It's safe to call regulator_unregister() with NULL, thus remove the NULL test
before regulator_unregister() calls.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Signed-off-by: Mark Brown <broonie@sirena.org.uk>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
commit 4d26f7 "regulator: max8660: Use devm_kzalloc()" missed to
replace kzalloc by devm_kzalloc. Fix it.
Rather than adding new arguments to regulator_register() every time we
want to add a new bit of dynamic information at runtime change the function
to take these via a struct. By doing this we avoid needing to do further
changes like the recent addition of device tree support which required each
regulator driver to be updated to take an additional parameter.
The regulator_desc which should (mostly) be static data is still passed
separately as most drivers are able to configure this statically at build
time.
The core already announces constraints and we're not adding any new
information such as the chip revision.
With device tree support for regulators, its needed that the
regulator_dev->dev device has the right of_node attached.
To be able to do this add an additional parameter to the
regulator_register() api, wherein the dt-adapted driver can
then pass this additional info onto the regulator core.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Change the interface used by set_voltage() to report the selected value
to the regulator core in terms of a selector used by list_voltage().
This allows the regulator core to know the voltage that was chosen
without having to do an explict get_voltage(), which would be much more
expensive as it will generally access hardware.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
In max8660_probe(), we allocate memory for max660.
In max8660_remove(), current implementation only free rdev
which is a member of struct max8660.
Thus, there is a small memory leak when we unload the module.
This patch fixes the memory leak by passing max660 to i2c clientdata,
and properly kfree(max8660) in max8660_remove().
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
I2C drivers can use the clientdata-pointer to point to private data. As I2C
devices are not really unregistered, but merely detached from their driver, it
used to be the drivers obligation to clear this pointer during remove() or a
failed probe(). As a couple of drivers forgot to do this, it was agreed that it
was cleaner if the i2c-core does this clearance when appropriate, as there is
no guarantee for the lifetime of the clientdata-pointer after remove() anyhow.
This feature was added to the core with commit
e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers.
As there is no need anymore to clear the clientdata-pointer, remove all current
occurrences in the drivers to simplify the code and prevent confusion.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Fix I2C-drivers which missed setting clientdata to NULL before freeing the
structure it points to. Also fix drivers which do this _after_ the structure
was freed already.
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Tested with a MX25-based custom board.
