path: root/drivers/regulator
2015-01-16Merge remote-tracking branch 'regulator/fix/s2mps11' into regulator-linusMark Brown
2015-01-16Merge remote-tracking branch 'regulator/fix/core' into regulator-linusMark Brown
2015-01-08regulator: s2mps11: Fix wrong calculation of register offsetJonghwa Lee
This patch adds missing registers('BUCK7_SW' & 'LDO29_CTRL'). Since BUCK7 has 1 more register (BUCK7_SW) than others, register offset should be added one more for which has bigger address than BUCK7 registers. Fixes: 76b9840b24ae04(regulator: s2mps11: Add support S2MPS13 regulator device) Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: <stable@vger.kernel.org>
2015-01-08regulator: core: fix race condition in regulator_put()Ashay Jaiswal
The regulator framework maintains a list of consumer regulators for a regulator device and protects it from concurrent access using the regulator device's mutex lock. In the case of regulator_put() the consumer is removed and regulator device's parameters are updated without holding the regulator device's mutex. This would lead to a race condition between the regulator_put() and any function which traverses the consumer list or modifies regulator device's parameters. Fix this race condition by holding the regulator device's mutex in case of regulator_put. Signed-off-by: Ashay Jaiswal <ashayj@codeaurora.org> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2014-12-29Merge tag 'regulator-v3.19-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull one regulator fix from Mark Brown: "One fix here, a fix for the voltage mapping on one of the s2mps11 regulators which broke systems using it including apparently the Gear 2 smartwatches" * tag 'regulator-v3.19-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: regulator: s2mps11: Fix dw_mmc failure on Gear 2
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-12regulator: s2mps11: Fix dw_mmc failure on Gear 2Krzysztof Kozlowski
Invalid buck4 configuration for linear mapping of voltage in S2MPS14 regulators caused boot failure on Gear 2 (dw_mmc-exynos): [ 3.569137] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: (null) [ 3.571716] VFS: Mounted root (ext4 filesystem) readonly on device 179:15. [ 3.629842] mmcblk0: error -110 sending status command, retrying [ 3.630244] mmcblk0: error -110 sending status command, retrying [ 3.636292] mmcblk0: error -110 sending status command, aborting Buck4 voltage regulator has different minimal voltage value than other bucks. Commit merging multiple regulator description macros caused to use linear_min_sel from buck[1235] regulators as value for buck4. This lead to lower voltage of buck4 than required. Output of the buck4 is used internally as power source for LDO{3,4,7,11,19,20,21,23}. On Gear 2 board LDO11 is used as MMC regulator (V_EMMC_1.8V). Fixes: 5a867cf28893 ("regulator: s2mps11: Optimize the regulator description macro") Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: <stable@vger.kernel.org>
2014-12-08Merge tag 'regulator-v3.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates from Mark Brown: "The main thing this time around is support for suspend mode configuration from DT which will enable some very useful power savings on systems where we can't rely on the bootloader configuration. We still don't really support dynamic configuration of this at runtime, that may come later if there is any demand. Summary: - Support for specifying the target regulation mode and voltage during system suspend via DT, enabling power savings in that mode. - Reduce the default verbosity of the logging on boot, improving boot times especially for systems with very large numbers of regulators. - Lots of cleanups and fixes for Maxim PMIC drivers. - New driver for Richtek RT5033" * tag 'regulator-v3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (62 commits) regulator: core: Fix regualtor_ena_gpio_free not to access pin after freeing regulator: sky81452: Modify Device Tree structure regulator: sky81452: Modify Device Tree structure dt-bindings: Update documentation for "system-power-controller" and fix misspellings of: Rename "poweroff-source" property to "system-power-controller" regulator: max77686: Remove support for board files regulator: max77802: Remove support for board files regulator: max77802: Fill regulator modes translation callback regulator: max77802: Document binding for regulator operating modes regulator: of: Add support for parsing initial and suspend modes regulator: of: Pass the regulator description in the match table regulator: of: Add regulator desc param to of_get_regulator_init_data() regulator: Add mode mapping function to struct regulator_desc regulator: Document binding for initial and suspend modes regulator: core: Add PRE_DISABLE notification regulator: gpio: fix parsing of gpio list regulator: rpm: add support for RPM-controller SMB208 regulator: da9063: Do not transform local IRQ to virtual regulator: sky81452: Modify dependent Kconfig symbol regulator: rt5033: Add RT5033 Regulator device driver ...
