path: root/drivers/regulator/wm831x-isink.c
2014-02-20regulator: wm831x-isink: Remove redundant error messageSachin Kamat
kzalloc prints its own OOM message upon failure. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-17regulator: wm831x-isink: Convert to devm_regulator_register()Mark Brown
2013-09-17regulator: wm831x-isink: Use devm_request_threaded_irq()Mark Brown
devm guarantees that resources are freed in the opposite order to that in which they are allocated. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-30regulator: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-05-12regulator: Remove all platform_set_drvdata(pdev, NULL) in driversAxel Lin
Since 0998d06310 "device-core: Ensure drvdata = NULL when no driver is bound", this is done by driver core after device_release or on probe failure. Thus we can remove all platform_set_drvdata(pdev, NULL) in drivers. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-20regulator: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-20regulator: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-20regulator: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-09-11mfd: wm831x: Convert to IORESOURCE_REGMark Brown
This was originally written by Russell King who unfortunately found himself unable to take the patch futher. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Tested-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-05-29Merge tag 'mfd-3.5-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD changes from Samuel Ortiz: "Besides the usual cleanups, this one brings: * Support for 5 new chipsets: Intel's ICH LPC and SCH Centerton, ST-E's STAX211, Samsung's MAX77693 and TI's LM3533. * Device tree support for the twl6040, tps65910, da9502 and ab8500 drivers. * Fairly big tps56910, ab8500 and db8500 updates. * i2c support for mc13xxx. * Our regular update for the wm8xxx driver from Mark." Fix up various conflicts with other trees, largely due to ab5500 removal etc. * tag 'mfd-3.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (106 commits) mfd: Fix build break of max77693 by adding REGMAP_I2C option mfd: Fix twl6040 build failure mfd: Fix max77693 build failure mfd: ab8500-core should depend on MFD_DB8500_PRCMU gpio: tps65910: dt: process gpio specific device node info mfd: Remove the parsing of dt info for tps65910 gpio mfd: Save device node parsed platform data for tps65910 sub devices mfd: Add r_select to lm3533 platform data gpio: Add Intel Centerton support to gpio-sch mfd: Emulate active low IRQs as well as active high IRQs for wm831x mfd: Mark two lm3533 zone registers as volatile mfd: Fix return type of lm533 attribute is_visible mfd: Enable Device Tree support in the ab8500-pwm driver mfd: Enable Device Tree support in the ab8500-sysctrl driver mfd: Add support for Device Tree to twl6040 mfd: Register the twl6040 child for the ASoC codec unconditionally mfd: Allocate twl6040 IRQ numbers dynamically mfd: twl6040 code cleanup in interrupt initialization part mfd: Enable ab8500-gpadc driver for Device Tree mfd: Prevent unassigned pointer from being used in ab8500-gpadc driver ...
2012-05-20mfd: Convert wm831x to irq_domainMark Brown
The modern idiom is to use irq_domain to allocate interrupts. This is useful partly to allow further infrastructure to be based on the domains and partly because it makes it much easier to allocate virtual interrupts to devices as we don't need to allocate a contiguous range of interrupt numbers. Convert the wm831x driver over to this infrastructure, using a legacy IRQ mapping if an irq_base is specified in platform data and otherwise using a linear mapping, always registering the interrupts even if they won't ever be used. Only boards which need to use the GPIOs as interrupts should need to use an irq_base. This means that we can't use the MFD irq_base management since the unless we're using an explicit irq_base from platform data we can't rely on a linear mapping of interrupts. Instead we need to map things via the irq_domain - provide a conveniencem function wm831x_irq() to save a small amount of typing when doing so. Looking at this I couldn't clearly see anything the MFD core could do to make this nicer. Since we're not supporting device tree yet there's no meaningful advantage if we don't do this conversion in one, the fact that the interrupt resources are used for repeated IP blocks makes accessor functions for the irq_domain more trouble to do than they're worth. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-04-10Merge tag 'v3.4-rc2' into regulator-driversMark Brown
Linux 3.4-rc2 contains some fixes that further patches depend upon.
2012-04-09regulator: core: Use a struct to pass in regulator runtime configurationMark Brown
Rather than adding new arguments to regulator_register() every time we want to add a new bit of dynamic information at runtime change the function to take these via a struct. By doing this we avoid needing to do further changes like the recent addition of device tree support which required each regulator driver to be updated to take an additional parameter. The regulator_desc which should (mostly) be static data is still passed separately as most drivers are able to configure this statically at build time. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-28regulator: wm831x-isink: Fix the logic to choose best current limit settingAxel Lin
Current code in wm831x_isink_set_current actually set the current limit setting smaller than specified range. Fix the logic in wm831x_isink_set_current to choose the smallest current limit setting falls within the specified range. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-20regulator: Convert wm831x regulator drivers to devm_kzalloc()Mark Brown
2011-11-23regulator: pass additional of_node to regulator_register()Rajendra Nayak
With device tree support for regulators, its needed that the regulator_dev->dev device has the right of_node attached. To be able to do this add an additional parameter to the regulator_register() api, wherein the dt-adapted driver can then pass this additional info onto the regulator core. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-03-26regulator: Convert WM831x regulators to genirqMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03Regulators: wm831x-xxx - clean up driver data after removalDmitry Torokhov
It is a good tone to reset driver data after unbinding the device. Also set up drivers owner. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-12-02regulator: Initialise wm831x structure pointor for ISINK driverMark Brown
The version that made it into mainline missed the initialisation of the chip handle. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-17regulator: Add WM831x ISINK supportMark Brown
The WM831x series of PMICs provide two constant current sinks designed to drive strings of serially connected LEDs for applications such as backlights. This driver adds support for those regulators. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
