx6110: remove owner assignment
rtc: pic32: Delete owner assignment
rtc: bq32k: Fix handling of oscillator failure flag
rtc: bq32k: Use correct mask name for 'minutes' register.
rtc: sysfs: fix a cast removing the const attribute
Documentation: dt: Intersil isl12057 is not a trivial device
'ib-mfd-input-4.9', 'ib-mfd-regulator-4.9', 'ib-mfd-regulator-4.9.1', 'ib-mfd-regulator-rtc-4.9', 'ib-mfd-regulator-rtc-4.9-1' and 'ib-mfd-rtc-4.9' into ibs-for-mfd-merged
This patch changes calls of spi read write calls to register map
read and write calls in rtc ds1347
Signed-off-by: Raghavendra Chandra Ganiga <ravi23ganiga@gmail.com>
Support configuration of ext_wakeup sources. This patch makes it
possible to enable ext_wakeup and set it's polarity, depending on board
configuration. AM335x's dedicated PMIC (tps65217) uses ext_wakeup to
notify about power-button presses. Handling power-button presses enables
to recover from RTC-only power states correctly.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
The rtc-asm9260 driver compiles correctly on other architectures, add
The Intersil isl12057 is now supported by the ds1307 driver.
Acked-by: Arnaud Ebalard <arno@natisbad.org>
Intersil ISL12057 is a drop-in replacement for DS1337. It can be supported
Add an option to properly support the century bit of ds1337 and compatibles
and ds1340.
Because the driver had a bug until now, it is not possible to switch users
to the fixed code directly as RTCs in the field will wrongly have the
century bit set.
The RK808 and RK818 PMICs are using a similar register map.
We can reuse the rtc driver for the RK818 PMIC. So let's add
the RK818 in the Kconfig description.
Signed-off-by: Wadim Egorov <w.egorov@phytec.de>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
X-Powers AC100 is a codec / RTC combo chip. This driver supports
the RTC sub-device.
The RTC block also has clock outputs and non-volatile storage.
Non-volatile storage wthin the RTC hardware is not supported.
Clock output support is added in the next patch.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