2014-12-08Merge tag 'mfd-for-linus-3.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to the core: - Honour PLATFORM_DEVID_NONE and PLATFORM_DEVID_AUTO dev IDs Changes to existing drivers: - IRQ additions/fixes; axp20x, da9063-core - Code simplification; i2c-dln2 - Regmap additions/fixes; max77693 - Error checking/handling improvements; dln2, db8500-prcmu - Bug fixes; dln2, wm8350-core - DT support/documentation; max77693, max77686, tps65217, twl4030-power, gpio-tc3589x - Decouple syscon interface from platform devices - Use MFD hotplug registration; rtsx_usb, viperboard, hid-sensor-hub - Regulator fixups; sec-core - Power Management additions/fixes; rts5227, tc6393xb - Remove relic/redundant code; ab8500-sysctrl, lpc_sch, max77693-private - Clean-up/coding style changes; tps65090 - Clk additions/fixes; tc6393xb, tc6387xb, t7l66xb - Add USB-SPI support; dln2 - Trivial changes; max14577, arizona-spi, lpc_sch, wm8997-tables, wm5102-tables wm5110-tables, axp20x, atmel-hlcdc, rtsx_pci New drivers/supported devices: - axp288 PMIC support added to axp20x - s2mps13 support added to sec-core - New support for Diolan DLN-2 - New support for atmel-hlcdc" * tag 'mfd-for-linus-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (55 commits) mfd: rtsx: Add func to split u32 into register mfd: atmel-hlcdc: Add Kconfig option description and name mfd: da9063: Get irq base dynamically before registering device mfd: max14577: Fix obvious typo in company name in copyright mfd: axp20x: Constify axp20x_acpi_match and rid unused warning mfd: t7l66xb: prepare/unprepare clocks mfd: tc6387xb: prepare/unprepare clocks mfd: dln2: add support for USB-SPI module mfd: wm5110: Add missing registers for AIF2 channels 3-6 mfd: tc3589x: get rid of static base mfd: arizona: Document HP_CTRL_1L and HP_CTRL_1R registers mfd: wm8997: Mark INTERRUPT_STATUS_2_MASK as readable mfd: tc6393xb: Prepare/unprepare clocks mfd: tps65090: Fix bonkers indenting strategy mfd: tc6393xb: Fail ohci suspend if full state restore is required mfd: lpc_sch: Don't call mfd_remove_devices() mfd: wm8350-core: Fix probable mask then right shift defect mfd: ab8500-sysctrl: Drop ab8500_restart mfd: db8500-prcmu: Provide sane error path values mfd: db8500-prcmu: Check return of devm_ioremap for error ...
2014-12-05Merge remote-tracking branches 'regulator/topic/sky81452' and ↵Mark Brown
'regulator/topic/stub' into regulator-next
2014-12-05Merge remote-tracking branches 'regulator/topic/rn5t618', ↵Mark Brown
'regulator/topic/rpm', 'regulator/topic/rt5033', 'regulator/topic/s2mpa01' and 'regulator/topic/s2mps11' into regulator-next
2014-12-05Merge remote-tracking branches 'regulator/topic/max77686', ↵Mark Brown
'regulator/topic/max77693', 'regulator/topic/max77802', 'regulator/topic/power-off' and 'regulator/topic/rk808' into regulator-next
2014-12-05Merge remote-tracking branches 'regulator/topic/anatop', ↵Mark Brown
'regulator/topic/disable', 'regulator/topic/dummy' and 'regulator/topic/gpio' into regulator-next
2014-12-05Merge remote-tracking branch 'regulator/topic/core' into regulator-nextMark Brown
2014-12-05Merge remote-tracking branch 'regulator/fix/da9063' into regulator-linusMark Brown
2014-12-05Merge branch 'topic/suspend' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator into regulator-sky81452 Conflicts: drivers/regulator/sky81452-regulator.c
2014-12-04regulator: core: Fix regualtor_ena_gpio_free not to access pin after freeingSeung-Woo Kim
After freeing pin from regulator_ena_gpio_free, loop can access the pin. So this patch fixes not to access pin after freeing. Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-02regulator: sky81452: Modify Device Tree structureGyungoh Yoo
Signed-off-by: Gyungoh Yoo <jack.yoo@skyworksinc.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-01of: Rename "poweroff-source" property to "system-power-controller"Romain Perier
It reverts commit a4b4e0461ec5 ("of: Add standard property for poweroff capability"). As discussed on the mailing list, it makes more sense to rename back to the old established property name, without the vendor prefix. Problem being that the word "source" usually tends to be used for inputs and that is out of control of the OS. The poweroff capability is an output which simply turns the system-power off. Also, this property might be used by drivers which power-off the system and power back on subsequent RTC alarms. This seems to suggest to remove "poweroff" from the property name and to choose "system-power-controller" as the more generic name. This patchs adds the required renaming changes and defines an helper function which checks if this property is set. Signed-off-by: Romain Perier <romain.perier@gmail.com> Acked-by: Grant Likely <grant.likely@linaro.org> Acked-by: Johan Hovold <johan@kernel.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-26regulator: max77686: Remove support for board filesKrzysztof Kozlowski
The driver is used only on Exynos based boards with DTS support. Simplify the driver and remove dead (unused) entries in platform_data structure. Convert the driver to DTS-only version. Parse all regulators at once, not one-by-one. Remove dependency on data provided by max77686 MFD driver. Use new DT style parsing method for regulators init data. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-26Merge tag 'v3.18-rc4' into regulator-max77686Mark Brown
Linux 3.18-rc4
2014-11-26regulator: max77802: Remove support for board filesKrzysztof Kozlowski
The driver is used only on Exynos based boards with DTS support. Simplify the driver and remove dead (unused) entries in platform_data structure. Convert the driver to DTS-only version. Parse all regulators at once, not one-by-one. Remove dependency on data provided by max77686 MFD driver. Use new DT style parsing method for regulators init data. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-26Merge tag 'v3.18-rc4' into regulator-max77802Mark Brown
Linux 3.18-rc4
2014-11-26regulator: max77802: Fill regulator modes translation callbackJavier Martinez Canillas
The max77802 PMIC regulators output can be configured in one of two modes: Output ON (normal) and Output ON in Low Power Mode. Some of the regulators support their operating mode to be changed on startup or by consumers when the system is running while others only support their operating mode to be changed while the system has entered in a suspend state. Use the max77802_map_mode() function to translate the device specific modes to the standard operating modes as used by the regulator core. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-26Merge branch 'topic/suspend' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator into regulator-max77802
2014-11-26regulator: of: Add support for parsing initial and suspend modesJavier Martinez Canillas
Some regulators support their operating mode to be changed on startup or by consumers when the system is running while others only support their operating mode to be changed while the system has entered in a suspend state. The regulator Device Tree binding documents a set of properties to configure the regulators operating modes from a FDT. This patch builds on (40e20d6 regulator: of: Add support for parsing regulator_state for suspend state) and adds support to parse those properties and fill the regulator constraints so the regulator core can call the right suspend handlers when the system enters into sleep. The modes are defined in the Device Tree using the hardware specific modes supported by the regulators. Regulator drivers have to define a translation function that is used to map the hardware specific modes to the standard ones. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-26regulator: of: Pass the regulator description in the match tableJavier Martinez Canillas
Drivers can use the of_regulator_match() function to parse the regulator init_data from DT. A match table is used to specify the name of the node containing the regulators, the device node and to return the init_data to the caller. But also the static regulator descriptor is needed to correctly extract some DT properties like the regulator initial and suspend modes. Use the match table to pass that information. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-26regulator: of: Add regulator desc param to of_get_regulator_init_data()Javier Martinez Canillas
The of_get_regulator_init_data() function is used to extract the regulator init_data but information on how to extract certain data is defined in the static regulator descriptor (e.g: how to map the hardware operating modes). Add a const struct regulator_desc * parameter to the function signature so the parsing logic could use the information in the struct regulator_desc. of_get_regulator_init_data() relies on of_get_regulation_constraints() to actually extract the init_data so it has to pass the struct regulator_desc but that is modified on a later patch. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-25regulator: s2mps11: Add support S2MPS13 regulator deviceChanwoo Choi
This patch adds S2MPS13 regulator device to existing S2MPS11 device driver. The S2MPS13 has just different number of regulators from S2MPS14. The S2MPS13 regulator device includes LDO[1-40] and BUCK[1-10]. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Sangbeom Kim <sbkim73@samsung.com> Acked-by: Mark Brown <broonie@kernel.org> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-11-24regulator: core: Add PRE_DISABLE notificationRichard Fitzgerald
Add a PRE_DISABLE notification so that consumers can use a notifier to run any steps required to prepare for the regulator being switched off. Since the regulator disable can fail an abort notification is also added. Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-21regulator: gpio: fix parsing of gpio listRichard Fitzgerald
The list of gpios is defined as optional but the code was failing to properly handle the case of no gpios, and also failing to check for errors reading the entry from the devicetree. This patch fixes the handling of optional gpios - this is a useful feature enabling the gpio-regulator to be used as a dummy variable voltage regulator without having to assign any real GPIO lines. Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-21regulator: rpm: add support for RPM-controller SMB208Josh Cartwright
The IPQ8064 reference boards make use of SMB208 regulators which are controlled by RPM. Implement support for these regulators in the RPM regulator driver. Signed-off-by: Josh Cartwright <joshc@codeaurora.org> Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-21regulator: da9063: Do not transform local IRQ to virtualDmitry Lavnikevich
Call platform_get_irq_byname() already returns VIRQ instead of local IRQ. Passing this value to regmap_irq_get_virq() causes error which results in IRQ registration failure. This patch fixes such behaviour. Signed-off-by: Dmitry Lavnikevich <d.lavnikevich@sam-solutions.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-17regulator: sky81452: Modify dependent Kconfig symbolGyungoh Yoo
2014-11-14regulator: rt5033: Add RT5033 Regulator device driverBeomho Seo
This patch add device driver of Richtek RT5033 PMIC. The driver support multiple regulator like LDO and synchronous Buck. The integrated synchronous buck converter is designed to provide 0.6 A application with high efficiency. Two LDOs are integrated. One safe LDO is for 60mA and the other one LDO is for 150 mA. Cc: Liam Girdwood <lgirdwood@gmail.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Beomho Seo <beomho.seo@samsung.com> Acked-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-07regulator: tps65090: Fix gpio initializationMarkus Pargmann
The config is used for multiple regulators within a for loop. The config field is not cleared before it is used for the next item. To avoid any issues this patch adds a proper initialization for the config->ena_gpio field in case no gpio is available. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-07regulator: gpio: Use gpio_is_validMarkus Pargmann
Use gpio_is_valid instead of an explicit comparison with 0. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-07regulator: fixed: Use gpio_is_validMarkus Pargmann
2014-11-07regulator: Set ena_gpio_initialized in regulator driversMarkus Pargmann
This patch sets ena_gpio_initialized for all drivers which set a ena_gpio from parsed DT properties. Drivers using pdata may get zero initialized pdata and therefore copy a 0 into the regulator_config ena_gpio field. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-05Merge remote-tracking branches 'regulator/fix/max1586', ↵Mark Brown
'regulator/fix/max77686', 'regulator/fix/max77693', 'regulator/fix/max77802', 'regulator/fix/max8860' and 'regulator/fix/s2mpa01' into regulator-linus
2014-11-05Merge remote-tracking branch 'regulator/fix/core' into regulator-linusMark Brown
2014-11-04regulator: max77802: Don't ignore return value of current opmodeKrzysztof Kozlowski
The return value of regmap_read() of current opmode for regulator was silently ignored and whatever happened to be in 'val' variable was used as new opmode. This could lead to using bogus opmode. Don't ignore what regmap_read() returns. If it fails just fall back to normal opmode. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-04regulator: max77686: Initialize opmode explicitly to normal modeKrzysztof Kozlowski
Minor nit: Initialize the opmode for each regulator to normal mode in a readable explicit way. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Suggested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-04regulator: max77686: Consistently index opmode array by rdev idKrzysztof Kozlowski
Mixed indexes were used for array of opmodes in max77686_data structure: id of regulator and index of regulator_desc array. These indexes are exactly the same but the mixture may confuse. Use consistently the id of regulator. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-03Merge branch 'platform/remove_owner' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into driver-core-next Remove all .owner fields from platform drivers
2014-11-03regulator: max77802: Use unsigned int for modes in max77802_map_mode()Javier Martinez Canillas
All function dealing with operating modes use unsigned int for modes so change max77802_map_mode() function signature for consistency. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-03regulator: s2mpa01: zero-initialize regulator match table arrayJavier Martinez Canillas
The struct of_regulator_match rmatch[] is declared as a non-static local variable so the structure members are not auto-initialized. Initialize the array at declaration time to avoid the structure members values to be indeterminate and have sane defaults instead. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-03regulator: max8660: zero-initialize regulator match table arrayJavier Martinez Canillas
2014-11-03regulator: max77802: zero-initialize regulator match tableJavier Martinez Canillas
The struct of_regulator_match is declared as a non-static local variable so the structure members are not auto-initialized. Initialize the struct at declaration time to avoid the structure members values to be indeterminate and have sane defaults instead. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-03regulator: max77686: zero-initialize regulator match tableJavier Martinez Canillas
